LT1395运放的输入电压范围
您好ADI工程师,请问:
  1. LT1395运放的共模输入电压范围是多少?输入共模电压和电源电压之间的关系是怎样的。数据手册只给出了5V和±5V条件下的输入共模电压范围。假如采用Vs=+7V单端供电,输入共模电压范围是多少?
  2. 同样运放输出电压和电源电压的关系呢?
  3. 想用这款芯片做电压跟随,有没有推荐的资料呢?谢谢!
Parents
  • +1
    on Nov 11, 2019 10:16 PM over 1 year ago
    Hi Feng Xuejian 476:   The common mode input range and output swing are really relative to the supplies.
    1.  On a single 5V supply, the input CM range is specified as from 1.0V to 4.0V.  Maximum guarantees over temperature (on +/-5V) extend an extra 0.5V of headroom, or 1.5V from each rail.  This should extend to a single 7V supply as from 1.5V min to 5.5V upper limit.
    2.  The output headroom is quite constant, relative to the supply voltages, although with a heavy load (see the 150 Ohm case) it does need more headroom.  With a light load, the output can swing up to 0.8V from the top (1.3V worst case), and down to 0.8V above the bottom (again 1.3V worst case).  So on a single 7V supply, worst case output swing would be 1.3V to 5.7V.
    3.  Do you mean G=1 voltage follower?  Yes, it can do that within the limits above.
  • Thanks for your reply!
    还想问一下:
    1. LT1395电流反馈运算放大器做电压跟随器的时候,整个电压跟随器的输入阻抗是多大呢?
    2.我用LT1395搭了一个电压跟随器,反馈电阻用的是360Ω。输入信号由函数发生器提供,幅值1.6-4.4V,频率5MHz的矩形波。但是,经示波器另一通道观察,实际施加到跟随器输入端的电压却是1.6-4.18V,而跟随器输出电压为560mv-2.68V,和输入信号大小也不一致。在供电电压从6V-12V上述现象均存在。是不是反馈电阻的大小选择有问题?还是跟随器输入阻抗不够?就上述现象希望您帮我分析分析。
    谢谢!
Reply
    还想问一下:
    谢谢!
Children
No Data
