关于AD7689数据采集的问题
        大家好,我现在用TI的DSP28335通过SPI与AD7689通讯,读出的数据变化非常大,也没有规律(比如0,540,2048,3680,4,1024等等),AD7689配置寄存器是0xF104。请问哪位能指导一下,或者有没有程序参考一下,谢谢!
    on Mar 29, 2018 10:54 AM
    //Head files
    #include <ADuC7026.H>
    #include "functions.h"
    #define
    SET_CNV()
    GP1DAT = (GP1DAT |
    0x00040000)
    //P1.2->CNV
    -- P3.40: Brown  -- A17
    #define
    CLR_CNV()
    GP1DAT = (GP1DAT & 0xFFFBFFFF)
    #define
    SET_CS()
    GP1DAT = (GP1DAT |
    0x00800000)
    #define
    CLR_CS()
    GP1DAT = (GP1DAT &
    0xFF7FFFFF)
    #define SET_SCK() GP1DAT = (GP1DAT | 0x00100000) //P1.4->SCK -- P3.38: White   -- A9
    #define
    CLR_SCK()
    GP1DAT = (GP1DAT &
    0xFFEFFFFF)
    #define
    MISO_BIT
    (GP1DAT &
    0x00000020)
    //P1.5->MISO -- P3.35: Grey     -- B11
    #define
    SET_MOSI()
    GP1DAT = (GP1DAT |
    0x00400000)
    //P1.6->MOSI -- P3.34: Green
    #define
    CLR_MOSI()
    GP1DAT = (GP1DAT & 0xFFBFFFFF)
    #define
    LED2_ON()
    GP4DAT = (GP4DAT &
    0xFFFEFFFF)
    //P4.0->LED2
    #define
    LED2_OFF()
    GP4DAT = (GP4DAT | 0x00010000)
    #define
    LED3_ON()
    GP4DAT = (GP4DAT &
    0xFFFDFFFF)
    //P4.1->LED3
    #define
    LED3_OFF()
    GP4DAT = (GP4DAT | 0x00020000)
    #define
    LED4_ON()
    GP4DAT = (GP4DAT &
    0xFFFBFFFF)
    //P4.2->LED4
    #define
    LED4_OFF()
    GP4DAT = (GP4DAT | 0x00040000)
    volatile unsigned char
    Timer1_flag;         // Timer1 interrupt
    flag
    void AD7689_gpiospiwrite_L14bitword(unsigned short
    data)           //CS low for
    reading 1 word from the first channel
    int i=0;
    unsigned short temp=0;
    temp = data;
    //Initial CNV=0, SCK=0
    temp = temp << 2;
    for (i=0;i<16;i++)
    if(0x8000 == (temp & 0x8000))
    SET_MOSI();
    else
    CLR_MOSI();
    temp = temp << 1;
    SET_SCK();           //rising
    edge for write in
    CLR_SCK();
    CLR_MOSI();
    //AD7689 SDI should be idle low
    unsigned short AD7689_gpiospireadword_writeL14bitword(unsigned
    short data)    //CS low for reading 1 word from the first
    channel
    int i=0;
    unsigned short temprev = 0, tempsend = 0;
    //CNV=0, SCK=0
    tempsend = data;
    tempsend = tempsend << 2;
    for (i=0;i<14;i++)
    temprev = temprev << 1;
    if (MISO_BIT!=0)
    temprev = temprev + 1;
    else
    if(0x8000 == (tempsend & 0x8000))
    SET_MOSI();
    else
    CLR_MOSI();
    tempsend = tempsend << 1;
    SET_SCK();
    CLR_SCK();          //falling edge
    for MSB-1, ...
