max96717f与max96712传输数据问题
The user is troubleshooting a lack of MIPI CSI output from the MAX96712 deserializer in a radar product setup, where the output is processed by an NVIDIA Jetson Orin NX. The final answer suggests checking if the issue is from a software perspective or if there is no signal on the lines, ensuring data format compatibility, and trying a different deserializer like the MAX96724F with tunnel mode. The user confirmed that the data format is RAW12 on both sides, and the tunnel mode configuration still resulted in no data, with specific error logs indicating issues with stream virtual channels.
Product Number: Max96712,max96717f, Max967
我们公司正在研发一款雷达产品,其中雷达输出的数据经过max96717f加串后再max96712解串,最后给到nvidia的Jetson orin nx 平台处理,但是max96712的mipi csi端口没有输出。
查看max96712的0x108寄存器=0x62 意思是”Video pipeline locked“,0x1dc寄存器=0x81 意思是”Video channel is locked
还有些其它寄存器的值,其中设备0x29为max96712,0x40为max96717f。
这是我正在使用的配置脚本
#// CSIConfigurationTool
#// GMSL-A / Serializer: MAX96717F (Pixel Mode) / Mode: 1x4 / Device Address: 0x80 / Multiple-VC Case: Single VC / Pipe Sharing: Separate Pipes
#// PipeZ:
#// Input Stream: VC0 RAW12 PortB (D-PHY) (Doubled)
#// GMSL-B / Serializer: MAX96717F (Pixel Mode) / Mode: 1x4 / Device Address: 0x84 / Multiple-VC Case: Single VC / Pipe Sharing: Separate Pipes
#// PipeZ:
#// Deserializer: MAX96712 / Mode: 1x4A + 2x2 / Device Address: 0x4E
#// Pipe0:
#// GMSL-A Input Stream: VC0 RAW12 PortB - Output Stream: VC0 RAW12 PortA (D-PHY)
#// Pipe1:
#// GMSL-B Input Stream: VC0 RAW12 PortB - Output Stream: VC1 RAW12 PortA (D-PHY)
i2ctransfer -f -y 2 w3@0x29 0x04 0x0B 0x00  #// BACKTOP : BACKTOP12 | CSI_OUT_EN (CSI_OUT_EN): CSI output disabled
#// Link Initialization for Deserializer
i2ctransfer -f -y 2 w3@0x29 0x00 0x06 0xF3  #// DEV : REG6 | (Default) LINK_EN_A (LINK_EN_A): Enabled | (Default) LINK_EN_B (LINK_EN_B): Enabled | LINK_EN_C (LINK_EN_C): Disabled | LINK_EN_D (LINK_EN_D): Disabled
i2ctransfer -f -y 2 w3@0x29 0x00 0x10 0x21  #// DEV : REG26 | RX_RATE_PHYA (RX_RATE_PHYA): 3
i2ctransfer -f -y 2 w3@0x29 0x00 0x18 0x01  #// TOP_CTRL : CTRL1 | RESET_ONESHOT_A (RESET_ONESHOT_A): Activated
i2ctransfer -f -y 2 w3@0x29 0x00 0x10 0x11  #// DEV : REG26 | RX_RATE_PHYB (RX_RATE_PHYB): 3
i2ctransfer -f -y 2 w3@0x29 0x00 0x18 0x03  #// TOP_CTRL : CTRL1 | RESET_ONESHOT_B (RESET_ONESHOT_B): Activated
sleep 0.12 #// 120 msec delay
i2ctransfer -f -y 2 w3@0x29 0x00 0x06 0xF3  #// DEV : REG6 | (Default) LINK_EN_A (LINK_EN_A): Enabled | (Default) LINK_EN_B (LINK_EN_B): Enabled | (Default) LINK_EN_C (LINK_EN_C): Disabled | (Default) LINK_EN_D (LINK_EN_D): Disabled
