典型电路抄的是LT3752与LT8311的典型电路,https://www.analog.com/cn/products/lt8311.html, 自己拟定的输入为18-36V,输出为12V,匝比为3.25:4,现发现空载和轻载时候次级的同步整流CG驱动波形提前关断,输入在空载或者轻载的时候占空比比预计的小很多,负载增大后占空比和次级的CG驱动波形正常,不知道怎么解决。
The front page of the datasheet says:
"In preactive mode, the output inductor current
operates in discontinuous conduction mode (DCM) at
light load. If forced continuous mode (FCM) operation is
…我加了脉冲变压器,但是在轻载和空载的时候还是工作在间隙模式,https://www.analog.com/media/en/technical-documentation/eval-board-schematic/DC2175A-3-SCH.PDF, 大概和这个图差不多,只不过我没用T3,直接用的输出电压给LT8311的Vin供电,PMODE引脚和INTVCC引脚也直接连接的Vin,不知道这会有…
desired at light load, the LT8311 can, alternatively, be used
in SYNC mode"
What you described is normal for DCM operation for a switching mode power supply (Please see page 18 of the datasheet).
If you prefer the FCM at light or no load, you can refer to this design.
https://www.analog.com/media/en/dsp-documentation/evaluation-kit-manuals/dc1994afa.pdf
我加了脉冲变压器,但是在轻载和空载的时候还是工作在间隙模式,https://www.analog.com/media/en/technical-documentation/eval-board-schematic/DC2175A-3-SCH.PDF, 大概和这个图差不多,只不过我没用T3,直接用的输出电压给LT8311的Vin供电,PMODE引脚和INTVCC引脚也直接连接的Vin,不知道这会有啥影响
