KCC's Quizzes AQQ304 - A pure logic
1. Quote of the month: "I am not lazy, I'm just in energy-saving mode" - unknown
2. Quiz AQQ304 about finding a pure logic puzzle
Mike is looking at Anne, but Anne is looking at Paul.
Mike is married, but Paul is not.
Question:
Is a married
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
HMC720
Recommended for New Designs
The HMC720LP3E is a 1:2 Fanout Buffer designed to support data transmission rates up to 14 Gbps, and clock frequencies as high as 14 GHz.
All differential...
Datasheet
HMC720 on Analog.com
Although it is accepted practice that an ECL/PECL buffer can properly drive a transmission-line with termination present only at the source (back termination), such a practice appears to never be discussed in any CML datasheet or app note.
Can a CML output pair be operated at speed successfully without external connection of 50 Ohm resistors to Vcc? (This likely comes down to whether a CML device can necessarily tolerate the 2x voltage swing that would then be present at its output.) If so, why is the viability of such a practice not widely acknowledged? If not, why not?
