Hello,I learn tarnsplant the AD7768-1driver on raspberry4B,and the I find the driver can not work.Because the raspberry4B maybe do not support 16-bits spi.
Any SPI timing waveform which follows the AD7768-1 SPI timing in the datasheet will be fine. You may make your raspberry4B interface to be compatible to the datasheet timing.
yes I known, i will try again. Do
Do
Do you have WeChat?
