Frequency divider not working issue
Product Number: AD9547
I want to use AD9547 to output two clocks of 150M and 50M. This is my relevant configuration. I have connected a 1GHz crystal oscillator externally, and I observed that DACOUT outputs a signal of 125MHz. However, when it is given to CLKIN, OUT0/1 does not output. Is it because my register is not configured correctly?
  • HI,
    next time just send me the stp file you created. Do you have an evaluation board on which you are downloading this configuration?
    I see two problems: First, you need to set up a profile for the AD9547 to work. Then, to generate outputs, you should execute a Sync operation (press Synchronize Distribution button in the Clock Distribution Window). See page 7 in the UG-639 eval board manual.
    Why do you use the AD9547? Use instead one of the AD9545 family of IC (AD9545/44/43/42) which is a much newer architecture and easy to use.
    Petre
  • �}��B�#c��˙��xL�
    ��vn䇴Hf�C`T��F�;]��7��Y��c�U�4���'�~c�E��<�*�_Ԕby=��#�{d����4"�êk�
    ��R^�&`��
    ����4q�oE۰Bw�D���5�Q�փB	�W4o�y��kj@9�?�E��̍�%M�:#�1�Aƒ.��p��F#���!�����@�O`Ⱥſ͝���a��+��1pv���Hd�s"=%���wS��S
    ����i��}��ł6���z������6�Pڐ������
    Z��n�~f&�dg�77�Ì�����]XI�&玛�|�2�#�#/!�i��'`�3�c�*�>z�xA<��_���=a�>��W�`ʚ���k�t���&�L�^�mz��C�>o�~{��%��D�1�r@�oh7
    ��*fEX"�8���S*��*�m9� ���ᅓ�瓭���z�\]	��nm��qW�~ۍT�c䟚!��E��^��Ѻ����8�������.y����!�]�e�1��N"�iSj�Ap[ц�|V��'ġ��.��M���~J�;>�!��E�|����dzc��v�"&���/��w�X��ish�!�W��q��0v(�h6��%�^���m�_���c�7_%�-�أ,54�/�^�\����Z�mS�s�dӉL��t��{V�P��-�|ŏB��E�uM��������M!�c}��I��0pv���He�s"=%���wS��S
    ����i��}��ٖU ���z�����&�������Ỡ�e3��|�j4%�r5�77�Ӝ������QTy�:��΀Q�q��#%#�m��I'`�#�h�*�VCUf�dև�;��In\�>��@�`ʊ���j�t���:�\��?�?�E�jNS�~q��9��D�!�bK�gh_EN��:lg����y��*�o8�<�����������5L�1�hA��)WW�|څH�1䟊1��Ev��B��lP������>���!���/p�Ρ�!�M�n�1�
    >�yeF�M5w��%�|\��Vض]��>��Mj���bZ�Bn�I��x�z��U��dpa�z�`�"'����.܆�4�H��=+�r%�Q�U��W��2v[�~d��5�^���.�Où�J�
    e#�y��,7@�/�N�L����j�c}C�&���q��X��*]V�R��1�.ŏR��N�uM⦬�Կ�I�0@��e��Vv���Iy�!"-5���wS������1�M�?G����s ���l-������&�����昙��� `��z�=g�r?�64��΂�����PTY�P���	�4�#�%	t�T��C%a�?�:�*�FS^f�hQ'ʖ�nܮ=a�8�C��5@�cʊ���j�d���:�\�J�/�G��/n�x]�����G� �t�gxOUE��:rUCpw�}���B*��,�8k����󉕲������l�G)\�I�0)��mQ�+��n�;矉-��Uf��B�����޶�fᥧ����|D�Ϋ�!�Q�<�!�>�y
    H�5`^���zp����W��;��Mj����bZ�*+�W���"����b\6�5�`�!'����.̖�?�H�xh�b]�	��m��e%�~n��#�^���%�O���Z�r0{�<�п*8`Q	#�,�F�ZØ��z�c}C�c���	��0��gP����$Ə[���u]�����VU� 8�
    ��1lp匈u_�+"\)�ֳvB������r�+�GN��ۑL&�N�4l'��韌'������񫻺Fp��"�x6#�t�d
    ��Ā����PEH�'��ސJ�R�^�}a1�l��or3��0�*�ZEf�xA,ʗ�+��-�`��F�5�����i���:�L�Z�/�/�^�?
    � 5��%����t�gSC��*bEHpw����R:��t�}8� ��K�̯��������|�L)\�!�s5��l8	�nڍT��̷��Tz��B��������%����N���/y�ȇ�r�w�6�#��T>�iC�]%Ж`�"��'İ{����Nk�먊bZ�:;�U��h�a���:4s��f�wt����
    /Ȋ�m�I��ic�b5�J���8�� t+�xBL��-#�_���w�O���[�u8�/���rP%4�z�s�Zɛ��f�c}S�s���a��,��o2�@��-���o���tZ������]U� P����I9(���He�Vq�ܱvK��I����y�]�/W
    ����~���j��ϟ�%�����໱�1p��a�m$^�,{�66����Ω���R5_�&��΀A�$�6�>}!��7`�#��y�|Ee�dW~ʗ�;��-q�#���Z�pʊ���?�Y��>�L�L�/�?�T�?
