ADF4030 SPI Interface
The user questions the accuracy of the ADF4030 Rev. 0 data sheet figures, suggesting corrections to t_ACCESS timing from the falling edge of SCLK and SCLK levels during CS edges. The final answer states that the current diagrams reflect the measurement conditions, but the accompanying answers suggest the figures are misleading and should be updated for clarity, similar to the ADF4371.
Category: Datasheet/Specs
Product Number: ADF4030
Shouldn't ADF4030 Rev. 0 data sheet, Figs. 2-4 be corrected to show tACCESS values from the falling edge of SCLK at the end of A0 rather than the beginning?
Shouldn't the SCLK levels be don't-care values during the CS edges rather than logic high as illustrated?
- The CS Falling Edge to SCLK Rise Setup Time (tS) is smaller than the SCLK Pulse Low (tLOW) minimum.
I would LOVE to see this diagram updated to be more like the ADF4371, for instance, unless these are different in a way that I need to accommodate.
    "Shouldn't ADF4030 Rev. 0 data sheet, Figs. 2-4 be corrected to show tACCESS values from the falling edge of SCLK at the end of A0 rather than the beginning?"
    the ADF4030 data sheet gives t_ACCESS_SDIO and t_ACCESS_SDO min values of 6ns measured from the falling edge of SCLK to SDIO and respectively to SDO becoming valid. This is what the test engineers measured to come up with the specification entry.
    The reason for this I believe is the fact that for the ADF4030:
    1. the controller has to put the A0 bit on the SDIO line on falling edge of SCLK,
    2. the ADF4030 reads the A0 bit on the rising edge of SCLK
    3. then the ADF4030 puts the D7 bit on SDIO line or SDO line on the rising edge of SCLK, so the controller reads it on the falling edge of SCLK.
    4. So  t_ACCESS_SDIO and t_ACCESS_SDO timings state that the ADF4030 puts D7 bit on SDIO and respectively on SDO line after min 6ns. I'll take an action item to confirm with the test engineer this is the timing they measured.
    "Shouldn't the SCLK levels be don't-care values during the CS edges rather than logic high as illustrated?"
    The ADF4030 figures 2-4 have SCLK levels as don't care when CSB line is high. When the CSB goes low, the SCLK should have a falling edge because this is the edge the controller needs to put bits on the SDIO line. I saw implementations in which people did not generate this edge, but they still set the R/WB bit earlier than the rising SCLK edge, so the ADF4030 can get the value on the first rising edge of SCLK. This is why we have the t_DS timing in the specification.
    "The CS Falling Edge to SCLK Rise Setup Time (tS) is smaller than the SCLK Pulse Low (tLOW) minimum."
    Basically this speaks about the case in which the first SCLK falling edge does not exist. Then the controller must be sure to generate the first rising edge of the SCLK at least 2ns after CSB went low.
    Petre
  • Item 1, the timing as described by you is what I expect.  That isn't what the diagram shows.
    Item 2, The controller generates the SCLK so the falling edge - real or virtual - often happens before the CS as you've observed.
    Item 3 agrees with your observation that the interfaces work as long as the data is valid tDS before the rising edge.
    Bottom line: the figures are misleading and should be cleaned up to be more like other compatible ADI parts that are clearer.
  • HI,
    sorry for getting back to you so late.
    I noted your feedback and I continue not to understand why you are asking for the diagrams to be changed if t_ACCESS_SDIO and t_ACCESS_SDO shown on the diagram replicate the measurement conditions.
    Petre
