Noise floor is very high in the AD9523-1 clock output
Product Number: AD9523-1
"AD9523 Regmap File"
"Rev.","1.0"
"Addr(Hex)","Value(Bin)","Value(Hex)"
"0000","10000001","81"
"0002","00000000","00"
"0003","00000000","00"
"0004","00000000","00"
"0005","00000000","00"
"0006","00000000","00"
"0010","00101000","28"
"0011","00000000","00"
"0012","00101000","28"
"0013","00000000","00"
"0014","00000001","01"
"0015","00000000","00"
"0016","00101000","28"
"0017","00000000","00"
"0018","00001100","0C"
"0019","00011111","1F"
"001A","00011010","1A"
"001B","00010111","17"
"001C","10010000","90"
"001D","00000000","00"
"001E","00000000","00"
"001F","00000000","00"
"0020","00000000","00"
"00F0","00000111","07"
"00F1","10000111","87"
"00F2","00010011","13"
"00F3","00000010","02"
"00F4","01000000","40"
"00F5","00000000","00"
"00F6","00000000","00"
"00F7","00000001","01"
"00F8","00000000","00"
"00F9","00000000","00"
"00FA","00000000","00"
"0190","01110011","73"
"0191","00001001","09"
"0192","00000100","04"
"0193","00100000","20"
"0194","00011111","1F"
"0195","00000100","04"
"0196","01101000","68"
"0197","01100011","63"
"0198","00000000","00"
"0199","01001001","49"
"019A","00001001","09"
"019B","00000000","00"
"019C","01001001","49"
"019D","00001001","09"
"019E","00000000","00"
"019F","01001001","49"
"01A0","00001001","09"
"01A1","00000000","00"
"01A2","01001001","49"
"01A3","00001001","09"
"01A4","00000100","04"
"01A5","01001001","49"
"01A6","01100011","63"
"01A7","00000000","00"
"01A8","01001001","49"
"01A9","01100011","63"
"01AA","00000000","00"
"01AB","01001001","49"
"01AC","01100011","63"
"01AD","00000000","00"
"01AE","01001001","49"
"01AF","01100011","63"
"01B0","00000000","00"
"01B1","01001001","49"
"01B2","01100011","63"
"01B3","00000000","00"
"01B4","01001001","49"
"01B5","00001001","09"
"01B6","00000000","00"
"01B7","01010011","53"
"01B8","00001001","09"
"01B9","00000000","00"
"01BA","00000000","00"
"01BB","00000000","00"
"022C","00000000","00"
"022D","00000000","00"
"022E","00000000","00"
"022F","00000000","00"
"0230","00000000","00"
"0231","00000001","01"
"0232","00001101","0D"
"0233","00000000","00"
"0234","00000001","01"
"0A00","00000000","00"
"0A01","00000000","00"
"0A02","00000000","00"
"0A03","00000010","02"
"0A04","00000000","00"
"0A05","00000100","04"
"0A06","00001110","0E"
"0A07","00000000","00"
"0A08","00010000","10"
"0A09","00001110","0E"
"0A0A","00000000","00"
"0A0B","11110000","F0"
"0A0C","00101011","2B"
"0A0D","00000001","01"
"0A0E","10010000","90"
"0A0F","00000001","01"
"0A10","00000001","01"
"0A11","11100000","E0"
"0A12","00000011","03"
"0A13","00000010","02"
"0A14","00110000","30"
"0A15","10000000","80"
"0A16","11111111","FF"
"0B00","00000000","00"
"0B01","00000000","00"
"0B02","00000000","00"
"0B03","00000000","00"
attached text file is what I configured to AD9523-1. REF A,REF B are of 100MHz. and I'm feeding REF B from the signal generator 100MHz clock with 6dBm input power. I took the screenshot of 100MHz clock output from the AD9523-1 and here I'm attaching that. noise floor at 100MHz has lifted very highly. How to reduce the noise floor.
for your reference I'm attaching the schematic also.  . I'm also attaching the screenshot of 100MHz clock, how we require.
please help us to make the AD9523-1 clock like this.
Parents
  • also a small help, can you please send the screenshot of AD9523-1's eval board 100 MHz clock out.
    I looked at the stp file you sent. The schematic shows REFA as being a differential LVDS, AC coupled. In the stp file,  REFA is not enabled as differential, but as single ended on REFA negative. Why?
    REFB is enabled as single ended on negative pin.
    You say you used REFB as reference. Please send me a scope capture of it.
    The zero delay differential mode is enabled and on the board the OUT0 to ZD_IN is AC coupled. But in the stp file, OUT0 is off. So how is the AD9523-1 is supposed to work?
    Did PLL1 and PLL2 lock?
    I cannot test your configuration in the lab because I do not have a 100MHz VCXO. I'll make a note to get some measurements on an eval board with the signal analyzer and the phase noise analyzer and get back to you.
    I recommend looking at the figures 11 and 12 in the data sheet, page 18 to see how the outputs should look.
    Petre
  • Hi again,
    I created a configuration in ADIsimCLK that takes an ideal 100MHz clock reference and it passes it through the AD9523-1. I then used the Crystek CVHD-950 of 100MHz. I then set up several 100MHz outputs, each with a different driver: LVPECL, LVDS, CMOS, HSTL. The tool provides the expected phase noise for each of these choices. If you had a phase noise analyzer, we could compare your results against these.