#i2ctransfer -f -y 2 w3@0x29 0x00 0x03 0xFA  #// DEV : REG3 | (Default) DIS_REM_CC_A (GMSL Link A I2C Port 0): Enabled | (Default) DIS_REM_CC_B (GMSL Link B I2C Port 0): Enabled | DIS_REM_CC_C (GMSL Link C I2C Port 0): Disabled | DIS_REM_CC_D (GMSL Link D I2C Port 0): Disabled
#// Video Transmit Configuration for Serializer(s)
i2ctransfer -f -y 2 w3@0x40 0x00 0x02 0x03  #// DEV : REG2 | VID_TX_EN_Z (VID_TX_EN_Z): Disabled
i2ctransfer -f -y 2 w3@0x42 0x00 0x02 0x03  #// DEV : REG2 | VID_TX_EN_Z (VID_TX_EN_Z): Disabled
#// INSTRUCTIONS FOR GMSL-A SERIALIZER MAX96717F
#// MIPI D-PHY Configuration
i2ctransfer -f -y 2 w3@0x40 0x03 0x30 0x00  #// MIPI_RX : MIPI_RX0 | (Default) RSVD (Port Configuration): 1x4
i2ctransfer -f -y 2 w3@0x40 0x03 0x83 0x00  #// MIPI_RX_EXT : EXT11 | Tun_Mode (Tunnel Mode): Disabled
i2ctransfer -f -y 2 w3@0x40 0x03 0x31 0x30  #// MIPI_RX : MIPI_RX1 | (Default) ctrl1_num_lanes (Port B - Lane Count): 4
i2ctransfer -f -y 2 w3@0x40 0x03 0x32 0xE0  #// MIPI_RX : MIPI_RX2 | (Default) phy1_lane_map (Lane Map - PHY1 D0): Lane 2 | (Default) phy1_lane_map (Lane Map - PHY1 D1): Lane 3
i2ctransfer -f -y 2 w3@0x40 0x03 0x33 0x04  #// MIPI_RX : MIPI_RX3 | (Default) phy2_lane_map (Lane Map - PHY2 D0): Lane 0 | (Default) phy2_lane_map (Lane Map - PHY2 D1): Lane 1
i2ctransfer -f -y 2 w3@0x40 0x03 0x34 0x00  #// MIPI_RX : MIPI_RX4 | (Default) phy1_pol_map (Polarity - PHY1 Lane 0): Normal | (Default) phy1_pol_map (Polarity - PHY1 Lane 1): Normal
i2ctransfer -f -y 2 w3@0x40 0x03 0x35 0x00  #// MIPI_RX : MIPI_RX5 | (Default) phy2_pol_map (Polarity - PHY2 Lane 0): Normal | (Default) phy2_pol_map (Polarity - PHY2 Lane 1): Normal | (Default) phy2_pol_map (Polarity - PHY2 Clock Lane): Normal
#// Controller to Pipe Mapping Configuration
i2ctransfer -f -y 2 w3@0x40 0x03 0x08 0x64  #// FRONTTOP : FRONTTOP_0 | (Default) RSVD (CLK_SELZ): Port B | (Default) START_PORTB (START_PORTB): Enabled
i2ctransfer -f -y 2 w3@0x40 0x03 0x11 0x40  #// FRONTTOP : FRONTTOP_9 | (Default) START_PORTBZ (START_PORTBZ): Start Video
i2ctransfer -f -y 2 w3@0x40 0x03 0x18 0x6C  #// FRONTTOP : FRONTTOP_16 | mem_dt1_selz (mem_dt1_selz): 0x6C
#// Double Mode Configuration
i2ctransfer -f -y 2 w3@0x40 0x01 0x10 0x60  #// VID_TX__Z : VIDEO_TX0 | AUTO_BPP (AUTO_BPP Pipe Z): Use bpp from bpp register
i2ctransfer -f -y 2 w3@0x40 0x01 0x11 0x58  #// VID_TX__Z : VIDEO_TX1 | (Default) BPP (BPP Pipe Z): 0x18
i2ctransfer -f -y 2 w3@0x40 0x01 0x12 0x08  #// VID_TX__Z : VIDEO_TX2 | RSVD (DRIFT_DET_EN Pipe Z): Disable PCLK frequency drift detection