    ~�c)���p��T� �r?�4EuC��+~Spw����S:��7�n(�u���񖓔׶�����`�)\�1�x5��}J�~�����1���h\��F��������.�������?����!�M�]�ٷ^:�m�M5Ж�a��_����>��9�ͨ�fZ�&-�U��x�k����y(g�p�>�2'����[}��g�H��~1�r%�A���}��0fP� *	��%�H
    ���}�O���Z�
    e3�,���1L5LLN�?�N�\����@�g}"�e���q��,��wK�P��x�`ՏR��:�&`Ƞ���U�0@����!|k���00�o"-5���$~��C����+�]�?G��ɄY=��
    �[2c����s�8���������0`��j�h$6�og�'O��������Fy;_�"��Җ�$�&�5}!�y��'p�v�t�*�FC*3U�BWtΗz�-Ʋ=a�(���]�`�����z�d��o�q�L�.�#��?n�h)��5��D�Y�*W�gxOE1��XStv����R*��<�m(�0�������������P*F�,\�-�*4��l@�ʝD����d_���Pc����.������|�������?i����1��r�!�rk�T'�Q#DІ�j��7ԫ��F�Y�]j����7	�-�P��d�8����r(c��}�"7���.̖�K�˟~;�u9���m��0f8�c6��B}�
    ^���Q�"���Z�sa�,�п:L5$
    �/�6�����z�6.n�e���m��,��g@�P�=�|ş*��R�u]�ӿ����S�2\����1l`���Xu�s2U`Ș�wC��oC։��!�]�#QT��ٔI6��
    �q������6����굵ۭ��0d��8�h4&�dg�''�؜���˫�ADY�s����$�:�g}!�i��'p�3�h�:�Bv�xQX��1�-̴;}�z��V�`ښ���j����*�L�J�L|��
    �?r�:)��%��D�1�iK�wY��*bU<%$�?���R"��n�m8� ���ᅈ�������|�8|�� 3��{�~ڍT�c䏚!��-3�R��������v��֨
    ���/y����1�]�n�Y��.�i7K�/w#N���8��'Ġ��.��MzѢ��rZ�:+��B�2��u�� (c��v�"7���>�ó#�H��xI�O����{ڮ0v(�h6��>�N���9�O���B	�0sk�,�̩hL54�/�^�G����/G�s}S�c�E��K��*�q�P��-�|şB��N�e%��������)�
    z����-z2���He�s2=%���g;������
    ��Q^��؈_d���z�����&�}�ĩ���ęc]��2�i6:�6g�77�Ӝ������Q<T�6��ΐ5�w��m{ �u��'`�#�h�:�VX^f�-	0ڗ�+��O[�p���`ʊ���j�t���:�4��	/�?�!�l T�0/��3�D�!�bK�wh_^E��R7
    T`w�����d�l>�6�����������o)�P9\�1�`��.{�ݑB�c䟊1��Ev��B��AM������Z�暎
    ���'eϊ��!�M�n�1�>�H[_�M%bV��"�2��;����>��Mz���bJ�os�E��x���;��*.b��$�"'����>܆�?�X�� �r%�5�Sփ{Ш14�:6��5�N���%�_g��Z�
    uG���bJ4q(T�/�N�L����j�cm+�;���q��y��-q�Q��;�|ŏR��N�eM⽧ꊼ��AE�0@��D΄z8�خTs�s"-5���gS���̙�e�]�?Wr���_n��k�(������&���������0`���;	�<a�7+큜������QTB�&炛�]�$�&�A(r�S��%a�5�h�*�FS^f�hJ,ʇt�s��=a�\�EҼ�bȖ���j�d���:�\�Q�?�j�I�?n�|�߹3�F�=�0K�gxOUE��:rNHpg�P��R*��H�>�6�����������l�L)L�d�d%��}5�-�B�e暖'E��Uf��B����䶛�2������Cπ��'�[�n�!�>�y
    C�j}
    І�Q����	��"�C�Mj����bJ�*0�U��-�v����}0�2�.� /�ɨ�.̖�?�X�cc�
    p�]��}��cK�00��g�^���%�_���J�_-/�,�ЯNf?^�-�R�����z�cmC�x���$�<��w4���;�z��N۴N�u]�����]U�H����1|Ċ�rs�uQ1#҄�wC������y�M�j��ٔYB�� �"y������&��������� ��v�h4&�2�
    틚�興��QDI�&��ދA�4�s�)m!�i��Nt]�5�n�\�P^f�xA,ʇ�0��E4�4��"�3�����i�x��:�L�Z�?�/�U�/e;�t9��5����:M�fdYE��*bEHpg����BR�� �m8�0��M�˃���ÿ��|�L)L�!�x5��A%]�~ڍD�6���'O��Ip�B��������.����S���/yɬ���[�h�=��>�iC�]>��M�v��'��Z��I�No����bZ�:;�U��h�j��~݉n8c���q�ɢ�
    (Ѐ�?�H��hc�b5�A���%��0v(�cJ��m�Y���%�O���J�n3�<م�&\54	r�|�t�����l]�c}S�s���a��,��B/\�P��=�)��h۾H�|A������]U� P����d$|���Hu�&P#؂�_������y�M�/L���*���*������%��޵��Ự� p��j�xLs�xw�77��Р����RfX�&��΀A�4�6�5}1�<��'`�3�=��PXer�n,ʗ�;��-q�(���GJ�`ʊ�Е9�^��9�P��/�?�U�/
    ~�h)���m��D�!��ZBY
    C��6tHpw����B:��<�}@�h�������عõ��j�L)\�1�x5��fA�n���s䟊!c���op��F��W������.�������W,����!�]�;[���:�uAC�M5���j÷r����>�e�W����fY�,i�U��x�j����r(s�]�j�"'�ώ�]���9�L�:c�r%�A���f�� }�t&��A�Nc���#�J���Z�
    e3�<���:L%zaQ�/�N�8�ˠ�lW�g{O�!���q��,��l@�@��e�lŏRݒ�Hg����ѕ]U�0@����!g`�ɣ-�c"-%���Jy����ڊy�]�?G��ɄB6��e�Ffo������u�?�Գ�����0`��j�x$6�dg�Ob�ό������(~�"����A�$�&�5}1�y��7�k�x�*�V'5;�n*���i��=a�(���V�p��ɸ�j�di�v��\�)�U�?n�h)��.��T�t�~[�gx_!ˌtNt���R*��<�}(�+����ݟ��ř��>-j�J-)�'�x5��mA�nʝ_�c���y��Uv����]�ʂ�ؿ.�������?i����Y��~�!��Sm�SKE�[gІ�j��7Ϡ��k�
    �Mj��ʍ1g�,c�P��n�j����r(s��v�2_͗�.̆�j�u̳0e�n3�A��m�� f8�h6	��_)�^���p�r%���Y�73�,�п:L%$�?��P����j{�0@i�+���g��,��g@�@�&�|����^�u]����џ[P�,V����1l`���Xn�sZx}���wC��NE��ڀ�[�)��ٔI6��
    �z������&�����۲���7|��j�h4&�dg�''�Ӝ������QD=�u����G�,�0�5}!�i��7p�(�h�R�ONf�h5y��6�c��!w�(��V�pښ���z�1���:�L�.�J�)�S�Nx�h)��%��T�1�bK�-IU��*r1#J���� 6��<�m8� ���ឃ��֝���l�za�'�~0��?A�~ڍT�c�:���.��B��q����ص(����I���/y����1�F�n�t��>�i
    gM�([m���j��'Ġ��.��]����bZ�*O���n�l���r(c��v�27����V���/�H��6O�H3�G���?��0v(�h6	��5�
    &��5�O���Dg�=5�-���:L54�?�^�L���2�c}S��C��g�*��5@�P��-�|՟B��N�
    V����'>`���He�s2=>�������ܬ,�`�)��ł6���z������6�Pڐ������
    Z��l�i(0�dg�77�Ӝ������AmIU�&������0�3u#���'`�#�h�:�MS^v~�0]<ʗ�O��!w�.��]V�`ʊ���z�t���*��F�/�/��'x�n!���w��D�!�bK�whDUE��*YXpw����o��:�h$�r�����������{B4�\)\�!�-f��5G�xƛ�c䟊1���Em��RШ\����ޙ{����C���3o����!�M�n�1�.�<US�]ACP��l��1����>��]z����r"�r'�U��h�?��<��t j��v�"'����>ܝ�?�0��ts�r5��=ѯ5��Aj>�h6��5�
    N���%�7J���Z�f����<DG"K�/�N�L����q�s�o���a����?F�#��|ŏR��N�eM����⑏�MU�0PЉB��'4f���^7�s"-5���gS�����i�]�/3S���0���\z������6������ݩ���0`��?�U0�bo�+!�Ӝ������AT
    I�6����Q�$�6�`.���'|�q�h�*�FS^v�sA,��Y�'��=q�}�+ՐWP�a֜Ӥ�j�d���*�\�Z�	W�w�E�?~�=z�ؕ}��F�7�bK�gxOUE��:iEH`�M���R*��i�P�x����ǃ������w�L9$�y�h5���C��j��c��Uf��R���ތ���>����o���o����=��n�!�.�yC�G)І�?W��1����(��Mj����rJ�1;�E��0�z����'{^��p�%;����.̖�?�X�hc�'m�Q����
    L>�n?��E5�^���%�_���"�By#�,���o8"A�&�X�L����z�smC�s���9��,���mǪu�u��D��N�u]������]E�e����!5���^=�zq>;g���wC������y�%�w[��ل=c��'�V|v��ɧ��&�������껰�H5ƚz�h46�14�
    !�Օ������QDI�6��ŀA�\�n�%}!�yΈHZ�{�a�6�S^f�xA,ڇ�;��dh)�8��{�]�٢��r���:�L�Z�	?�4�U�GH&�x)��Q��y�7�d:�{nUE��*bEH`g����*��,�m8�T�#��ͅ��������|�L9L�:�x%ѫ\qQ�~ڝ �0٥�i��C4��B��������.�������/i�������7��>�iC�F5��P�z��7��\��(��Iv����bZ�:;�E��s�j�S��b(c��#�����2���?�H��hc�b.�A�x��q��0v8�=e$��O3�B���%�O���J�e3�T��*L5$mS��X�J���(�c}S�s���z��<��_{P�P��Y�/��D��?�iK�������]E� K����ypp���X� >;m���kU�����y�M�4G����U&���z/,��ɭ��W������Ự� p��j�an�tg�7'��Ͼ����#	RSI�&��΀A�4�-�5mY�!��'`�W�;��U/�*A,ʗ�;��-j�(�n��F�`ʚ��W�r���N�Z�Z�/�?�U�/
    e�h9���9��D�1�7�]nS4�<0EHpw����B:��<�m�<�����ֳ�ߕ�딎.�L)\�1�x%��mA���H�c䟚EB�ךC>��B��F������.������z1����!�9�=5�7��t?�OC�M5���j��oذ��.�D�pP����`F�h;�U��x�j����r8�@�f�"'����3���M�T��hc�r%�A���m��H#`�x6��c`� d���W�S	���Z�
    e3�<�ۿ:\MW|�/�^�¥��"	�faE�s���q��<��g@�(��1�|ŏB���OK����ҕ�]U�0@����:l`���y�s"=A�׏MU�i����y�]�?G��ɟI6��H�j��ρ܍�ʊǷ������0`��j�x$-�dw�b�Ü���궹l/RYO�/�윀A�$�&�5m1�b��_5�?�h�*�2
    [<� G^���;��=a�(���V����j�t����Z�\�k3�m�U�?n�h9��%��<�i�rK�gh;��<:C:k�W���R*��<�}(� ��fҹ���員���9$�>]@�c�x5��mA�nʆT�s���-��E����L���؜�.�������?r���t�Q�n�1��U�E1h�5І�j��,Ġ��v��Mj���_`�b=�U��*�j����r8s��v�Zr���.��l�r��n�dw�A��m�� f#�h&a۞%�^���v�u	��F�Xe3�,�п:\%?�W��\����Z�^GE�u���#��,��g@�@�-�l����N�uM���נҟ�.Q�&����1l`���Ce�c{we)���wS��H+����
    �A�mG��ٔI6��
    �zoٿ���&����ܞ����,v܆j�h4&�dw�'<�ӌ��܂��QTu��얆2�8�t�5}!�i��7p�#�x��ZC^f����=�+3�(��V�pځ����,���:�\��$�g�&�#<�h)��%��T�*�b[�20SEE��:MM�]��N<��<�m8� ���������������f�i�G��FmA�~ڍT�s�1���z��B��`P���ؖ�]�������/y����1�M�~p�i��>�yiF#�3ew̐J�j��'Ġ��5��5?���bZ�Nn�h�� �����r(c��v�27����v{���?�H��=0!�d}�2���m��0v(�h&	��5�e๚%�OϹ�*`�RcG�0���:L54�?�E�L��ȇf�c}C�&�-��)��-��Eg@�P��-�l՟Y��^� �Գ�h�&����cl`���He�c2&5���"������*�g�gAr����I6���zo������^�M����昕���
    vր�t"t�dg�77�ӌ������)@Y�&�����~�Ax=�;��'`�#�x�:�FSNS�dQ,ʗ�nǏ&+9�\�
    ��V�`ʊ���z�o���B��J�/�K��6�.���%��D�!�b[�wsOUU��b~UHpw�q���h<��H�q.� �����������V_`�L)\�E�+��Lk5�b��T�c䟊1���^f��:�����޺�}�������9+����!�M�~�*�F�!C�9`E>�@�v��uĠ��>��]z�����&+�U���9����[�Z�v�"'����>ǖ�/���xc�bQ��:��k��,`z�h6��5�
    N���5�W���Z�~0`����N9)f�/�N�L����z�(�c�������Oa4�L��-�|ŏR��^�eV򶷒ό��]U� 4�,��ij���e�s"-5���gH��n����y�]�KU����OC���z������6����dz�����0p��9�R"~�e�!e�Ӝ������AOI�^��ҐA�$�R�f@�1��;v�#�h�*�FSNv�xA<��D�+��-�{�,��V�|�؁��j�d���*�G�Z�az�#�U�?