    I attach the report:
    AD9523_1_setup.clk analysed at Wed Jan 29 16:31:23 2025
    Clock Chip is AD9523-1
    VCO is AD9523-1
    Reference is custom
    PLL1 Loop Filter specified by: Phase Margin
    	Design Objective:  Loop Bandwidth: 30.0 Hz   Phase Margin: 75.0 deg
    	Simulation Result: Loop Bandwidth: 31.04 Hz   Phase Margin:  82.9 deg
    PLL2 Loop Filter specified by: Phase Margin
    	Design Objective:  Loop Bandwidth:  450kHz   Phase Margin: 75.0 deg
    	Simulation Result: Loop Bandwidth: 445.8kHz   Phase Margin:  74.5 deg
    Power Dissipation Estimate
    Core			 325mW
    Ref single		4.0mW
    OUT0			48.6mW
    OUT1			30.4mW
    OUT2			35.9mW
    OUT3			57.8mW
    OUT4			92.1mW
    OUT5			92.1mW
    OUT6			92.1mW
    OUT7			92.1mW
    OUT8			92.1mW
    OUT9			92.1mW
    OUT10			92.1mW
    OUT11			92.1mW
    OUT12			92.1mW
    OUT13			92.1mW
    PLL1_OUT		24.4mW
    Total Power		1.45 W
    OUT0:
      Frequency: 100.000MHz
      Broadband Jitter (>1kHz) =  212fs rms
        SNR =  77.52dB  ENOB =  12.92bits
          at IF Freq =  100MHz
      SONET OC-1 Jitter =  110fs rms
      Integrated Phase Noise from  100kHz to 1.25MHz
        Timing Jitter = 98.4fs rms
        Phase Jitter EVM = 0.0062 %rms
        Phase Jitter =   0.004 degrees rms
        ACI / ACR =  -87.2dBc
      Delay from Ref to OUT0 is 0s
    OUT1:
          at IF Freq =  100MHz
      Delay from Ref to OUT1 is 0s
    OUT2:
          at IF Freq =  100MHz
      Delay from Ref to OUT2 is 0s
    OUT3:
          at IF Freq =  100MHz
      Delay from Ref to OUT3 is 0s
    OUT4:
      Frequency: 500.000MHz
      Broadband Jitter (>1kHz) =  218fs rms
        SNR =  77.28dB  ENOB =  12.88bits
          at IF Freq =  100MHz
        Timing Jitter = 96.2fs rms
        Phase Jitter EVM =   0.03 %rms
        Phase Jitter =   0.017 degrees rms
        ACI / ACR =  -73.4dBc
      Delay from Ref to OUT4 is 0s
    OUT5:
          at IF Freq =  100MHz
      Delay from Ref to OUT5 is 0s
    OUT6:
          at IF Freq =  100MHz
      Delay from Ref to OUT6 is 0s
    OUT7:
          at IF Freq =  100MHz
      Delay from Ref to OUT7 is 0s
    OUT8:
          at IF Freq =  100MHz
      Delay from Ref to OUT8 is 0s
    OUT9:
          at IF Freq =  100MHz
      Delay from Ref to OUT9 is 0s
    OUT10:
          at IF Freq =  100MHz
      Delay from Ref to OUT10 is 0s
    OUT11:
          at IF Freq =  100MHz
      Delay from Ref to OUT11 is 0s
    OUT12:
          at IF Freq =  100MHz
      Delay from Ref to OUT12 is 0s
    OUT13:
          at IF Freq =  100MHz
      Delay from Ref to OUT13 is 0s
    PLL1_OUT:
      Frequency: 50.0000MHz
      Broadband Jitter (>1kHz) =  180fs rms
        SNR =  78.94dB  ENOB =  13.16bits
          at IF Freq =  100MHz
        Timing Jitter = 39.0fs rms
        Phase Jitter EVM = 0.0012 %rms
        Phase Jitter = 0.00070 degrees rms
        ACI / ACR = -101.3dBc
      Delay from Ref to PLL1_OUT is 0s
    Frequency Domain Analysis of PLL2
      Analysis at PLL output frequency of 3.00GHz
    Phase Noise Table
    Freq	Total	VCO	Ref	Chip	Filter
     100 	-76.92 	-149.1 	-77.61 	-85.25 	-180.2
    1.00k	-93.45 	-135.1 	-101.3 	-94.23 	-160.2
    10.0k	-105.8 	-121.3 	-125.4 	-106.0 	-140.4
     100k	-111.5 	-115.7 	-129.8 	-113.9 	-126.9
    1.00M	-124.4 	-132.3 	-139.2 	-126.1 	-133.4
           ----    End of Frequency Domain Results   ----
    Transient Analysis of PLL2
      Power up transient to frequency of 3.00GHz
      Simulation run for  349us
    Frequency Locking
      Time to lock to 1.00kHz is  330us
      Time to lock to 10.0 Hz is  344us
    Phase Locking (VCO Output Phase)
      Time to lock to 10.0 deg is  324us
      Time to lock to 1.00 deg is  330us
    Lock Detect Threshold
      Lock Detect output did not pass 2.50 V
           ----    End of Time Domain Results   ----
           ----    Summary of Settings   ----
    Reference	custom
       Frequency	 100MHz
       Phase Noise	None
    PLL1
       Design Freq	 100MHz
       VCO	CVHD-950
          Tuning Law	Datasheet Kv
             Kv	1.21kHz/V
             V1	0V
             F1	99.998MHz
             V2	3.30 V
             F2	100.002MHz
          Input Cap. (Ct)	0F
          Phase Noise	Table
             PN Floor	-162 dBc/Hz
