自己写的DSP代码
#include "def21375.h"
#include "sru21375.h"
#define In_Bit          -31
#define Out_Bit          31
#define D1_L0                429               // = 266 @ 29761 Hz Fs
#define D2_L0               4797          // = 2974 @ 29761 Hz Fs
#define D3_L0               3085          // = 1913 @ 29761 Hz Fs
#define D4_L0               3219          // = 1996 @ 29761 Hz Fs
#define D5_L0               3210          // = 1990 @ 29761 Hz Fs
#define D6_L0               302               // = 187 @ 29761 Hz Fs
#define D7_L0               1719          // = 1066 @ 29761 Hz Fs
// reverb right channel 0 output taps at 48 kHz fs
#define D1_R0               569               // = 353 @ 29761 Hz Fs
#define D2_R0               5849          // = 3627 @ 29761 Hz Fs
#define D3_R0               1981          // = 1228 @ 29761 Hz Fs
#define D4_R0               4311          // = 2673 @ 29761 Hz Fs
#define D5_R0               3404          // = 2111 @ 29761 Hz Fs
#define D6_R0               540               // = 335 @ 29761 Hz Fs
#define D7_R0               195               // = 121 @ 29761 Hz Fs
// reverb left channel 1 output taps at 48 kHz fs
#define D1_L1               329
#define D2_L1               2797
#define D3_L1               1085
#define D4_L1               2219
#define D5_L1               2210
#define D6_L1               102
#define D7_L1               719
// reverb right channel 1 output taps at 48 kHz fs
#define D1_R1               369
#define D2_R1               2627
#define D3_R1               1228
#define D4_R1               1673
#define D5_R1               2311
#define D6_R1               340
#define D7_R1               95
#define     allpass_Dline1          2168               // = 1344 @ 29761 Hz Fs
#define     allpass_Dline2          2930               // = 1816 @ 29761 Hz Fs
#define     ALLPASS1_LENGTH          229                    // = 142 @ 29761 Hz Fs
#define     ALLPASS2_LENGTH          172                    // = 107 @ 29761 Hz Fs
#define     ALLPASS3_LENGTH          611                    // = 379 @ 29761 Hz Fs
#define     ALLPASS4_LENGTH          447                    // = 277 @ 29761 Hz Fs
#define     ALLPASS5_LENGTH          2168/2//1301///2//1301////1518///
#define     ALLPASS6_LENGTH          2930/2//1758///2//1758////2051//
#define     ALLPASS7_LENGTH          2903               // = 1800 @ 29761 Hz Fs
#define     ALLPASS8_LENGTH          4284               // = 2656 @ 29761 Hz Fs
#define     D_Line1                    7182               // = 4453 @ 29761 Hz Fs
#define     D_Line2                    6000               // = 3720 @ 29761 Hz Fs
#define     D_Line3                    6801               // = 4217 @ 29761 Hz Fs
#define D_Line4                    5101               // = 3163 @ 29761 Hz Fs
#define D_PDel              4800
//#define D_CLIP0             0.98
#define D_CLIP1             0x7ffffffe//0x7ffffeff;//0x7D70A3D6//0x7ffffff8//0x7ffffff8//
.extern  _FBX0Init;
.extern  _FBX0;
.extern   FBX0_In;
.extern   FBX0_Out;
.extern      DigitalReverberator;
.extern      InitReverb_Buffers;
.extern   Rev_In;
.extern   Rev_L_Out;
.extern   Rev_R_Out;
.extern   Rev_SL_Out;
.extern   Rev_SR_Out;
.extern      _Echo;
.extern  _EchoInit;
.extern   Echo_In;
.extern   Echo_Out;
.extern   Echo_Main_L_Out;
.extern   Echo_Main_R_Out;
.extern   Echo_SL_Out;
.extern   Echo_SR_Out;
.extern  biquadvec;
//%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%   外部引用函数声名   %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
.global _main;
.global _talkThroughISR;
//%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%系统缓冲%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
//.section/dm seg_dm32D;
//%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%算法临时变量%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
.section/dm seg_dm48D;
.var   ADC_In;
.var   ADC_In1;
.var  AdcDelay[66];
.var  AdcDelay_ptr = AdcDelay;
//=================================反馈抑制=======================================
.var   FBX0_In;
.var   FBX0_Out;
.var   FBX0w1[999];
