AD9954可以设置成突发模式吗
The user wants to configure AD9954 to output a 20 MHz sine wave burst for 100 clock cycles after a pin trigger. The final answer suggests using the single-burst mode to achieve this by providing 100 consecutive trigger signals. No other specific configuration details or alternative DDS chips were mentioned.
Category: Datasheet/Specs
Product Number: AD9954
想让AD9954输出一个突发波形,频率20M,通过一个引脚触发输出连续100个时钟周期的正弦波后就停止输出,如何设置呢,如果不能设置,有没有其他可以用的DDS芯片来实现这个功能呢,谢谢
I want AD9954 to output a burst waveform with a frequency of 20M. After triggering through a pin,it will output a sine wave for 100 consecutive clock cycles , then the output stop. How to set it? If it cannot be set, are there any other DDS chips that can be used to achieve this function? Thank you
