AD7705采集数据不稳定
主控为STM32F107VC,7片AD7705用于采集PT100的信号,PT100为三线制,2.5V基准电压通过一个电阻串联到PT100,然后PT100上端接入AD7705的通道,下端接地。AD7705基准电压2.5V,电源5V。测量输入电压88mv左右。设置的参数如下:
程序运行后,输出的AD数据不稳定,刚开始全是65535,然后重新上电后,过几秒种输出数据是18410左右,和计算出来的值差不多,应该是正常值 ,但是运行一会后,输出 数据就全部是0或都一会18410,一会0.请问是什么原因?
u16 AD7705_AD[7][2];
u16 PT100_R[7];
u16 PT100_T[7];
void GPIO_AD7705(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE | RCC_APB2Periph_GPIOB, ENABLE);
  /* PC 11输入 MISO*/
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //上拉输入
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  /* PC 12输出 MOSI*/
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
  /* PC 10输出 SCLK*/
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_10;
  /* PD 12输出 RST*/
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  /* PE 3,7,9,11,13,15 DRDY 1 2 3 4 5 6中断输入*/
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_3|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_11|GPIO_Pin_13|GPIO_Pin_15;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
  /* PD 10 DRDY 7中断输入*/
  /* PB 2,10 输出 cs 1 6*/
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_2|GPIO_Pin_10;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /* PE 8,10,12,14 输出 cs 2 3 4 5*/
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_8|GPIO_Pin_10|GPIO_Pin_12|GPIO_Pin_14;
  /* PD 11 输出 cs 7*/
  SET_CS_AD7705_1;
  SET_CS_AD7705_2;
  SET_CS_AD7705_3;
  SET_CS_AD7705_4;
  SET_CS_AD7705_5;
  SET_CS_AD7705_6;
  SET_CS_AD7705_7;
/**AD7705复位**/
void Reset7705(u8 ch)
  unsigned char i;
  switch (ch)
  case 1:{ CLR_CS_AD7705_1; break; }
  default:break;
  Delay_1us(100);
  for(i=0;i<40;i++)
  { /* 多于连续32个 DIN=1 使串口复位 */
  CLR_CLK_AD7705;
  Delay_1us(20);
  SET_SDI_AD7705;
  Delay_1us(20);
  SET_CLK_AD7705;
  Delay_1us(20);
  switch (ch)
  case 1:{ SET_CS_AD7705_1; break; }
  default:break;
/*等待DRDY变低*/
void AD7705_WaitDRDY_L(u8 ch)
  switch (ch)
  case 1:{ while (INT_AD7705_H_1); break; }
  default:break;
/*等待DRDY变高*/
void AD7705_WaitDRDY_H(u8 ch)
  switch (ch)
  case 1:{ while (INT_AD7705_L_1); break; }
  default:break;
  功能:向AD7705写入一个字节
  ch:输入通道
  c :写入数据
void WriteByte7705(u8 ch, u8 c)
  u8  tmp_8u,i;
  tmp_8u=c;
  switch (ch)
  case 1:{ SET_CS_AD7705_1; SET_CLK_AD7705; Delay_1us(20); CLR_CS_AD7705_1; break; }
  default:break;
  for(i=0; i<8; i++)
  Delay_1us(10);
  CLR_CLK_AD7705;
  Delay_1us(10);
  if((tmp_8u&0x80)==0)
     CLR_SDI_AD7705;
  else
     SET_SDI_AD7705;
  tmp_8u <<= 1;
  Delay_1us(10);
  SET_CLK_AD7705;
  Delay_1us(10);
  switch (ch)
  default:break;
}//WriteByte7705
  功能:从AD7705读一个字节
  ch:输入通道
  返回8位数据
u8 ReadByte7705(u8 ch)
  u8 i;
  u8 x=0;
  switch (ch)
  default:break;
  for (i = 0,x=0 ; i < 16 ; i++)
  CLR_CLK_AD7705;
  Delay_1us(10);
  x<<=1;
  if (SDO_AD7705_H)
  x |= 0x01;
  SET_CLK_AD7705;
  Delay_1us(10);
  switch (ch)
  default:break;
  return x;
  功能:从AD7705读一个字
  ch:输入通道
  返回16位数据
u16 ReadWord7705(u8 ch)
  u8 i;
  u16 x=0;
  switch (ch)
  default:break;
  for (i = 0 ; i < 16 ; i++)
  CLR_CLK_AD7705;
  Delay_1us(20);
  x<<=1;
  if (SDO_AD7705_H)
  x |= 0x01;
  SET_CLK_AD7705;
  Delay_1us(20);
  switch (ch)
  default:break;
  return x;
void AD7705_Configuration(void)
  /*初始化IO口*/
  GPIO_AD7705();
  DELAY_MS(10);
  /*硬件复位*/
  SET_RST_AD7705;
  DELAY_MS(1);
  CLR_RST_AD7705;
  DELAY_MS(2);
  SET_RST_AD7705;
  DELAY_MS(5);
  /*同步*/
  Reset7705(1);
  DELAY_MS(5);
  WriteByte7705(1, 0x20) ;                //通道1 ,下一个写时钟寄存器
  WriteByte7705(1, 0x04) ;                //写时钟寄存器设置更新速率为50Hz
  WriteByte7705(1, 0x10) ;                //通道1 ,下一个写设置寄存器
  WriteByte7705(1, 0x5C) ;                //写设置寄存器 ,设置成单极性、无缓冲、增益为8、滤波器工作、自校准
  AD7705_WaitDRDY_L(1);
  WriteByte7705(1, 0x21) ;                //通道2 ,下一个写时钟寄存器
  WriteByte7705(1, 0x11) ;                //通道1 ,下一个写设置寄存器
/*获取AD*/
void GetAD7705Ad(u8 ch, u8 num)
  switch (ch)
  case 1:
  if (num == 1)
  WriteByte7705(1, 0x38);
  AD7705_AD[0][0] = ReadWord7705(1);
  AD7705_WaitDRDY_H(1);
  else
  WriteByte7705(1, 0x39);
  AD7705_AD[0][1] = ReadWord7705(1);
  break;
Parents
No Data
Reply Children
No Data
