求助
求助:在ISE功能仿真无错误,无WARNing,但在XST进行RTL综合时却出现如下的错误和警告。各位大虾给个注意。
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date:    17:08:02 09/14/2007
// Design Name:
// Module Name:    da_fir
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module da_fir(clk, reset, fir_in, fir_out);
parameter IDATA_WIDTH = 12;   //输入数据位宽
parameter PDATA_WIDTH = 13;   //处理数据位宽
parameter FIR_TAP = 8;        //fir滤波器抽头数
parameter FIR_TAPHALF = 4;    //fir滤波器的一半抽头数
parameter COEFF_WIDTH = 12;   //系数位宽
parameter OUT_WIDTH = 27;     //输出数据位宽
parameter cof1 = 12'd41;
parameter cof2 = 12'd132;
parameter cof3 = 12'd341;
parameter cof4 = 12'd510;
parameter S0 = 1'b0;    //初始状态
parameter S1 = 1'b1;    //处理状态
input clk;
input reset;
input [IDATA_WIDTH-1:0] fir_in;
output [OUT_WIDTH-1:0] fir_out;
reg [OUT_WIDTH-1:0] fir_out;
reg [IDATA_WIDTH-1:0] fir_in_reg;
reg [PDATA_WIDTH-1:0] shift_buf[FIR_TAP-1:0];   //定义移位寄存器
reg [PDATA_WIDTH-1:0] add_buf[FIR_TAPHALF-1:0];
reg [PDATA_WIDTH-1:0] state_shift_buf[FIR_TAPHALF-1:0];
wire [3:0] table_4b;    //查表输入
wire [COEFF_WIDTH-1:0] table_out_12b;        //查表输出
reg [OUT_WIDTH-1:0] sum;
reg STATE;
reg [3:0] divfre_count_4b;
reg divfre13_clk;
integer i,j,k,l,m,n,p;
//定义移位寄存器左移的函数delta
function [OUT_WIDTH-1:0] delta;
   input [OUT_WIDTH-1:0] IQ;
   input [3:0] pipe;
      begin
         case(pipe)
            4'b0000: delta = IQ;
            4'b0001: delta = {IQ[OUT_WIDTH-2:0],1'b0};
            4'b0010: delta = {IQ[OUT_WIDTH-3:0],2'b00};
            4'b0011: delta = {IQ[OUT_WIDTH-4:0],3'b000};
            4'b0100: delta = {IQ[OUT_WIDTH-5:0],4'b0000};
            4'b0101: delta = {IQ[OUT_WIDTH-6:0],5'b00000};
            4'b0110: delta = {IQ[OUT_WIDTH-7:0],6'b000000};
            4'b0111: delta = {IQ[OUT_WIDTH-8:0],7'b0000000};
            4'b1000: delta = {IQ[OUT_WIDTH-9:0],8'b00000000};
            4'b1001: delta = {IQ[OUT_WIDTH-10:0],9'b000000000};
            4'b1010: delta = {IQ[OUT_WIDTH-11:0],10'b0000000000};
            4'b1011: delta = {IQ[OUT_WIDTH-12:0],11'b00000000000};
            4'b1100: delta = {IQ[OUT_WIDTH-13:0],12'b000000000000};
            4'b1101: delta = {IQ[OUT_WIDTH-14:0],13'b0000000000000};
            4'b1110: delta = {IQ[OUT_WIDTH-15:0],14'b00000000000000};
            4'b1111: delta = {IQ[OUT_WIDTH-16:0],15'b000000000000000};
            default: delta = IQ;
         endcase
      end
endfunction
always @(posedge clk or negedge reset)
begin
   if(!reset)
      begin
         divfre13_clk <= 1'b0;
         divfre_count_4b <= 4'b0000;
      end
   else
      begin
         if(divfre_count_4b==PDATA_WIDTH)
            begin
               divfre13_clk <= 1'b1;
            end
         else
            begin
               divfre_count_4b <= divfre_count_4b + 1'b1;
            end
      end
end
begin
   if(!reset)
      fir_in_reg <= 12'b0000_0000_0000;
   else
      if(divfre13_clk)
         fir_in_reg <= fir_in;
end
begin
   if(!reset)
      for(i=0; i<=FIR_TAP-1; i="i"+1)
         shift_buf[i] <= 13'b0000_0000_00000;
   else
      if(divfre13_clk)
      begin
         for(j=0; j<FIR_TAP-1; j="j"+1)
            shift_buf[j+1] <= shift_buf[j];
         shift_buf[0] <= {fir_in_reg[IDATA_WIDTH-1],fir_in_reg};    //符号位扩展
      end
end
begin
   if(!reset)
      for(k=0; k<=FIR_TAPHALF-1; k="k"+1)
         add_buf[k] <= 13'b0000_0000_00000;
   else
      if(divfre13_clk)
         for(l=0; l<=FIR_TAPHALF-1; l="l"+1)
            add_buf[l] <= shift_buf[l]+shift_buf[FIR_TAP-1-l];
end
//有限状态机的初始化,比特移位
begin
   if(!reset)
      begin
         for(m=0; m<=FIR_TAPHALF-1; m="m"+1)
            state_shift_buf[m] <= 13'b0000_0000_00000;
         STATE <= S0;
      end
   else
      case(STATE)
         S0:begin
               for(n=0; n<=FIR_TAPHALF-1; n="n"+1)
                  state_shift_buf[n] <= add_buf[n];
               STATE <= S1;
            end
         S1:begin
               if(divfre_count_4b==4'b1101)
                  STATE <= S0;
               else
                  begin
                     for(p=0; p<=PDATA_WIDTH-2; p="p"+1)
                        begin
                           state_shift_buf[0][p] <= state_shift_buf[0][p+1];
                           state_shift_buf[1][p] <= state_shift_buf[1][p+1];
                           state_shift_buf[2][p] <= state_shift_buf[2][p+1];
                           state_shift_buf[3][p] <= state_shift_buf[3][p+1];