       Dividers
          R1	1
          N1	1
       Phase Detector	 100MHz
          Icp	16.0uA
          V max	3.30V
          V min	0V
          ABP Pulse	0s
          PN Floor	-219dBc/Hz
       Loop Filter	AD952x LF
          Specify:	Phase Margin
          Loop Bandwidth	30.0 Hz
          Phase Margin	75.0 deg
          Zero Loc.	3.38 Hz
          Pole Loc.	 266 Hz
          Last Pole Loc.	 799 Hz
          Cpole1	1.50nF
          Rzero	10.0k
          Cext	4.70uF
          Rpole2	 165k
          Cpole2	 337pF
          Rext	0
       FreqDomain
          Min Freq	1.00 Hz
          Max Freq	1.00MHz
          Pts per Decade	10
          Analysis at	 100MHz
    PLL2
       PLL Setup
          Min Freq	3.00GHz
          Max Freq	3.00GHz
          PD Freq.	 200MHz
             Ref Divider	1
             Ref Doubler	enabled
          Design Freq	3.00GHz
       VCO	AD9523-1
          Tuning Law	Multiband
          Phase Noise	Table
             PN Floor	-173 dBc/Hz
       Chip - PLL	AD9523-1
          Main Divider
             Prescaler P	4
             Min ctgs div.	Not Used
             Counter Bits	13
             Min value	1
             Max Freq.	3.10GHz
             Max PS Out Freq	Not Used
             Min Freq.	2.93GHz
          Ref Divider
             Counter Bits	10
             Min value	0.500
             Max Freq.	 400MHz
             Min Freq.	0Hz
          Phase Detector	Charge Pump
             CP Current	 515uA
             Polarity	positive
             Leakage	0A
             AB Pulse	Not Used
             Vsupply	3.30 V
             Vmin	0V
             Vmax	3.30 V
             Max Freq.	 250MHz
             PN Floor	-226 dBc/Hz
          Lock Detect	None
          Loop Bandwidth	 450kHz
          Zero Loc.	50.7kHz
          Pole Loc.	4.00MHz
          Last Pole Loc.	12.0MHz
          Cpole1	8.00pF
          Rzero	1.85k
          Cext	1.80nF
          Rpole2	 900
          Cpole2	16.0pF
          Rext	0
       TimeDomain
          Type	Power On
          Frequency	3.00GHz
          Stop Time	 349us
          Max Time Step	 250ps
          VCO Autocal.	enable
    Clock Dist.
       VCO Freq	3.00GHz
       M1 Div Output	1.00GHz
          M1 Div	3
       M2 Div Output	1.00GHz
          M2 Div	3
       OUT0	OUT0
          Frequency	 100MHz
          Divider
             div N	10
             Phase Offset	0
          Duty Cycle Corr.	Enable
          Output	LVPECL
             Voltage Swing	 780mV
             Termination	Option 1
             Max Frequency	1.00GHz
       OUT1	OUT1
          Frequency	 100MHz
          Divider
             div N	10
             Phase Offset	0
          Output	LVDS
             Output Current	3.50mA
       OUT2	OUT2
          Frequency	 100MHz
          Divider
             div N	10
             Phase Offset	0
          Output	CMOS
             Max Frequency	 250MHz
       OUT3	OUT3
          Frequency	 100MHz
          Divider
             div N	10
             Phase Offset	0
          Output	HSTL
             Output Current	8.00mA
       OUT4	OUT4
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT5	OUT5
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT6	OUT6
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT7	OUT7
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT8	OUT8
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT9	OUT9
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT10	OUT10
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT11	OUT11
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT12	OUT12
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT13	OUT13
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       PLL1_OUT	PLL1_OUT
          Frequency	50.0MHz
          Divider
             div N	2
          Output	CMOS
    Timing An.
       Start Time	-1.00ns
       Stop Time	50.0ns
    FreqDomain
       Min Freq	1.00kHz
       Max Freq	 100MHz
       Pts per Decade	10
       Analysis at	3.00GHz
    This is the phase noise you should obtain for a LVPECL 100MHz output:
    This is for 100MHz LVDS:
    This is for 100MHz CMOS:
    This is for 100MHz HSTL:
    This will give you the characteristics of your 100MHz outputs.
    I attach the ADIsimCLK file (take out txt extension before loading it).
