FREQUENCY UPDATE SEQUENCE OF ADF4356
According to the manual, when PDF> 75MHz, you need to lock according to half of the PDF first, and then use PDF lock. I want to know if this is necessary?
At present, I use PDF = 100MHz, and calculate the register lock directly according to 100MHz. Is there any problem? Do I have to follow the manual? thank you very much!
