Phase Alignment Issues with Dual HMC7044 Clocking 8 ADCs
Product Number: HMC7044
Software Version: vivado 2018.3, sdk2018.3
We are using two HMC7044 clock chips to provide clock inputs to eight ADC chips. Each HMC7044 distributes a 122.88 MHz clock to four ADCs, and all ADCs receive this reference clock from the same source.
The HMC7044 initialization code we are using was taken from the Analog Devices official GitHub repository.
Our goal is to ensure that the ADC output data maintains a consistent phase relationship across all devices, even across power cycles. However, we have observed that ADC phases vary from power-on to power-on, which is a critical issue for our application.
Requirements:
  1. Clock outputs within each HMC7044 must be phase-aligned and maintain a constant phase relationship across power cycles.
  2. Both HMC7044 chips must be synchronized so that their outputs are also phase-aligned.
Issue with Requirement 1 – Internal Clock Alignment
We probed the clock outputs of individual HMC7044 devices and observed that the outputs are not phase-aligned after each power-on. The phase relationship between outputs also varies from reset to reset.
To address this, after completing the HMC7044 initialization using the ADI GitHub code, we issued a reset (resync) pulse by setting bit 1 of register 0x005B to logic 1, then clearing it to 0 after a short duration. We then read back register 0x007D, and observed the value 0x13, which indicates that PLL2 is not synchronized and the phase output is unstable.
We need help understanding:
  • Why PLL2 is not synchronizing,
  • And how to ensure that all output dividers within each HMC7044 are phase-aligned.
Issue with Requirement 2 – Multi-Chip Synchronization
We understand that multi-chip synchronization can only succeed if the individual HMC7044 devices are internally aligned first.
Assuming we resolve the internal alignment issue, we would like to confirm:
  • Is applying a simultaneous one-shot SYNC pulse to both HMC7044 chips (after initialization) sufficient for multi-chip synchronization?
Request
We are currently blocked due to these phase alignment issues, which are critical to our system performance. Despite referring to documentation and community forums, we have not yet found a working solution.
Could you please provide:
  • A clear, step-by-step sequence to achieve both internal phase alignment within each HMC7044 and cross-chip synchronization?
  • Any register configurations or timing considerations we may have missed?
We appreciate your support in resolving this issue.
Best regards
    After you have configured HMC7044s, are you sending restart request (Toggling Register 0x01[1])
    To synchronize the single part, you need to send a reseed request. The reseed request is sent by toggling Register 0x01[7]. Register 0x5B is the control register for the SYNC FSM. Does not trigger sync.
    You can also use the SYNC pin to trigger a sync request. A one-shot CMOS sync signal can be used to trigger sync.
    One important point is that the R divider of the PLL2 should be 1. When R Divider of the PLL2 is set to a value other than 1, it is possible to observe different phase points because the SYNC FSM doesn't reset the R2 divider.
    SYNC input should comply with the setup hold time restrictions in the OSCIN input, as the Sync pulse is retimed with the OSCIN input.
    If you share your register configuration, I can check if there is any error in the configuration.
    This the configuration for using SYNC input.
    Additionally, the SYSREF Timer value should have an integer multiple relationship with the channel divider values.For  example, if channel dividers are 1, 4, 256, 1024, the sysref timer should be 1024.
    Emrecan
  • Hello,
    We have studied your previous response carefully and incorporated all the suggestions and points you shared. Despite this, we are still encountering an issue and would appreciate your further support.
    We are using the following registers and APIs, most of which are based on the code provided by Analog Devices on their GitHub repository. The relevant API and register function details used for configuring the HMC7044 are attached below for your reference.
    Currently, we are observing that register 0x007D returns the value 0x13. Upon investigation, we found that the reference clock input to CLKIN was lost, which caused PLL1 to enter holdover mode. We have now restored a continuous reference clock, and reading register 0x0082 returns 0x51.
    In our system, clocks from both HMC7044 chips are critical. We have reviewed the multi-chip synchronization section in the datasheet, but we still need clarification on the exact synchronization procedure.
    Could you please help us understand:
    1. When exactly the SYNC pulse should be applied during the initialization sequence.
    2. How long the SYNC pulse needs to be (duration or number of cycles).
    3. Any other critical sequence or register settings we might be missing to achieve reliable synchronization across both HMC7044 devices.
    We know you are doing your best to support us — this is a critical issue on our end, and your help is sincerely appreciated.
    The API and register configuration details we are using for the HMC7044.
    Best regards
     *   @file   hmc7044.c
     *   @brief  Implementation of HMC7044, HMC7043 Driver.
     *   @author DBogdan (dragos.bogdan@analog.com)
     * Copyright 2018-2020(c) Analog Devices, Inc.
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions are met:
     *  - Redistributions of source code must retain the above copyright
     *    notice, this list of conditions and the following disclaimer.
     *  - Redistributions in binary form must reproduce the above copyright
     *    notice, this list of conditions and the following disclaimer in
     *    the documentation and/or other materials provided with the
     *    distribution.
     *  - Neither the name of Analog Devices, Inc. nor the names of its
     *    contributors may be used to endorse or promote products derived
     *    from this software without specific prior written permission.
     *  - The use of this software may or may not infringe the patent rights
     *    of one or more patent holders.  This license does not release you
     *    from the requirement that you obtain separate licenses from these
     *    patent holders to use this software.