//================================燥声门=======================================
.var   Noise_Gate0_In  = 0.0;
.var   Noise_Gate0_Rms = 0.0;
.var   Noise_Gate0_Out = 0.0;
//===============================麦克风参量========================================
.var Mic_PEQ_In;
.var Mic_PEQ_Out;
.var Mic_PEQ_State[15*2+1]=
     0,  0,0, 0,0, 0,0, 0,0, 0,0, 0,0, 0,0, 0,0, 0,0, 0,0, 0,0, 0,0, 0,0, 0,0, 0,0
.var Mic_Echo_PEQ_In;
.var Mic_Echo_PEQ_Out;
.var Mic_Echo_PEQ_State[5*2+1]=
.var Mic_Rev_PEQ_In;
.var Mic_Rev_PEQ_Out;
.var Mic_Rev_PEQ_State[5*2+1]=
//============================回声====================================
.var   Echo_feedback_state  = 0.0;
.var   Echo_In  = 0.0;
.var   Echo_Out  = 0.0;
.var   Echo_Main_L_Out  = 0.0;
.var   Echo_Main_R_Out  = 0.0;
.var   Echo_SL_Out  = 0.0;
.var   Echo_SR_Out  = 0.0;
//=============================混响===================================
.var   Rev_In;
.var   Rev_L_Out;
.var   Rev_R_Out;
.var   Rev_SL_Out;
.var   Rev_SR_Out;
.var   comb1_feedback_state;
.var   comb2_feedback_state;
.var   comb3_feedback_state;
.var   recirculate1_feedback;
.var   recirculate2_feedback;
.var   diffusion_result;
.var   predelay_output;
.var   reverb_left0;
.var   reverb_right0;
.var   reverb_left1;
.var   reverb_right1;
.var   L0rev_output_taps[6];
.var   R0rev_output_taps[6];
.var   L1rev_output_taps[6];
.var   R1rev_output_taps[6];
.var   holdtank_input1;
.var   holdtank_input2;
//===============================话筒混合输出======================================
.var   Mic_Main_LOut;
.var   Mic_Main_ROut;
.var   Mic_C_Out;
.var   Mic_SW_Out;
.var   Mic_SL_LOut;
.var   Mic_SR_ROut;
//================================音乐参量========================================
.var Music_L_PEQ_In;
.var Music_L_PEQ_Out;
.var Music_L_PEQ_State[10*2+1]=
.var Music_R_PEQ_In;
.var Music_R_PEQ_Out;
.var Music_R_PEQ_State[10*2+1]=
//================================多通道参量========================================
.var ML_Ch_PEQ_In;
.var ML_Ch_PEQ_Out;
.var ML_Ch_PEQ_State[10*2+1]=
.var MR_Ch_PEQ_In;
.var MR_Ch_PEQ_Out;
.var MR_Ch_PEQ_State[10*2+1]=
.var C_Ch_PEQ_In;
.var C_Ch_PEQ_Out;
.var C_Ch_PEQ_State[10*2+1]=
.var SW_Ch_PEQ_In;
.var SW_Ch_PEQ_Out;
.var SW_Ch_PEQ_State[10*2+1]=
.var SL_Ch_PEQ_In;
.var SL_Ch_PEQ_Out;
.var SL_Ch_PEQ_State[10*2+1]=
.var SR_Ch_PEQ_In;
.var SR_Ch_PEQ_Out;
.var SR_Ch_PEQ_State[10*2+1]=
.var   Main_Mix_LOut = 0.0;
.var   Main_Mix_ROut = 0.0;
.var   C_Mix_Out     = 0.0;
.var   SW_Mix_Out    = 0.0;
.var   SL_Mix_LOut   = 0.0;
.var   SR_Mix_ROut   = 0.0;
//%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%系数变量%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
.section/dm seg_dm32C;
//=================================通讯缓冲与临时变量========================================
.var  SPI_R_DMA[16]=0, 0, 0, 0, 0, 0, 0, 0,0, 0, 0, 0, 0, 0, 0, 0;
.var  SPI_temp = 0;
.var  SPI_TAG  = 0;
//=================================ADC _ DAC DMA缓冲区============================================
.var rx0a_buf[2];   // SPORT0 接收缓冲 A (DMA) 用作话筒输入
.var rx0b_buf[2];   // SPORT0 接收缓冲 B (DMA) 用作音乐输入
//.var rx1a_buf[2];   // SPORT1 接收缓冲 A (DMA) 用作数字输入
//.var rx1b_buf[2];   // SPORT1 接收缓冲 B (DMA) 用作数字输入
.var rx0a_tcb[4]   =  0, 2, 1, rx0a_buf;  // SPORT0 接收tcb_a
.var rx0b_tcb[4]   =  0, 2, 1, rx0b_buf;  // SPORT0 接收tcb_b
//.var rx1a_tcb[4]   =  0, 2, 1, rx1a_buf;  // SPORT1 接收tcb_a
//.var rx1b_tcb[4]   =  0, 2, 1, rx1b_buf;  // SPORT1 接收tcb_b
//==============================================---输入延时=================================================
.var  AdcDelayOut;
//==============================================话筒反馈抑制系数============================================
.var    FBX0_rate    = 139; //128
.var    FBX0_rate1   = 860;// FBX0_rate1 = 888 - FBX0_rate   7hz
.var    FBX0_Switch  = 0;
.var    FBX0_Addr    = FBX0w1;
.var    FBX0_counter = 0;//0xbaffffff;//
.var    FBX0_Num     = 0;
.var    FBX0_FLAG    = 0;//0x57ffff;//
.var    FBX0_inc     = 1;
//===================================================燥声门=================================================
.var    Noise_Gate0_threshold =  0.000000018;
