SECTION 1
HIGH SPEED OP AMPS
n Voltage Feedback Op Amps
n Current Feedback Op Amps
n Effects of Feedback Capacitance
n High-Speed Current-to-Voltage Converters, and
the Effects of Inverting Input Capacitance
n Noise Comparisons between Voltage Feedback
Op Amps and Current Feedback Op Amps
n DC Characteristics of High Speed Op Amps
SECTION 2
HIGH SPEED OP AMP APPLICATIONS
n Optimizing the Feedback Network for Maximum
Bandwidth Flatness in Wideband CFB Op Amps
n Driving Capacitive Loads
n Cable Drivers and Receivers
n A High Performance Video Line Driver
n Differential Line Drivers/Receivers
n High Speed Clamping Amplifiers
n Single-Supply/Rail-to-Rail Considerations
n High Speed Video Multiplexing with Op Amps Using
Disable Function
n Video Programmable Gain Amplifier
n Video Multiplexers and Crosspoint Switches
n High Power Line Drivers and ADSL
n High Speed Photodiode Preamps
SECTION 3
RF/IF SUBSYSTEMS
n Dynamic Range Compression
n Linear VCAs
n Log/Limiting Amplifiers
n Receiver Overview
n Multipliers, Modulators, and Mixers
n Modulation / Demodulation
n Receiver Subsystems
SECTION 4
HIGH SPEED SAMPLING AND HIGH SPEED ADCs
n Fundamentals of High Speed Sampling
n Baseband Antialiasing Filters
n Undersampling
n Antialiasing Filters in Undersampling Applications
n Distortion and Noise in an Ideal N-bit ADC
n Distortion and Noise in Practical ADCs
n High Speed ADC Architectures
SECTION 5
HIGH SPEED ADC APPLICATIONS
n Driving ADC Inputs for Low Distortion and Wide
Dynamic Range
n Applications of High Speed ADCs in CCD Imaging
n High Speed ADC Applications in Digital Receivers
SECTION 6
HIGH SPEED DACs AND DDS SYSTEMS
n Introduction to DDS
n Aliasing in DDS Systems
n 125MSPS DDS System (AD9850)
n DDS Systems as ADC Clock Drivers
n Amplitude Modulation in a DDS System
n The AD9831/AD9832 Complete DDS System
n Spurious Free Dynamic Range Considerations in
DDS Systems
n High Speed Low Distortion DAC Architectures
n Improving SFDR Using Sample-and-Hold Deglitchers
n High Speed Interpolating DACs
n QPSK Signal Generation Using DDS (AD9853)
SECTION 7
HIGH SPEED HARDWARE DESIGN TECHNIQUES
n Analog Circuit Simulation
n Prototyping Analog Circuits
n Evaluation Boards
n Grounding in High Speed Systems
n Power Supply Noise Reduction and Filtering
n Power Supply Regulation/Conditioning
n Thermal Management
n EMI/RFI Considerations
n Shielding Concepts
【ANALOG DEVICES】高速设计技术.rar