     *  - Use of the software either in source or binary form, must be run
     *    on or directly connected to an Analog Devices Inc. component.
     * THIS SOFTWARE IS PROVIDED BY ANALOG DEVICES "AS IS" AND ANY EXPRESS OR
     * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, NON-INFRINGEMENT,
     * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
     * IN NO EVENT SHALL ANALOG DEVICES BE LIABLE FOR ANY DIRECT, INDIRECT,
     * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     * LIMITED TO, INTELLECTUAL PROPERTY RIGHTS, PROCUREMENT OF SUBSTITUTE GOODS OR
     * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
     * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
     * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    /***************************** Include Files **********************************/
    #include <hmc7044/hmc7044.h>
    #include <stdlib.h>
    #include <stdio.h>
    #include "error.h"
    #include "util.h"
    /********************** Macros and Constants Definitions **********************/
    #define HMC7044_WRITE		(0 << 15)
    #define HMC7044_READ		(1 << 15)
    #define HMC7044_CNT(x)		(((x) - 1) << 13)
    #define HMC7044_ADDR(x)		((x) & 0xFFF)
    /* Global Control */
    #define HMC7044_REG_SOFT_RESET		0x0000
    #define HMC7044_SOFT_RESET		BIT(0)
    #define HMC7044_REG_REQ_MODE_0		0x0001
    #define HMC7044_RESEED_REQ		BIT(7)
    #define HMC7044_HIGH_PERF_DISTRIB_PATH	BIT(6)
    #define HMC7044_HIGH_PERF_PLL_VCO	BIT(5)
    #define HMC7044_FORCE_HOLDOVER		BIT(4)
    #define HMC7044_MUTE_OUT_DIV		BIT(3)
    #define HMC7044_PULSE_GEN_REQ		BIT(2)
    #define HMC7044_RESTART_DIV_FSM		BIT(1)
    #define HMC7044_SLEEP_MODE		BIT(0)
    #define HMC7044_REG_REQ_MODE_1		0x0002
    #define HMC7044_PLL2_AUTOTUNE_TRIG	BIT(2)
    #define HMC7044_SLIP_REQ		BIT(1)
    #define HMC7044_REG_EN_CTRL_0		0x0003
    #define HMC7044_RF_RESEEDER_EN		BIT(5)
    #define HMC7044_VCO_SEL(x)		(((x) & 0x3) << 3)
    #define HMC7044_VCO_EXT			0
    #define HMC7044_VCO_HIGH		1
    #define HMC7044_VCO_LOW			2
    #define HMC7044_SYSREF_TIMER_EN		BIT(2)
    #define HMC7044_PLL2_EN			BIT(1)
    #define HMC7044_PLL1_EN			BIT(0)
    #define HMC7044_REG_EN_CTRL_1		0x0004
    #define HMC7044_SEVEN_PAIRS(x)		((x) & 0x7f)
    #define HMC7044_REG_GLOB_MODE		0x0005
    #define HMC7044_REF_PATH_EN(x)		((x) & 0xf)
    #define HMC7044_RFSYNC_EN		BIT(4)
    #define HMC7044_VCOIN_MODE_EN		BIT(5)
    #define HMC7044_SYNC_PIN_MODE(x)	(((x) & 0x3) << 6)
    /* PLL1 */
    #define HMC7044_REG_CLKIN0_BUF_CTRL	0x000A
    #define HMC7044_REG_CLKIN1_BUF_CTRL	0x000B
    #define HMC7044_REG_CLKIN2_BUF_CTRL	0x000C
    #define HMC7044_REG_CLKIN3_BUF_CTRL	0x000D
    #define HMC7044_REG_OSCIN_BUF_CTRL	0x000E
    #define HMC7044_REG_PLL1_REF_PRIO_CTRL	0x0014
    #define HMC7044_HIGH_Z_EN		BIT(4)
    #define HMC7044_LVPECL_EN		BIT(3)
    #define HMC7044_AC_COUPLING_EN		BIT(2)
    #define HMC7044_100_OHM_EN		BIT(1)
    #define HMC7044_BUF_EN			BIT(0)
    #define HMC7044_REG_CLKIN_PRESCALER(x)	(0x001C + (x))
    #define HMC7044_REG_OSCIN_PRESCALER	0x0020
    #define HMC7044_REG_PLL1_R_LSB		0x0021
    #define HMC7044_R1_LSB(x)		((x) & 0xff)
    #define HMC7044_REG_PLL1_R_MSB		0x0022
    #define HMC7044_R1_MSB(x)		(((x) & 0xff00) >> 8)
    #define HMC7044_REG_PLL1_N_LSB		0x0026
    #define HMC7044_N1_LSB(x)		((x) & 0xff)
    #define HMC7044_REG_PLL1_N_MSB		0x0027
    #define HMC7044_N1_MSB(x)		(((x) & 0xff00) >> 8)
    #define HMC7044_REG_PLL1_LOCK_DETECT	0x0028
    #define HMC7044_LOCK_DETECT_SLIP	BIT(5)
    #define HMC7044_LOCK_DETECT_TIMER(x)	((x) & 0x1f)
    /* PLL2 */
    #define HMC7044_REG_PLL2_FREQ_DOUBLER	0x0032
    #define HMC7044_PLL2_FREQ_DOUBLER_DIS	BIT(0)
    #define HMC7044_REG_PLL2_R_LSB		0x0033
    #define HMC7044_R2_LSB(x)		((x) & 0xff)
    #define HMC7044_REG_PLL2_R_MSB		0x0034
