ADIS16209使用STM32内部SPI通信读不出数据
程序如下:使用STM32 HAL库
uint8_t SPI_ADIS16209_Sendbyte(uint8_t byte)
uint8_t d_read,d_send = byte;
if(HAL_SPI_TransmitReceive(&hspi1,&d_send,&d_read,1,1000)!=HAL_OK)
d_read = Dummy_Byte;
return d_read;
uint8_t Read_ADIS16209_Data(uint8_t Dst,uint8_t *RcvBuf)
uint8_t i = 0;
CLR_CS();
__nop();__nop();__nop();__nop();
SPI_ADIS16209_Sendbyte(Dst&0x3f);
SPI_ADIS16209_Sendbyte(0X00);
SET_CS();
for(i=1;i>0;i--);
CLR_CS();
for(i=0;i<2;i++)
RcvBuf[i] = SPI_ADIS16209_Sendbyte(0x00);
SET_CS();
for(i=1;i>0;i--);
return 1;
int main(void)
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_SPI1_Init();
__HAL_SPI_ENABLE(&hspi1);
while (1)
Read_ADIS16209_Data(XINCL_OUT,XINCL_OUT_DATA);
HAL_Delay(10);
Read_ADIS16209_Data(YINCL_OUT,YINCL_OUT_DATA);
HAL_Delay(10);
Read_ADIS16209_Data(ROT_OUT,ROT_OUT_DATA);
HAL_Delay(10);
以下是模拟SPI通信程序:
void WriteToADIS16209ViaSpi(unsigned char RegisterAddress, unsigned char NumberofRegisters, unsigned char *RegisterData)
unsigned char ControlValue = 0;
unsigned int ValueToWrite = 0;
unsigned char RegisterIndex = 0;
unsigned char i = 0;
for(RegisterIndex=0; RegisterIndex<NumberofRegisters*2; RegisterIndex++)//every register of ADIS16209 takes up two bytes
//Create the 8-bit header
ControlValue = (RegisterAddress + RegisterIndex) | 0x80;
SET_SCL();
Delay(1);
SET_CS();
Delay(1);
CLR_CS();
Delay(1);
//Write out the control word
for(i=0; i<8; i++)
CLR_SCL();
if(0x80 == (ControlValue & 0x80))
SET_SDO(); //Send one to DIN pin of ADIS16209
else
CLR_SDO(); //Send zero to DIN pin of ADIS16209
Delay(1);
SET_SCL();
Delay(1);
ControlValue <<= 1; //Rotate data
//And then the data
ValueToWrite = *(RegisterData + RegisterIndex);
for (i=0; i<8; i++)
CLR_SCL();
if(0x80 == (ValueToWrite & 0x80))
else
Delay(1);
SET_SCL();
Delay(1);
ValueToWrite <<= 1; //Rotate data
SET_CS(); //bring CS high again
Delay(2);
uint16_t ReadFromADIS16209ViaSpi(unsigned char RegisterAddress, unsigned char NumberofRegisters, unsigned char *RegisterData)
unsigned char ReceiveData = 0;
unsigned char i = 0, j = 0;
//unsigned int iTemp = 0;
for(RegisterIndex=0; RegisterIndex<NumberofRegisters; RegisterIndex++)
for(j=0;j<2;j++) //Repeat reading to make sure the data on DOUT is just the register which you are going to read
ControlValue = RegisterAddress + RegisterIndex*2;//every register of ADIS16209 takes up two bytes
SET_SCL();
Delay(1);
SET_CS();
Delay(1);
CLR_CS(); //bring CS low
Delay(1);
for(i=0; i<8; i++)
CLR_SCL();
else
Delay(1);
SET_SCL();
ReceiveData <<= 1; //Rotate data
if(HAL_GPIO_ReadPin(GPIOA,GPIO_PIN_6)==GPIO_PIN_SET)
ReceiveData |= 1;
Delay(1);
//*(RegisterData + RegisterIndex*2 + 1) = ReceiveData;
//Read data in
for(i=0; i<8; i++)
CLR_SCL();
Delay(1);
SET_SCL();
ReceiveData |= 1;
Delay(1);
//*(RegisterData + RegisterIndex*2) = ReceiveData;
Delay(2);
return ReceiveData;
int main()
//其他省略
RegisterData[0] = 0x01;
RegisterData[1] = 0x23;
RegisterData[2] = 0x05;
RegisterData[3] = 0xA6;
WriteToADIS16209ViaSpi(SUPPLY_OUT,2,RegisterData);
RegisterData[0] = 0x88;
RegisterData[1] = 0x88;
RegisterData[2] = 0x88;
RegisterData[3] = 0x88;
aa = ReadFromADIS16209ViaSpi(SUPPLY_OUT,2,RegisterData);
ADIS16209读取数据前 是否要先发送2个字节的地址,然后在读吗?
