KCC Quizzes AQQ303 about the radius of a circle
1. Quote of the month: "When I die, I want to die like my grandfather who died peacefully in his sleep. Not screaming like all the passengers in his car" - Will Rogers
2. Quiz AQQ304 about finding the radius of a circle
Good luck, and try to be
August Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Important: Read the blog first . The quiz questions are all based on the content of the blog:
Stay in the loop and win! Read the blog Current Output Driving Industrial Loops , then take our quick five-question quiz for a chance to win a gift card
| SLA Status | Assignee | Support Status |
| SLA Closed. Met after 5 hours |
neilw |
Awaiting Customer Response |
AD9544
Recommended for New Designs
The 10 clock outputs of the AD9544 are synchronized to any one of up to four input references. The digital phase-locked loops (DPLLs) reduce timing jitter...
Datasheet
AD9544 on Analog.com
Let me clarify several things about the AD9644:
- it is pin for pin compatible with the AD9545 and register compatible.
- the data sheet is still at rev 0. The AD9545 data sheet is at rev C. I recommend using the AD9545 data sheet for the AD9544 features.
- the ACE AD9544 plugin is missing key features relative to the ACE AD9545 plugin
So my recommendation is to procure an AD9545 eval board and use the AD9545 ACE plugin to develop the configuration for the AD9544.
The only AD9545 device drivers we have are here:
https://www.analog.com/en/products/ad9545.html#software-resources
Petre