    #define HMC7044_R2_MSB(x)		(((x) & 0xf00) >> 8)
    #define HMC7044_REG_PLL2_N_LSB		0x0035
    #define HMC7044_N2_LSB(x)		((x) & 0xff)
    #define HMC7044_REG_PLL2_N_MSB		0x0036
    #define HMC7044_N2_MSB(x)		(((x) & 0xff00) >> 8)
    #define HMC7044_REG_OSCOUT_PATH		0x0039
    #define HMC7044_REG_OSCOUT_DRIVER_0	0x003A
    #define HMC7044_REG_OSCOUT_DRIVER_1	0x003B
    /* GPIO/SDATA Control */
    #define HMC7044_REG_GPI_CTRL(x)		(0x0046 + (x))
    #define HMC7044_REG_GPI_SEL(x)		((x) & 0xf)
    #define HMC7044_REG_GPO_CTRL(x)		(0x0050 + (x))
    #define HMC7044_GPO_SEL(x)		(((x) & 0x3f) << 2)
    #define HMC7044_GPO_MODE		BIT(1)
    #define HMC7044_GPO_EN			BIT(0)
    /* SYSREF/SYNC Control */
    #define HMC7044_REG_PULSE_GEN		0x005A
    #define HMC7044_PULSE_GEN_MODE(x)	((x) & 0x7)
    #define HMC7044_REG_SYNC		0x005B
    #define HMC7044_SYNC_RETIME		BIT(2)
    #define HMC7044_SYNC_THROUGH_PLL2	BIT(1)
    #define HMC7044_SYNC_POLARITY		BIT(0)
    #define HMC7044_REG_SYSREF_TIMER_LSB	0x005C
    #define HMC7044_SYSREF_TIMER_LSB(x)	((x) & 0xff)
    #define HMC7044_REG_SYSREF_TIMER_MSB	0x005D
    #define HMC7044_SYSREF_TIMER_MSB(x)	(((x) & 0xf00) >> 8)
    #define HMC7044_CLK_INPUT_CTRL		0x0064
    #define HMC7044_LOW_FREQ_INPUT_MODE	BIT(0)
    #define HMC7044_DIV_2_INPUT_MODE	BIT(1)
    /* Status and Alarm readback */
    #define HMC7044_REG_ALARM_READBACK	0x007D
    #define HMC7044_REG_PLL1_STATUS		0x0082
    #define HMC7044_PLL1_FSM_STATE(x)	((x) & 0x7)
    #define HMC7044_PLL1_ACTIVE_CLKIN(x)	(((x) >> 3) & 0x3)
    #define HMC7044_PLL2_LOCK_DETECT(x)	((x) & 0x1)
    #define HMC7044_SYSREF_SYNC_STAT(x)	((x) & 0x2)
    #define HMC7044_CLK_OUT_PH_STATUS(x)	((x) & 0x4)
    #define HMC7044_PLL1_PLL2_LOCK_STAT(x)	((x) & 0x8)
    #define HMC7044_SYNC_REQ_STATUS(x)	((x) & 0x10)
    /* Other Controls */
    #define HMC7044_REG_CLK_OUT_DRV_LOW_PW	0x009F
    #define HMC7044_REG_CLK_OUT_DRV_HIGH_PW	0x00A0
    #define HMC7044_REG_PLL1_DELAY		0x00A5
    #define HMC7044_REG_PLL1_HOLDOVER	0x00A8
    #define HMC7044_REG_VTUNE_PRESET	0x00B0
    /* Clock Distribution */
    #define HMC7044_REG_CH_OUT_CRTL_0(ch)	(0x00C8 + 0xA * (ch))
    #define HMC7044_HI_PERF_MODE		BIT(7)
    #define HMC7044_SYNC_EN			BIT(6)
    #define HMC7044_CH_EN			BIT(0)
    #define HMC7044_START_UP_MODE_DYN_EN	(BIT(3) | BIT(2))
    #define HMC7044_REG_CH_OUT_CRTL_1(ch)	(0x00C9 + 0xA * (ch))
    #define HMC7044_DIV_LSB(x)		((x) & 0xFF)
    #define HMC7044_REG_CH_OUT_CRTL_2(ch)	(0x00CA + 0xA * (ch))
    #define HMC7044_DIV_MSB(x)		(((x) >> 8) & 0xFF)
    #define HMC7044_REG_CH_OUT_CRTL_3(ch)	(0x00CB + 0xA * (ch))
    #define HMC7044_REG_CH_OUT_CRTL_4(ch)	(0x00CC + 0xA * (ch))
    #define HMC7044_REG_CH_OUT_CRTL_5(ch)	(0x00CD + 0xA * (ch))
    #define HMC7044_REG_CH_OUT_CRTL_6(ch)	(0x00CE + 0xA * (ch))
    #define HMC7044_REG_CH_OUT_CRTL_7(ch)	(0x00CF + 0xA * (ch))
    #define HMC7044_REG_CH_OUT_CRTL_8(ch)	(0x00D0 + 0xA * (ch))
    #define HMC7044_DRIVER_MODE(x)		(((x) & 0x3) << 3)
    #define HMC7044_DRIVER_Z_MODE(x)	(((x) & 0x3) << 0)
    #define HMC7044_DYN_DRIVER_EN		BIT(5)
    #define HMC7044_FORCE_MUTE_EN		BIT(7)
    #define HMC7044_NUM_CHAN	14
    #define HMC7044_LOW_VCO_MIN	2150000
    #define HMC7044_LOW_VCO_MAX	2880000
    #define HMC7044_HIGH_VCO_MIN	2650000
    #define HMC7044_HIGH_VCO_MAX	3200000
    #define HMC7044_RECOMM_LCM_MIN	30000
    #define HMC7044_RECOMM_LCM_MAX	70000
    #define HMC7044_RECOMM_FPD1	10000
    #define HMC7044_R1_MAX		65535
    #define HMC7044_N1_MAX		65535
    #define HMC7044_R2_MIN		1
    #define HMC7044_R2_MAX		4095
    #define HMC7044_N2_MIN		8
    #define HMC7044_N2_MAX		65535
    #define HMC7044_OUT_DIV_MIN	1
    #define HMC7044_OUT_DIV_MAX	4094
    /************************** Functions Implementation **************************/
     * SPI register write to device.
