在ADE7953英文数据手册中看到是要接地的
而在ADE7953中文数据手册中看到是不允许接地
部分代码如下
while(1) { LED0 = ~LED0; IRQStatusReadA = SPIRead4Bytes(RSTIRQSTATA); if((IRQStatusReadA&BIT18) == BIT18) { printf("Energe: %d\r\n",SPIRead4Bytes(AENERGYA)); printf(" IRMS: %d\r\n",SPIRead4Bytes(IRMSA)); printf(" VRMS: %d\r\n",SPIRead4Bytes(VRMS)); printf(" VPEAK: %d\r\n",SPIRead4Bytes(VPEAK)); printf(" IPEAK: %d\r\n",SPIRead4Bytes(IAPEAK)); printf("PERIOD: %d\r\n",SPIRead2Bytes(PERIOD)); } } void ADE7953_Init(void) { SPI1_Init(); SPI1CS_Init(); ADE7953CS = 0; /* 通信方式设置为 SPI */ delay_ms(50); ADE7953_RST(); /* 软件复位 */ delay_ms(50); ADE7953_ComLock(); /* 锁定通信方式 */ delay_ms(50); /* 检测复位成功 */ while((SPIRead4Bytes(RSTIRQSTATA) & BIT20) != BIT20) { delay_ms(50); printf("ADE7953 resetting...\r\n"); } { printf("ADE7953 OK!\r\n"); } /* read the chip version number */ printf("Version : %d\r\n",SPIRead4Bytes(VERSION)); /* For optimum performance, Register Address 0x120 must be configured by the user after powering up the ADE7953. */ SPIWrite1Byte(0x00FE,0xAD); SPIWrite2Bytes(0x0120,0x0030); /* 对 ADE7953 进行一些相关配置 */ ADE7953Cfg(); } void ADE7953Cfg(void) { SPIWrite2Bytes(CONFIG,0x0004); /* HPF Enable (high pass filter) */ SPIWrite4Bytes(AIGAIN,0x400000); SPIWrite4Bytes(AVGAIN,0x400000); /* 电压通道增益 */ SPIWrite4Bytes(AWGAIN,0x400000); SPIWrite4Bytes(AVARGAIN,0x400000); SPIWrite4Bytes(AVAGAIN,0x400000); SPIWrite4Bytes(AIRMSOS,0x000000); SPIWrite4Bytes(AVRMSOS,0x000000); /* 电压通道有效值失调校正 */ SPIWrite4Bytes(AWATTOS,0x000000); SPIWrite4Bytes(AVAROS,0x000000); SPIWrite4Bytes(AVAOS,0x000000); SPIWrite4Bytes(BIGAIN,0x400000); /* 电流通道 B 增益 */ SPIWrite4Bytes(BWGAIN,0x400000); /* 电流通道 B,有功功率增益 */ SPIWrite4Bytes(BVARGAIN,0x400000); /* 电流通道 B,无功功率增益 */ SPIWrite4Bytes(BVAGAIN,0x400000); /* 电流通道 B,视在功率增益 */ SPIWrite4Bytes(BIRMSOS,0x000000); /* 电流通道 B,有效值失调校正 */ SPIWrite4Bytes(BWATTOS,0x000000); /* 电流通道 B,有功功率失调校正 */ SPIWrite4Bytes(BVAROS,0x000000); /* 电流通道 B,无功功率失调校正 */ SPIWrite4Bytes(BVAOS,0x000000); /* 电流通道 B,视在功率失调校正 */ SPIWrite2Bytes(CFMODE,0x0000); /* CF output selection,CF1 and CF2 output is disabled */ SPIWrite2Bytes(CF1DEN,0x003F); /* CF1 分频器分母 */ SPIWrite2Bytes(CF2DEN,0x003F); /* CF2 分频器分母 */ SPIWrite4Bytes(OVLVL,0x4B0000); /* 311mv at the input get pead read 0x3DB88C, times 1.2 get this */ SPIWrite4Bytes(OILVL,0x4FFFFF); /* 过流值 */ SPIWrite1Byte(SAGCYC,0xFF); /* The SAGCYC register holds a maximum value of 255. */ /* At 50 Hz, the maximum sag cycle time is 2.55 seconds */ SPIWrite4Bytes(SAGLVL,0x200000); /* 骤降电压 */ SPIWrite2Bytes(ZXTOUT,0xFFFF); /* the maximum programmable timeout period is 4.58 seconds to zero-cross */ SPIWrite1Byte(LCYCMODE,0x4F); /* 电流通道 A、B 有、无功线周期累计模式,所有寄存器读后复位 */ SPIWrite2Bytes(LINECYC,0x00C8); /* 在线周期电能累计模式下半线周期数 200 */ //SPIWrite4Bytes(IRQENA,0x140000); }
问题已解决
解决办法,官方给的代码的读函数内部有 1 Byte Dummy,去掉即可。
你好,电能数据单位转换弄明白了吗,我也想请教下
