Dear Team,
We wants to generate the 16.369MHz (800mVp-p clipped sinewave) from 10MHz(1ppb) clock input.
We want to use both the PLL to generate the stable 16.369MHz.. Please provide hardware configuration needs to follow.
Sreekanth
KCC's Quizzes AQQ306 about a fish stick challenge
1. First the quote of the month: " I am so clever that sometimes I don't understand a single word of what I am saying" - Oscar Wilde
2. New quiz AQQ306 about a fish stick challenge:
Here below is a pseudo fish diagram swimming to the right.
Question
Strong EMC design
AD9576
Recommended for New Designs
The AD9576 provides a multiple output clock generator function comprising two dedicated phase-locked loop (PLL) cores with flexible frequency translation...
Datasheet
AD9576 on Analog.com
Dear Team,
Sreekanth
HI,
I believe one of your colleagues opened this enquiry with the same request:
RE: AD9576 Eval board SPI configuration support and frequency conversion with dual PLL
It is not clear to me what in my response was so wrong, that you opened on new issue.
The AD9576 cannot generate clipped sinewave clocks.
I already provided a cso file in that thread that takes in 10MHz clock and creates 16.369MHz clocks from PLL0.
Now you seem to want to generate 16.369MHz clocks from PLL1 as well. I'm sorry to say, but from a 10MHz clock is impossible to generate 16.369MHz clocks using PLL1. PLL1 is an integer PLL. PLL0 can be configured because it a fractional PLL.
If you, for example, provide REF2=16.369MHz clock, then you can obtain OUT8,9,10=16.389MHz.
<?xml version="1.0" encoding="utf-8"?>
<Session Name="Session" AppVersion="" FileVersion="" xmlns="AnalogDevices/Csa/Configuration/Schemas/Session.xsd">
<Elements>
<Element Id="Scripts">
<ScriptManager xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="AnalogDevices/Csa/Scripting/Sessions/ScriptManagerSessionElement.Schema.xsd">
<Scripts>
<Script Name="3_ADF4030_DEMO_cascaded.py" FilePath="file:///C:/Users/pminciu/AppData/Local/Analog Devices/ACE/Scripts/3_ADF4030_DEMO_cascaded.py" ScriptTypeId="Python3" ScriptLanguage="Python" Lines="# Generated code compatible with Python 2.7+
## Copyright (c) 2024 by Analog Devices, Inc. All rights reserved. This software is proprietary to Analog Devices, Inc. and its licensors.
## This software is provided on an 'as is' basis without any representations, warranties, guarantees or liability of any kind.
## Use of the software is subject to the terms and conditions of the Clear BSD License ( https://spdx.org/licenses/BSD-3-Clause-Clear.html ).
# Requirements:
# - pythonnet
import sys
sys.path.append(r'C:\Program Files\Analog Devices\ACE\Client')
import time
# noinspection SpellCheckingInspection
import clr # noqa
clr.AddReference('AnalogDevices.Csa.Remoting.Clients')
clr.AddReference('AnalogDevices.Csa.Remoting.Contracts')
# noinspection PyUnresolvedReferences,SpellCheckingInspection
from AnalogDevices.Csa.Remoting.Clients import ClientManager #noqa
def main():
 manager = ClientManager.Create()
 client = manager.CreateRequestClient("localhost:2357")
 ADF4030Demo(client)
def set_frequency(client,board_id,ref_in,bsync_out):
 """ Set BSYNC frequency for give ref_in and bsync_out values. Calculates PLL and output divider settings. """
 client.SetIntParameter("virtual-parameter-device_id", f"{int(board_id)}", "-1")
 client.Run("@ReadSettings")
 if(ref_in < 10e6 or ref_in > 250e6):
 raise ValueError("ref_in Out of Range")
 if(bsync_out < 650e3 or bsync_out > 200e6):
 raise ValueError("bsync_out Out of Range")
 o_div = 1
 if(2.5e9 % bsync_out == 0):
 vco_freq = 2.5e9
 o_div = vco_freq/bsync_out
 else:
 vco_min = 2.375e9
 vco_max = 2.625e9
 vco_freq = 0
 for o_div in range(1,4095):
 vco_freq = bsync_out * o_div
 if(vco_freq >= vco_min and vco_freq <= vco_max):
 break
 pfd_min = 10e6
 pfd_max = 20e6