     * @param dev - The device structure.
     * @param reg - The register address.
     * @param val - The register data.
     * @return SUCCESS in case of success, negative error code otherwise.
    static int hmc7044_write(struct hmc7044_dev *dev,
    			 uint16_t reg,
    			 uint8_t val)
    	uint8_t buf[3];
    	uint16_t cmd;
    	cmd = HMC7044_WRITE | HMC7044_CNT(1) | HMC7044_ADDR(reg);
    	buf[0] = cmd >> 8;
    	buf[1] = cmd & 0xFF;
    	buf[2] = val;
    	return spi_write_and_read(dev->spi_desc, buf, ARRAY_SIZE(buf));
     * SPI register read from device.
    int32_t hmc7044_read(struct hmc7044_dev *dev, uint16_t reg, uint8_t *val)
    	uint8_t buf[3];
    	uint16_t cmd;
    	int ret;
    	cmd = HMC7044_READ | HMC7044_CNT(1) | HMC7044_ADDR(reg);
    	buf[0] = cmd >> 8;
    	buf[2] = 0;
    	ret = spi_write_and_read(dev->spi_desc, buf, ARRAY_SIZE(buf));
    	if (ret < 0)
    		return ret;
    	*val = buf[2];
    	return SUCCESS;
     * Calculate the output channel divider.
     * @param rate - The desired rate.
     * @param parent_rate - The parent rate.
     * @return The output divider.
    uint32_t hmc7044_calc_out_div(uint32_t rate,
    			      uint32_t parent_rate)
    	uint32_t div;
    	div = DIV_ROUND_CLOSEST(parent_rate, rate);
    	/* Supported odd divide ratios are 1, 3, and 5 */
    	if ((div != 1) && (div != 3) && (div != 5) && (div % 2))
    		div = DIV_ROUND_CLOSEST(parent_rate, rate * 2) * 2;
    	div = clamp_t(unsigned int,
    		      div,
    		      HMC7044_OUT_DIV_MIN,
    		      HMC7044_OUT_DIV_MAX);
    	return div;
     * Recalculate rate corresponding to a channel.
     * @param chan - Channel number.
     * @param rate - Channel rate.
    int32_t hmc7044_clk_recalc_rate(struct hmc7044_dev *dev, uint32_t chan,
    				uint64_t *rate)
    	if (chan > dev->num_channels)
    		return FAILURE;
    	*rate = dev->pll2_freq / dev->channels[chan].divider;
    	return SUCCESS;
     * Calculate closest possible rate
     * @param rounded_rate - The closest possible rate of desired rate.
    int32_t hmc7044_clk_round_rate(struct hmc7044_dev *dev, uint32_t rate,
    			       uint64_t *rounded_rate)
    	uint32_t div = hmc7044_calc_out_div(rate, dev->pll2_freq);
    	*rounded_rate = DIV_ROUND_CLOSEST(dev->pll2_freq, div);
    	return SUCCESS;
     * Set channel rate.
    int32_t hmc7044_clk_set_rate(struct hmc7044_dev *dev, uint32_t chan,
    			     uint64_t rate)
    	uint32_t div;
    	int32_t ret;
    	if (chan >= dev->num_channels)
    		return FAILURE;
    	dev->channels[chan].divider = div;
    	ret = hmc7044_write(dev, HMC7044_REG_CH_OUT_CRTL_1(chan),
    			    HMC7044_DIV_LSB(div));
    	if(ret < 0)
    		return ret;
    	return hmc7044_write(dev, HMC7044_REG_CH_OUT_CRTL_2(chan),
    			     HMC7044_DIV_MSB(div));
     * Setup the device.
