We are currently using the HMC7043 evaluation board (EK1HMC7043LP7F) along with the configuration GUI.
While the GUI provides options to generate both pulsed and continuous SYSREF signals, we couldn’t find a way to configure individual output channels to function specifically as CLK or SYSREF, or to select between pulsed and continuous SYSREF modes on a per-channel basis.
Could you please confirm:
Is it possible to configure each output channel individually as CLK, pulsed SYSREF, or continuous SYSREF? If so, how can this be done using the GUI?
When the Pulser Mode is enabled, which of the seven SCLKOUT channels will output the SYSREF signal? Will it appear on all channels, or just one? If it appears on all, how can we restrict it to a single specific channel?
Thank you
