Hi Sir,
can you help to verify , is there any ripple noise spec requirment for GMSL PoC power supply?
thanks
Hi Sir,
thanks
POC source should be filtered before coupled into GMSL path. Theoretically the noises should be eliminated to protect GMSL signals from disturbance.
Hi Mason,
thanks for your answer , so we don't need concern about PoC power noise even the noise is 00mVp-p or higher , due the filter can eliminated the noise to protect GMSL signal correctly.
Thansk
Yes, but that depends on the ripple frequency and your designed POC filter characteristics. The designer should be careful about this and make some simulation to verify your design.