.var    Noise_Gate0_Open_Time  = 0;
.var    Noise_Gate0_Close_Time = 3888;
.var    Noise_Gate0_Time0 = 0;
.var    Noise_Gate0_Time1 = 0;
//================================================话筒参量系数===============================================
.var   Mic_PEQ_Sections = 15;//15;
.var   Mic_PEQ_coeffs[15 * 5 ] =
//    B2,                 B1,               B0,            A2,             A1
//0.0144104957580,0.0288209915161,0.0144104957580,-0.691665291786,1.63402318954, //2k LPF
//0.664677500724,-1.69868814945,1.09393382072,-0.758611440658,1.69868814945,        //2k PEQ +5db
//1.13898932933,-2.74164867401, 1.67486667633 ,-0.598148584365,1.52594125270,  //2K HS +5db
0.00000000,0.00000000, 1.0000000000 ,0.00000000,0.00000000,
.var   Mic_Echo_PEQ_Sections = 5;//5;
.var   Mic_Echo_PEQ_coeffs[5*5] =
.var   Mic_Rev_PEQ_Sections = 5;//5;
.var   Mic_Rev_PEQ_coeffs[5*5] =
//============================================回声系数===============================================
.var   EchoAddr       = EcohDeley;
.var   EcohInVol      = 1.0;//
.var   EcohRep        = 0.81;//
.var   EcohDel        = 9018;//
.var   EcohMainLDel   = 3000;//
.var   EcohMainRDel   = 6000;//
.var   EcohSLDel      = 6000;//
.var   EcohSRDel      = 6000;//
.var   Echo_bandwidth = 0.93;
.var   EcohOVol       = 0.0;//
.var   EchoMainVol    = 0.0;
.var   EchoSLRVol     = 0.0;
//============================================混响系数===============================================
.var   Predel_ptr    = Predelay;
.var   decay             = 0.83;      // 混响时间
.var   bandwidth         = 0.0001;
.var   damping           = 0.0001;              // 高频阻尼; 无阻尼 = 0.0
.var   predelay_time     = 0;
.var   input_diffusion_1 = 0.75;      //  = 0.75, 解相关的输入信号  My = 0.615;
.var   input_diffusion_2 = 0.625;    //  = 0.625,解相关的输入信号  My = 0.615;
.var   all_pass_ptr1 = diffuser_1;   //  衰减扩散 2 = 衰减 +0.15, 地板 = 0.25, 天花板 - 0.50
.var   all_pass_ptr2 = diffuser_2;
.var   all_pass_ptr3 = diffuser_3;
.var   all_pass_ptr4 = diffuser_4;
.var   decay_diffusion_1 = 0.70;      //  = 0.70, 控制尾音的密度  My = 0.615;
.var   decay_diffusion_2 = 0.50;      //  = 0.50, 解相关水箱信号       My = 0.615;
.var   all_pass_ptr5 = decay_diffuser_A1;
.var   RevW1_ptr     = RevW1;
.var   all_pass_ptr6 = decay_diffuser_A2;
.var   RevW2_ptr     = RevW2;
.var   all_pass_ptr7 = decay_diffuser_B1;
.var   RevW3_ptr     = RevW3;
.var   all_pass_ptr8 = decay_diffuser_B2;
.var   RevW4_ptr     = RevW4;
.var   RevOut        = 0.0;
//=============================================话筒音量系数===========================================
.var    MicBBEVol     = 1.0;//2.188;
.var    MicEffVol     = 1.0;
//=============================================话筒混合系数===========================================
.var    Main_Mic_Z_Vol      = 1.0;
.var    Main_Mic_Echo_Vol   = 1.0;
.var    Main_Mic_EchoS_Vol  = 1.0;
.var    Main_Mic_Rev_Vol    = 1.0;
.var    SLR_Mic_Z_Vol       = 1.0;
.var    SLR_Mic_Echo_Vol    = 1.0;
.var    SLR_Mic_EchoS_Vol   = 1.0;
.var    SLR_Mic_Rev_Vol     = 1.0;
.var    C_Mic_Z_Vol         = 1.0;
.var    C_Mic_Echo_Vol      = 1.0;
.var    C_Mic_EchoS_Vol     = 1.0;
.var    C_Mic_Rev_Vol       = 1.0;
.var    SW_Mic_Z_Vol        = 1.0;
//==============================================话筒压缩系数=============================================
.var    MicVol                 = 0.88;
.var     Mic_compress_threshold = 1.0;
.var     Mic_compress_ratio     = 0.1;
.var     Mic_compress_OffOn     = 0;
//=============================================音乐参量系数===========================================
.var Music_PEQ_Sections  = 10;//10;
.var Music_PEQ_coeffs[10*5]=
//=============================================话筒音乐混合系数===========================================
.var    MusicVol           = 0.18;  //音乐音量
.var    Main_Music_Vol     = 1.0;
.var    SLR_Music_Vol      = 1.0;
.var    C_Music_Vol        = 1.0;
.var    SW_Music_Vol       = 1.0;
//=============================================通道参量系数===========================================
.var  MLR_Ch_PEQ_Sections = 10;//;10;
.var  MLR_Ch_PEQ_coeffs[10*5]=
.var  C_Ch_PEQ_Sections = 10;//10;
