AD9213-DUAL-EBZ: LTC6946 settings
Product Number: AD9213S
Hi folks
I have purchased a AD9213-DUAL-EBZ and I'm pairing it with a Xilinx VMK180. I am struggling a bit with the LTC6946/LTC6952 pairing - I can't get the LTC6952 to lock its PLL. Please might you supply the register settings for the 6946 that you use in the design with the Stratix board? I have the 6952 settings from that design's DTS but can't find any scripts or lists of settings for the 6946. Please might you help me?
Thank you!
Roddy
Thread Notes
  • Moving this question to the Clocks & Timers forum. Someone here should be able to assist you.
  • Just in case it's helpful, I have attached the contents of the LTC6946 registers and the LTC6952 DTS section. The LTC6952 driver shows in dmesg:
    ltc6952 spi3.1: CLKIN: 3750.000000 MHz REFIN: 500.000000 MHz REF: Valid VCO: Valid PLL: Unlocked
    	ltc6952: ltc6952@1 {
    		compatible = "adi,ltc6952";
    		reg = <1>;
    		#address-cells = <1>;
    		#size-cells = <0>;
    		spi-max-frequency = <1000000>;
    		jesd204-device;
    		#jesd204-cells = <0x02>;
    		jesd204-sysref-provider;
    		clock-output-names = "ltc6952_out0", "ltc6952_out1",
    				"ltc6952_out2", "ltc6952_out3", "ltc6952_out4",
    				"ltc6952_out5", "ltc6952_out6", "ltc6952_out7",
    				"ltc6952_out8", "ltc6952_out9", "ltc6952_out10";
    		#clock-cells = <1>;
    		adi,vco-frequency-hz = <3750000000>; /* = 3.75 GHz = <0xdf847580>; */
    		/* adi,ref-frequency-hz = <250000000>; */ /* = 250 MHz */
    		adi,ref-frequency-hz = <500000000>; /* = 500 MHz */
    		adi,charge-pump-microamp = <1000>; /* another file has <3370> for for vco=1.25GHz & vref = 1000MHz */
    		channel@0 {
    			reg = <0x00>;
    			adi,extended-name = "SYSREF_0";
    			adi,divider = <0x300>; /* => sysref = 4.8828125 MHz = (device clock) / JESD_N / JESD_K */
    			adi,digital-delay = <0x00>;
    			adi,analog-delay = <0x00>;
    			adi,sysref;
    		channel@1 {
    			reg = <0x01>;
    			adi,extended-name = "SYSREF_1";
    			adi,sysref;
    		channel@4 {
    			reg = <0x04>;
    			adi,extended-name = "CLK_COPY"; /* CLK_COPY or GLBLCLK or LA00_CC*/
    			adi,divider = <0x0c>; /* => 312.5 MHz */
    		channel@5 {
    			reg = <0x05>;
    			adi,extended-name = "SYSREF_COPY"; /* SYSREF_COPY or LA02 */
    		channel@6 {
    			reg = <0x06>;
    			adi,extended-name = "FMC_P1_GBTCLK1M2C";
    		channel@7 {
    			reg = <0x07>;
    			adi,extended-name = "FMC_P1_GBTCLK3M2C";
    		channel@8 {
    			reg = <0x08>;
    			adi,extended-name = "FMC_P2_GBTCLK1M2C";
    		channel@9 {
    			reg = <0x09>;
    			adi,extended-name = "FMC_P2_GBTCLK3M2C";
    LTC6946-2 status: LOCK=1, UNLOCK=0, ALC[HI/LO]=0/1, TUNE[HI/LO]=0/0
    Dividers: O=1, R=3, N=45 | fPFD=83.333333 MHz, fVCO=3750.000000 MHz, fOUT=3750.000000 MHz
    0x00 0x33
    0x01 0x04
    0x02 0x00
    0x03 0xf0
    0x04 0x01
    0x05 0x2d
    0x06 0xfa
    0x07 0x61
    0x08 0x39
    0x09 0x9b
    0x0a 0xe4
    0x0b 0x62
  • It hasn't fixed the problem, but I had a bug in my LTC6946 script, which I have now fixed, so my LTC6946 registers (which still don't work) are:
    LTC6946-2 status: LOCK=1, UNLOCK=0, ALC[HI/LO]=0/0, TUNE[HI/LO]=0/0
    0x00 0x22
    0x01 0x04
    0x02 0x00
    0x03 0xf0
    0x04 0x03
    0x05 0x00
    0x06 0x2d
    0x07 0x61
    0x08 0x39
    0x09 0x9b
    0x0a 0xe4
    0x0b 0x62
  • I've now found the LTC6946 settings for this project: they are in the altera_adxcvr_master branch of the Analog Devices kernel source, file ltc6946.c
    (Sorry for wasting anyone's time with this.)
