DFB激光器驱动
DFB激光器的激光管的正极是接
Parents
  • Your selected laser module is in a butterfly package with the laser anode pin connected to the case ground.
    There are two ways to use this laser module with ADN2871:
    1.     Connecting the laser module case ground to supply Vcc. This keeps the "positive supply" design
            and you can use Fig. 29 circuit directly; or
    2.     Using "negative supply" way to ADN2871 circuitry. In the Fig. 29 circuit, change all external Vccs to new
            "negative supply" ground, change all external GNDs to -3.3V. Now, you can connect the laser module case
             to negative supply ground. In this way, you may have to pay attention to the ADN2871 control/monitor signal
             levels accordingly. Please note, in this case, all these DC levels are referred to -3.3V, not the ground.
Reply
Children
No Data
