adau1701 使用Surround Sound Volume Control,如何通过坐标计算出要写入的reg数值?
The user is experiencing issues with a component where setting the position does not generate I2C data; only dragging does. The final answer suggests that after setting new values, pressing Enter should work, and converting XY coordinates to register values typically involves reading the four bytes of the float value. No specific Analog Devices products are mentioned.
这个组件,在set position时候不产生i2c数据,要拖动才行,不能精确设置位置,
请问下是否有对应的计算方法,把xy坐标,换算成reg数值
或者有大表来查表也可以
