Dear All:
我想知道如何設置ADcmXL3021 MTC模式嗎? 有任何文件或流程設置規則可以參考嗎? 我需要ADcmXL3021 MTC模式初始SW代碼(initial SW Code),希望為我提供加速的產品開發
Best
Jack
Dear All:
Best
Jack
The MTC configuration can be found in the DS. We have an evaluation setup that you can test these features with. Here is a link to the wikipage. Here are some examples that can help.
https://github.com/juchong/iSensor-FX3-Firmware
Dear Sir:
This S/W Code only focus Cypress FX3 ,ADI provide open source S/W code to support any one system?? (ex:STM32F xxx ,arduino ,Raspberry Pi)?? thanks
Best
Jack
# adcmxl3021 Driver in Python # SPI Master is using Raspberry Pi # spidev is the Raspberry Pi spi communication library # Date: 2019.7.11 import sys import spidev import time SPI_MAX_SPEED =1953125 class adcmxl3021(): #Configuration Constant based on ADcmXL3021 datasheet PAGE_ID =0x00 TEMP_OUT =0x02 SUPPLY_OUT =0x04 FFT_AVG1 =0x06 FFT_AVG2 =0x08 BUF_PNTR =0x0A REC_PNTR =0x0C X_BUF =0x0E Y_BUF =0x10 Z_BUF =0x12 X_ANULL =0x14 Y_ANULL =0x16 Z_ANULL =0x18 REC_CTRL =0x1A REC_PRD =0x1E ALM_F_LOW =0x20 ALM_F_HIGH =0x22 ALM_X_MAG1 =0x24 ALM_Y_MAG1 =0x26 ALM_Z_MAG1 =0x28 ALM_X_MAG2 =0x2A ALM_Y_MAG2 =0x2C ALM_Z_MAG2 =0x2E ALM_PNTR =0x30 ALM_S_MAG =0x32 ALM_CTRL =0x34 DIO_CTRL =0x36 FILT_CTRL =0x38 AVG_CNT =0x3A DIAG_STAT =0x3C GLOB_CMD =0x3E ALM_X_STAT =0x40 ALM_Y_STAT =0x42 ALM_Z_STAT =0x44 ALM_X_PEAK =0x46 ALM_Y_PEAK =0x48 ALM_Z_PEAK =0x4A TIME_STAMP_L =0x4C TIME_STAMP_H =0x4E REV_DAY =0x52 YEAR_MON =0x54 PROD_ID =0x56 SERIAL_NUM =0x58 USER_SCRATCH =0x5A REC_FLASH_CNT =0x5C MISC_CTRL =0x64 REC_INFO1 =0x66 REC_INFO2 =0x68 REC_PNTR =0x6A ALM_X_FREQ =0x6C ALM_Y_FREQ =0x6E ALM_Z_FREQ =0x70 STAT_PNTR =0x72 X_STASTIC =0x74 Y_STASTIC =0x76 Z_STASTIC =0x78 FUND_FREQ =0x7A FLASH_CNT_L =0x7C FLASH_CNT_H =0x7E PAGE_ID =0x00 def __init__(self, device=0, ce_pin=0): """ device: the SPI device (often 0) ce_pin: pass 0 for CE0, 1 for CE1, etc. device and ce_pin map to device file /dev/spidev{device}.{ce_pin} """ self.spi_init(device, ce_pin) def spi_init(self,device,ce_pin): """ Using "pinout" command to check the raspberry spi definition. device: SPI0 (0), SPI1 (1) ce_pin: CE0 (0), CE1 (1) SPI0 definition CE0 : GPIO8 (0) PIN24 CE1 : GPIO7 (1) PIN26 MOSI: GPIO10 PIN19 MISO: GPIO9 PIN21 SCLK: GPIO11 PIN23 SPI1 definition CE0 : GPIO18 (0) PIN12 CE1 : GPIO17 (1) PIN11PAGE_ID CE2 : GPIO16 (2) PIN36 MOSI: GPIO20 PIN38 MISO: GPIO19 PIN35 SCLK: GPIO21 PIN40 """ # init spi for communication self.spi = spidev.SpiDev() self.spi.open(device, ce_pin) # (x,0) == CE0, (x,1) == CE1 # Set 4-line spi mode self.spi.threewire =False # Set spi msb first self.spi.lsbfirst =False # Set clock phase and polarity to default # SPI_CPOL=0, SPI_CPHA=0 self.spi.mode =3 # Set SPI CS Active Low self.spi.cshigh =False # Set SPI clock rate: 7.8125MHz, cdiv=32, fsclk=250MHz/cdiv, cdiv = [2,4,8,16,32,...32768] self.spi.max_speed_hz=SPI_MAX_SPEED