 pfd_freq = 0
 r_div = 1
 for r_div in range(1,32):
 pfd_freq = ref_in / r_div
 if(pfd_freq >= pfd_min and pfd_freq <= pfd_max):
 break
 n_div = (vco_freq/pfd_freq)
 n_div_min = 0
 n_div_max = 256
 if(n_div < n_div_min or n_div > n_div_max):
 raise ValueError("n_div Out of Range")
 n_div = round(n_div)
 out_pfd = ref_in / int(r_div)
 out_vco = out_pfd * int(n_div)
 out_bsync = out_vco / int(o_div)
 print("out_bsync",out_bsync)
 client.SetBoolParameter("PLL_CAL_EN", "True", "-1")
 client.Run("@ApplySettings")
 time.sleep(0.5)
 client.SetDecimalParameter("virtual-parameter-reference-frequency", f"{int(ref_in)}", "-1")
 client.SetByteParameter("RDIV", f"{int(r_div)}", "-1")
 client.SetBigIntParameter("ODIV1", f"{int(o_div)}", "-1")
 client.SetBigIntParameter("ODIV2", f"{int(o_div)}", "-1")
 client.SetByteParameter("NDIV", f"{int(n_div)}", "-1")
 time.sleep(0.5)
 client.SetBoolParameter("PLL_CAL_EN", "False", "-1")
 time.sleep(0.5)
def adf4030_init(client,board_id,tx_channel,ref_in,bsync_out):
 """Loads Default Registers, Sets the Bsync freqeuncy and Enable initial BSYNC Channel"""
 client.Run("@LoadDefault")
 client.SetIntParameter("PD_TX_PATH1", "1", "-1")
 time.sleep(0.5)
 set_frequency(client,board_id=board_id,ref_in=ref_in,bsync_out=bsync_out)
 if tx_channel != None:
 client.SetIntParameter(f"PD_TX_PATH{tx_channel}", "0", "-1")
 client.SetIntParameter(f"EN_DRV{tx_channel}", "1", "-1")
 time.sleep(0.5)
def tdc_meas(client,board_id,tdc_source,tdc_target):
 """ Measure TDC between 2 BSYNC channels """
 client.SetIntParameter("TDC_SOURCE", f"{tdc_source}", "-1")
 client.SetIntParameter("TDC_TARGET", f"{tdc_target}", "-1")
 time.sleep(0.5)
 client.Run("@TDCMeasurementSequence")
 result = float(client.GetDecimalParameter("virtual-parameter-tdc-result-value"))
 result_s = "{:.3f}".format(result)
 print(f"TDC Meas Board{board_id}: BSYNC{tdc_source}->BSYNC{tdc_target}= {result_s} ps")
 return result
def set_direction(client, source_board, chan1, target_board, chan2):
 """ Sets the direction of a connected pair of bidirectional channels (BSYNCs). """
 cmmnt = f"Board{source_board}.BSYNC{chan1} --> Board{target_board}.BSYNC{chan2}"
 client.SetIntParameter("virtual-parameter-device_id", f"{int(target_board)}", "-1")
 client.SetIntParameter(f"EN_DRV{chan2}", "0", "-1")
 time.sleep(0.5)
 client.SetIntParameter("virtual-parameter-device_id", f"{int(source_board)}", "-1")
 client.SetIntParameter(f"EN_DRV{chan1}", "1", "-1")
 time.sleep(0.5)
 print(f"Set Direction: {cmmnt}")
def align_with_delay(client,board_id,chan1,chan2,delay=0):
 """ Align 2 BSYNC with certain delay """
 client.SetIntParameter("TDC_SOURCE", f"{chan1}", "-1")
 client.SetIntParameter("TDC_TARGET", f"{chan2}", "-1")
 client.SetIntParameter("virtual-parameter-delay-adjust-value", f"{int(delay)}", "-1")
 client.Run("@AutoAlignDelayAdjust")
 time.sleep(0.5)
 result_str = f"Board{board_id}.BSYNC{chan1}-BSYNC{chan2}"
 print("Pin Alignment: {} = {:0.3f} ps".format(result_str, result))
 print("Alignment Result: {} = {:0.3f} ps".format(result_str,(delay+result)))
def set_channel(client,board_id,channel,tx_drive):
 """ Power up and Set Drive of Channel """
 client.SetIntParameter(f"PD_TX_PATH{channel}", "0", "-1")
 client.SetIntParameter(f"EN_DRV{channel}", f"{tx_drive}", "-1")
 time.sleep(0.5)
def align_2_ADF4030(client,board_id_1,channel_1_to_2,board_id_2,channel_osc):
 """2 ADF4030 PIN Alignment"""
 set_channel(client,board_id=board_id_1,channel=channel_1_to_2,tx_drive=1)
 set_channel(client,board_id=board_id_2,channel=channel_1_to_2,tx_drive=0)
 set_direction(client, source_board=board_id_1, chan1=channel_1_to_2, target_board=board_id_2, chan2=channel_1_to_2)
 tdc_1_1 = tdc_meas(client,board_id=board_id_1,tdc_source=channel_osc,tdc_target=channel_1_to_2)
