Transforming EVAL-AD9545 into EVAL-AD9546?
The user inquired about updating the EVAL-AD9545 eval board to work with the AD9546 chip by reprogramming the on-board EEPROM. The support engineer noted that while the AD9546 is backwards compatible with the AD9545 and has the same pinout, the AD9546 eval software has not been tested on the AD9545 eval board and may attempt to save additional registers, which could cause issues. Therefore, the engineer does not recommend this approach.
Product Number: AD9545
Hello Sir,
I could find similar topics but related to the AD9544 and AD9545 describing how to update AD9544 eval boards to the AD9545 by re-programming their on-board EEPROMs (used for USB):
https://ez.analog.com/clock_and_timing/f/q-a/596283/how-to-use-ad9544-eval-board
https://ez.analog.com/clock_and_timing/f/q-a/103275/ad9544-pcbz-ace-does-not-work/324551#324551
Is it also possible to make similar change (after previously replacing EVAL-AD9545's AD9545 chip for the AD9546 chip) but for the EVAL-AD9545 in order to make it working like EVAL-AD9546? From what I can see electrical connections/parameters are practically the same in both cases but maybe is there anything else besides this EEPROM re-progamming I'd have take into account?
Best regards
    The AD9546 is an upgrade of the AD9545. It was designed to be used with the Digitized Clocking technology. It has more registers than the AD9545, although the AD9545 registers may be found into the AD9546 registers. The pinout is the same. We call the AD9546 as being backwards compatible with the AD9545.
    Using the AD9546 eval software (with related USB EEPROM reprogramming) onto the AD9545 eval board was never tried. My problem is that the AD9546 eval software will try to save all the AD9546 registers and I am not sure how the AD9545 reacts. So I am not recommending this approach.
    Petre
  • Hello,
    thank you for getting back to me with an answer. However there is one misunderstanding - I meant the situation where there is AD9546 chip put into (soldered) AD9545 Eval board and then reprogrammed (EEPROM) to be compatible with AD9546 software and use this board as eval for AD9546. Is it still possible then?
    Best regards
  • HI,
    I never tried this. I'm sorry.
    Petre