i2ctransfer -f -y 2 w3@0x40 0x03 0x13 0x40  #// FRONTTOP : FRONTTOP_11 | bpp12dblz (bpp12dblz): Send 12-bit pixels as 24-bit
i2ctransfer -f -y 2 w3@0x40 0x03 0x1E 0x38  #// FRONTTOP : FRONTTOP_22 | (Default) soft_bppz (soft_bppz): 0x18 | soft_bppz_en (soft_bppz_en): Software override enabled
#// Pipe Configuration
i2ctransfer -f -y 2 w3@0x40 0x00 0x5B 0x00  #// CFGV__VIDEO_Z : TX3 | TX_STR_SEL (TX_STR_SEL Pipe Z): 0x0
#// INSTRUCTIONS FOR GMSL-B SERIALIZER MAX96717F
i2ctransfer -f -y 2 w3@0x42 0x03 0x30 0x00  #// MIPI_RX : MIPI_RX0 | (Default) RSVD (Port Configuration): 1x4
i2ctransfer -f -y 2 w3@0x42 0x03 0x83 0x00  #// MIPI_RX_EXT : EXT11 | Tun_Mode (Tunnel Mode): Disabled
i2ctransfer -f -y 2 w3@0x42 0x03 0x31 0x30  #// MIPI_RX : MIPI_RX1 | (Default) ctrl1_num_lanes (Port B - Lane Count): 4
i2ctransfer -f -y 2 w3@0x42 0x03 0x32 0xE0  #// MIPI_RX : MIPI_RX2 | (Default) phy1_lane_map (Lane Map - PHY1 D0): Lane 2 | (Default) phy1_lane_map (Lane Map - PHY1 D1): Lane 3
i2ctransfer -f -y 2 w3@0x42 0x03 0x33 0x04  #// MIPI_RX : MIPI_RX3 | (Default) phy2_lane_map (Lane Map - PHY2 D0): Lane 0 | (Default) phy2_lane_map (Lane Map - PHY2 D1): Lane 1
i2ctransfer -f -y 2 w3@0x42 0x03 0x34 0x00  #// MIPI_RX : MIPI_RX4 | (Default) phy1_pol_map (Polarity - PHY1 Lane 0): Normal | (Default) phy1_pol_map (Polarity - PHY1 Lane 1): Normal
i2ctransfer -f -y 2 w3@0x42 0x03 0x35 0x00  #// MIPI_RX : MIPI_RX5 | (Default) phy2_pol_map (Polarity - PHY2 Lane 0): Normal | (Default) phy2_pol_map (Polarity - PHY2 Lane 1): Normal | (Default) phy2_pol_map (Polarity - PHY2 Clock Lane): Normal
i2ctransfer -f -y 2 w3@0x42 0x03 0x08 0x64  #// FRONTTOP : FRONTTOP_0 | (Default) RSVD (CLK_SELZ): Port B | (Default) START_PORTB (START_PORTB): Enabled
i2ctransfer -f -y 2 w3@0x42 0x03 0x11 0x40  #// FRONTTOP : FRONTTOP_9 | (Default) START_PORTBZ (START_PORTBZ): Start Video
i2ctransfer -f -y 2 w3@0x42 0x03 0x18 0x6C  #// FRONTTOP : FRONTTOP_16 | mem_dt1_selz (mem_dt1_selz): 0x6C
i2ctransfer -f -y 2 w3@0x42 0x01 0x10 0x60  #// VID_TX__Z : VIDEO_TX0 | AUTO_BPP (AUTO_BPP Pipe Z): Use bpp from bpp register
i2ctransfer -f -y 2 w3@0x42 0x01 0x11 0x58  #// VID_TX__Z : VIDEO_TX1 | (Default) BPP (BPP Pipe Z): 0x18
i2ctransfer -f -y 2 w3@0x42 0x01 0x12 0x08  #// VID_TX__Z : VIDEO_TX2 | RSVD (DRIFT_DET_EN Pipe Z): Disable PCLK frequency drift detection
i2ctransfer -f -y 2 w3@0x42 0x03 0x13 0x40  #// FRONTTOP : FRONTTOP_11 | bpp12dblz (bpp12dblz): Send 12-bit pixels as 24-bit
i2ctransfer -f -y 2 w3@0x42 0x03 0x1E 0x38  #// FRONTTOP : FRONTTOP_22 | (Default) soft_bppz (soft_bppz): 0x18 | soft_bppz_en (soft_bppz_en): Software override enabled