.var  C_Ch_PEQ_coeffs[10*5]=
.var  SW_Ch_PEQ_Sections = 10;//10;
.var  SW_Ch_PEQ_coeffs[10*5]=
.var  SLR_Ch_PEQ_Sections = 10;//10;
.var  SLR_Ch_PEQ_coeffs[10*5]=
//=============================================通道压限系数===========================================
.var  Main_Channel_threshold        = 1.00;
.var  Main_Channel_ratio            = 0.5;
.var  Main_Channel_Compress_Off_On  = 0;
.var  C_Channel_threshold           = 1.00;
.var  C_Channel_ratio               = 0.5;
.var  C_Channel_Compress_Off_On     = 0;
.var  SW_Channel_threshold          = 1.00;
.var  SW_Channel_ratio              = 0.5;
.var  SW_Channel_Compress_Off_On    = 0;
.var  SLR_Channel_threshold         = 1.00;
.var  SLR_Channel_ratio             = 0.5;
.var  SLR_Channel_Compress_Off_On   = 0;
//==============================================通道延时系数===========================================
.var  Main_Delay_L_Addr =D_Main_Delay_L;
.var  Main_Delay_L = 0;
.var  Main_Delay_R_Addr =D_Main_Delay_R;
.var  Main_Delay_R = 0;
.var  SW_Delay_Addr     =D_SW_Delay;
.var  SW_Delay     = 0;
.var  C_Delay_Addr      =D_C_Delay;
.var  C_Delay      = 0;
.var  Aux_Delay_L_Addr  =D_Aux_Delay_L;
.var  Aux_Delay_L  = 0 ;
.var  Aux_Delay_R_Addr  =D_Aux_Delay_R;
.var  Aux_Delay_R  = 0;
.var tx2a_buf[2];   // SPORT2 发送缓冲 A (DMA) 用作DAC0 存放L+R
.var tx2b_buf[2];   // SPORT2 发送缓冲 B (DMA) 用作DAC1 存放L+R
.var tx3a_buf[2];   // SPORT3 发送缓冲 A (DMA) 用作DAC2 存放L+R
//.var tx3b_buf[2];   // SPORT3 发送缓冲 B (DMA) 用作DAC3 数字输出
.var tx2a_tcb[4]   =  0, 2, 1, tx2a_buf;  // SPORT3 发送tcb_a
.var tx2b_tcb[4]   =  0, 2, 1, tx2b_buf;  // SPORT3 发送tcb_b
.var tx3a_tcb[4]   =  0, 2, 1, tx3a_buf;  // SPORT4 发送tcb_a
//.var tx3b_tcb[4]   =  0, 2, 1, tx3b_buf;  // SPORT4 发送tcb_b
.var   MainLOut = 0.0;
.var   MainROut = 0.0;
.var   COut     = 0.0;
.var   SWOut    = 0.0;
.var   SLOut   = 0.0;
.var   SROut   = 0.0;
//%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%延时外部内存%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
.section/dm seg_extsdram;
.var  EcohDeley[12818];
.var  Predelay[D_PDel];
.var  diffuser_1[ALLPASS1_LENGTH];
.var  diffuser_2[ALLPASS2_LENGTH];
.var  diffuser_3[ALLPASS3_LENGTH];
.var  diffuser_4[ALLPASS4_LENGTH];
.var  decay_diffuser_A1[ALLPASS5_LENGTH];     // 全通扩散器 同 可变延时
.var  RevW1[D_Line1];
.var  decay_diffuser_B1[ALLPASS6_LENGTH];     // 全通扩散器 同 可变延时
.var  RevW2[D_Line2];
.var  decay_diffuser_A2[ALLPASS7_LENGTH];
.var  RevW3[D_Line3];
.var  decay_diffuser_B2[ALLPASS8_LENGTH];
.var  RevW4[D_Line4];
.var  D_Main_Delay_L[3848];
.var  D_Main_Delay_R[3848];
.var  D_SW_Delay[3848];
.var  D_C_Delay[3848];
.var  D_Aux_Delay_L[3848];
.var  D_Aux_Delay_R[3848];
//%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%    程序      %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
.section/code seg_pmco;
_main:
    //=============================设置系统时钟========================================
    //ustat1 = PLLM32|INDIV|DIVEN;
    ustat1 = PLLM16|PLLD1|DIVEN;
changePLL:
    //设置核心时钟(CCLK)的 Set the Core clock (CCLK) to SDRAM clock (SDCLK) ratio to 2
    bit set ustat1 SDCKR2;
    dm(PMCTL) = ustat1;
    bit set ustat1 PLLBP;
    bit clr ustat1 DIVEN;
    dm(PMCTL) = ustat1;
    //等待5000个循环
    lcntr = 5000, do loopend2 until lce;
loopend2:     nop;
    ustat1 = dm(PMCTL);
    bit clr ustat1 PLLBP;
    dm(PMCTL) = ustat1;   //以上程序达到预期
    //要将下面的程序进行变更设定
    // 编程SDRAM控制寄存器。
    // RDIV = ((f SDCLK X t REF )/NRA) - (tRAS + tRP )
    // CCLK_SDCLK_RATIO==2
    // RDIV         11-0位    刷新分频记数
    // SDROPT         16位    读优化
    // SDMODIFY   20–17位    修改 优化读寻址
    ustat4 = 0x7F7; // (131.072(10^6)64*(10^-3)/4096) - (6+3) = 2039
    //ustat4 = 0x777; // (122.280(10^6)64*(10^-3)/4096) - (6+3) = 1911
    // 配置 SDRAM 控制寄存器 (SDCTL) 对于美光科技公司的 MT48LC8M16
    //  SDCL3  : SDRAM CAS延迟 = 3 cycles
    //  DSDCLK1: 关闭  SDRAM Clock 1
    //  SDPSS  : 开始SDRAM上电序列
    //  SDCAW9 : SDRAM 银行列地址宽度 = 9 bits
    //  SDRAW12: SDRAM 行地址宽度     = 12 bits
    //  SDTRAS7: SDRAM tRAS 规范。 激活命令延迟  = 6 cycles
    //  SDTRP3 : SDRAM tRP  规范。 预充电延迟    = 3 cycles.