    static int32_t hmc7044_setup(struct hmc7044_dev *dev)
    	struct hmc7044_chan_spec *chan;
    	bool high_vco_en;
    	bool pll2_freq_doubler_en;
    	uint32_t vcxo_freq, pll2_freq;
    	uint32_t clkin_freq[4];
    	uint32_t lcm_freq;
    	uint32_t in_prescaler[5];
    	uint32_t pll1_lock_detect;
    	uint32_t n1, r1;
    	uint32_t pfd1_freq;
    	uint32_t vco_limit;
    	uint32_t n2[2], r2[2];
    	uint32_t i, ref_en = 0;
    	vcxo_freq = dev->vcxo_freq / 1000;
    	pll2_freq = dev->pll2_freq / 1000;
    	lcm_freq = vcxo_freq;
    	for (i = 0; i < ARRAY_SIZE(clkin_freq); i++) {
    		if (dev->clkin_freq_ccf[i])
    			clkin_freq[i] = dev->clkin_freq_ccf[i] / 1000;
    		else
    			clkin_freq[i] = dev->clkin_freq[i] / 1000;
    		if (clkin_freq[i]) {
    			lcm_freq = greatest_common_divisor(clkin_freq[i], lcm_freq);
    			ref_en |= BIT(i);
    	while (lcm_freq > HMC7044_RECOMM_LCM_MAX)
    		lcm_freq /= 2;
    		if (clkin_freq[i])
    			in_prescaler[i] = clkin_freq[i] / lcm_freq;
    		else
    			in_prescaler[i] = 1;
    	in_prescaler[4] = vcxo_freq / lcm_freq;
    	pll1_lock_detect = log_base_2((lcm_freq * 4000) / dev->pll1_loop_bw);
    	/* fVCXO / N1 = fLCM / R1 */
    	rational_best_approximation(vcxo_freq, lcm_freq,
    				    HMC7044_N1_MAX, HMC7044_R1_MAX,
    				    &n1, &r1);
    	pfd1_freq = vcxo_freq / n1;
    	while ((pfd1_freq > HMC7044_RECOMM_FPD1) &&
    	       (n1 <= HMC7044_N1_MAX / 2) &&
    	       (r1 <= HMC7044_R1_MAX / 2)) {
    		pfd1_freq /= 2;
    		n1 *= 2;
    		r1 *= 2;
    	dev->pll1_pfd = pfd1_freq;
    	if (pll2_freq < HMC7044_LOW_VCO_MIN  ||
    	    pll2_freq > HMC7044_HIGH_VCO_MAX)
    		return FAILURE;
    	vco_limit = (HMC7044_LOW_VCO_MAX + HMC7044_HIGH_VCO_MIN) / 2;
    	if (pll2_freq >= vco_limit)
    		high_vco_en = true;
    	else
    		high_vco_en = false;
    	/* fVCO / N2 = fVCXO * doubler / R2 */
    	pll2_freq_doubler_en = true;
    	rational_best_approximation(pll2_freq, vcxo_freq * 2,
    				    HMC7044_N2_MAX, HMC7044_R2_MAX,
    				    &n2[0], &r2[0]);
    	if (pll2_freq != vcxo_freq * n2[0] / r2[0]) {
    		rational_best_approximation(pll2_freq, vcxo_freq,
    					    &n2[1], &r2[1]);
    		if (abs((int)pll2_freq - (int)(vcxo_freq * 2 * n2[0] / r2[0])) >
    		    abs((int)pll2_freq - (int)(vcxo_freq * n2[1] / r2[1]))) {
    			n2[0] = n2[1];
    			r2[0] = r2[1];
    			pll2_freq_doubler_en = false;
    	while ((n2[0] < HMC7044_N2_MIN) && (r2[0] <= HMC7044_R2_MAX / 2)) {
    		n2[0] *= 2;
    		r2[0] *= 2;
    	if (n2[0] < HMC7044_N2_MIN)
    		return -FAILURE;
    	/* Resets all registers to default values */
    	hmc7044_write(dev, HMC7044_REG_SOFT_RESET, HMC7044_SOFT_RESET);
    	mdelay(10);
    	hmc7044_write(dev, HMC7044_REG_SOFT_RESET, 0);
    	mdelay(10);
    	/* Disable all channels */
    	for (i = 0; i < HMC7044_NUM_CHAN; i++)
    		hmc7044_write(dev, HMC7044_REG_CH_OUT_CRTL_0(i), 0);
    	/* Load the configuration updates (provided by Analog Devices) */
    	hmc7044_write(dev, HMC7044_REG_CLK_OUT_DRV_LOW_PW, 0x4d);
    	hmc7044_write(dev, HMC7044_REG_CLK_OUT_DRV_HIGH_PW, 0xdf);
    	hmc7044_write(dev, HMC7044_REG_PLL1_DELAY, 0x06);
    	hmc7044_write(dev, HMC7044_REG_PLL1_HOLDOVER, 0x06);
    	hmc7044_write(dev, HMC7044_REG_VTUNE_PRESET, 0x04);
    	hmc7044_write(dev, HMC7044_REG_GLOB_MODE,
    		      HMC7044_SYNC_PIN_MODE(dev->sync_pin_mode) |
    		      (dev->clkin0_rfsync_en ? HMC7044_RFSYNC_EN : 0) |
    		      (dev->clkin1_vcoin_en ? HMC7044_VCOIN_MODE_EN : 0) |
    		      HMC7044_REF_PATH_EN(ref_en));
    	/* Program PLL2 */
    	/* Select the VCO range */
    //	hmc7044_write(dev, HMC7044_REG_EN_CTRL_0,
    //		      (dev->rf_reseeder_en ? HMC7044_RF_RESEEDER_EN : 0) |
    //		      HMC7044_VCO_SEL(high_vco_en ?
