AD7708
使用AD7708时发现,偶尔设备重新上电,CPU采集到AD7708输出的码值为全0或都32767.不知道是怎么回事,大部份时间芯片能正常工作,就是上电的时候会出现所有通道采集到的值都不变,一直是0或32767.以下是硬件和程序。断电后重新启动故障消失,芯片工作正常。
这是硬件连接,基准电压是2.5V,单端方式工作。
INT8U channel2[10] = {0x0f,0x1f,0x2f,0x3f,0x4f,0x5f,0x6f,0x7f,0xef,0xff};  //0-10v==0-65535
void SpiWrite (unsigned int data,unsigned char s )
  unsigned char i;
  //chop_select();//片选
  //spi_clk_hi();
  if(s == 0) s = 8;
  else s = 16;
  for(i=0;i<s;i++)
  spi_clk_lo();//低时钟
  nop();
  nop();
  nop();
  nop();
  WDR();
  if(data&0x80)
  spi_data_hi();
  else
  spi_data_lo();
  spi_clk_hi();
  nop();
  nop();
  nop();
  nop();
  WDR();
  data = data << 1;
   //chop_unselect();
unsigned int SpiRead (unsigned char s)
  int i,data=0;
  //spi_clk_hi();
  if(s == 0) s = 8;
  else s = 16;
  for(i=0;i<s;i++)
    data = data << 1;
  spi_clk_lo();
  WDR();
  nop();
  nop();
  nop();
  nop();
  if(AD7708_DATA)
  data |=  0x01;
  else
  data &= ~0x01;
  spi_clk_hi();
  nop();
  nop();
  nop();
  nop();
  WDR();
   //chop_unselect();
   return(data);
void AD7708Init ( void )
  chop_select();//片选
  nop();
  nop();
  nop();
  nop();
  SpiWrite(0x07,0);//write I/O Control Register
  SpiWrite(0x30,0);
  SpiWrite(0x03,0);//write Filter Register
  SpiWrite(0x0D,0);
  SpiWrite(0x02,0);//ADC Control Register
  SpiWrite(0x0F,0);
  SpiWrite(0x01,0);//write Mode Register
  SpiWrite(0x02,0);//
  nop();
  chop_unselect();
void Start(unsigned char data)
  SpiWrite(0X01,0);//write Mode Register
  SpiWrite(0x02,0);//
  SpiWrite(0x02,0);//ADC控制寄存器
  SpiWrite(channel2[data],0);
unsigned int GegAdcValuea (unsigned char data)
  unsigned int i,temp_data = 0;
  //AD7708Init();
  chop_select();
  nop();
  Start(data);
  WDR();
  while(!AD7708_READY)
  WDR();
  SpiWrite(DATA_REG_R,0);//5
  temp_data = SpiRead(1);
  chop_unselect();
  return (temp_data);
