I've configured AD9546 Eval Board using configuration program running on PC.
Here you can see config file in the attachments.
As you know there are two output channels and I configured them 1Hz single ended dual divider. (Ref clock is 10MHz connected to RefA)
But now, when I scope two signals one from Channel 0 while other one from Channel 1 and there is a phase offset.
How can I syncronize these two?
Thanks in advance,
Sincerely,
