AD9546 system clock range from 25 MHz to 80 MHz for crystal as per the datasheet, I need suggestions and your thoughts for using a Rubidium Oscillator with 10MHz frequency output to use as the System Clock for AD9546. Whether it is possible or not to interface it with AD9546 as I am looking forward to use this IC for Grand master Clock and Boundary Clock applications. If it is not possible then which IC will be suitable for this application ?