    CLR_MOSI();       //MOSI idle low
    for (i=14;i<16;i++)
    if (MISO_BIT!=0)
    else
    SET_SCK();
    for MSB-1, ...
    return temprev;
    void AD7689_gpiospiread_word(unsigned char
    *data)        //CS low for reading 1 word from
    the first channel
    int i=0;
    CLR_CS();
    //CS falling edge output first MSB
    for (i=0;i<8;i++) //CNV falling for MSB
    *data = (*data) << 1;
    if (MISO_BIT!=0)
    *data = (*data)+1;
    else
    SET_SCK();           //
    CLR_SCK();          //SCK falling
    edge for MSB-1, ...
    delay1us(10);
    data++;
    for (i=0;i<8;i++)
    *(data) = (*(data)) << 1;
    if (MISO_BIT!=0)
    *(data) = (*(data))+1;
    else
    SET_SCK();
    CLR_SCK();          //intially low
    delay1us(10);
    SET_CS();
    data--;
    void ADuC7026_Initiate(void)
    void AD7689_Initiate(void)
    int i=0;
    CLR_SCK();          //initially low
    CLR_CNV();//intially high
    //idle conv after power up
    SET_CNV();
    delay1us(10);      //delay 4us, tCONV > 2.2us for no
    BUSY Indicator
    CLR_CNV();
    //Configuration Register:
    //[13] = 1: overwrite contents of register.
    //[12:10] = 111: Unipolar, INx referenced to GND.
    //[9:7] = 111: IN7
    //[6] = 1: full BW.
    //[5:3] = 110:External reference 5V, driver disabled, temperature disabled.
    //[2:1] = 11 :scan from IN0 to CFG[9:7].
    //[0] = 1:do not read back contents of configuration.
    AD7689_gpiospiwrite_L14bitword(0x3FC7);//8 ch selected in sequencer, full bandwidth,
    external REF,
    delay1us(10);
    for (i=0;i<1;i++)  //delay one phase
    SET_CNV();
    no BUSY Indicator
    CLR_CNV();
    delay1us(10);
    int main (void)
    unsigned char HByte=0, LByte=0;
    unsigned char combuf[4]={0};
    unsigned long T1_LD=0;
    unsigned long CNVNum = 0, convnum=0,convcount=0;
    unsigned char
    adcbuf_2Byte[2]={0};          //1
    word
    unsigned short adcrevbuf=0;
    unsigned char CHNum = 8;
    ADuC7026_Initiate();
    //ADuC7026 Initiation
    AD7689_Initiate();
    /*** UART ***/
    COMIEN0 =
    0x01;
    //Enable Receive Buffer Full Interrupt
    IRQEN =
    0x00004000;
    // Enable UART interupt
    while(1)
    Intcount=0;
    convcount=0x08;
    convnum=CNVNum;
    while (convnum)
    LED3_ON();
    LED4_ON();
    adcbuf_2Byte[0] = 0;
    adcbuf_2Byte[1] = 0;