 tdc_1_2 = tdc_meas(client,board_id=board_id_2,tdc_source=channel_1_to_2,tdc_target=channel_osc)
 set_direction(client, source_board=board_id_2, chan1=channel_1_to_2, target_board=board_id_1, chan2=channel_1_to_2)
 tdc_2_2 = tdc_meas(client,board_id=board_id_2,tdc_source=channel_1_to_2,tdc_target=channel_osc)
 tdc_2_1 = tdc_meas(client,board_id=board_id_1,tdc_source=channel_osc,tdc_target=channel_1_to_2)
 bsync_freq = float(client.GetDecimalParameter(fr"virtual-parameter-bsync-frequency-{channel_osc}"))
 bsync_t = 10 ** 12 / bsync_freq # BSYNC period in picoseconds
 path_delay_ps = (((tdc_1_1 + tdc_1_2 - tdc_2_1 - tdc_2_2)+bsync_t) % bsync_t)/2
 path_delay_ps_t = "{:.3f}".format(path_delay_ps)
 print(f"Cable Delay = {path_delay_ps_t} ps",)
 align_with_delay(client,board_id=board_id_1,chan1=channel_osc,chan2=channel_1_to_2,delay=-path_delay_ps)
 align_with_delay(client,board_id=board_id_2,chan1=channel_1_to_2,chan2=channel_osc,delay=0)
def ADF4030Demo(client):
 client.ContextPath = "\System\Subsystem_1\ADF4030 Board\ADF4030"
 ref_in = 100e6
 bsync_out = 100e6
 channel_ADF4030_1_to_2 = 4
 channel_ADF4030_1_to_3 = 6
 channel_ADF4030_to_Osc = 2
 EVB1_ADDR = 0
 EVB2_ADDR = 1
 EVB3_ADDR = 2
 adf4030_init(client,board_id=EVB1_ADDR,tx_channel=channel_ADF4030_to_Osc,ref_in=ref_in,bsync_out=bsync_out)
 adf4030_init(client,board_id=EVB2_ADDR,tx_channel=channel_ADF4030_to_Osc,ref_in=ref_in,bsync_out=bsync_out)
 adf4030_init(client,board_id=EVB3_ADDR,tx_channel=channel_ADF4030_to_Osc,ref_in=ref_in,bsync_out=bsync_out)
 align_2_ADF4030(client=client,board_id_1=EVB1_ADDR,channel_1_to_2=channel_ADF4030_1_to_2,board_id_2=EVB2_ADDR,channel_osc=channel_ADF4030_to_Osc)
 align_2_ADF4030(client=client,board_id_1=EVB1_ADDR,channel_1_to_2=channel_ADF4030_1_to_3,board_id_2=EVB3_ADDR,channel_osc=channel_ADF4030_to_Osc)
if __name__ == "__main__":
 main()" />
<Script Name="2_ADF4030_DEMO_cascaded.py" FilePath="file:///C:/Users/pminciu/AppData/Local/Analog Devices/ACE/Scripts/2_ADF4030_DEMO_cascaded.py" ScriptTypeId="Python3" ScriptLanguage="Python" Lines="# Generated code compatible with Python 2.7+
# Requirements:
# - pythonnet
import sys
import time
import clr # noqa
def main():
 ADF4030Demo(client)
 o_div = 1
 vco_freq = 2.5e9
 else:
 vco_min = 2.375e9
 vco_max = 2.625e9
 vco_freq = 0
 break
 pfd_min = 10e6
 pfd_max = 20e6
 pfd_freq = 0
 r_div = 1
 break
 n_div_min = 0
 n_div_max = 256
 time.sleep(0.5)
 time.sleep(0.5)
 time.sleep(0.5)
 time.sleep(0.5)
 time.sleep(0.5)
 time.sleep(0.5)
 return result
 time.sleep(0.5)
 time.sleep(0.5)
 time.sleep(0.5)
 time.sleep(0.5)
 ref_in = 100e6
 bsync_out = 100e6
 channel_ADF4030_1_to_2 = 6
 EVB1_ADDR = 0
 EVB2_ADDR = 1
 main()" />
</Scripts>
</ScriptManager>
</Element>
<Element Id="EvalSystem">
<System xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Name="System" xmlns="AnalogDevices/Csa/Evaluation/Sessions/EvalSystemSessionElement.Schema.xsd">
<Subsystems>
<Subsystem Name="Subsystem_1">
<Components>
<Component ComponentId="AD9576Board" Name="AD9576 Board">
<Info Name="AD9576 Board" Description="AD9576 Evaluation Board" />
<SavedState>
<Board Id="AD9576Board" Version="1.1.0" xmlns="">
<Parameter Id="fx2-port-a-pins" Value="7" Type="System.Numerics.BigInteger" />
<Parameter Id="pa_usb_status-direction-fx2-port-a-pins" Value="true" Type="System.Boolean" />
<Parameter Id="pa_usb_status-data-fx2-port-a-pins" Value="true" Type="System.Boolean" />
<Parameter Id="pa_csb-direction-fx2-port-a-pins" Value="true" Type="System.Boolean" />
<Parameter Id="pa_csb-data-fx2-port-a-pins" Value="true" Type="System.Boolean" />
<Parameter Id="pa_resetb-direction-fx2-port-a-pins" Value="true" Type="System.Boolean" />
<Parameter Id="pa_resetb-data-fx2-port-a-pins" Value="true" Type="System.Boolean" />