                        end
                  STATE <= S1;
                  end
               end
      endcase
end
assign table_4b[0] = state_shift_buf[0][0];
assign table_4b[1] = state_shift_buf[1][0];
assign table_4b[2] = state_shift_buf[2][0];
assign table_4b[3] = state_shift_buf[3][0];
DA_table U_DA(
              .table_in_4b(table_4b),
              .table_out_12b(table_out_12b)
wire [26:0] sign_ex={table_out_12b[11],table_out_12b[11],table_out_12b[11],table_out_12b[11],table_out_12b[11],table_out_12b[11],table_out_12b[11],table_out_12b[11],table_out_12b[11],table_out_12b[11],table_out_12b[11],table_out_12b[11],table_out_12b[11],table_out_12b[11],table_out_12b[11],table_out_12b};
begin
   if(!reset)
      sum <= 27'b0;
   else
      if(divfre_count_4b==4'b0000)
         sum <= 27'b0;
      else
            sum <= sum - delta(sign_ex, divfre_count_4b-4'b0001);
         else
            sum <= sum + delta(sign_ex, divfre_count_4b-4'b0001);
end
begin
   if(!reset)
      fir_out <= 27'b0;
   else
         fir_out <= sum;
end
endmodule
错误和警告
WARNING:HDLCompilers:176 - Include directory \da_fir\ does not exist
WARNING:Xst - Property "use_dsp48" is not applicable for this technology.
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<0><12>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<0><11>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<0><10>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<0><9>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<0><8>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<0><7>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<0><6>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<0><5>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<0><4>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<0><3>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<0><2>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<0><1>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<0><0>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<1><12>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<1><11>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<1><10>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<1><9>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<1><8>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<1><7>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<1><6>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<1><5>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<1><4>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<1><3>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<1><2>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<1><1>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<1><0>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<2><12>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<2><11>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<2><10>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<2><9>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<2><8>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<2><7>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<2><6>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<2><5>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<2><4>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<2><3>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<2><2>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<2><1>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<2><0>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<3><12>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<3><11>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<3><10>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<3><9>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<3><8>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<3><7>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<3><6>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<3><5>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<3><4>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<3><3>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<3><2>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<3><1>>
ERROR:Xst:528 - Multi-source in Unit <da_fir> on signal <state_shift_buf<3><0>>
Parents Reply Children
No Data