    AD9523_1_setup.clk.txt
    I also attach the lib files you need to install in this folder (maybe two of them come already installed, just check first). You need to first take out txt extension, then unzip them, then copy the content into this folder: C:\ProgramData\Applied Radio Labs\ADIsimCLK\lib\VCO
    PK�|'6 �/F�&�ylib_files/Crystek.lib�]]�$�q|?���BO6�۬�z�l��	[ ��ǣt0�#Hʄ`��;"3��zgfw�+�������Ȭ����_�����?|��۟�v��߽����Ow����/>��������7��O���_����������?���w�s�o������_�����W���y���o��cs���wɹ{ל���Wx��_������o?�����K_}�_���_�w������x���_����ﯼ���?�w��_޿����������ៜ?��w��o�Q�����w��;��ׯ��q���_����s8
    8j<����A<�?���?��Oo����ׯ�[�s�p��%���p�w׶������pv_���U�eW��vqyˡ�^Nj�rf��Ǹ�w;km˽�)�,�)l%�=�Y/[Im�����Ը7~^�]�
    ��.g�m5d��ǭf��.g�n��5���֜��������fn}khת����Z�{�=���e
    z�Ѓ}�T��[M|��W<������~��<a�_�����ι�<߂o�r�x�﹆�j�G���v���Z+�}Ŏ'p���b�=�=>���rqU�����ޫ���||�{���=�v��Eܻw!ȷe���'���]:q�=�b�]�UZK/�i�'T��c�C�^���W�j깍~0t�=�W�1�`�dy1��zl�'v����>|�����q+[��my_��p�7[ުO�V_�~�-�)��|�U_u�G�Y�����n�ݝ��2�"����_��eU�}��A�q��r��U�����!��4Ӌ��q��ަ��^�gp�����g�޸�r�kZ�� �,����pf���$'@g/M��o�K��wG�p�O<�m�Q�6�2�p����-<	N���ﻑ�3�{yLZD����	[$��c�Ci�x�rƓ��-���j�<�Y�>K���'r�����m�1h�aJJ�7̃{h�e�_I=:_�A�(��XR���)��
    h[�
    �t�
    �`��J:rty;H�Jƀ0�R����q�T�������{�mt����э�GH�/����U�`k���m!����w\���*��*�D��{njy���-�������3~�K�y���+�r�3/xΟ��𬷁�.x�2��9	8�֡��W��5��<�M8̈�����3n]�<c��[��Tw���x�!�$Dgԏ3Dc�����*:k:]|\Mu"��! %�6�)�y��[lS�Dt��Yx�ľ-x�/TA����0]�>�U�3���^@<�Yv������Z6�P<�W0DM'<f�k�	�/���瞒o��<�$��V<�	9��I$��B��(e[��3&�ё���\�+�{��r�.���5<cfz�1;�����6��oi�W<�O³̃:	j\2���N�U�HE�'��2?Ǵ :�q"m0E
    }�P8 6�g<����ζU>xNZ��s���:�D�P�6I�ghѿc~Άm� Qh+����ӂ��4g`9%������|̀P�c���e9���&��;mS�'����@c;7'3Q�P�!-n��̜ۢ���4��v��L��-�0��x���ϓ3�t��9�Bf�X��;&{��4��6�'s��J�'0S�f�i��%��&�Y�_1 ���N���'�:z��ł\@%��:>��K�O+}>���$5 ��<��~o3I�2�ՃIʧ1	�zWWA���}3&I�aLBW��>!m�I����ep(�|� ��r	���%9���M
    �Krk��/.}�$�U:ϛRHT�2�M�rӪ
    ����Δ~�JJ��F�6uA�iaL]�P�?�K
    ����r�����ͦ��%��=���	lȥ$���L�%nڅt��C3�dRT-�P2�ӪP���@�.d��S�p�A&yg���$B�<�"h�^�d�{G��{��	>�����3/.�Z��Xe`a�r�L=.��p8�	VŵW
    \�ykv.��v�tI'm��,X��DO�	²�P_�NF����r�6���n�I��S:�2��g@���K�:!��[�ۤF?�@#Q��	�`���ѷ8�9ɫݖ�7b�kߙ^d�!|��^����Ia���u�@E�2?��
    Y�m�Y ۅYy#���U����A���X��No��ѶE�\����j�+��P;�i��À�[�h7��HԀr������ч��g�c��g�V�U�/K�[C��c<��~��ptB�gw0���3��'B1AV:��������'�hJWDS���.w�_��1�Z�	��C��	�k0��9��n��^���0#	�k�f@�O��e(���>�A�
    ӪzTY�y���M�I�(��g��	�نb�����v�z��7���&�[4��͖��{2ΐ]o��W� (vޙy 'Y�^���	��P#��m��8\���Z����@�]�סL���z tv���@2��n*~�j���[9��>��s��9�oG��Q?B2�9�0 3��
    |�X�t1���;���TG/�p;5a|Sx�@Ng_�q�F<4��0ta�zB2C�*��Y-D�����.���zP�r|�f�f�Nb��B̖���ã��c1..I#�$�1g��^�D���$��~��41��Sh����H�zt���z�7���x��V�7�^��l��^�!���2ҼȍA�ac`�j��LGB%�X4��¨�)$
    ���<��L����������
    �k�%�QK2zo��|#���7j��$&v^�Lu%c�GB�lSp�Pr9e0�Pe �
    ���+�Е�9�.��'�5�ˣѠ�]�x�U�����]�U��#�z&ë,��:=Vx`i)2�AH!�8
    PGW�+��5H�x�`�x��=�}D�h^=�6�	�:���0&O,i6ϋ�vU�	-(g���b�)������t�Fg]�0������:�݆J��j��B�2�T�Љ�����:Q�1)4YW��b�$��]ŀW�H�X��/N�:� y���M�$�(,�9�QJv�m��*6̌y��zC7�)݀v	ݖn@��y�/!�+�����7L�y�u�YҘ���qh�a��p�k������x&�A�
