紧急:咨询ADuC7039的SPI通讯故障问题(红色内容表示已有现象)
      你好,我处最近在使用ADuC7039芯片的SPI通讯(从机模式)时,从机无法发出任何数据和信号,尝试了很多方法依然不行。以下是我的SPI通讯的从机程序主要部分,请帮忙核查或者纠正一下,或者直接提供该芯片的SPI通讯例程也行。谢谢贵公司的帮助!
int main(void)
while((PLLSTA&0x2)==0) {}   // Ensure That thePLL is locked to the 3%
                                  // SysClock=20.48MHz/2=10.24MHz (POWCON:CD=1 by default)
//-------void main()------------
    GPCON = 0x00001111;      //  GPIO configured as SPI IO
    GPSET = 0x00000000;      // GPSET=0 does not affect GPIO output level
    GPCLR = 0x00000000;      // GPCLR=0 does not affect GPIO output level
//  GPDAT = 0x34000000;      //GPIO_2(MISO)/4/5 set as output, write 1; others GPIO_x£¨/SS, SCLK, MOSI£Copyrightas input
    GPDAT = 0x30000000;      //--4/5 set as output, write 1; SPI不用去设置了吗?
    SPICON = 0x0809;//=0x0009;//0x0005;//=0x4861;   // 这几个都试过了,不行!
/* IRQ/FIR setup */
    IRQ = Vector_IRQ;                       // no use?
    FIQ = Vector_FIQ;
    IRQEN = 0x00000020;                     // SPI int
    FIQEN = 0x00000100;                     // ADuC7039 only: Enable ADC int
    while(1)                                // Infinite Loop
/* FIQ service */
void Vector_FIQ(void)
.....省略....//
void IRQ_Handler()__irq             //SPI int
        unsigned short temp_SPI;
        temp_SPI = IRQSTA;
//  if((IRQSTA & 0x200) != 0x000)       //  IRQSTA[9]-> SPI
        if((SPISTA & 0x1) != 0x0)       //
            GPSET = 0x00100000;      // 此处用来点亮二极管,用以判断是否产生该中断。结果灯已点亮!!
            SPI_rd_data = SPIRX;     //接着在MISO端口上始终是高电平,没有任何变化!
            switch (SPI_rd_data)
                case 1:
                    SPITX= 0x01;  //ADC_T;
                        break;
                case 2:
                    SPITX= 0x22;   //ADC_V;
                        break;
                case 3:
                    SPITX= 0x33;   //ADC_I;
                        break;
                case 4:
                    SPITX= 0x44;   //ADC0ACC;
                        break;
                default:
                        break;
        return;