    //  SDTWR2 : SDRAM tWR  规范。 tWR           = 2 cycles.
    //  SDTRCD3: SDRAM tRCD 规范。 tRCD          = 3 cycles.
    //  X16DE  : SDRAM 外部总线宽度 = 16 位宽
    ustat1 = SDNOBSTOP|SDCL3|DSDCLK1|SDPSS|SDCAW9|SDRAW12|SDTRAS6|SDTRP3|SDTWR2|SDTRCD3|X16DE;
    dm(SDCTL) = ustat1;
    // 将此值更改优化性能类似连续访问(步 >1)
    #define SDMODIFY 1                    // 修改设置1
    bit set ustat4 (SDMODIFY<<17)|SDROPT; // 启用SDRAM读优化
    dm(SDRRC) = ustat4;
    // 需要注意的是FLAG2及FLAG3复用MS2和MS3脚。
    // 必须启用MSEN位访问SDRAM,但不能同时驱动LED8和SDRAM
    ustat1=dm(SYSCTL);
    bit set ustat1 MSEN ;    //此设置允许访问的SDRAM
    //bit clr ustat3 MSEN;  //此设置Flag3被允许使用
    dm(SYSCTL)=ustat1;
    // 映射SDRAM到0块
    // 确保跳线适当设置,以便MS0的是连接到
    // 16位SDRAM器件芯片选择
    ustat1 = dm(EPCTL);
    bit set ustat1 B0SD;
    bit clr ustat1 B2SD|B1SD|B3SD;
    dm(EPCTL) = ustat1;
    //SRAM 设置
    //ustat4 = WS2|HC1|AMIEN|BW8;
    ustat1 = WS2|HC1|BW8;
    dm(AMICTL0)= ustat1;
    //Flash  设置
    //ustat4 = WS23|AMIEN|BW8;
    ustat1 = WS23|BW8;
    dm(AMICTL1)= ustat1;
    //==============================精密时钟发生器设置========================================================================
    // 时钟源取 PCLK  = 90.3168MHz  FSDIV  CLKDIV
    // SCLK = PCLK/CLKDIV = 90.3168/16   = 5.6448MHz
    // FS   = PCLK/FSDIV = 90.3168/16*64 = 88.2Khz
    // PCGA 输出 BCLK 与 LRCLK , PCGA 输出 MCLK
    /*r0 = 0x00000000 | 0x00000000;
    dm(PCG_PW) = r0;  //0-15位 FS A/C脉宽| 15-31位 FS B/D脉宽   是输入时钟的个数
    //0x3FF00000
     r0 = 0x00000028 | 0x01400000 | 0x00000000;    //这里122.88M分频到 3.072M 的位时钟
     dm(PCG_CTLA1) = r0;//0-19位 CLKA分频系数| 20-29 FSB相位补偿低|30位 FSB选择CLKIN或PCG_EXTx_I|31位 CLKA选择CLKIN或PCG_EXTx_I
    r0 = 0x0000000A | 0x01400000 | 0x00000000; //这里122.88M分频到 12.288M供ADC DAC的时钟
    dm(PCG_CTLB1) = r0;//0-19位 CLKB分频系数| 20-29 FSB相位补偿低|30位 FSB选择CLKIN或PCG_EXTx_I|31位 CLKA选择CLKIN或PCG_EXTx_I
    r0 = CLKA_SOURCE_IOP | FSA_SOURCE_IOP | CLKB_SOURCE_IOP | FSB_SOURCE_IOP; //设置时钟源 为PCLK=122.88M
    dm(PCG_SYNC) = r0;
     r0 = 0x00000A00 | 0x00000000 | ENFSA | ENCLKA; //这里122.88M分频到 48k 的左右通道时钟
     dm(PCG_CTLA0) = r0;//0-19位 FSA分频系数 | 20-29 FSA相位补偿高 | 30位 启用FSA | 31位 启用CLKA
     r0 = 0x00000A00 | 0x00000000 |ENFSA|  ENCLKA; //这里122.88M分频到 48k 的左右通道时钟供DAC
     dm(PCG_CTLB0) = r0;//0-19位 FSB分频系数 | 20-29 FSB相位补偿高 | 30位 启用FSB | 31位 启用CLKB*/
     //==============================音频串行端口设置========================================================================
     r0 = 0;
    //清除串行端口控制寄存器
     dm(SPCTL0) = r0;
     dm(SPCTL1) = r0;
     dm(SPCTL2) = r0;
     dm(SPCTL3) = r0;
     //清除串行端口多通道控制寄存器
     dm(SPMCTL0) = r0;
     dm(SPMCTL1) = r0;
     dm(SPMCTL2) = r0;
     dm(SPMCTL3) = r0;
     //设置串行端口时钟分频 根据具体情况来设置 这里先设置为0
     r0 = 0;
     dm(DIV1)    = r0;
     dm(DIV0)    = r0;
     dm(DIV3)    = r0;
     dm(DIV2)    = r0;
     //设置串行端口链式DMA 链寄存器  对于DMA链,19位PCI决定产生中断两种方法之一: 这里是每个链完成就产生中断。也就是每接收两个数据产生中断
     //这里的两个数据就是每个串行通道接收到的左右通道数据 ,下面的链是指到了链自己。
     //ADSP-2137x  链指针还有一个 CPDR位 。在20位//| (1<<19) 是否在每个DMA完成时产生中断。 还是整个链DMA完成产生中断
     //r3 = (rx0a_tcb  + 3);
     r0 = rx0a_tcb + 3 - 0x00080000  + 0x00080000  ;      dm(rx0a_tcb+0) = r0;
     r0 = rx0a_buf - 0x00080000 ;                         dm(rx0a_tcb+3) = r0;
     r0 = rx0a_tcb - 0x00080000 + 3 ;                 dm(CPSP0A) = r0;
     r0 = rx0b_tcb + 3 - 0x00080000 ; ;      dm(rx0b_tcb+0) = r0; // + 0x00080000
     r0 = rx0b_buf - 0x00080000 ;                         dm(rx0b_tcb+3) = r0;
     r0 = rx0b_tcb - 0x00080000 + 3 ;                 dm(CPSP0B) = r0;
     r0 = tx2a_tcb + 3 - 0x00080000 ;  ;      dm(tx2a_tcb+0) = r0; // + 0x00080000
     r0 = tx2a_buf - 0x00080000 ;                         dm(tx2a_tcb+3) = r0;