    �m;�`U?�!ԕ7�e艈1��9�!}h�ИʴÅ-�2̼8)��jQ������	#OG��~��A�I:����r��xW�������l�v��(P���f���A��i�Lh�O+P�,���3~ؖPۊ?gs�����������2�;�6����v�ڜʹ��������\Q�Fcԋv�)M�C=�|)�a�C=p��pE�@�{�a��u)Tw臒5\�6�L������mu��3�b@��T؛~�I�WX��m/�S�	���i����V)DsC�"|\	�d+d�S�VL�|�?qJd�l|�N$	�V�P�Kj���˃h�a�i%�!T�|ȉ:i%E��lP-�+*b�C�F#�{
    ����K�XE��TH�!�H��ׯx�k8rûd�4������2�}D��W��rW��qʝ����ޠ���a^�+h��A2�i��p�@�x?��}dD$6Ar���A3E�CR��T $�\�6M�u�&]�&M�xỜԱ��k��Uɀ�2*�U��!/\T��>^9�`X�̋�2��]�C�d���P���n&M��[B��-����%/�;.�c��?�r�Gl��7��-�0n��%�Ѓ�J0�o#�9x$���0���]����`IPy�W�ZR�YCm犉��|r:���:,W�=�)�02�I�������a[z*Q��x�t@"e��v�t�ZB��+��3zU?���΁��:��
    �%�8k�F�5j!�>�Z����zqj�~�'WґɬF�RåE���2�
    ����B1fз4�(V����$�&Z�U�$o'�&�F!��F�MU�\I�-VG�bͨlrX95��e��d��UF%�[|ӌ��r%w�.Ҡ�M�Jqm+���fbq���QZ�a[͎p+��4߈�OV�.�|y�ă@(��@�Ȓ�ߵ��$3�َ��I&aI��LЮj��B&����`,#��X'���^}WU�pITA�?dX����d<N-�^���WC<٦4S[�ş|�^�Z*'2	��։L���w�U��#��[<~�M警3�@ٔx%�I��l�1�6��>�~F��T�Y�ū��+�@n�,�{sMi���K�tM^o�4Z�5j�$�3�e7�(R��VK���GZ-�k2S���k�l�IӞ��t�ق�}1[J�
    j5[J��3[JӠ��C)P͖jE�aj�w�liN���li�
    MC����jfׇm����ذ��0��TS袵��=�bs(�R�����N���E�Ll&)%�SX����Ԇ�)����X\8q
    &p��}M�aMn�d����V��{n'�r������:ꈀ��j��VfOf��\g�_-�����X=y�k�,x�.�#��]�,轖��т�.<a��5(:-�i����GȽ����#�1�Wװ͕�(�`��G5� �.i�Pf��V}5�A��ldC"�ydf�Ѩ��Q�I��|�,}�����̾�U�jYF3U���4q"��zƾz�쫷hq����6(�a���4�����H;Ȣ(�I�ș|�Ț�����V�o��b�B�,?����a$�X��RX�\t�.�Z�	��B|?��dA ����B��6S�Rҁ�y l�Z���v�J���G/�2,�p�iFa����<���+��n�ש��eF�&����i�A��\��R�`�Ah���޳��T�}�ay�3�v:�訲�-�~"�1p�rqJ�ɤ�f.g�9�~�����#����1}/l�l=�r^�F�4��fEV�g�k���!�@*��5 !���z�[�z�� ~3=P2=�c���&��f"�b�8Q3�Πf"B�%�n�M�D�A@�nePQ3,�d5�H�����䕪��$Q�� Ŕ�db��{6b޳��X�"e��Ϲ��"ep�o�q�a�4fY�H�:�#A�5_V�5Y�u3�.����2�,���c[X�PNaWƂ�h<�:K`�O�xl��ũ\���r?i�XZKg��©9�ރgxu\�Le٨˗&�}̾i� i���j��4b
    ����q�����)nZ�Ly2n��{�I����/�>R����X�9��?'i��E+���l�ta"�m3&��t`}�Ue�����` ���E��#h3�3�󰎂w�ZZ�����D]�ɸ)�$W��5�`�aQY���k��*"����lx<���q6�^y"���qA�Ⱦ
    �A���>s�K���qqR�`���l(�k/�H�]<�)��07�@��y׻�vk�*��R�{/��ګ��cE�J�ҧ�J%u����w`.�s��L�1P�)��<5B�4%P6&�00�w�*����C��\�Gڷ���%�nKϜ�I��^I
    מ��(V���������z�k���9�͛{�au��������HA{���q.�Ac��2ƍ���n��� �8����_����Y�_p=�LSl��2i�����tm�3�d�[A�6�յ�T�	C/���%�0][�=[��iz>���z><�Ei3
    ��&8��4Jl���d�0�̡�1���%�g��禹'E�5��RU]A��RX�Ϛ]���R;֓u5��)=�n-[a�	$~�k�êe.ɟ�1�E�9@H:�Iex�Ƕ��r�S�C	������÷�^	Pg������۪?:W��x�S&'z���iq
    5��~�B
    1��#�UJ��]{i<�~��������g&Q�T\��J堗 ��ũ2�6&W��Ud݄���&4
    Д+��
    b7�0|us47����*�8��5��mz��|�,��n\��&���"BW�DC��'�Cli.��##� =a�`_���9��G��MLs+�m� A@��o+�C��;E��4��ªhgW�B�)�v� �5g��9mD7�C�D��
    �t�A7���<��*�r�������aYs?�P4��t���W"���*�U[��T/�^]��
    �#�k_�M��'`�r��N�)�b��NlۖY�gAw��8L�lC�i5N�n��M�}��J�L��6���s��v��m��B�vm.�n�Ԧ�n����lӜXu�`���h�LvJ��a_�A'su�}��V����ڦ(3b�>g�feZ�
    	5˼++���I@͌h���tl�q�\?����J墑����rNq���,�D�SG����S��
    �:�}'�Ꮦ��`}�*=�m�5G���j)o���,&��TM2��z�5�5X#hx��p���k���#DԸr����wc�Wgc���O0��Dݸ}���-$�a�k����K����Dc�ۤ-m��oSP7�褪�m_)�[d��6@
    }�&��;Ż���@M�'�ڦ��D\�m�2��ST���NI?A@��奍m�P�z���6����eC\���|0�� ��2S�����E}{F6��˜D	� P���������@������HE]��e̊�|,O��*��"l5n3�S,i4��`�Y{�Twj(�g����ЋO���{��P�)��d���HF1�Pa(��l�xp����0���5�LzFk�U�2�X�l՗������rU6�X��{E//änKFq�6��蘎<�p9�0��;m�@�$3/kt�北��z�A��lBd�d��/��N�k�^T}B/2���9U��D��\�{9�e�Y1�5��b��[�UVn�ٺ�Aׂ��Z�i��4!��
    +��H�\E���c�?	p�}eʰ�E�s/�X�1���ӬZ�9����r�4s�斣��T��C�"J�;ֶ�,Yp�	������:@�oY"��ɠ�(hɦ�Š�̜f���A�}P!9Lٝ:��mj���d��)��<���Q�Q��׻��ʣ��lN�^V',��fD����[s��r���2Ul&@�j~Q*d���>�I�;���0��m�]�֍�M�m�2[jy.�E�q�8K�P����!@�C*0n,J#��/SxUJ�P��!j)�7�쥂M:뾕�p�ͽ�Ѓӻ�a�]qE)tf��R����'l#k�94e7��C)�=.~�
    �-�ǟ%��}N˺tR���h�� =`Z-��2Z�T��Rpdg����r�!L��M�Z�!�֠�s"��?����L����e�Y(�9������/Y�v����)��}�P P7�Ot�O��R��/c����#Ď[��8�#D�[3���j��w�])%�X
    �,���޽p������
    FA�_��� ���O��NC�37�
    C�@�D�i����5w�[ȭ\3�u	`�-6b��}���Mn�x@(�-�w7f�t�d���=��~�&���';���7�IU�*rz4�Q�Y�Q�(ܷO�a�>$7��F�m����0[�d�r��O��J	cV�`y��E�����!E��+Vpi��]UK��9�⏤���-�'[;�Ax��3���ۙNՖ;��x.�o�X��
    tK���0W?T��fn�����V*=,o�N⊓�NX�iW�$Ҙ5f�	��/W�������#�Tc*�?/�OF����d��>�S�,�7Ȥ5K��λin���/����~c�S��$'���	N�~�W�����u��@�aNv���v(^9f8*D�iN".VC�\�s���4a	��[��l¢�I%���6A�������i�{/T�	�A>y��%�pk�]�r��QƬ�N�,�^��6V�
    ��4<pW��a��k��J	aH�0e��b�qV0ve��+hJ��v\�̥�EI�pn7��ā�8{ܷ|7���x��"86�H8 Z�H����=��ZI��%DC����ڤ�X�J
    eKϥ[l{"�T��W}��PWV����Ǝ�O�����|�^v����#��Ɏ�3�kT�3|Q����6��	�:R��M���zƒ���u�Uǟ�\GP9$og������"�o����!��#ֱ�mQ&)j7��&;uX50C�Q^G�Ӫ��0EkS+����V:u�.A@�O2�J�n�Ӣ�	t�r��d�Lک����T�5Yí$%�v4-X�t��c*�D'�;�D���d����}p3�WKT��'a�DY]��O)�(j����.�~7��u�=����F�\wR&\����C6�G�<7�Ayj�7����_�$a��y���
    �<�R��]�����L�b�`�(���(�*�ktV�N@wsU�,�M�5�(����5���
    X�	h*��r�']����4y�"!���7��:J���Gy�]!�F����M�-m�(2�.`!<C ȟ���]Ɏ)(m�\<�r��.XZ�ܚ�O1 ����iٴ���%��\Ie�̜]� gB����5Mے��/�v�L��D��i ���XP���U�c�M親191MqZm!��4�GR�@ȴn��DO�ʑRUa�B��L�n���b�ܪ�
    �t�W2�>�����]�'��{�h�[(�(�,�>J'����{�pmS����r�r��e�����n�D��;��n�O��
    ~�0/�����w1*����1Os��f�ف���و^�s)�p%=��[\����b�W�@9�R/n��ѩ;�N�n��^zc�]F�j����,[��|�ml�K#L��n›��6��B3�\��Ο#X^��vY�{2�vn�D������`�.�R\*�@��R[<{\f�.� �8����h$R��nНi&�0sV��Id�qh�3�0�t62,�mpK�}r|�24�����ѓ��hյ3��f�2�}|���D8�R��W��%���/�VX������D����ź�_�^I	t>M3�-_�fF���̲[������^��[��dp-�dVA"+ƣ��l1�Y�
    ��-[��/	r������H�T2w�{
    V?������q�$m���<3�����=���.P0.wȥ���j���q���<��d]�-�ޒLZr�O�*�u��֭I���F��Jtl˝J
    �4�[��˕�����2U��(�\�4!���B��i-i�?'��-�aw�y��E��!�N��b���C8"N���Sy%�)�>G���a�3�H�ed����;��%�y�n0|��-��C��<�Q�H�����`%o�.^���g+��|D��h�,g8q"�>l�j��+���ʙ�F�d�>}%P�y��<3�}tq��|��2w�h�
    =���Y'�:��⍙Z��"�����c)`�pY�ZW&β�f<S��?��-1��"�-�&��
    xK�C@l����.�C:2:��-V�%M�[Խ��dbH���%s>* �V���mv7N�>{4j�}қ���>;
    �F�u-*X�s����aak?�L��׌�L�v�qn.��rɇB�ӻc�:[���ѷk5Z�=(��to�:7�2[}���Q�H�}���	>[jU]�d�X�Mz��4kC�.��$�.�
    ��]r��8�����m��gRB|v���\&U�P���,���%^�L ��v�1�&�f]�nL\D�a�PK��WFA"���!lib_files/Crystek.sfm��iLWpP)4�R*[K�f`vٓ�8�b�
    �X�c�B\(ZV)bD($
    �`�TT�"
    рҮZ��AQ�@E!B�x�X�{Û�vf��f��2�����c�����E�[+�3RRca��B��B�8�Kp�.==�K=��K��V���;E��R�ccSS�׫����&z�#yibV�ߵyh�A�ڏ_�_
    �����!í���-�7n��8$+�4�y�Ү&���Et���q ������^����FR����0�"!#�[�:h3=vw7�h:q��Z��e�\c�:8k�V���O#�>�5�adCd:[Է!�#>}��Ft$d��F����2fT�'��6R-RNX�E?�2J���#WF>B�2�9��H��r��5�hU�u���w�Z��o��|c�}�k]��N���2�9��H�(�L�m�e�<R*�]���ѱ�UY7Djǟ;��&$�����H�c|�9��H��}�32����2�<�f}���}���rI�ݑ0�%RƍetHx��+%I��xR���HT9��6���w�呲�-M�*R6��O���B�v��
    ��eR�T��6��@�Vk#�ʣ�!�Qqo�=c=�����zv������������,�ƙyC��E��q�2�X`�	�($�'���}��8XUU�ٹQ�KjI;|]'+m�Ulw!�����w��=�m;GF`dc|s��HȨ���4ZsΦ��\Ӕ��F�f��é���َU������##�;��f0�"!��;'�6/�	̞�'�Q�P����})x�,�`����HmY)����4Q֝.�e\�i$��`�"!�†k�FW��Gsʖ������^&�ߺtmd�2�Ν�������K�QkT$d4���4�/qx��G���C�ڴ�퉊��&���U�;����y8�^�L7�"!��D�?��9�F^d�-Y��R8�慣<r �F�'*?})GF��||̑GT$d�:�~r9��i�#f�+�L���X���q�Ȋ�G9�����DžQ �#�+3�l� 2��}�chs�<k�h?���G��Jf;��p�I����wZ'"k�WӹeF
