ADCLK854 Clock puls missing
Product Number: ADCLK854
Hello.
Even when a group of clock pulses is input to ADCLK854, the number of pulses in the output group of pulses decreases.
For example, an input of 11 pulses results in an output of 6 pulses.
The input/output conditions are LVDS and terminated at 100 Ω, and the phenomenon is observed even when the electrical
conditions are changed within the specifications.
Could you please tell me the cause and a solution?
Best regards
    The ADCLK854 takes 4 to 6 pulses on start-up before the output appears. That is why the 11 input pulses being provided to the part was reduced to 6 output pulses. We recommend to have 10 pulses that meet input sensitivity specs to guarantee that the pulse swallowing is complete. This recommendation came from the 4 to 6 pulses observed and adding some margin for initial state (high/low) and marginal pulses. If all input pulses are needed to come out without any pulse swallowing, we recommend not to use the ADCLK854.
    Mark
  • We are encountering this same issue. Is there a pin compatible device that does not exhibit this behavior. Additionally this behavior is not documented in the datasheet.
    sorry for this. At the time of the design, complete correlation between input and output pulses was not a requirement.
    All outputs have this behavior.
    Petre