    //				      HMC7044_VCO_HIGH :
    //				      HMC7044_VCO_LOW) |
    //		      HMC7044_SYSREF_TIMER_EN | HMC7044_PLL2_EN |
    //		      HMC7044_PLL1_EN);
    			      ( HMC7044_RF_RESEEDER_EN ) |
    					      HMC7044_VCO_HIGH :
    					      HMC7044_VCO_LOW) |
    			      HMC7044_PLL1_EN);
    	/* Program the dividers */
    	hmc7044_write(dev, HMC7044_REG_PLL2_R_LSB,
    		      HMC7044_R2_LSB(r2[0]));
    	hmc7044_write(dev, HMC7044_REG_PLL2_R_MSB,
    		      HMC7044_R2_MSB(r2[0]));
    	hmc7044_write(dev, HMC7044_REG_PLL2_N_LSB,
    		      HMC7044_N2_LSB(n2[0]));
    	hmc7044_write(dev, HMC7044_REG_PLL2_N_MSB,
    		      HMC7044_N2_MSB(n2[0]));
    	/* Program the reference doubler */
    	hmc7044_write(dev, HMC7044_REG_PLL2_FREQ_DOUBLER,
    		      pll2_freq_doubler_en ? 0 : HMC7044_PLL2_FREQ_DOUBLER_DIS);
    	/* Program PLL1 */
    	/* Set the lock detect timer threshold */
    	hmc7044_write(dev, HMC7044_REG_PLL1_LOCK_DETECT,
    		      HMC7044_LOCK_DETECT_TIMER(pll1_lock_detect));
    	/* Set the LCM */
    		hmc7044_write(dev, HMC7044_REG_CLKIN_PRESCALER(i),
    			      in_prescaler[i]);
    	hmc7044_write(dev, HMC7044_REG_OSCIN_PRESCALER,
    		      in_prescaler[4]);
    	hmc7044_write(dev, HMC7044_REG_PLL1_R_LSB,
    		      HMC7044_R2_LSB(r1));
    	hmc7044_write(dev, HMC7044_REG_PLL1_R_MSB,
    		      HMC7044_R2_MSB(r1));
    	hmc7044_write(dev, HMC7044_REG_PLL1_N_LSB,
    		      HMC7044_N2_LSB(n1));
    	hmc7044_write(dev, HMC7044_REG_PLL1_N_MSB,
    		      HMC7044_N2_MSB(n1));
    	hmc7044_write(dev, HMC7044_REG_PLL1_REF_PRIO_CTRL,
    		      dev->pll1_ref_prio_ctrl);
    	/* Program the SYSREF timer */
    	/* Set the divide ratio */
    	hmc7044_write(dev, HMC7044_REG_SYSREF_TIMER_LSB,
    		      HMC7044_SYSREF_TIMER_LSB(dev->sysref_timer_div));
    	hmc7044_write(dev, HMC7044_REG_SYSREF_TIMER_MSB,
    		      HMC7044_SYSREF_TIMER_MSB(dev->sysref_timer_div));
    	/* Set the pulse generator mode configuration */
    	hmc7044_write(dev, HMC7044_REG_PULSE_GEN,
    		      HMC7044_PULSE_GEN_MODE(dev->pulse_gen_mode));
    	/* Enable the input buffers */
    	hmc7044_write(dev, HMC7044_REG_CLKIN0_BUF_CTRL,
    		      dev->in_buf_mode[0]);
    	hmc7044_write(dev, HMC7044_REG_CLKIN1_BUF_CTRL,
    		      dev->in_buf_mode[1]);
    	hmc7044_write(dev, HMC7044_REG_CLKIN2_BUF_CTRL,
    		      dev->in_buf_mode[2]);
    	hmc7044_write(dev, HMC7044_REG_CLKIN3_BUF_CTRL,
    		      dev->in_buf_mode[3]);
    	hmc7044_write(dev, HMC7044_REG_OSCIN_BUF_CTRL,
    		      dev->in_buf_mode[4]);
    	for (i = 0; i < ARRAY_SIZE(dev->in_buf_mode); i++) {
    			printf("  in buf mode indes %d value that is written is %x\r\n",i,dev->in_buf_mode[i]);
    		uint8_t data = 0;
    		hmc7044_read(dev, HMC7044_REG_CLKIN0_BUF_CTRL, &data);
    		xil_printf("data buf 0 is %x \r\n",data);
    		hmc7044_read(dev, HMC7044_REG_CLKIN1_BUF_CTRL, &data);
    		xil_printf("data is buf 1 %x \r\n",data);
    		hmc7044_read(dev, HMC7044_REG_CLKIN2_BUF_CTRL, &data);
    		xil_printf("data is buf 2 %x \r\n",data);
    		hmc7044_read(dev, HMC7044_REG_CLKIN3_BUF_CTRL, &data);
    		xil_printf("data is buf 3 %x \r\n",data);
    		hmc7044_read(dev, HMC7044_REG_OSCIN_BUF_CTRL, &data);
    		xil_printf("data is buf osc %x \r\n",data);
    	/* Set GPIOs */
    	for (i = 0; i < ARRAY_SIZE(dev->gpi_ctrl); i++) {
    		hmc7044_write(dev, HMC7044_REG_GPI_CTRL(i),
    			      dev->gpi_ctrl[i]);
    	for (i = 0; i < ARRAY_SIZE(dev->gpo_ctrl); i++) {
    		hmc7044_write(dev, HMC7044_REG_GPO_CTRL(i),
    			      dev->gpo_ctrl[i]);
    	mdelay(10);
    	/* Program the output channels */
    	for (i = 0; i < dev->num_channels; i++) {
    		chan = &dev->channels[i];
    		if (chan->num >= HMC7044_NUM_CHAN || chan->disable)
    			continue;
    		hmc7044_write(dev, HMC7044_REG_CH_OUT_CRTL_1(chan->num),
    			      HMC7044_DIV_LSB(chan->divider));
    		hmc7044_write(dev, HMC7044_REG_CH_OUT_CRTL_2(chan->num),
    			      HMC7044_DIV_MSB(chan->divider));
    		hmc7044_write(dev, HMC7044_REG_CH_OUT_CRTL_8(chan->num),
    			      HMC7044_DRIVER_MODE(chan->driver_mode) |
    			      HMC7044_DRIVER_Z_MODE(chan->driver_impedance) |
    			      (chan->dynamic_driver_enable ?