<Parameter Id="pa_gpio_3-direction-fx2-port-a-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pa_gpio_3-data-fx2-port-a-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pa_gpio_4-direction-fx2-port-a-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pa_gpio_4-data-fx2-port-a-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pa_gpio_5-direction-fx2-port-a-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pa_gpio_5-data-fx2-port-a-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pa_gpio_6-direction-fx2-port-a-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pa_gpio_6-data-fx2-port-a-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pa_gpio_7-direction-fx2-port-a-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pa_gpio_7-data-fx2-port-a-pins" Value="false" Type="System.Boolean" />
<Parameter Id="fx2-port-b-pins" Value="0" Type="System.Numerics.BigInteger" />
<Parameter Id="pb_sdio-direction-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pb_sdio-data-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pb_sp_sel0-direction-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pb_sp_sel0-data-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pb_sp_sel1-direction-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pb_sp_sel1-data-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pb_ld_pll0-direction-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pb_ld_pll0-data-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pb_ld_pll1-direction-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pb_ld_pll1-data-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pb_gpio_5-direction-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pb_gpio_5-data-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pb_gpio_6-direction-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pb_gpio_6-data-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pb_ref_sw-direction-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pb_ref_sw-data-fx2-port-b-pins" Value="false" Type="System.Boolean" />
<Parameter Id="fx2-port-c-pins" Value="0" Type="System.Numerics.BigInteger" />
<Parameter Id="pc_gpio_0-direction-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pc_gpio_0-data-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pc_gpio_1-direction-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pc_gpio_1-data-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pc_gpio_2-direction-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pc_gpio_2-data-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pc_gpio_3-direction-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pc_gpio_3-data-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pc_gpio_4-direction-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pc_gpio_4-data-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pc_gpio_5-direction-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pc_gpio_5-data-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pc_gpio_6-direction-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pc_gpio_6-data-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pc_gpio_7-direction-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pc_gpio_7-data-fx2-port-c-pins" Value="false" Type="System.Boolean" />
<Parameter Id="fx2-port-d-pins" Value="0" Type="System.Numerics.BigInteger" />
<Parameter Id="pd_ref_status-direction-fx2-port-d-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pd_ref_status-data-fx2-port-d-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pd_ref_act-direction-fx2-port-d-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pd_ref_act-data-fx2-port-d-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pd_gpio_2-direction-fx2-port-d-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pd_gpio_2-data-fx2-port-d-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pd_ref_sel-direction-fx2-port-d-pins" Value="true" Type="System.Boolean" />