    �;���"��X�s�bK�gxOUU��!bEX"����R:��o�W.�'������������|�\Q	�-�x5��`8�D��S�`���1��Uf��R��Ѷ����.����N���9!����7�M�n�!�.�bSf�ZQ%Жl�99��à
    ��l��Mj����rJ�:;�-��d�j����!Y�P�v�>1����.̖�/�X��hsd�:9�A���8ۓ
    `p�h1��5�^���5�_���o�u3�,���iql�3��L����z�smX�s�hӒm��,��c2�j��*�uٙ��N�u]������M-�x\����E93���b�45���wC������i��#W����e���	z
    ������&�������Ỡ�e(��j�h$R�7Z�!o��ƞ��QDI�6��΀Q�q�:�5}!��&v�$��<�FS^f�xA<ڇ�;��Iu}�(���Z�Z�҆��v�6���:�L�Z�	?�?�E�jUr�h)���p�~�y�b=�q*OUE��*bEX`g����b��<�m(�u��$�����������|�\9L�1�hM��}A�~���^މ�6���f��B��������>������?
    ����7�J�l�s�>�iS�M5{���j��S��2��f��Q|����bZ�:;�E��x�z��N��r(c�|�%�1����8���?�H��hs�y%�Q�U��}��0f\�;#��4�H���%�O���J�
    e#�y�̯:L5@LU���M����z�c}S�s���q��T��w@�P��x�A��
    ��I�c�����ME�;@��i��-|`���<0�N94u2���a������i�M�?G����Y6��
    �[)B�����:�W�����Ỡ� k��z�=|:�dg�'C�����̙�MI�&��΀Q�4�&�%t�u��'p�v�U�<�AR,z�xA,ʗ�;��6a�8�C��V�`�����P�<���&��Z�/�?�E�/n�xQ���5��D�U�1v�q HT1��xbEHpw����B!��,�8p�0������ݸ�����E|�L)\�1�h%��mQ�+��D�c��dD�ж
    a��^��������>������ge����1��S2�y�"�;C�M5���z|��;Ԡ��J�B�w|���~L�:;�U��x�z��
    ��bP6��v�"7슩�48���=�^��hc�r%�Q��m��e>4�h6��Bf�'H�&�YM���Z�
    e#�<�п*4`J(	�/�:�����}
    �k�s���q��<��gP���=�|ş&��s�c��������]U�0@����1lp錓Tu�s2Y`ӹ�a��
    ����y�]�?G��ҔI&�U�z�������]������Ự�0`��z�x?&�t�+�Ӝ���˰�kK�:�΀A�$�&�%m1�i��cr(�3�h�:�c\�C%ց^�;��=a�8��F�5�����j������X�9�?�U�?n�x9��%���=�bK�wx��reG:la����R*��,�}3� ��K�텃�������O{�?5J�1�x5��mQ�nэT��ז!��!3�x�������.�������$y�ȋ�i�]�n�U��;�16�@M5І�z��'İw��"��Mzݢ��XL�=9�I��x�j����b8s��f�wo����>�è�^��kc� %�A��m�� }(�xNL��5�N����YG���L�
    e3�,�п*\%	4�z�R�L����/\�Yk�p���q��,��gP�@��-���N��N�e)��Ќ���^I�b@����1lp���He�Vj1%���g7��&,����}�K�?G��ٔI&���j����&�q�߈���渵�&2��j�h4&�tw�<7����Ո���Q0T��ɃG�2�&�5}!�i��7k�#��b�VS^f�-�T�8��
    oa�(��F�p�����?�x���:�8�	�#9�8�]�)On�h)��%��T�!�r3�/d_UE��^7uJa����Dx��<�m8� ���񕓘׭�����c)�qJ�6�	)��mA�~ڍT�s��1���Iv��B��AV�����\������/y����*�M�]�=�>�H@~$�JJ6e���j��'İ��>��"���bJ�oh�o�����T��r(c��f�2,����[fІ�?�X��;^&�*"�4���m��0v(�x&	��%�H���%�_k��-L�
    fE�:�п:L54�?�N�\����j�cm'� �*��v��0��g@�P��-�lՄR��6�=A⶧ꊰ��`o�hG��
    ��1l`���He�c)-5���?_������D�K�8C�ꋔI6���jo������s����������&8��i�~f&�dg�77�Ì�����]XI�&玛�|�2�!�1a7�i��'`�#�x�!�FC&3N�hA,ʇx�h��
    ef�-���V�`ʊ���z�d��o�P�Z�?�j�h�)Ei�n5���%��D�!�r[�lxOE=��6rEHpg�P���Dr��;�{j� ����������Kl�L)L�d�E��iI�h��T�c䟊1���Uf������些�ǣ�����}y����!�M�~�!�~k�u
    C�ff+9���ŝ'Ġ��>��]a����7�*;�U��-�W��^��4u��v�"'���%̖�G��hc�p�|���i��&$(�h6��%�
    U���]����J�_6�:�׻NP#P4�/�N�\����z�65O�s���$����c5�F��-�|ŏR��^�~]�߿����]U�D��+��6h�ωHe�s"-5���|C��cCͨ��y�M�j;�ꁓL6��O�z������6����ꮔ�� ��W�~l!�e{�e7�Ӝ������ADY�s��ހA�4�s�G7�n��12�#�h�*�FCNv
    �xQT���;��I4����
    U�v�����j�d���*�L�J�Lg�/�U�/i;�U��� ��R�!�bK�gxOEU��*bU0%?����B^���{`�%����������|�4|�!�x5��A>|�h��Q��͊1��Uf��R��������.����H���w~����s�M�n�!�.�i;K�]5��M�W>ŗ ����>��Mj����rQ�:+��h�j��rݒOu���4u����.̖�/�C��xI�n5�A���>��&./�*��5�^���5�D���B�e3�<Յ�v#Z3t�9�N�L����z�svS�c�E��a��,��B4}�F��(�`��R��N�u]������%�,P����d?]�σO`�op-5���wC��������/G�����E�c������&�������șx|��j�x@s�Y]�o0����ϔ���QDY�6��ΐ9�l�6�5}1�<��!18�%�t�x�FS^f�xQ<ڜ�+��T!q�(���\k�v�����|�d���:�L�J�	$�?�-�w~�h)���v��R�&�`W�5xOUE��*bUX`|���6��<�}L�s��������������|�\9W�1�`��mA�n���Y�Ǎ9���Uf��B��������V�������[,����y�E�r�!�>�iS�M%nV���jûr��5��9��[8����bZ�:+�E��x�����r(s�]�K�4����|̖�?�H��xs�r%�9�H��m�� }�U��1����%�O���Q�
    uK�d���:L%vaJ;�9�I�I����z�c}S�c���q��y��g@�@��~�F��U��R�']�����ME�0@��Dե!l`�ɯ6�Iz*=���%C������i�V�?W~��ńI6��i�]GE������0������᫠�;`��� (6�dg�Cb�œ���GGDI�&��ΐQ�/�&�M(i�y��7�p�R�r�N"BpT�xA,ʗ�+��=a�P�^�V�p��ҙ�|�c���,�L�Z�/�?�E�4n�|���%��T�t�_q�?G&Y��*bEHpw����Y*��D�%$� ���ƾڔ��ݙ��Q|�L)\�1�h%��}9�6ƝT�c���b*���RnײT��������>������3i����U��T�&��(�iC�M%ۆ�Q��7Ġ��k�,�[2����t�:;�U��x�z����
    }+��v�2S͌Ljv˟�#���hc�r%�Q��}��xj8�h6	��D����9����Z�
    u#�'�ЯB}$�?��q����s�u/S�s���q��<��w8��-�|����t�-Z��������]U�0@����1|đ�Xe�sVxf���/D��״��y�]�?W��ٔYN���z������0�������Ự�0`��z�c4&�2�+'�Ӝ������GMCN�0��΀A�$�&�%m*�i��No|�#�h�^�ndp^�qI0���;��=a�8��.�(֚���z�1���,�K�S�}�?�U�?n�x9��5���1�bK�-h��-k4Tf%����R*��,�f8�0̱V�ᕃ��ֆ���[u�P?�1�x5��}Q�uڍD�6���1���5��T��v�ئ���.�������/yɠ��=�M�n�t��<(�ng_�M5І�z��'��Z��.��]����t�3N�C�x�j����b8h���j;����Z�����
    �r%�A��}��;v(�cQ��5�
    e3�,�Я*\>4	~�g�^�L���)2�u%T�r���q��,��wP�[��=�)��B��N������ö�AC�0@����1|p���Hu�&K>=5����!ݳ��e��?G��ٔY&���*������6�P����������b`��j�h4&�tw�77��ˁ����AaRt�0����]�v�&�5}!�i��,`�3�=�6�FS^vr�+|���=��N=a�(��F�kʊ�ܕ"�t���*��g�w�N�I�mn�h)��5��O�!��{hOUE��1xrf/�t���*��<�m8�0�������������wB/�v?�@�d#��mA�~ڍD�s!o���Ef��RܨG8�جɿ�2�秴���/y����!�]�;@�1�.�<N.y�<G
    ���j��'԰��>�i�v����r.�i�C�	�v����r(c��f�)'�ς�F2ܖ�?�<��UY
    �uT�]�R�m��0v(�x&��M�UB���%�;J����{/�~�п:L54	�$�N�4�Ё�z�s	�N���߷:��g@�P��=�lΏRݞ�iM���gC�72��Ϲ1l`���Hu�c"-%���kS�����C��MF��ٔI6���jo�����n������ݲ���hg��v�:4&�dg�77�Ì������	TI�6����{�|�T�)ks�i��'`�3�x�*�V+.�xA,��Y���D:�4�D�V�`ʊ���a�dr�\�Z�	[�l�o�g�t?��%��D�!�r[�gx_-Э:bEH`�V���
    -�� �?8� ������ŕ��|�L9(�b�B#��fj]�,ڍT�c䟊!��Uv��
    ���ހ���������/y����!�]�~�!��Sv�yC�G,��j�v��'Ġ��>��Fj��ƍ*F�:;�E��+�P����n>1��v�"'���.̆�j�T�hc�'v�{�X����bv(�h6��%�^���p�S���.�YX	�t���&Zg4�/�N�\����jw�+aC�s��"��:��e\���-�|ŏR��^�u]������]E�e��žC|���He�s"-%���wC��N^����y�)�lz<����?*���z�����-�������Ự�D5ݻP�03U�xq�77�Ӝ������ZD1�n��΀A�P�u�ky���
    u`�#�h�*�VCNm�h9y���;��hh2��N��
    J�2ʊ���j�d���1�L�"�Q3�?�U�KH=�R?���&���!�bK�gx_EU��*r=8k����&���5?�$��L��������l�a@�1�x%ݫGP{�&��Q�u���1��Uv��I��}������.����&���(
    ���!�M�n�!�5�i
    kV�M5��K�P��Tü�>��Mj���iZ�*C���x�j�S��H>;�{�j�p'����.̆�/�H��6T�b%�A�t��P��hq[�t K��5�^���5�O���_F�
    e3�X�ZmGh�}�N�L����j�h}S��X��q��<��DZz���_�j��R��N�u]⦷��׿� @����bQZ���;�eQ"-5���wC����ܠ,�A�?G����t���zfi������&���������,p��j�au�^q�0D�ϊѝ����QDY�-�����8�&�5mU�:��
    g�U�~�*�FS^f�hQ<���C��-a�(�b��2l�8�����8�d���:�L�J�/�/��#
    n�h9������U�~]�gxOUE��*rUX{w����N:��<�m���F�����������l�\"\�!�-}��mA�
    ��i�u���2Ǹ�Uf��B������ޕ{�������z*���&�I�xZ�!�>�i
    S�]MCK̖�j��t���J�
    �j����bZ�*+�^��h�?����r8�[�L�z ���\.̖�?�H��xs�r5����m��D#{�R A��)�O^���%�O���Z�f�0�п:\AWg$<�w�:�P�ʝ�z�c}S�c���a��d��g@�$���j��&��X�u]�����M^�0P܉Y��1l`���X�e[%YD���wC������i�]�/?S��ɔI6��H�3@i�����t��������0`��?�t$&�dw�bd��ۚ����DI�&��ސQ�$�6�`5=�i��S5��~�-�2OH4�xA,ʗ�+��=q�}�
    ��V��ټ��2����h�L�Z�/�/�E�?~�=a��%��0�r�X]�`9ISʱ*bEHpw����R*��i�q(� ��jҢ���������|�L)\�!�h>���bʍT�s���-Dz� g����������>����c���?y���t�p�xP�T�l�iC�]%І�?L��'Ġ��m�+�m���0Z�:;�U��h�z����'`��v�Vr����V_̖�)�H��hc�r5�Q����,f(�h&mۅ*�E/���3�O���Z�u#�,���o)4�[��v����x�1}S�s���a��'���L�-�l����X�]񪱸����]U�0P����!5���He�cww~���C��
    D����y�]�/W��ل1c��
    �zoտ�ȳ�~������Ự�0`��z�h46�1/�'7�ӌ��ǣ��	dDU�t��΀A�$�6�%v!�yˆS;p�#�x��{iH>w�]:���;��=q�8��w�|ڊ����7���b�L�F�K/�?�U�?~�x"��]��X�!�b[�2+roS��*kY^"w����R*��,�m8�X����������r�Z{\�1�x5��}Q�~ڝ,�+���1���[����`ל����.�������/i����1�M�~|�rޛf�ihUL�M5І�z��7��G��>��9?�ʄ�:+�L'���x�j����b#c��#�>7����z{���)�9��tuN�r%�A��}��0v8�=~��5�i���3�:���EZ�
    e3�,���*G5$aS�3�N�L��ȜG5�;S�o�B��q��,��wP�P��U�4ٟR��^� ό������K�0@����!|p���X�;2-5���"��
    N���o�]�?G��لY&���v/7������R�V���瓉᧦�0`��k�h46�tl�?'��ԟ�����%@<s�~��ϜW�$�&�5}!�y��'a�[� �:�FRNS�E{:��
    �'��=a�(��F�`ʚ��v�d���N��`�AZ�<�C�>n�h)��5��L�1�7�wyM]U��y_^(����S*��<�m8�0��o���֨�������VDA�Zq)�4�ng��lA�~ڝD�h囚IB���Ud��6��)?ז����8�������/i����#�5�&�!�J�: )UF�J)QІ�j��7԰��.�D�Qz������
    ;p�|����s(b��f�#U����>̔�/���RuD�s,�W��m��1w8�x=��o`�N���5�L���O/�{y%�,�п:L5$	�/�^�ل��z�(�I�H����~��fA�P��=�wĆB���e]𳷞ϗ��K
    �13��C��1l`���Xu�x&=M�̮gC��b����o�(�K[��ٔI6���jt��ύܖ:����˳�܁��Ea��|�i4&�dg�7'�×���涢MEA�R���W�Q�P�#/!�i��&a�3�c�-�>z�xF<��_���i?a�>��V�`˚���j�t���&�L�_�mz��C�Jo�~{��%��D�1�r@�gh7
    ��*bEX"�8���'(��*�m9� ���ᅓ�擭���u�\]	��nm��qW�~ڍT�b埚!��E��^��Ѻ����8�������/y����!�]�e�1��N"�iSj�Ap[���|V��&Ġ��.��Ki���~J�32�!��E�|����dzc��v�#'���(��w�X��nsh�!�W�u�q��1v(�h6��%�^���m�_���c�7_%�Y�أ,55�.�^�\����Z�mS�z�dӉL��t��{V�P��-�}ĎB��E�rM��������M!�c}��I�@pv���He�s"=%���wS��S
    ����i��}����U ���z����� �������負�e3��|�6U�r5�77�ӝ������QTy�:��·Q�q��#%T���I&`�#�h�*�VCUn�dև
    �3��In\�>�c��@�aʊ���j�t���2�\��?�=�E�jNS�~q���9��D�!�bK�gh_EN��:lg����y��*�;�<����������r�5L�0�hA��)WW�ٌH�1䟊1��Ev��B��lP������>���!���,{�Ρ�!�M�n�1�
    6�yeF�O=w��%�|\��$ض]��?��Lk���,�Bn�I��}�z��U��dp��`�"'����.܆�4�H��=+�r%�Q�U��W��Eu-�~d��5�^���.�Où�J�
    e#�y��,@2�/�N�L����j�c}C�&���q��X��*]V�%��1�.ŏR��N�uM⦬�Կ�I�0@��e��Vvɬ�@y�!"-5���wS������1�M�?G����s ̑�l-������&�����昙��� `��z�=g�r?�4F��΃�����QTY�&���	�4�&�%	t�T��CRc�?�:�*�FS^f�hQ'ʗ�nܮ=a�8�C��5@������j�d���:�\�J�/�G��/n�x]�����1�U�t�gxOUE��:rUCpw�}���B*��,�8k���k�����������l�G)\�I�0)��mQ�+��n�;���-��Uf��B�����޶�fᥧ����|D���t��*]�\���T'#G�q	dRV��%�d��dɶWş��-3����&�4�h���<��Wʔ}'�Q�!�,����QW��k���hs�b5�Q���}��;m�7Of�Cd�HN���a�H�ֈQ�h<g�V��ov}J{S�z�C�\����{�s�1�IҏaԶL�����=�)����
    �e]⻷�ّ׺@5�nPޙL��s|ĝ�;�0>PU���3��Xb����.��j��لY&���W$o®��ܝ6�Z��௷ȡ��dp��z�0a6�y�it��������T
    �b�����f�w�F!~�2��'`�3�x�_�8W�h2p��W�M��]x4�{���+�*�����5� ���o���Gx�1�o
    The configuration file seems to be related to reference input, right? I thought I didn't have any reference input, so I didn't configure the relevant files
  • The STP file cannot be uploaded, so I changed the STP suffix to txt.