    			       HMC7044_DYN_DRIVER_EN : 0) |
    			      (chan->force_mute_enable ?
    			       HMC7044_FORCE_MUTE_EN : 0));
    		hmc7044_write(dev, HMC7044_REG_CH_OUT_CRTL_3(chan->num),
    			      chan->fine_delay & 0x1F);
    		hmc7044_write(dev, HMC7044_REG_CH_OUT_CRTL_4(chan->num),
    			      chan->coarse_delay & 0x1F);
    		hmc7044_write(dev, HMC7044_REG_CH_OUT_CRTL_7(chan->num),
    			      chan->out_mux_mode & 0x3);
    		hmc7044_write(dev, HMC7044_REG_CH_OUT_CRTL_0(chan->num),
    			      (chan->start_up_mode_dynamic_enable ?
    			       HMC7044_START_UP_MODE_DYN_EN : 0) |
    			      (chan->output_control0_rb4_enable ? BIT(4) : 0) |
    			      (chan->high_performance_mode_dis ?
    			       0 : HMC7044_HI_PERF_MODE) | HMC7044_SYNC_EN |
    			      HMC7044_CH_EN);
    //		------added by charan
    //		hmc7044_read(dev, HMC7044_REG_CH_OUT_CRTL_0(chan->num), &data);
    //			xil_printf("sync enable debug in channel %d is   %x \r\n",chan->num,data);
    	mdelay(10);
    	/* Do a restart to reset the system and initiate calibration */
    	hmc7044_write(dev, HMC7044_REG_REQ_MODE_0,
    		      HMC7044_RESTART_DIV_FSM);
    	mdelay(1);
    		      (dev->high_performance_mode_clock_dist_en ?
    		       HMC7044_HIGH_PERF_DISTRIB_PATH : 0) |
    		      (dev->high_performance_mode_pll_vco_en ?
    		       HMC7044_HIGH_PERF_PLL_VCO : 0));
    	mdelay(1);
    	//	added by charan
    		hmc7044_read(dev, HMC7044_REG_PLL1_STATUS, &data);
    			xil_printf("pll status is  %x \r\n",data);
    			hmc7044_write(dev, HMC7044_REG_SYNC,
    					0x06);
    			usleep(1);
    //			hmc7044_write(dev, HMC7044_REG_SYNC,
    //					      0);
    					BIT(1));
    								BIT(7));
    								0x00);
    			usleep(1);
    			hmc7044_read(dev, HMC7044_REG_ALARM_READBACK, &data);
    						xil_printf("val in reg %x is  %x \r\n",HMC7044_REG_ALARM_READBACK,data);
    	return SUCCESS;
     * Setup the device.
    static int32_t hmc7043_setup(struct hmc7044_dev *dev)
    	uint32_t i;
    	if (dev->clkin_freq_ccf[0])
    		dev->pll2_freq = dev->clkin_freq_ccf[0];
    	else
    		dev->pll2_freq  = dev->clkin_freq[0];
    	if (!dev->pll2_freq) {
    		printf("%s: Failed to get valid parent rate\n", __func__);
    		return FAILURE;
    	mdelay(10);
    	mdelay(10);
    	if (dev->pll2_freq < 1000000000U)
    		hmc7044_write(dev, HMC7044_CLK_INPUT_CTRL,
    			      HMC7044_LOW_FREQ_INPUT_MODE);
    		      HMC7044_SYSREF_TIMER_EN);
    	/* Set GPIOs */
    	hmc7044_write(dev, HMC7044_REG_GPI_CTRL(0),
    		      dev->gpi_ctrl[0]);
    	hmc7044_write(dev, HMC7044_REG_GPO_CTRL(0),
    		      dev->gpo_ctrl[0]);
    			continue;
    			      HMC7044_CH_EN);
    	mdelay(10);
    	mdelay(1);
    		       HMC7044_HIGH_PERF_DISTRIB_PATH : 0));
    	mdelay(1);
    	return SUCCESS;
     * Initialize the device.
     * @param device - The device structure.