<Parameter Id="pd_ref_sel-data-fx2-port-d-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pd_xo2_en-direction-fx2-port-d-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pd_xo2_en-data-fx2-port-d-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pd_xo0_en-direction-fx2-port-d-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pd_xo0_en-data-fx2-port-d-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pd_xo1_en-direction-fx2-port-d-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pd_xo1_en-data-fx2-port-d-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pd_gpio_7-direction-fx2-port-d-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pd_gpio_7-data-fx2-port-d-pins" Value="false" Type="System.Boolean" />
<Parameter Id="fx2-port-e-pins" Value="0" Type="System.Numerics.BigInteger" />
<Parameter Id="pe_gpio_0-direction-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pe_gpio_0-data-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pe_gpio_1-direction-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pe_gpio_1-data-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pe_gpio_2-direction-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pe_gpio_2-data-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pe_gpio_3-direction-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pe_gpio_3-data-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pe_gpio_4-direction-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pe_gpio_4-data-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pe_gpio_5-direction-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pe_gpio_5-data-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pe_gpio_6-direction-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pe_gpio_6-data-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pe_gpio_7-direction-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="pe_gpio_7-data-fx2-port-e-pins" Value="false" Type="System.Boolean" />
<Parameter Id="virtual-parameter-wasdeserialized" Value="true" Type="System.Boolean" />
<Chips>
<Chip Id="Chip.AD9576.AD9576" InstanceName="AD9576" Version="1.1.0">
<Parameter Id="ad9576-pins" Value="1" Type="System.Numerics.BigInteger" />
<Parameter Id="resetb-direction-ad9576-pins" Value="false" Type="System.Boolean" />
<Parameter Id="resetb-data-ad9576-pins" Value="true" Type="System.Boolean" />
<Parameter Id="ref_sel-direction-ad9576-pins" Value="false" Type="System.Boolean" />
<Parameter Id="ref_sel-data-ad9576-pins" Value="false" Type="System.Boolean" />
<Parameter Id="ref_act-direction-ad9576-pins" Value="true" Type="System.Boolean" />
<Parameter Id="ref_act-data-ad9576-pins" Value="false" Type="System.Boolean" />
<Parameter Id="ref_sw-direction-ad9576-pins" Value="true" Type="System.Boolean" />
<Parameter Id="ref_sw-data-ad9576-pins" Value="false" Type="System.Boolean" />
<Parameter Id="ref_status-direction-ad9576-pins" Value="true" Type="System.Boolean" />
<Parameter Id="ref_status-data-ad9576-pins" Value="false" Type="System.Boolean" />
<Parameter Id="sp_sel0-direction-ad9576-pins" Value="true" Type="System.Boolean" />
<Parameter Id="sp_sel0-data-ad9576-pins" Value="false" Type="System.Boolean" />
<Parameter Id="sp_sel1-direction-ad9576-pins" Value="true" Type="System.Boolean" />
<Parameter Id="sp_sel1-data-ad9576-pins" Value="false" Type="System.Boolean" />
<Parameter Id="ld_pll0-direction-ad9576-pins" Value="true" Type="System.Boolean" />
<Parameter Id="ld_pll0-data-ad9576-pins" Value="false" Type="System.Boolean" />
<Parameter Id="ld_pll1-direction-ad9576-pins" Value="true" Type="System.Boolean" />
<Parameter Id="ld_pll1-data-ad9576-pins" Value="false" Type="System.Boolean" />
<Parameter Id="virtual-parameter-Fvco" Value="2619040000.000" Type="System.Decimal" />
