AD9545 Free Run mode outputs aligment
The user asks if it's possible to align the rising edges of all outputs (156.25 MHz, 10 MHz, and 1 PPS) of a channel in Free Run mode on the AD9545 and AD9546. The final answer states that executing a sync command (or enabling auto-sync) aligns the outputs, regardless of the DPLL mode. No external reference is required at startup for this alignment.
Product Number: AD9545
I've question regarding Free Run mode in AD9545 (and AD9546 as well) - is there any way to have all outputs of the given channel alligned together (e.g. 156.25 MHz, 10 MHZ and 1 PPS of Channel 0) in terms of their rising edges when forcing Free Mode? I use also stabile external 10 MHz signal for clock compensation but can not achieve such state. I'm going to need this for scenario where some reference will be provided on one on the inputs after some time and first device must run on its own clock source. Or any reference will be necessary from the start-up state?
  • HI,
    sorry for getting so late back to you.
    Let's say we power up the AD9545. In order for the AD9545 to generate outputs, you need to execute a sync command (or enable one of the auto-sync modes) for that channel to generate outputs. Once this is done, the outputs of that particular channel start toggling in the same time. It does not matter if the DPLL is in free run or not.
    Petre