self.spi.bits_per_word =8 def spi_write(self, address, value): # Write value (1 byte) to address # Send instruction (command bit7=1 for write), address[6:0], and value address=address+0x80 self.spi.xfer([address, value]) def spi_write_word(self,address,value_16b): value_l=value_16b & 0xFF value_h=value_16b>>8 self.spi_write(address,value_l) self.spi_write(address+1,value_h) def spi_read_bytes(self, address): # Read # Send instruction (command bit7=0 for read), address bit6:0 rb=self.spi.xfer([address,0],SPI_MAX_SPEED,16,8) return rb def spi_read(self, address): # Read # Send instruction (command bit7=0 for read), address bit6:0 rb=self.spi.xfer([address,0],SPI_MAX_SPEED,16,8) rbc= rb[0]*256 + rb[1] return rbc def spi_read2s(self, address): # Read # Send instruction (command bit7=0 for read), address bit6:0 rb=self.spi.xfer([address,0],SPI_MAX_SPEED,16,8) rbc= rb[0]*256 + rb[1] rbc2= self.twos_comp(rbc,16) return rbc2 def twos_comp(self,val, bits): # two's complement of value in bits if val&(1<<(bits-1)) != 0: val = val - (1<<bits) return val def check_spi_rd(self): #Readback Device ID to check the SPI Read self.get_prod_id() rb=self.get_prod_id() print ("--------------") print ("product_id readback:%s"%(rb)) if (rb == 3021) : print ("spi Read OK, Find DUT=ADcmXL3021") else: print ("spi Read Failure, Please check SPI timing and hardware connections") def software_reset(self): self.spi_read(self.GLOB_CMD) rb=self.spi_read(self.GLOB_CMD) rb=rb | 0x80 self.spi_write_word(self.GLOB_CMD,rb) #wait s time.sleep(0.5) def get_diag_sts(self): self.spi_read(self.DIAG_STS) rb=self.spi_read(self.DIAG_STS) return hex(rb) def get_temp_out(self): #return unit:C #self.set_page_id(page_id=0) self.spi_read(self.TEMP_OUT) rb=self.spi_read(self.TEMP_OUT) return (self.twos_comp(rb,16)*(-0.46)+460) def get_prod_id(self): #self.set_page_id(page_id=0) self.spi_read(self.PROD_ID) rb=self.spi_read(self.PROD_ID) return rb def set_user_scratch(self,user_scratch): #self.set_page_id(page_id=0) self.spi_write_word(self.USER_SCRATCH,user_scratch) def get_user_scratch(self): #self.set_page_id(page_id=0) self.spi_read(self.USER_SCRATCH) rb=self.spi_read(self.USER_SCRATCH) return rb def get_year_mon_day_rev(self): #self.set_page_id(page_id=0) self.spi_read(self.YEAR_MON) year_mon=self.spi_read(self.YEAR_MON) self.spi_read(self.REV_DAY) rev_day=self.spi_read(self.REV_DAY) return year_mon, rev_day def set_page_id(self,page_id): self.spi_write_word(self.PAGE_ID,page_id) def get_page_id(self): self.spi_read(self.PAGE_ID) rb=self.spi_read(self.PAGE_ID) return rb # MTC mode Register Settings: # AVG_CNT: decimation filter D after ADC fs=220ksps # FILT_CTL: FIR filter 32 taps # REC_CTRL: [bit1:0] Record mode control = 0b10 (MTC) # [bit13:12] Window Setting =01 (hanning default) # [bit11:8] SR settings =0b0001 (sr0 enabled, sr1~3 disabled) # GLOB_CMD: Bit11= record start/stop or external trigger # /BUSY signal will toggle when the data record USER_SCRATCHis stored and the alarms are checked. # 4096 DATA will be stored in X/Y/Z_BUF def mtc_set(self): self.spi_write_word(self.AVG_CNT,0x7421) self.spi_write_word(self.FILT_CTRL,0x0000) self.spi_write_word(self.REC_CTRL,0x1102) self.record_start() time.sleep(2) def mtc_read(self): gain=-0.001907 self.set_buf_pntr(buf_pntr=0) for i in range(10): if i==0: self.spi_read2s(self.X_BUF) x=self.spi_read2s(self.X_BUF)*gain print (x) self.set_buf_pntr(buf_pntr=0) for i in range(10): if i==0: self.spi_read2s(self.Y_BUF) y=self.spi_read2s(self.Y_BUF)*gain print (y) self.set_buf_pntr(buf_pntr=0) for i in range(10): if i==0: self.spi_read2s(self.Z_BUF) z=self.spi_read2s(self.Z_BUF)*gain print (z) # MFFT mode Register Settings: # AVG_CNT: decimation filter D after ADC fs=220ksps # FILT_CTL: FIR filter 32 taps # REC_CTRL: [bit1:0] Record mode control = 0b00 (MFFT) # [bit13:12] Window Setting =01 (hanning default) # [bit11:8] SR settings =0b0001 (sr0 enabled, sr1~3 disabled) # FFT_AVG1: spectral average settings for sr0 and sr1, default (0x0108) # FFT_AVG2: spectral average settings for sr2 and sr3, default (0x0101) # GLOB_CMD: Bit11= record start/stop or external trigger # /BUSY signal will toggle when the data record USER_SCRATCHis stored and the alarms are checked. # 4096 DATA will be stored in X/Y/Z_BUF def mfft_set(self): self.spi_write_word(self.AVG_CNT,0x0000) self.spi_write_word(self.FILT_CTRL,0x0000) self.spi_write_word(self.REC_CTRL,0x1100) self.spi_write_word(self.FFT_AVG1,0x0108) self.spi_write_word(self.FFT_AVG2,0x0101) self.record_start() time.sleep(10) def mfft_read(self): self.set_buf_pntr(buf_pntr=0) for i in range(10): if i==0: self.spi_read(self.X_BUF) x=self.spi_read(self.X_BUF) print (x) self.set_buf_pntr(buf_pntr=0) for i in range(10): if i==0: self.spi_read(self.Y_BUF) y=self.spi_read(self.Y_BUF) print (y) self.set_buf_pntr(buf_pntr=0) for i in range(10): if i==0: self.spi_read(self.Z_BUF) z=self.spi_read(self.Z_BUF) print (z) def get_avg_cnt(self): #self.set_page_id(page_id=0) self.spi_read(self.AVG_CNT) rb=self.spi_read_bytes(self.AVG_CNT) sr3=rb[0]>>4 sr2=rb[0]&0x0F sr1=rb[1]>>4 sr0=rb[1]&0x0F return [sr3,sr2,sr1,sr0] def set_buf_pntr(self,buf_pntr): #self.set_page_id(page_id=0) self.spi_write_word(self.BUF_PNTR,buf_pntr) def record_start(self): self.spi_read(self.GLOB_CMD) rb=self.spi_read(self.GLOB_CMD) rb=rb | 0x0800 self.spi_write_word(self.GLOB_CMD,rb) def self_test(self): self.spi_read(self.GLOB_CMD) rb=self.spi_read(self.GLOB_CMD) rb=rb | 0x0004 self.spi_write_word(self.GLOB_CMD,rb) time.sleep(1) rb=self.spi_read_bytes(self.DIAG_STAT) return rb if __name__ == "__main__": try: if 1: time.sleep(1) except KeyboardInterrupt: spi.close() sys.exit(0)
I'm looking for a routine for the adcmxl3201 program