<Parameter Id="virtual-parameter-Fin_pfd" Value="20000000" Type="System.Decimal" />
<Parameter Id="virtual-parameter-Fout_VCO1" Value="785712000.000" Type="System.Decimal" />
<Parameter Id="virtual-parameter-PFD1_Fin" Value="32738000.000" Type="System.Decimal" />
<Parameter Id="virtual-parameter-Fref_sel" Value="10000000" Type="System.Decimal" />
<Parameter Id="virtual-parameter-FracNValue" Value="130.952" Type="System.Decimal" />
<Parameter Id="virtual-parameter-N0 SDM Active" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-SDM_Mod" Value="1000" Type="System.Numerics.BigInteger" />
<Parameter Id="virtual-parameter-SDM_Frac" Value="952" Type="System.Numerics.BigInteger" />
<Parameter Id="virtual-parameter-N0_SDM_PowerDown" Value="0" Type="System.Int32" />
<Parameter Id="virtual-parameter-N0LoopMode" Value="0" Type="System.Int32" />
<Parameter Id="virtual-parameter-Out10_Clk_Sel" Value="1" Type="System.Byte" />
<Parameter Id="virtual-parameter-PLL1_PD" Value="false" Type="System.Boolean" />
<Parameter Id="virtual-parameter-ActiveRef" Value="0" Type="System.Int32" />
<Parameter Id="virtual-parameter-REF_SEL_Pin" Value="0" Type="System.Int32" />
<Parameter Id="virtual-parameter-PLL0_FBDiv_Value" Value="130.952" Type="System.Decimal" />
<Parameter Id="virtual-parameter-R0Div" Value="1" Type="System.Byte" />
<Parameter Id="virtual-parameter-FRef0" Value="10000000" Type="System.Decimal" />
<Parameter Id="virtual-parameter-FRef1" Value="10000000" Type="System.Decimal" />
<Parameter Id="virtual-parameter-FRef2" Value="16369000.000" Type="System.Decimal" />
<Parameter Id="virtual-parameter-R1_Div" Value="1" Type="System.Int32" />
<Parameter Id="virtual-parameter-R1Div_Enable" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-Q3_Clock_Select" Value="0" Type="System.Byte" />
<Parameter Id="virtual-parameter-Out89_Clock_Select" Value="0" Type="System.Byte" />
<Parameter Id="virtual-parameter-N0a_Div_Ratio" Value="0" Type="System.Numerics.BigInteger" />
<Parameter Id="virtual-parameter-PLL0_REF_STAT_MNA" Value="0" Type="System.Int32" />
<Parameter Id="virtual-parameter-REF0_Present" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-REF1_Present" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-REF2_Present" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-OUT0_DIFF_MODE" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-OUT1_DIFF_MODE" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-OUT2_DIFF_MODE" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-OUT3_DIFF_MODE" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-OUT4_DIFF_MODE" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-OUT5_DIFF_MODE" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-OUT6_DIFF_MODE" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-OUT7_DIFF_MODE" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-OUT8_DIFF_MODE" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-OUT9_DIFF_MODE" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-OUT10_DIFF_MODE" Value="true" Type="System.Boolean" />
<Parameter Id="virtual-parameter-Chip_Power_Down" Value="false" Type="System.Boolean" />
<Parameter Id="virtual-parameter-RefSelMode" Value="0" Type="System.Int32" />
<Parameter Id="virtual-parameter-PLL1_Enable2X" Value="1" Type="System.Int32" />
<RegisterMap UniqueId="0.Serial_Port_Configuration" Address="0" Count="16">
<Register Address="0" Value="24" />
<Register Address="1" Value="0" />
<Register Address="2" Value="0" />
<Register Address="3" Value="5" />
<Register Address="4" Value="4F" />
<Register Address="5" Value="1" />
<Register Address="6" Value="11" />
<Register Address="7" Value="0" />
<Register Address="8" Value="0" />
<Register Address="9" Value="0" />
<Register Address="A" Value="0" />
<Register Address="B" Value="0" />
<Register Address="C" Value="56" />