    SET_CNV();
    no BUSY Indicator
    CLR_CNV();
    if (convcount%CHNum==0)//IN0
    AD7689_gpiospiread_word(adcbuf_2Byte);
    else if (convcount%CHNum==1)//IN1
    else if (convcount%CHNum==2)//IN2
    else if (convcount%CHNum==3)//IN3
    else if (convcount%CHNum==4)//IN4
    else if (convcount%CHNum==5)//IN5
    else if (convcount%CHNum==6)//IN6
    else if (convcount%CHNum==7)//IN7
    else
    putchar(adcbuf_2Byte[0]);//MSB byte
    putchar(adcbuf_2Byte[1]);
    convnum--;
    convcount++;
    }//while
       LED3_OFF();
       if (convcount==CNVNum)
    LED4_OFF();
    }//else if (0x11 == combuf[0])
    return 0;
  • 您好,研究AD7689的数据手册好久了,我这里发现了几种测试现象如下所示:
    1-使用内部VREF 2.5输作为基准源输出,VREFIN VREF都接了电容,就是有时重新上电没有电压-现在我把VREFIN和VREF短接在一起,测量出的电压是4.9V(外部供电5V),  这样问题基本解决,但是很奇怪为什么选择的是2.5V,测量的输出是4.9V呢
    2-使用您上边的程序,虽然测量有数据输出(不是之前的0XFFFF),但是总是感觉通道错了一位,我的的程序就在您的基础上加了打印的语句,并没有影响您的初始化和采样逻辑顺序,输出的结果如下,(我先打印了8个通道的结果,最后的DA=?代表外边实际加的电压)-----现在怀疑程序的延时是不是对结果有很明显的影响啊,如您文章中加的延时我都加的足够长了。
    init ok
    CH0=:2.50 CH1=:1.46 CH2=:1.31 CH3=:1.25 CH4=:0.27 CH5=:1.24 CH6=:0.34 CH7=:0.55 DA=0.06
    CH0=:0.74 CH1=:0.81 CH2=:1.24 CH3=:1.15 CH4=:1.25 CH5=:0.27 CH6=:1.24 CH7=:0.34 DA=0.06
    CH0=:0.51 CH1=:0.45 CH2=:0.60 CH3=:1.25 CH4=:1.12 CH5=:1.25 CH6=:0.27 CH7=:1.24 DA=0.12
    CH0=:0.34 CH1=:0.23 CH2=:0.47 CH3=:0.62 CH4=:1.24 CH5=:1.11 CH6=:1.25 CH7=:0.27 DA=0.18
    CH0=:1.24 CH1=:0.34 CH2=:0.48 CH3=:0.66 CH4=:0.71 CH5=:1.24 CH6=:1.11 CH7=:1.25 DA=0.24
    CH0=:0.27 CH1=:1.24 CH2=:0.34 CH3=:0.49 CH4=:0.66 CH5=:0.71 CH6=:1.24 CH7=:1.11 DA=0.31
    CH0=:1.25 CH1=:0.27 CH2=:1.24 CH3=:0.35 CH4=:0.49 CH5=:0.66 CH6=:0.71 CH7=:1.24 DA=0.37
    CH0=:1.11 CH1=:1.25 CH2=:0.27 CH3=:1.24 CH4=:0.41 CH5=:0.55 CH6=:0.68 CH7=:0.74 DA=0.43
    CH0=:1.24 CH1=:0.67 CH2=:1.25 CH3=:0.27 CH4=:1.24 CH5=:0.47 CH6=:0.57 CH7=:0.71 DA=0.49
    CH0=:0.77 CH1=:1.25 CH2=:1.11 CH3=:1.25 CH4=:0.27 CH5=:1.24 CH6=:0.53 CH7=:0.62 DA=0.55
    CH0=:0.74 CH1=:0.41 CH2=:1.24 CH3=:1.11 CH4=:1.25 CH5=:0.27 CH6=:1.24 CH7=:0.60 DA=0.61
    CH0=:0.68 CH1=:0.43 CH2=:0.56 CH3=:1.24 CH4=:1.11 CH5=:1.25 CH6=:0.27 CH7=:1.24 DA=0.67
    CH0=:0.66 CH1=:0.36 CH2=:0.57 CH3=:0.67 CH4=:1.24 CH5=:1.11 CH6=:1.25 CH7=:0.27 DA=0.73
    CH0=:1.24 CH1=:0.78 CH2=:0.77 CH3=:0.83 CH4=:0.84 CH5=:1.24 CH6=:1.11 CH7=:1.25 DA=0.79
    CH0=:0.27 CH1=:1.24 CH2=:0.84 CH3=:0.82 CH4=:0.88 CH5=:0.87 CH6=:1.24 CH7=:1.11 DA=0.85
