关于起流时序问题
The user is experiencing frame drop issues when the 96717 starts streaming before the 96714 enables the MIPI port. The final answer suggests following the normal configuration order: 96714 initialization, enabling MIPI port, then 96717 streaming. The accompanying answer mentions the possibility of disabling the 96714 link during initialization to avoid timing dependencies.
hi,
     采用96714解串,96717加串,使用tunnel mode,由两个soc分别配置。
     目前发现96714初始化->96714使能mipi port->96717起流 数据正常。
     但96717如果先起流,96714端使能mipi port 后soc 接收数据会有概率掉帧异常。
      请问96714对于输入的起流顺序有严格时序要求么?