<Register Address="D" Value="4" />
<Register Address="E" Value="0" />
<Register Address="F" Value="1" />
</RegisterMap>
<RegisterMap UniqueId="20.Status" Address="20" Count="2">
<Register Address="20" Value="0" />
<Register Address="21" Value="0" />
</RegisterMap>
<RegisterMap UniqueId="40.Chip_Mode" Address="40" Count="1">
<Register Address="40" Value="1" />
</RegisterMap>
<RegisterMap UniqueId="80.Receiver_Monitor" Address="80" Count="4">
<Register Address="80" Value="11" />
<Register Address="81" Value="0" />
<Register Address="82" Value="0" />
<Register Address="83" Value="0" />
</RegisterMap>
<RegisterMap UniqueId="100.PLL0" Address="100" Count="17">
<Register Address="100" Value="0" />
<Register Address="101" Value="08" />
<Register Address="102" Value="08D" />
<Register Address="103" Value="0E0" />
<Register Address="104" Value="0" />
<Register Address="105" Value="1" />
<Register Address="107" Value="082" />
<Register Address="108" Value="0B8" />
<Register Address="109" Value="3" />
<Register Address="10A" Value="0" />
<Register Address="10B" Value="0E8" />
<Register Address="10C" Value="3" />
<Register Address="10D" Value="0" />
<Register Address="10E" Value="0" />
<Register Address="10F" Value="0" />
<Register Address="110" Value="0" />
<Register Address="111" Value="0" />
</RegisterMap>
<RegisterMap UniqueId="120.VCO_Dividers" Address="120" Count="3">
<Register Address="120" Value="20" />
<Register Address="121" Value="44" />
<Register Address="122" Value="0" />
</RegisterMap>
<RegisterMap UniqueId="140.PLL0_Distribution" Address="140" Count="14">
<Register Address="140" Value="27" />
<Register Address="141" Value="0" />
<Register Address="142" Value="0" />
<Register Address="143" Value="0" />
<Register Address="144" Value="0" />
<Register Address="145" Value="0" />
<Register Address="146" Value="27" />
<Register Address="147" Value="0" />
<Register Address="148" Value="0" />
<Register Address="149" Value="0" />
<Register Address="14A" Value="27" />
<Register Address="14B" Value="0" />
<Register Address="14C" Value="0" />
<Register Address="14D" Value="0" />
</RegisterMap>
<RegisterMap UniqueId="200.PLL1" Address="200" Count="3">
<Register Address="200" Value="0" />
<Register Address="201" Value="18" />
<Register Address="202" Value="3" />
</RegisterMap>
<RegisterMap UniqueId="240.PLL1_Distribution" Address="240" Count="7">
<Register Address="240" Value="0A7" />
<Register Address="241" Value="40" />
<Register Address="242" Value="0C1" />
<Register Address="243" Value="0C1" />
<Register Address="244" Value="0AF" />
<Register Address="245" Value="080" />
<Register Address="246" Value="0C1" />
</RegisterMap>
<Children />
</Chip>
</Chips>
<StateControls AllowStatePolling="true" />
</Board>
</SavedState>
</Component>
</Components>
<Connections />
</Subsystem>
</Subsystems>
</System>
</Element>
<Element Id="Controllers">
<Controller Name="AD9576 Board" HardwareID="Virtual&4BEE9BF79FE3" Path="Root::System.Subsystem_1.AD9576 Board" xmlns="" />
</Element>
<Element Id="Macros">
<MacroManager xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="AnalogDevices/Csa/Evaluation/UI/Models/Sessions/MacroManagerSessionElement.Schema.xsd">
<Macros />
</MacroManager>
</Element>
<Element Id="Views" ActiveWorkspaceElement="Root::System.Subsystem_1.AD9576 Board.AD9576" WorkspaceElements="Root::,Root::System,Root::System.Subsystem_1.AD9576 Board,Root::System.Subsystem_1.AD9576 Board.AD9576" />
<Element Id="VectorGenerator">
<VectorGenerator xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Name="VectorGenerator" xmlns="AnalogDevices/Csa/VectorGenerator/Sessions/VectorGeneratorSessionElement.Schema.xsd">
<Vectors />
</VectorGenerator>
</Element>
</Elements>
</Session>
Take out txt extension before loading it into the AD9576 eval software.
Petre