    ��Ua�@`��a$d��K���[��~}w"�Gd�<Y���-��J��z%GF��?��FT$dT���&9������2�w�5_�F[�����@y��2�!�,\ĕ�X"���&�~�HȈx߭�x�F�7Vk՞�*�h������h���2ѝ�?�P����Wf�Z�"!�ƞu�M]���e�Z�:�6<Y;q�-
    ����&�ٸVpb��|>���<2����_7TA��	'N1��	xú���H����'���5w��A����n�b����ȓz��yd	�?%:�
    ه��g�d��I/��B<��Q{HG�\�8S��>�47y�m	�����G[�Ul#؏�oͤ���+J[纍z���i���+����/5GQ���*���o�dt�W|�L���u/�qo��w�G�`0�D�BL}�7����'�A���:���ʦ
    t�%�a7x�e9��Xy$��N��2X|���"Q=��J2�4e�F��2�j�G��}G��@�6��G����y�v����H��<������F��G�C{�_��*ʨey�^Ǭ��<"��}�##[V�ez�lj
    92���c3Q����V�C�>{wŏ#1ܟ֯��n��~9)�~O������I�'E���t#*2?o�F��vt3�βˤ�z��n�Gy�Ϊ���Xm����PK�dM?���WIlib_files/CrystekVCXO.libݐ_O�0�ߛ�;��	lݰ�	���,�!J6�L�h�ز�@����"Q�|�/=�����7\I8�Xe5��)-aV��I8d`z²��j�XÙ8���ඪ��9<�\��q�Cܢ̥�N����n�8d�W�1���Z.�Q��&�n��h+�(��2��\~+ڍ��4y�5��f!���Į�s�*��U���0:B���21!��D�w���$|�F�Fk����q�3m^��م����(�ՌYݚKj����!�t�K9�� �״k|V8dZ���03�ߙ�k�ƕ�����+B�/h)b�:�4��-���EN��Z��'r�w�PK��WF�O���lib_files/CrystekVCXO.sfmcb```eH```w.�,.I��p�pѵ45�///�K��%���"��TbN1H\��/.HM�-�HM-)�/K��ׇ��W������z�#�N=;L�@p9��x��o�������g��~�\���}��&F�r}�#�����J�`�!,~
    0����
    �Ĕ�A�� �PK�|'6 �/F�&�y!lib_files/Crystek.libPK��WFA"���! �&lib_files/Crystek.sfmPK�dM?���WI!�-lib_files/CrystekVCXO.libPK��WF�O��� i/lib_files/CrystekVCXO.sfmPKM0
    Petre
Reply
  • Hi again,
    VCO is AD9523-1
    Reference is custom
    Core			 325mW
    Ref single		4.0mW
    OUT0			48.6mW
    OUT1			30.4mW
    OUT2			35.9mW
    OUT3			57.8mW
    OUT4			92.1mW
    OUT5			92.1mW
    OUT6			92.1mW
    OUT7			92.1mW
    OUT8			92.1mW
    OUT9			92.1mW
    OUT10			92.1mW
    OUT11			92.1mW
    OUT12			92.1mW
    OUT13			92.1mW
    PLL1_OUT		24.4mW
    Total Power		1.45 W
    OUT0:
          at IF Freq =  100MHz
    OUT1:
          at IF Freq =  100MHz
    OUT2:
          at IF Freq =  100MHz
    OUT3:
          at IF Freq =  100MHz
    OUT4:
          at IF Freq =  100MHz
    OUT5:
          at IF Freq =  100MHz
    OUT6:
          at IF Freq =  100MHz
    OUT7:
          at IF Freq =  100MHz
    OUT8:
          at IF Freq =  100MHz
    OUT9:
          at IF Freq =  100MHz
    OUT10:
          at IF Freq =  100MHz
    OUT11:
          at IF Freq =  100MHz
    OUT12:
          at IF Freq =  100MHz
    OUT13:
          at IF Freq =  100MHz
    PLL1_OUT:
          at IF Freq =  100MHz
    Phase Noise Table
    Frequency Locking
    Reference	custom
       Frequency	 100MHz
       Phase Noise	None
    PLL1
       Design Freq	 100MHz
       VCO	CVHD-950
             Kv	1.21kHz/V
             V1	0V
             F1	99.998MHz
             V2	3.30 V
             F2	100.002MHz
          Input Cap. (Ct)	0F
          Phase Noise	Table
       Dividers
          R1	1
          N1	1
          Icp	16.0uA
          V max	3.30V
          V min	0V
          ABP Pulse	0s
          PN Floor	-219dBc/Hz
          Zero Loc.	3.38 Hz
          Pole Loc.	 266 Hz
          Cpole1	1.50nF
          Rzero	10.0k
          Cext	4.70uF