     * @param init_param - The structure that contains the device initial
     * 		       parameters.
    int32_t hmc7044_init(struct hmc7044_dev **device,
    		     const struct hmc7044_init_param *init_param)
    	struct hmc7044_dev *dev;
    	int32_t ret;
    	unsigned int i;
    	dev = (struct hmc7044_dev *)malloc(sizeof(*dev));
    	if (!dev)
    		return FAILURE;
    	ret = spi_init(&dev->spi_desc, init_param->spi_init);
    	if (ret < 0)
    		return ret;
    	dev->is_hmc7043 = init_param->is_hmc7043;
    	dev->clkin_freq[0] = init_param->clkin_freq[0];
    	dev->clkin_freq[1] = init_param->clkin_freq[1];
    	dev->clkin_freq[2] = init_param->clkin_freq[2];
    	dev->clkin_freq[3] = init_param->clkin_freq[3];
    	dev->clkin_freq_ccf[0] = init_param->clkin_freq_ccf[0];
    	dev->clkin_freq_ccf[1] = init_param->clkin_freq_ccf[1];
    	dev->clkin_freq_ccf[2] = init_param->clkin_freq_ccf[2];
    	dev->clkin_freq_ccf[3] = init_param->clkin_freq_ccf[3];
    	dev->vcxo_freq = init_param->vcxo_freq;
    	dev->pll1_pfd = init_param->pll1_pfd;
    	dev->pll2_freq = init_param->pll2_freq;
    	dev->pll1_loop_bw = init_param->pll1_loop_bw;
    	dev->sysref_timer_div = init_param->sysref_timer_div;
    	dev->pll1_ref_prio_ctrl = init_param->pll1_ref_prio_ctrl;
    	dev->clkin0_rfsync_en = init_param->clkin0_rfsync_en;
    	dev->clkin1_vcoin_en = init_param->clkin1_vcoin_en;
    	dev->high_performance_mode_clock_dist_en =
    		init_param->high_performance_mode_clock_dist_en;
    	dev->high_performance_mode_pll_vco_en =
    		init_param->high_performance_mode_pll_vco_en;
    	dev->rf_reseeder_en = !init_param->rf_reseeder_disable;
    	dev->sync_pin_mode = init_param->sync_pin_mode;
    	dev->pulse_gen_mode = init_param->pulse_gen_mode;
    	dev->in_buf_mode[0] = init_param->in_buf_mode[0];
    	dev->in_buf_mode[1] = init_param->in_buf_mode[1];
    	dev->in_buf_mode[2] = init_param->in_buf_mode[2];
    	dev->in_buf_mode[3] = init_param->in_buf_mode[3];
    	dev->in_buf_mode[4] = init_param->in_buf_mode[4];
    	dev->gpi_ctrl[0] = init_param->gpi_ctrl[0];
    	dev->gpi_ctrl[1] = init_param->gpi_ctrl[1];
    	dev->gpi_ctrl[2] = init_param->gpi_ctrl[2];
    	dev->gpi_ctrl[3] = init_param->gpi_ctrl[3];
    	dev->gpo_ctrl[0] = init_param->gpo_ctrl[0];
    	dev->gpo_ctrl[1] = init_param->gpo_ctrl[1];
    	dev->gpo_ctrl[2] = init_param->gpo_ctrl[2];
    	dev->gpo_ctrl[3] = init_param->gpo_ctrl[3];
    	dev->num_channels = init_param->num_channels;
    	dev->channels = (struct hmc7044_chan_spec *)
    			malloc(sizeof(*dev->channels) * dev->num_channels);
    		dev->channels[i].num = init_param->channels[i].num;
    		dev->channels[i].disable = init_param->channels[i].disable;
    		dev->channels[i].divider = init_param->channels[i].divider;
    		dev->channels[i].driver_mode =
    			init_param->channels[i].driver_mode;
    		dev->channels[i].high_performance_mode_dis =
    			init_param->channels[i].high_performance_mode_dis;
    		dev->channels[i].start_up_mode_dynamic_enable =
    			init_param->channels[i].start_up_mode_dynamic_enable;
    		dev->channels[i].dynamic_driver_enable =
    			init_param->channels[i].dynamic_driver_enable;
    		dev->channels[i].output_control0_rb4_enable =
    			init_param->channels[i].output_control0_rb4_enable;
    		dev->channels[i].force_mute_enable =
    			init_param->channels[i].force_mute_enable;
    		dev->channels[i].driver_impedance =
    			init_param->channels[i].driver_impedance;
    		dev->channels[i].coarse_delay =
    			init_param->channels[i].coarse_delay;
    		dev->channels[i].fine_delay =
    			init_param->channels[i].fine_delay;
    		dev->channels[i].out_mux_mode =
    			init_param->channels[i].out_mux_mode;
    	*device = dev;
    	if (!dev->is_hmc7043)
    		return hmc7044_setup(dev);
    	else
    		return hmc7043_setup(dev);
     * Remove the device - release resources.
    int32_t hmc7044_remove(struct hmc7044_dev *device)
    	int32_t ret;
    	ret = spi_remove(device->spi_desc);
    	free(device->channels);
    	free(device);
    	return ret;
    Here is my comments to the questions:
    1. When exactly the SYNC pulse should be applied during the initialization sequence?
      SYNC pulse should be applied after the PLL2 is locked and all the channel dividers are configured.
      A rising edge is enough, but we recommend pulse length of 4 VCXO cycles. SYNC is triggered with the rising edge of the SYNC signal. SYNC input is insensitive the any signal on the SYNC pin after 16 * 6 * PLL2 PFD Period.
    3. Any other critical sequence or register settings we might be missing to achieve reliable synchronization across both HMC7044 devices?
      SYSREF Timer Value: Should have an integer relationship with channel dividers.
      RF Reseeder: Can you try disabling it?
      SYNC Thru PLL2: Can you try disabling it?
      SYNC Enable of each channel that requires synchronization must be enabled.
      PLL2 R divider should be 1.
      PLL1 Reference and VCXO should have an integer relationship.
    Emrecan