     r0 = tx2a_tcb - 0x00080000 + 3 ;                 dm(CPSP2A) = r0;
     r0 = tx2b_tcb + 3 - 0x00080000 ;  ;      dm(tx2b_tcb+0) = r0; // + 0x00080000
     r0 = tx2b_buf - 0x00080000 ;                         dm(tx2b_tcb+3) = r0;
     r0 = tx2b_tcb - 0x00080000 + 3 ;                 dm(CPSP2B) = r0;
     r0 = tx3a_tcb + 3 - 0x00080000 ; ;      dm(tx3a_tcb+0) = r0; // + 0x00080000
     r0 = tx3a_buf - 0x00080000 ;                         dm(tx3a_tcb+3) = r0;
     r0 = tx3a_tcb - 0x00080000 + 3 ;                 dm(CPSP3A) = r0;
     /*r0 = (rx0a_tcb  + 3) & 0x7FFFF | (1<<19);     dm(rx0a_tcb  + 0) = r0; dm(CPSP0A) = r0;
     r0 = (rx0b_tcb  + 3) & 0x7FFFF ;            dm(rx0b_tcb  + 0) = r0; dm(CPSP0B) = r0;*/
     //r0 = (rx1a_tcb  + 3) & 0x7FFFF ;             dm(rx1a_tcb  + 0) = r0; dm(CPSP1A) = r0;  //目前串口2没使用
     //r0 = (rx1b_tcb  + 3) & 0x7FFFF ;             dm(rx1b_tcb  + 0) = r0; dm(CPSP1B) = r0;
     /*r0 = (tx2a_tcb  + 3) & 0x7FFFF ;             dm(tx2a_tcb  + 0) = r0; dm(CPSP2A) = r0;
    r0 = (tx2b_tcb  + 3) & 0x7FFFF ;             dm(tx2b_tcb  + 0) = r0; dm(CPSP2B) = r0;
     r0 = (tx3a_tcb  + 3) & 0x7FFFF ;             dm(tx3a_tcb  + 0) = r0; dm(CPSP3A) = r0;*/
     //r0 = (tx3b_tcb  + 3) & 0x7FFFF ;             dm(tx3b_tcb  + 0) = r0; dm(CPSP3B) = r0;
     //CKRE|FSR| DIFS |LSBF |  DIFS |FSR|
     //位说明  L_FIRST是左右通道选择   LAFS表示左对齐   SPTRAN表示接收还是发送
     //设置串行端口控制寄存器  //FSR |  DIFS |  CKRE| LSBF | BHD|FS_BOTH|      MSTR
     //接收              左对齐       24位    A通道启动   A启动DMA链   A启用DMA   B通道启动   B启动DMA链   B启用DMA
     r0 =  (         OPMODE |  BHD |SLEN32 |   SPEN_A  |   SCHEN_A  |  SDEN_A  |   SPEN_B  |  SCHEN_B   | SDEN_B  );
     dm(SPCTL0) = r0;
     //r0 = 0;
     //dm(SPCTL1) = r0; //目前串口2没使用
      //FSR| DIFS |  CKRE|  LSBF | BHD|FS_BOTH|  //LSBF |FSR| DIFS |  MSTR
     //发送              左对齐       24位    A通道启动   A启动DMA链   A启用DMA   B通道启动   B启动DMA链   B启用DMA
     r0 =  (SPTRAN | OPMODE |  BHD |SLEN32 |   SPEN_A  |   SCHEN_A  |  SDEN_A  |   SPEN_B  |  SCHEN_B   | SDEN_B  );
     dm(SPCTL2) = r0;
     r0 =  (SPTRAN | OPMODE |  BHD |SLEN32 |   SPEN_A  |   SCHEN_A  |  SDEN_A   );
     dm(SPCTL3) = r0;
     //==============================SRU设置========================================================================
    // 禁用所有20个引脚上的上拉电阻
    r0 = 0x000FFFFF;
    dm(DAI_PIN_PULLUP) = r0;
    r0 = 0x00003FFF;
    dm(DPI_PIN_PULLUP) = r0;
时钟到串口--
     SRU(DAI_PB19_O,        SPORT0_CLK_I);
    SRU(DAI_PB18_O,        SPORT0_FS_I);
     //SRU(DAI_PB19_O,        SPORT1_CLK_I);//目前串口2没使用
    //SRU(DAI_PB18_O,        SPORT1_FS_I);
    SRU(DAI_PB19_O,        SPORT2_CLK_I);
    SRU(DAI_PB18_O,        SPORT2_FS_I);
    SRU(DAI_PB19_O,        SPORT3_CLK_I);
    SRU(DAI_PB18_O,        SPORT3_FS_I);
以下是ADC的布线--
    SRU(LOW,  PBEN08_I);
    SRU(DAI_PB08_O,       SPORT0_DA_I); //麦克风输入
    SRU(LOW,  PBEN14_I);
    SRU(DAI_PB14_O,       SPORT0_DB_I); //音乐输入
以下是DAC数据--
    SRU(SPORT2_DA_O,       DAI_PB13_I);
    SRU(HIGH,              PBEN13_I);   //配置为输出 输出到DAC
    SRU(SPORT2_DB_O,       DAI_PB12_I);
    SRU(HIGH,              PBEN12_I);   //配置为输出 输出到DAC
    SRU(SPORT3_DA_O,       DAI_PB11_I);
    SRU(HIGH,              PBEN11_I);   //配置为输出 输出到DAC
时钟到引脚--
     SRU (LOW,          PBEN19_I);   //BCLK   输入  到DSP
     SRU (LOW,          PBEN18_I);   //LRCLK  输入  到DSP
麦克风检测--
     SRU (DAI_PB01_O,   DAI_PB01_I);   //LRCLK  输入  到DSP
     SRU (HIGH,         PBEN01_I);   //LRCLK  输入  到DSP
以下是SPI--
    SRU2(LOW,               DPI_PB01_I);
    SRU2(LOW,               DPI_PBEN01_I);
    SRU2(DPI_PB01_O,        SPI_MOSI_I );  //输入 数据
    SRU2(LOW,               DPI_PB03_I);
    SRU2(LOW,               DPI_PBEN03_I);