    CH0=:1.25 CH1=:0.27 CH2=:1.24 CH3=:0.91 CH4=:0.88 CH5=:0.92 CH6=:0.90 CH7=:1.24 DA=0.92
    CH0=:1.11 CH1=:1.25 CH2=:0.27 CH3=:1.24 CH4=:0.97 CH5=:0.89 CH6=:0.91 CH7=:0.90 DA=0.98
    CH0=:1.24 CH1=:0.68 CH2=:1.25 CH3=:0.27 CH4=:1.24 CH5=:1.03 CH6=:0.95 CH7=:0.97 DA=1.04
    CH0=:0.92 CH1=:1.25 CH2=:1.11 CH3=:1.25 CH4=:0.27 CH5=:1.24 CH6=:1.09 CH7=:1.00 DA=1.10
    CH0=:0.99 CH1=:0.54 CH2=:1.24 CH3=:1.11 CH4=:1.25 CH5=:0.27 CH6=:1.24 CH7=:1.16 DA=1.16
    CH0=:1.03 CH1=:0.61 CH2=:0.70 CH3=:1.24 CH4=:1.11 CH5=:1.25 CH6=:0.27 CH7=:1.24 DA=1.22
    CH0=:1.22 CH1=:0.65 CH2=:0.75 CH3=:0.79 CH4=:1.24 CH5=:1.11 CH6=:1.25 CH7=:0.27 DA=1.28
    CH0=:1.24 CH1=:1.34 CH2=:1.13 CH3=:1.06 CH4=:1.00 CH5=:1.24 CH6=:1.11 CH7=:1.25 DA=1.34
    CH0=:0.27 CH1=:1.24 CH2=:1.41 CH3=:1.19 CH4=:1.13 CH5=:1.03 CH6=:1.24 CH7=:1.11 DA=1.40
    CH0=:1.25 CH1=:0.27 CH2=:1.24 CH3=:1.47 CH4=:1.22 CH5=:1.16 CH6=:1.06 CH7=:1.24 DA=1.46
    CH0=:1.11 CH1=:1.25 CH2=:0.27 CH3=:1.24 CH4=:1.53 CH5=:1.28 CH6=:1.15 CH7=:1.06 DA=1.53
    CH0=:1.24 CH1=:0.68 CH2=:1.25 CH3=:0.27 CH4=:1.24 CH5=:1.60 CH6=:1.30 CH7=:1.18 DA=1.59
    CH0=:1.09 CH1=:1.25 CH2=:1.11 CH3=:1.25 CH4=:0.27 CH5=:1.24 CH6=:1.66 CH7=:1.36 DA=1.65
    CH0=:1.22 CH1=:0.68 CH2=:1.24 CH3=:1.11 CH4=:1.25 CH5=:0.27 CH6=:1.24 CH7=:1.72 DA=1.71
    CH0=:1.42 CH1=:0.82 CH2=:0.84 CH3=:1.24 CH4=:1.11 CH5=:1.25 CH6=:0.27 CH7=:1.24 DA=1.77
    CH0=:1.78 CH1=:0.96 CH2=:0.97 CH3=:0.92 CH4=:1.24 CH5=:1.11 CH6=:1.25 CH7=:0.27 DA=1.83
    硬件电路图如下所示
    主程序的代码如下所示
    uint8_t i,j=0;
    uint16_t value;
    printf("init ok\r\n");
    AD7689_Initiate();
    for(;;)
    osSemaphoreWait(tickHandle,osWaitForever);
    da7311Out(1,DA_CH1);//16*200=3200
    for(i=0;i<8;i++)
    AD_VAL[i] = AD7689_read(i);
    printf("CH%d=:%3.2f ",i,(float)AD_VAL[i]*2.5/65536);
    if(DA_CH1 == 4096) DA_CH1=0;
    printf("DA=%3.2f\r\n",(float)DA_CH1*2.5/4096);
    set_value.Real_Voltage=AD_VAL[2]*2.5/65536;
    set_value.Output_Voltage=(float)DA_CH1*2.5/4096;
    其中AD7689_read()
    uint16_t AD7689_read(uint8_t AD7689_INx)
    unsigned short AD7689_Data=0;
    SET_CNV();
    delay1us(100); //delay 4us, tCONV > 2.2us for no BUSY Indicator
    CLR_CNV();
    AD7689_gpiospiread_word(&AD7689_Data);
    osDelay(20);
    return AD7689_Data*2;//此处*2感觉数据能对上
    希望能帮我查下问题,搞得真头大!裸机跑每次上电采样值和通道固定输出都不一样