          Rpole2	 165k
          Cpole2	 337pF
          Rext	0
       FreqDomain
          Min Freq	1.00 Hz
          Max Freq	1.00MHz
          Pts per Decade	10
          Analysis at	 100MHz
    PLL2
       PLL Setup
          Min Freq	3.00GHz
          Max Freq	3.00GHz
          PD Freq.	 200MHz
             Ref Divider	1
             Ref Doubler	enabled
          Design Freq	3.00GHz
       VCO	AD9523-1
          Phase Noise	Table
       Chip - PLL	AD9523-1
          Main Divider
             Prescaler P	4
             Counter Bits	13
             Min value	1
             Max Freq.	3.10GHz
             Min Freq.	2.93GHz
          Ref Divider
             Counter Bits	10
             Min value	0.500
             Max Freq.	 400MHz
             Min Freq.	0Hz
             CP Current	 515uA
             Polarity	positive
             Leakage	0A
             AB Pulse	Not Used
             Vsupply	3.30 V
             Vmin	0V
             Vmax	3.30 V
             Max Freq.	 250MHz
          Lock Detect	None
          Zero Loc.	50.7kHz
          Pole Loc.	4.00MHz
          Cpole1	8.00pF
          Rzero	1.85k
          Cext	1.80nF
          Rpole2	 900
          Cpole2	16.0pF
          Rext	0
       TimeDomain
          Type	Power On
          Frequency	3.00GHz
          Stop Time	 349us
          Max Time Step	 250ps
          VCO Autocal.	enable
    Clock Dist.
       VCO Freq	3.00GHz
          M1 Div	3
          M2 Div	3
       OUT0	OUT0
          Frequency	 100MHz
          Divider
             div N	10
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT1	OUT1
          Frequency	 100MHz
          Divider
             div N	10
             Phase Offset	0
          Output	LVDS
       OUT2	OUT2
          Frequency	 100MHz
          Divider
             div N	10
             Phase Offset	0
          Output	CMOS
       OUT3	OUT3
          Frequency	 100MHz
          Divider
             div N	10
             Phase Offset	0
          Output	HSTL
       OUT4	OUT4
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT5	OUT5
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT6	OUT6
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT7	OUT7
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT8	OUT8
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT9	OUT9
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT10	OUT10
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT11	OUT11
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT12	OUT12
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       OUT13	OUT13
          Frequency	 500MHz
          Divider
             div N	2
             Phase Offset	0
          Output	LVPECL
             Voltage Swing	 780mV
       PLL1_OUT	PLL1_OUT
          Frequency	50.0MHz
          Divider
             div N	2
          Output	CMOS
    Timing An.
       Start Time	-1.00ns
       Stop Time	50.0ns
    FreqDomain
       Min Freq	1.00kHz
       Max Freq	 100MHz
       Pts per Decade	10
       Analysis at	3.00GHz
    h[�
    �t�
    ���<��L����������
    5��~�B
    Д+��
    �,���޽p������
    �X�c�B\(ZV)bD($
    �`�TT�"
    0����
    Petre
Children