    SRU2(DPI_PB03_O,        SPI_CLK_I);    //时钟 数据
    SRU2(LOW,               DPI_PB04_I);
    SRU2(LOW,               DPI_PBEN04_I);
    SRU2(DPI_PB04_O,        SPI_DS_I);     //时钟 片选
    SRU2(HIGH,              DPI_PBEN02_I);
    SRU2(SPI_MISO_O,        DPI_PB02_I );  //数据 输出
    SRU2(HIGH,              DPI_PBEN05_I);
    SRU2(LOW,               DPI_PB05_I );  //标志 输出
     USTAT1 = TMROFF|SP45OFF|EPOFF| TWIOFF|PWMOFF|UART0OFF|SP67OFF|SRCOFF|CRAT0 | CRAT1 ;//;  ;
    //DM(PMCTL) =USTAT1; //电源管理
     //==============================SPI通讯接口初始化========================================================================
    USTAT1 = 0;
    DM(SPI_TAG) =USTAT1;                       //将SPI通讯接口自定义状态变量初始化为0
    BIT CLR IRPTL SPIHI;                       //清除SPI中断锁存
    USTAT1 = 0x00000000 | TXFLSH | RXFLSH;     //清除SPI接收发送移位寄存器
    DM(SPICTL) = USTAT1;
    USTAT1 = 0x00000000 | FIFOFLSH;            //清理停止DMA
    DM(SPIDMAC) = USTAT1;
    USTAT1 = 0x00000000|MME|TUNF|ROVF|TXCOL ;  //清理错误状态
    DM(SPISTAT) = USTAT1;
    //==============================内存工作字长设置================================================================
    nop;
    ustat1=dm(SYSCTL);
    bit set ustat1   IMDW1;//| IMDW3
    dm(SYSCTL)=ustat1;nop;
    nop;
    nop;
    //==============================初始化算法==============================
    call _FBX0Init;
    call _EchoInit;
    call InitReverb_Buffers;
    call InitChannelApp;
    //==============================中断设置========================================================================
    bit set mode1  IRPTEN; //全局中断激活
    nop;
    LIRPTL =  SP0IMSK;
    nop;
    nop;
    loopend6:
     IDLE;////nop;//
    jump loopend6;
_main.end:
//&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&  音频中断程序  &&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&
_talkThroughISR:
//================================================音乐 话筒ADC输入处理======================================================
    r8   = dm(rx0a_buf+0);   话筒ADC L
    r9   = dm(rx0a_buf+1);   话筒ADC R
    r10  = dm(rx0b_buf+0);   音乐ADC L
    r11  = dm(rx0b_buf+1);   音乐ADC R
    dm(tx2a_buf+4) = r8;   //主L
    dm(tx2a_buf+2) = r9;   //C
    dm(tx2a_buf+0) = r10;   //SL
    dm(tx2a_buf+5) = r8;  //主R
    dm(tx2a_buf+3) = r9;  //SW
    dm(tx2a_buf+1) = r8;  //SR
   //这个硬件设置 ,可以做到整个音频系统只用一个12.228的晶体。
    //因为涉及产品机密。其他部分全部删掉。就想结识做软件开发的朋友18028703418
    //全套Dsp程序 计算机程序 和中文手机屏面板程序
    //这种框架最大的好处就是省资源(那就是省钱)。 声音延时只有一个取样。
    // 基本上266M的芯片可以做到400M芯片干的活。就是代码需要自己改
//=====================自创反馈抑制=========================================================================================
//========================================话筒延时==========================================================================
//=========================================静躁门========================================================================
//=========================================话筒参量=========================================================================
//=======================================话筒效果参量=======================================================================
//========================================    回声  ========================================================================
//===================================================   混响  ==============================================================
预延时--
4级全通--
桶箱处理左通道--
//====================================================话筒混合处理==========================================================
//========================================话筒压缩==========================================================================