i2ctransfer -f -y 2 w3@0x42 0x00 0x5B 0x00  #// CFGV__VIDEO_Z : TX3 | TX_STR_SEL (TX_STR_SEL Pipe Z): 0x0
#// INSTRUCTIONS FOR DESERIALIZER MAX96712
#// Video Pipes And Routing Configuration
i2ctransfer -f -y 2 w3@0x29 0x00 0xF0 0x40  #// VIDEO_PIPE_SEL : VIDEO_PIPE_SEL_0 | (Default) VIDEO_PIPE_SEL_0 (Pipe 0 GMSL2 PHY): A | VIDEO_PIPE_SEL_0 (Pipe 0 Input Pipe): X | (Default) VIDEO_PIPE_SEL_1 (Pipe 1 GMSL2 PHY): B | VIDEO_PIPE_SEL_1 (Pipe 1 Input Pipe): X
i2ctransfer -f -y 2 w3@0x29 0x00 0xF4 0x03  #// VIDEO_PIPE_SEL : VIDEO_PIPE_EN | (Default) VIDEO_PIPE_EN (Video Pipe 0): Enabled | (Default) VIDEO_PIPE_EN (Video Pipe 1): Enabled | VIDEO_PIPE_EN (Video Pipe 2): Disabled | VIDEO_PIPE_EN (Video Pipe 3): Disabled | STREAM_SEL_ALL (Stream Select All): Disabled
#// Pipe to Controller Mapping Configuration
i2ctransfer -f -y 2 w3@0x29 0x09 0x0B 0x07  #// MIPI_TX__0 : MIPI_TX11 | MAP_EN_L (MAP_EN_L Pipe 0): 0x7
i2ctransfer -f -y 2 w3@0x29 0x09 0x0C 0x00  #// MIPI_TX__0 : MIPI_TX12 | (Default) MAP_EN_H (MAP_EN_H Pipe 0): 0x0
i2ctransfer -f -y 2 w3@0x29 0x09 0x0D 0x2C  #// MIPI_TX__0 : MIPI_TX13 | MAP_SRC_0 (MAP_SRC_0 Pipe 0 DT): 0x2C | (Default) MAP_SRC_0 (MAP_SRC_0 Pipe 0 VC): 0x0
i2ctransfer -f -y 2 w3@0x29 0x09 0x0E 0x2C  #// MIPI_TX__0 : MIPI_TX14 | MAP_DST_0 (MAP_DST_0 Pipe 0 DT): 0x2C | (Default) MAP_DST_0 (MAP_DST_0 Pipe 0 VC): 0x0
i2ctransfer -f -y 2 w3@0x29 0x09 0x0F 0x00  #// MIPI_TX__0 : MIPI_TX15 | (Default) MAP_SRC_1 (MAP_SRC_1 Pipe 0 DT): 0x0 | (Default) MAP_SRC_1 (MAP_SRC_1 Pipe 0 VC): 0x0
i2ctransfer -f -y 2 w3@0x29 0x09 0x10 0x00  #// MIPI_TX__0 : MIPI_TX16 | (Default) MAP_DST_1 (MAP_DST_1 Pipe 0 DT): 0x0 | (Default) MAP_DST_1 (MAP_DST_1 Pipe 0 VC): 0x0
i2ctransfer -f -y 2 w3@0x29 0x09 0x11 0x01  #// MIPI_TX__0 : MIPI_TX17 | MAP_SRC_2 (MAP_SRC_2 Pipe 0 DT): 0x1 | (Default) MAP_SRC_2 (MAP_SRC_2 Pipe 0 VC): 0x0
i2ctransfer -f -y 2 w3@0x29 0x09 0x12 0x01  #// MIPI_TX__0 : MIPI_TX18 | MAP_DST_2 (MAP_DST_2 Pipe 0 DT): 0x1 | (Default) MAP_DST_2 (MAP_DST_2 Pipe 0 VC): 0x0
i2ctransfer -f -y 2 w3@0x29 0x09 0x2D 0x15  #// MIPI_TX__0 : MIPI_TX45 | MAP_DPHY_DEST_0 (MAP_DPHY_DST_0 Pipe 0): 0x1 | MAP_DPHY_DEST_1 (MAP_DPHY_DST_1 Pipe 0): 0x1 | MAP_DPHY_DEST_2 (MAP_DPHY_DST_2 Pipe 0): 0x1
i2ctransfer -f -y 2 w3@0x29 0x09 0x4B 0x07  #// MIPI_TX__1 : MIPI_TX11 | MAP_EN_L (MAP_EN_L Pipe 1): 0x7
i2ctransfer -f -y 2 w3@0x29 0x09 0x4C 0x00  #// MIPI_TX__1 : MIPI_TX12 | (Default) MAP_EN_H (MAP_EN_H Pipe 1): 0x0
