我已经看过AD9467的评估板在ZEDboard和KC705的引脚约束为"LVDS_25",对应FPGA的BANK VCCO供电2.5V,但是现在我的项目中FPGA BANK 的VCCO供电是1.8V,我对其做引脚约束为"LDVS"可行吗?
I am no FPGA expert, but i believe that LVDS is an ANSI standard. The standard depends on the differential swing of signals around a common mode voltage of ~1.2V. See datasheet excerpt below:
So if your FPGA supports this mode, then the AD9467 should be able to send data to your FPGA.
答案来源:The output of the AD9467 is LVDS level standard... | EngineerZone