//====================================================音乐参量==============================================================
//==================================================话筒音乐混合处理 =======================================================
//&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&通道处理&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&
//================================================通道参量==========================================================================
//================================================压限处理==========================================================================
//================================================延时处理==========================================================================
//===============================通讯程序==================================================================================
_talkThroughISR.end:rti;
//================================================初始化处理========================================================================
InitChannelApp:
    B0 = D_Main_Delay_L;  L0 = @D_Main_Delay_L;
     m0 = 1;
     LCNTR = L0;
    DO Delay1 UNTIL LCE;
Delay1:    dm(i0, m0) = 0;
    B0 = D_Main_Delay_R;  L0 = @D_Main_Delay_R;
     m0 = 1;
     LCNTR = L0;
    DO Delay2 UNTIL LCE;
Delay2:    dm(i0, m0) = 0;
    B0 = D_SW_Delay;  L0 = @D_SW_Delay;
     m0 = 1;
     LCNTR = L0;
    DO Delay3 UNTIL LCE;
Delay3:    dm(i0, m0) = 0;
    B0 = D_C_Delay;  L0 = @D_C_Delay;
     m0 = 1;
     LCNTR = L0;
    DO Delay4 UNTIL LCE;
Delay4:    dm(i0, m0) = 0;
    B0 = D_Aux_Delay_L;  L0 = @D_Aux_Delay_L;
     m0 = 1;
     LCNTR = L0;
    DO Delay5 UNTIL LCE;
Delay5:    dm(i0, m0) = 0;
    B0 = D_Aux_Delay_R;  L0 = @D_Aux_Delay_R;
     m0 = 1;
     LCNTR = L0;
    DO Delay6 UNTIL LCE;
Delay6:    dm(i0, m0) = 0;
InitChannelApp.end:rts;
_FBX0Init:
    r0 = FBX0w1;  r1 = @FBX0w1;
    dm(FBX0_Addr) = r0;
     B3 = r0;      L3 = r1;
     m3 = 1;
     r0 =0;
     LCNTR = L3;
    DO clrDline1 UNTIL LCE;
clrDline1:  DM(i3,m3) = r0;
_FBX0Init.end:rts;
_EchoInit:
    r0 = EcohDeley;  r1 = @EcohDeley;  dm(EchoAddr) = r0;
     B0 = r0;  L0 = r1;
     m0 = 1;
     r0 =0;
     LCNTR = L0;
    DO Ecoh1 UNTIL LCE;
Ecoh1:  DM(i0,m0) = r0;
_EchoInit.end:RTS;
InitReverb_Buffers:
    r0 = diffuser_1;
     B4 = r0;
     DM(all_pass_ptr1) = r0;
    r0 = diffuser_2;
     B4 = r0;
     DM(all_pass_ptr2) = r0;
    r0 = diffuser_3;
     B4 = r0;
     DM(all_pass_ptr3) = r0;
    r0 = diffuser_4;
     B4 = r0;
     DM(all_pass_ptr4) = r0;
     r0 = decay_diffuser_A1;
     B4 = r0;
     DM(all_pass_ptr5) = r0;
     r0 = decay_diffuser_B1;
     B4 = r0;
     DM(all_pass_ptr6) = r0;
     r0 = decay_diffuser_A2;
     B4 = r0;
     DM(all_pass_ptr7) = r0;
     r0 = decay_diffuser_B2;
     B4 = r0;
     DM(all_pass_ptr8) = r0;
     m4 = 1;
     r0 = RevW1;  r1 = @RevW1;
     B4 = r0;     L4 = r1;          DM(RevW1_ptr)=r0;r0 = 0;
     LCNTR = L4;
     DO clrDline_1 UNTIL LCE;
clrDline_1:        dm(i4, m4) = r0;
     r0 = RevW2;  r1 = @RevW2;
     B4 = r0;     L4 = r1;        DM(RevW2_ptr)=r0;r0 = 0;
     LCNTR = L4;
     DO clrDline_2 UNTIL LCE;
clrDline_2:        dm(i4, m4) = r0;
     r0 = RevW3;  r1 = @RevW3;
     B4 = r0;     L4 = r1;        DM(RevW3_ptr)=r0;r0 = 0;
     LCNTR = L4;
     DO clrDline_3 UNTIL LCE;
clrDline_3:        dm(i4, m4) = r0;
     r0 = RevW4;  r1 = @RevW4;
     B4 = r0;     L4 = r1;        DM(RevW4_ptr)=r0;r0 = 0;
     LCNTR = L4;
     DO clrDline_4 UNTIL LCE;
clrDline_4:        dm(i4, m4) = r0;
     r0 = Predelay; r1 = @Predelay;
     B4 = r0;       L4 = r1; DM(Predel_ptr)=r0;r0 = 0;
     LCNTR = L4;
     DO clrDline_5 UNTIL LCE;
clrDline_5:        dm(i4, m4) = r0;
InitReverb_Buffers.end:RTS;