i2ctransfer -f -y 2 w3@0x29 0x09 0x4D 0x2C  #// MIPI_TX__1 : MIPI_TX13 | MAP_SRC_0 (MAP_SRC_0 Pipe 1 DT): 0x2C | (Default) MAP_SRC_0 (MAP_SRC_0 Pipe 1 VC): 0x0
i2ctransfer -f -y 2 w3@0x29 0x09 0x4E 0x6C  #// MIPI_TX__1 : MIPI_TX14 | MAP_DST_0 (MAP_DST_0 Pipe 1 DT): 0x2C | MAP_DST_0 (MAP_DST_0 Pipe 1 VC): 0x1
i2ctransfer -f -y 2 w3@0x29 0x09 0x4F 0x00  #// MIPI_TX__1 : MIPI_TX15 | (Default) MAP_SRC_1 (MAP_SRC_1 Pipe 1 DT): 0x0 | (Default) MAP_SRC_1 (MAP_SRC_1 Pipe 1 VC): 0x0
i2ctransfer -f -y 2 w3@0x29 0x09 0x50 0x40  #// MIPI_TX__1 : MIPI_TX16 | (Default) MAP_DST_1 (MAP_DST_1 Pipe 1 DT): 0x0 | MAP_DST_1 (MAP_DST_1 Pipe 1 VC): 0x1
i2ctransfer -f -y 2 w3@0x29 0x09 0x51 0x01  #// MIPI_TX__1 : MIPI_TX17 | MAP_SRC_2 (MAP_SRC_2 Pipe 1 DT): 0x1 | (Default) MAP_SRC_2 (MAP_SRC_2 Pipe 1 VC): 0x0
i2ctransfer -f -y 2 w3@0x29 0x09 0x52 0x41  #// MIPI_TX__1 : MIPI_TX18 | MAP_DST_2 (MAP_DST_2 Pipe 1 DT): 0x1 | MAP_DST_2 (MAP_DST_2 Pipe 1 VC): 0x1
i2ctransfer -f -y 2 w3@0x29 0x09 0x6D 0x15  #// MIPI_TX__1 : MIPI_TX45 | MAP_DPHY_DEST_0 (MAP_DPHY_DST_0 Pipe 1): 0x1 | MAP_DPHY_DEST_1 (MAP_DPHY_DST_1 Pipe 1): 0x1 | MAP_DPHY_DEST_2 (MAP_DPHY_DST_2 Pipe 1): 0x1
i2ctransfer -f -y 2 w3@0x29 0x09 0x73 0x01  #// MIPI_TX__1 : MIPI_TX51 | ALT_MEM_MAP12 (ALT_MEM_MAP12 CTRL1): Alternate memory map enabled
i2ctransfer -f -y 2 w3@0x29 0x08 0xA0 0x08  #// MIPI_PHY : MIPI_PHY0 | phy_4x2 (Port Configuration): 1x4A + 2x2
i2ctransfer -f -y 2 w3@0x29 0x09 0x4A 0xD0  #// MIPI_TX__1 : MIPI_TX10 | (Default) CSI2_LANE_CNT (Port A - Lane Count): 4
i2ctransfer -f -y 2 w3@0x29 0x08 0xA3 0xE4  #// MIPI_PHY : MIPI_PHY3 | (Default) phy0_lane_map (Lane Map - PHY0 D0): Lane 0 | (Default) phy0_lane_map (Lane Map - PHY0 D1): Lane 1 | (Default) phy1_lane_map (Lane Map - PHY1 D0): Lane 2 | (Default) phy1_lane_map (Lane Map - PHY1 D1): Lane 3
i2ctransfer -f -y 2 w3@0x29 0x08 0xA5 0x00  #// MIPI_PHY : MIPI_PHY5 | (Default) phy0_pol_map (Polarity - PHY0 Lane 0): Normal | (Default) phy0_pol_map (Polarity - PHY0 Lane 1): Normal | (Default) phy1_pol_map (Polarity - PHY1 Lane 0): Normal | (Default) phy1_pol_map (Polarity - PHY1 Lane 1): Normal | (Default) phy1_pol_map (Polarity - PHY1 Clock Lane): Normal
i2ctransfer -f -y 2 w3@0x29 0x09 0x43 0x07  #// MIPI_TX__1 : MIPI_TX3 | DESKEW_INIT (Controller 1 Auto Initial Deskew): Disabled
i2ctransfer -f -y 2 w3@0x29 0x09 0x44 0x01  #// MIPI_TX__1 : MIPI_TX4 | DESKEW_PER (Controller 1 Periodic Deskew): Disabled
i2ctransfer -f -y 2 w3@0x29 0x1D 0x00 0xF4  #//  (config_soft_rst_n - PHY1): 0x0
#// This is to set predefined (coarse) CSI output frequency
#// CSI Phy 1 is 1500 Mbps/lane.
