ADF4002的配置
ADF4002特性 相位检测 频率合成
400Mhz 带宽
104Mhz 频率相位检测
调试说明:
         利用ADI PLL Int-N ,选择ADF4002,根据需求得到想要的值即可。
配置顺序如下所示。
ADI_Int-N_Setup_v7_3_1.zip
ADI PLL Int-N 使用说明
软件界面如下所示:
首先选择ADF4002,如下图所示:
然后进入Main Controls界面,输入你的频率和你要的频率即可得到寄存器的值。
示例代码 Verilog
case (count)
57:if(!CLK_AD9516)begin
                 count <= 0;
                  SEND_Start <= 1'b0;
                  Send_Busy <= 1'b0;
                  end
                //write data
                //send data and pull down CSB
                0:if(!CLK_AD9516)begin
            AD9516_SCLK <=1'b0;
                AD9516_CSB <= 1'b0;
                count <= count+1'b1;
                Temp_Out <=Data[23-(count / 2'd2)];
                end
                // clk
                1,3,5,7,9,11,13,15,17,19,21,23,25,27,29,31,33,35,37,39,41,43,45:
                if(CLK_AD9516)begin AD9516_SCLK <=1'b1;count <= count+1'b1;end
                //data
                2,4,6,8,10,12,14,16,18,20,22,24,26,28,30,32,34,36,38,40,42,44,46:
                AD9516_SCLK <= 1'b0;
                end
                //clk
                47:if(CLK_AD9516)begin
                AD9516_SCLK <= 1'b1;
                end
                //send data over
                48:if(!CLK_AD9516) begin
                Temp_Out <= 1'b0;
                end
