POE和辅助电源同时供电时,如何优先使用POE电源
Product Number: LT4295
我有一个问题请教一下。由采用LT4295的开发样板DC2476A-A中如果POE和辅助电源同时供电时,会优先采用辅助电源。请问有什么办法可以改变优先级。同时有辅助外部电源和POE电源时,可以优先采用POE电源。
Thread Notes
  • 感谢您的提问!获取更多关于该产品的信息,欢迎您联系术支持  · Support Portal (analog.com)
  • Due to an issue with EZ I did not receive notifications for this post. My apologies. I understand this reply is likely too late to be useful for you. In case anyone else has a similar request, I will answer your question.
    No, there is no way to switch PoE and auxiliary priority with the LT4295, as an auxiliary supply will corrupt the PoE detection signature. You would need to use a PD interface such as the LT4294 and MAX5995B and diode OR the PoE supply with the auxiliary supply to a DC-DC converter such as the MAX5974A. A MOSFET or other switch could be used to enforce your preferred priority.
    Best Regards,
    Eric