i2ctransfer -f -y 2 w3@0x29 0x1D 0x00 0xF4  #// (Default)
i2ctransfer -f -y 2 w3@0x29 0x04 0x18 0x2F  #// (Default)
i2ctransfer -f -y 2 w3@0x29 0x1D 0x00 0xF5  #//  | (Default)  (config_soft_rst_n - PHY1): 0x1
i2ctransfer -f -y 2 w3@0x29 0x08 0xA2 0x34  #// MIPI_PHY : MIPI_PHY2 | phy_Stdby_n (phy_Stdby_2): Put PHY2 in standby mode | phy_Stdby_n (phy_Stdby_3): Put PHY3 in standby mode
i2ctransfer -f -y 2 w3@0x29 0x04 0x0B 0x02  #// BACKTOP : BACKTOP12 | CSI_OUT_EN (CSI_OUT_EN): CSI output enabled
i2ctransfer -f -y 2 w3@0x40 0x00 0x02 0x43  #// DEV : REG2 | VID_TX_EN_Z (VID_TX_EN_Z): Enabled
i2ctransfer -f -y 2 w3@0x42 0x00 0x02 0x43  #// DEV : REG2 | VID_TX_EN_Z (VID_TX_EN_Z): Enabled
  • 1. CSI口没有输出,是从jetson的软件角度看没有数据,还是实测信号线上没有信号;
    2. 检查数据格式是否匹配;
    3. 可尝试使用MAX96724F等带有tunnel传输模式的DES。
  • 1.后续试过更换max96724的解串器底板,实测max96724的csi口上是没有波形的
    2.脚本里面两边配置的数据格式都是RAW12
    3.tunnel模式我也试过,依然没有数据,但是log里面会有个”kworker/2:2-5662    [002] ....... 14753.495858: rtcpu_nvcsi_intr: tstamp:461966815825 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004“错误,我也不知道该怎么处理
     vi-output, fzca-6864    [000] ....... 14751.976550: tegra_channel_capture_setup: vnc_id 0 W 2048 H 768 fmt c4
     vi-output, fzca-6863    [000] ....... 14752.043167: vi_task_submit: class_id:48 ch:0 syncpt_id:31 syncpt_thresh:24646 pid:6863 tid:6863
         kworker/2:2-5662    [002] ....... 14752.075872: rtcpu_vinotify_event: tstamp:461921940244 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:14781495008416 data:0x799e300010000000
         kworker/2:2-5662    [002] ....... 14752.075874: rtcpu_vinotify_event: tstamp:461921940383 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:14781495014816 data:0x0000000031000001
         kworker/2:2-5662    [002] ....... 14752.075875: rtcpu_vinotify_event: tstamp:461921940537 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:14781495017792 data:0x0000000007020001
         kworker/2:2-5662    [002] ....... 14752.187865: rtcpu_nvcsi_intr: tstamp:461925615100 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:3 status:0x00000004
         kworker/2:2-5662    [002] ....... 14752.187868: rtcpu_nvcsi_intr: tstamp:461925615100 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:3 status:0x00000004
         kworker/2:2-5662    [002] ....... 14752.187871: rtcpu_vinotify_event: tstamp:461925658688 cch:-1 vi:1 tag:CHANSEL_NOMATCH channel:0xc4 frame:27670 vi_tstamp:14781619599584 data:0x0000000000000649
         kworker/2:2-5662    [002] ....... 14752.583851: rtcpu_nvcsi_intr: tstamp:461937386586 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:10 status:0x00000004
         kworker/2:2-5662    [002] ....... 14752.583854: rtcpu_nvcsi_intr: tstamp:461937386586 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:10 status:0x00000004
         kworker/2:2-5662    [002] ....... 14752.751843: rtcpu_nvcsi_intr: tstamp:461943272232 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:11 status:0x00000004
         kworker/2:2-5662    [002] ....... 14752.751846: rtcpu_nvcsi_intr: tstamp:461943272232 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:11 status:0x00000004
         kworker/2:2-5662    [002] ....... 14753.147845: rtcpu_nvcsi_intr: tstamp:461955044174 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:11 status:0x00000004
         kworker/2:2-5662    [002] ....... 14753.147849: rtcpu_nvcsi_intr: tstamp:461955044174 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:11 status:0x00000004
         kworker/2:2-5662    [002] ....... 14753.147851: rtcpu_vinotify_error: tstamp:461955045402 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0xb7 frame:52758 vi_tstamp:14782561411904 data:0x0000000008000402
         kworker/2:2-5662    [002] ....... 14753.147854: rtcpu_vinotify_event: tstamp:461955068578 cch:-1 vi:1 tag:CSIMUX_FRAME channel:0xb7 frame:52758 vi_tstamp:14782561411904 data:0x0000000008000402
         kworker/2:2-5662    [002] ....... 14753.439861: rtcpu_nvcsi_intr: tstamp:461964854816 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:4 status:0x00000004
         kworker/2:2-5662    [002] ....... 14753.439864: rtcpu_nvcsi_intr: tstamp:461964854816 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:4 status:0x00000004
         kworker/2:2-5662    [002] ....... 14753.495854: rtcpu_nvcsi_intr: tstamp:461966815825 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
         kworker/2:2-5662    [002] ....... 14753.551864: rtcpu_nvcsi_intr: tstamp:461968776809 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:14 status:0x00000004
         kworker/2:2-5662    [002] ....... 14753.551867: rtcpu_nvcsi_intr: tstamp:461968776809 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:14 status:0x00000004
         kworker/2:2-5662    [002] ....... 14753.723868: rtcpu_nvcsi_intr: tstamp:461972701363 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:4 status:0x00000004
         kworker/2:2-5662    [002] ....... 14753.723871: rtcpu_nvcsi_intr: tstamp:461972701363 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:4 status:0x00000004
         kworker/2:2-5662    [002] ....... 14753.779826: rtcpu_nvcsi_intr: tstamp:461974663413 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:8 status:0x00000004
         kworker/2:2-5662    [002] ....... 14753.779829: rtcpu_nvcsi_intr: tstamp:461974663413 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:8 status:0x00000004
         kworker/2:2-5662    [002] ....... 14753.839822: rtcpu_nvcsi_intr: tstamp:461976625332 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:8 status:0x00000004
         kworker/2:2-5662    [002] ....... 14753.839825: rtcpu_nvcsi_intr: tstamp:461976625332 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:8 status:0x00000004
         kworker/2:2-5662    [002] ....... 14754.287832: rtcpu_nvcsi_intr: tstamp:461990361219 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:15 status:0x00000004
         kworker/2:2-5662    [002] ....... 14754.287835: rtcpu_nvcsi_intr: tstamp:461990361219 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:15 status:0x00000004
         kworker/2:2-5662    [002] ....... 14754.515803: rtcpu_nvcsi_intr: tstamp:461998210074 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:9 status:0x00000004
         kworker/2:2-5662    [002] ....... 14754.515807: rtcpu_nvcsi_intr: tstamp:461998210074 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:9 status:0x00000004
         kworker/2:2-5662    [002] ....... 14754.683812: rtcpu_nvcsi_intr: tstamp:462004096870 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:8 status:0x00000004
         kworker/2:2-5662    [002] ....... 14754.683815: rtcpu_nvcsi_intr: tstamp:462004096870 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:8 status:0x00000004
  • tunnel传输模式的脚本是用”GMSL Ser Des GUI“生成的
    #// GMSL-A / Serializer: MAX96717F (Tunnel Mode) / Mode: 1x4 / Device Address: 0x80 / Multiple-VC Case: Single VC / Pipe Sharing: Separate Pipes
    #// PipeZ:
    #// Deserializer: MAX96724 / Mode: 1x4A + 2x2 / Device Address: 0x4E
    #// Pipe0:
    i2ctransfer -f -y 2 w3@0x27 0x04 0x0B 0x00   #// BACKTOP : BACKTOP12 | CSI_OUT_EN (CSI_OUT_EN): CSI output disabled
    i2ctransfer -f -y 2 w3@0x27 0x00 0x06 0xF1   #// DEV : REG6 | (Default) LINK_EN_A (LINK_EN_A): Enabled | LINK_EN_B (LINK_EN_B): Disabled | LINK_EN_C (LINK_EN_C): Disabled | LINK_EN_D (LINK_EN_D): Disabled
    i2ctransfer -f -y 2 w3@0x27 0x00 0x10 0x21   #// DEV : REG26 | RX_RATE_PHYA (RX_RATE_PHYA): 3
    i2ctransfer -f -y 2 w3@0x27 0x00 0x18 0x01   #// TOP_CTRL : CTRL1 | RESET_ONESHOT_A (RESET_ONESHOT_A): Activated
    sleep 0.12 # #// 120 msec delay
    i2ctransfer -f -y 2 w3@0x27 0x00 0x06 0xF1   #// DEV : REG6 | (Default) LINK_EN_A (LINK_EN_A): Enabled | (Default) LINK_EN_B (LINK_EN_B): Disabled | (Default) LINK_EN_C (LINK_EN_C): Disabled | (Default) LINK_EN_D (LINK_EN_D): Disabled
    i2ctransfer -f -y 2 w3@0x27 0x00 0x03 0xFE   #// DEV : REG3 | (Default) DIS_REM_CC_A (GMSL Link A I2C Port 0): Enabled | DIS_REM_CC_B (GMSL Link B I2C Port 0): Disabled | DIS_REM_CC_C (GMSL Link C I2C Port 0): Disabled | DIS_REM_CC_D (GMSL Link D I2C Port 0): Disabled
    i2ctransfer -f -y 2 w3@0x40 0x03 0x30 0x40   #// MIPI_RX : MIPI_RX0 | (Default) RSVD (Port Configuration): 1x4
    i2ctransfer -f -y 2 w3@0x40 0x03 0x83 0x80   #// MIPI_RX_EXT : EXT11 | (Default) Tun_Mode (Tunnel Mode): Enabled
    #// INSTRUCTIONS FOR DESERIALIZER MAX96724
    i2ctransfer -f -y 2 w3@0x27 0x00 0xF0 0x60   #// VIDEO_PIPE_SEL : VIDEO_PIPE_SEL_0 | (Default) VIDEO_PIPE_SEL_0 (Pipe 0 GMSL2 PHY): A | VIDEO_PIPE_SEL_0 (Pipe 0 Input Pipe): X
    i2ctransfer -f -y 2 w3@0x27 0x00 0xF4 0x01   #// VIDEO_PIPE_SEL : VIDEO_PIPE_EN | (Default) VIDEO_PIPE_EN (Video Pipe 0): Enabled | VIDEO_PIPE_EN (Video Pipe 1): Disabled | VIDEO_PIPE_EN (Video Pipe 2): Disabled | VIDEO_PIPE_EN (Video Pipe 3): Disabled | STREAM_SEL_ALL (Stream Select All): Disabled
    i2ctransfer -f -y 2 w3@0x27 0x08 0xA0 0x08   #// MIPI_PHY : MIPI_PHY0 | phy_4x2 (Port Configuration): 1x4A + 2x2
    i2ctransfer -f -y 2 w3@0x27 0x09 0x4A 0xD0   #// MIPI_TX__1 : MIPI_TX10 | (Default) CSI2_LANE_CNT (Port A - Lane Count): 4
    i2ctransfer -f -y 2 w3@0x27 0x08 0xA3 0xE4   #// MIPI_PHY : MIPI_PHY3 | (Default) phy0_lane_map (Lane Map - PHY0 D0): Lane 0 | (Default) phy0_lane_map (Lane Map - PHY0 D1): Lane 1 | (Default) phy1_lane_map (Lane Map - PHY1 D0): Lane 2 | (Default) phy1_lane_map (Lane Map - PHY1 D1): Lane 3
    i2ctransfer -f -y 2 w3@0x27 0x08 0xA5 0x00   #// MIPI_PHY : MIPI_PHY5 | (Default) phy0_pol_map (Polarity - PHY0 Lane 0): Normal | (Default) phy0_pol_map (Polarity - PHY0 Lane 1): Normal | (Default) phy1_pol_map (Polarity - PHY1 Lane 0): Normal | (Default) phy1_pol_map (Polarity - PHY1 Lane 1): Normal | (Default) phy1_pol_map (Polarity - PHY1 Clock Lane): Normal
    i2ctransfer -f -y 2 w3@0x27 0x09 0x43 0x07   #// MIPI_TX__1 : MIPI_TX3 | DESKEW_INIT (Controller 1 Auto Initial Deskew): Disabled
    i2ctransfer -f -y 2 w3@0x27 0x09 0x44 0x01   #// MIPI_TX__1 : MIPI_TX4 | DESKEW_PER (Controller 1 Periodic Deskew): Disabled
    i2ctransfer -f -y 2 w3@0x27 0x1D 0x00 0xF4   #//  (config_soft_rst_n - PHY1): 0x0
    i2ctransfer -f -y 2 w3@0x27 0x1D 0x00 0xF4   #// (Default)
    i2ctransfer -f -y 2 w3@0x27 0x04 0x18 0x2F   #// (Default)
    i2ctransfer -f -y 2 w3@0x27 0x1D 0x00 0xF5   #//  | (Default)  (config_soft_rst_n - PHY1): 0x1
    i2ctransfer -f -y 2 w3@0x27 0x08 0xA2 0x34   #// MIPI_PHY : MIPI_PHY2 | phy_Stdby_n (phy_Stdby_2): Put PHY2 in standby mode | phy_Stdby_n (phy_Stdby_3): Put PHY3 in standby mode
    #// Tunnel Mode Configuration
    i2ctransfer -f -y 2 w3@0x27 0x08 0xCA 0xE5   #// MIPI_PHY : MIPI_CTRL_SEL | MIPI_CTRL_SEL_0 (MIPI Controller Pipe 0): 0x1
    i2ctransfer -f -y 2 w3@0x27 0x09 0x39 0x10   #// MIPI_TX__0 : MIPI_TX57 | (Default) TUN_DEST (Tunneling Destination Pipe 0): 0x1
    i2ctransfer -f -y 2 w3@0x27 0x09 0x36 0x09   #// MIPI_TX__0 : MIPI_TX54 | TUN_EN (Pipe 0 Tunnel Mode): Enabled
    i2ctransfer -f -y 2 w3@0x27 0x09 0x39 0x50   #// MIPI_TX__0 : MIPI_TX57 | DIS_AUTO_TUN_DET (Pipe 0 Disable Auto Tunnel Detection): Enabled
    i2ctransfer -f -y 2 w3@0x27 0x08 0xCA 0xE5   #// MIPI_PHY : MIPI_CTRL_SEL | (Default) MIPI_CTRL_SEL_1 (MIPI Controller Pipe 1): 0x1
    i2ctransfer -f -y 2 w3@0x27 0x09 0x79 0x10   #// MIPI_TX__1 : MIPI_TX57 | (Default) TUN_DEST (Tunneling Destination Pipe 1): 0x1
    i2ctransfer -f -y 2 w3@0x27 0x04 0x0B 0x02   #// BACKTOP : BACKTOP12 | CSI_OUT_EN (CSI_OUT_EN): CSI output enabled