  • Regarding PROFILE, I did not connect Ref A/AA/B/BB, so I did not configure the profile file before. I did not use an evaluation board, I only used a chip, the register configuration was generated by the evaluation board software, and then communicated using a three wire SPI.
  • HI,
    I'm sorry to say, but the stp file you uploaded did not load correctly. The file should be a simple ASCII file and yours looks like this:
    I do not have an AD9547 evaluation board, so I used an AD9548 one. I was able to configure it and obtain the output frequencies you want.
    ;Header contains information about the setup file and revision
    <Header>
    Product = AD9547
    FileVersion = 1.0
    DecimalSeparator=.    ;Used for internationalization
    </Header>
    <RegisterMap>
    &h0,&b00010000   ;10 Hex, 016 Dec
    &h1,&b00000000   ;00 Hex, 000 Dec
    &h4,&b00000000   ;00 Hex, 000 Dec
    &h5,&b00000000   ;00 Hex, 000 Dec
    &h100,&b00011000   ;18 Hex, 024 Dec
    &h101,&b00101000   ;28 Hex, 040 Dec
    &h102,&b01000010   ;42 Hex, 066 Dec
    &h103,&b01000000   ;40 Hex, 064 Dec
    &h104,&b01000010   ;42 Hex, 066 Dec
    &h105,&b00001111   ;0F Hex, 015 Dec
    &h106,&b00000001   ;01 Hex, 001 Dec
    &h107,&b00000000   ;00 Hex, 000 Dec
    &h108,&b00000000   ;00 Hex, 000 Dec
    &h200,&b00000000   ;00 Hex, 000 Dec
    &h201,&b00000000   ;00 Hex, 000 Dec
    &h202,&b00000000   ;00 Hex, 000 Dec
    &h203,&b00000000   ;00 Hex, 000 Dec
    &h204,&b00000000   ;00 Hex, 000 Dec
    &h205,&b00000000   ;00 Hex, 000 Dec
    &h206,&b00000000   ;00 Hex, 000 Dec
    &h207,&b00000000   ;00 Hex, 000 Dec
    &h208,&b00000000   ;00 Hex, 000 Dec
    &h209,&b00000000   ;00 Hex, 000 Dec
    &h20A,&b00000000   ;00 Hex, 000 Dec
    &h20B,&b00000000   ;00 Hex, 000 Dec
    &h20C,&b00000000   ;00 Hex, 000 Dec
    &h20D,&b00000000   ;00 Hex, 000 Dec
    &h20E,&b00000000   ;00 Hex, 000 Dec
    &h211,&b00000000   ;00 Hex, 000 Dec
    &h212,&b00000000   ;00 Hex, 000 Dec
    &h213,&b11111111   ;FF Hex, 255 Dec
    &h214,&b00000001   ;01 Hex, 001 Dec
    &h300,&b01100110   ;66 Hex, 102 Dec
    &h301,&b01100110   ;66 Hex, 102 Dec
    &h302,&b01100110   ;66 Hex, 102 Dec
    &h303,&b01100110   ;66 Hex, 102 Dec
    &h304,&b01100110   ;66 Hex, 102 Dec
    &h305,&b00100110   ;26 Hex, 038 Dec
    &h306,&b00000000   ;00 Hex, 000 Dec
    &h307,&b00000000   ;00 Hex, 000 Dec
    &h308,&b00000000   ;00 Hex, 000 Dec
    &h309,&b00000000   ;00 Hex, 000 Dec
    &h30A,&b11111111   ;FF Hex, 255 Dec
    &h30B,&b11111111   ;FF Hex, 255 Dec
    &h30C,&b11111111   ;FF Hex, 255 Dec
    &h30D,&b00000000   ;00 Hex, 000 Dec
    &h30E,&b00000000   ;00 Hex, 000 Dec
    &h30F,&b00000000   ;00 Hex, 000 Dec
    &h310,&b00000000   ;00 Hex, 000 Dec
    &h311,&b00000000   ;00 Hex, 000 Dec
    &h312,&b00000000   ;00 Hex, 000 Dec
    &h313,&b00000000   ;00 Hex, 000 Dec
    &h314,&b11101000   ;E8 Hex, 232 Dec
    &h315,&b00000011   ;03 Hex, 003 Dec
    &h316,&b00000000   ;00 Hex, 000 Dec
    &h317,&b00000000   ;00 Hex, 000 Dec
    &h318,&b00110000   ;30 Hex, 048 Dec
    &h319,&b01110101   ;75 Hex, 117 Dec
    &h31A,&b00000000   ;00 Hex, 000 Dec
    &h31B,&b00000000   ;00 Hex, 000 Dec
    &h400,&b00001100   ;0C Hex, 012 Dec
    &h401,&b00000011   ;03 Hex, 003 Dec
    &h402,&b00000000   ;00 Hex, 000 Dec
    &h403,&b00000000   ;00 Hex, 000 Dec
    &h404,&b00001100   ;0C Hex, 012 Dec
    &h405,&b00000000   ;00 Hex, 000 Dec
    &h408,&b00000000   ;00 Hex, 000 Dec
    &h409,&b00000000   ;00 Hex, 000 Dec
    &h40A,&b00000000   ;00 Hex, 000 Dec
    &h40B,&b00000000   ;00 Hex, 000 Dec
    &h40C,&b00000010   ;02 Hex, 002 Dec
    &h40D,&b00000000   ;00 Hex, 000 Dec
    &h40E,&b00000000   ;00 Hex, 000 Dec
    &h40F,&b00000000   ;00 Hex, 000 Dec
    &h418,&b00000000   ;00 Hex, 000 Dec
    &h419,&b00000000   ;00 Hex, 000 Dec
    &h500,&b11110000   ;F0 Hex, 240 Dec
    &h501,&b00000000   ;00 Hex, 000 Dec
    &h503,&b00000000   ;00 Hex, 000 Dec
    &h504,&b00000000   ;00 Hex, 000 Dec
    &h507,&b00000000   ;00 Hex, 000 Dec
    &h600,&b00000000   ;00 Hex, 000 Dec
    &h601,&b00000000   ;00 Hex, 000 Dec
    &h602,&b11100001   ;E1 Hex, 225 Dec
    &h603,&b11110101   ;F5 Hex, 245 Dec
    &h604,&b00000101   ;05 Hex, 005 Dec
    &h605,&b00000000   ;00 Hex, 000 Dec
    &h606,&b00000000   ;00 Hex, 000 Dec
    &h607,&b00000000   ;00 Hex, 000 Dec
    &h608,&b11101000   ;E8 Hex, 232 Dec
    &h609,&b00000011   ;03 Hex, 003 Dec
    &h60A,&b00000000   ;00 Hex, 000 Dec
    &h60B,&b11101000   ;E8 Hex, 232 Dec
    &h60C,&b00000011   ;03 Hex, 003 Dec
    &h60D,&b00000000   ;00 Hex, 000 Dec
    &h60E,&b10001000   ;88 Hex, 136 Dec
    &h60F,&b00010011   ;13 Hex, 019 Dec
    &h610,&b10001000   ;88 Hex, 136 Dec
    &h611,&b00010011   ;13 Hex, 019 Dec
    &h612,&b01111110   ;7E Hex, 126 Dec
    &h613,&b10011100   ;9C Hex, 156 Dec
    &h614,&b00001010   ;0A Hex, 010 Dec
    &h615,&b10111110   ;BE Hex, 190 Dec
    &h616,&b10101001   ;A9 Hex, 169 Dec
    &h617,&b01000111   ;47 Hex, 071 Dec
    &h618,&b10010001   ;91 Hex, 145 Dec
    &h619,&b11110111   ;F7 Hex, 247 Dec
    &h61A,&b00100011   ;23 Hex, 035 Dec
    &h61B,&b10101010   ;AA Hex, 170 Dec
    &h61C,&b01101001   ;69 Hex, 105 Dec
    &h61D,&b00000110   ;06 Hex, 006 Dec
    &h61E,&b00001001   ;09 Hex, 009 Dec
    &h61F,&b00000000   ;00 Hex, 000 Dec
    &h620,&b00000000   ;00 Hex, 000 Dec
    &h621,&b00000000   ;00 Hex, 000 Dec
    &h622,&b10010101   ;95 Hex, 149 Dec
    &h623,&b00000000   ;00 Hex, 000 Dec
    &h624,&b00000000   ;00 Hex, 000 Dec
    &h625,&b00000000   ;00 Hex, 000 Dec
    &h626,&b00000000   ;00 Hex, 000 Dec
    &h627,&b00000000   ;00 Hex, 000 Dec
    &h628,&b00000000   ;00 Hex, 000 Dec
    &h629,&b00010000   ;10 Hex, 016 Dec
    &h62A,&b00100111   ;27 Hex, 039 Dec
    &h62B,&b00100000   ;20 Hex, 032 Dec
    &h62C,&b01000100   ;44 Hex, 068 Dec
    &h62D,&b11110100   ;F4 Hex, 244 Dec
    &h62E,&b00000001   ;01 Hex, 001 Dec
    &h62F,&b00000000   ;00 Hex, 000 Dec
    &h630,&b00100000   ;20 Hex, 032 Dec
    &h631,&b01000100   ;44 Hex, 068 Dec
    &h632,&b00000000   ;00 Hex, 000 Dec
    &h633,&b00000000   ;00 Hex, 000 Dec
    &h634,&b00000000   ;00 Hex, 000 Dec
    &h635,&b00000000   ;00 Hex, 000 Dec
    &h636,&b00000000   ;00 Hex, 000 Dec
    &h637,&b00000000   ;00 Hex, 000 Dec
    &h638,&b00000000   ;00 Hex, 000 Dec
    &h639,&b00000000   ;00 Hex, 000 Dec
    &h63A,&b00000000   ;00 Hex, 000 Dec
    &h63B,&b00000000   ;00 Hex, 000 Dec
    &h63C,&b00000000   ;00 Hex, 000 Dec
    &h63D,&b00000000   ;00 Hex, 000 Dec
    &h63E,&b00000000   ;00 Hex, 000 Dec
    &h63F,&b00000000   ;00 Hex, 000 Dec
    &h640,&b00000000   ;00 Hex, 000 Dec
    &h641,&b00000000   ;00 Hex, 000 Dec
    &h642,&b00000000   ;00 Hex, 000 Dec
    &h643,&b00000000   ;00 Hex, 000 Dec
    &h644,&b00000000   ;00 Hex, 000 Dec
    &h645,&b00000000   ;00 Hex, 000 Dec
    &h646,&b00000000   ;00 Hex, 000 Dec
    &h647,&b00000000   ;00 Hex, 000 Dec
    &h648,&b00000000   ;00 Hex, 000 Dec
    &h649,&b00000000   ;00 Hex, 000 Dec
    &h64A,&b00000000   ;00 Hex, 000 Dec
    &h64B,&b00000000   ;00 Hex, 000 Dec
    &h64C,&b00000000   ;00 Hex, 000 Dec
    &h64D,&b00000000   ;00 Hex, 000 Dec
    &h64E,&b00000000   ;00 Hex, 000 Dec
    &h64F,&b00000000   ;00 Hex, 000 Dec
    &h650,&b00000000   ;00 Hex, 000 Dec
    &h651,&b00000000   ;00 Hex, 000 Dec
    &h652,&b00000000   ;00 Hex, 000 Dec
    &h653,&b00000000   ;00 Hex, 000 Dec
    &h654,&b00000000   ;00 Hex, 000 Dec
    &h655,&b00000000   ;00 Hex, 000 Dec
    &h656,&b00000000   ;00 Hex, 000 Dec
    &h657,&b00000000   ;00 Hex, 000 Dec
    &h658,&b00000000   ;00 Hex, 000 Dec
    &h659,&b00000000   ;00 Hex, 000 Dec
    &h65A,&b00000000   ;00 Hex, 000 Dec
    &h65B,&b00000000   ;00 Hex, 000 Dec
    &h65C,&b00000000   ;00 Hex, 000 Dec
    &h65D,&b00000000   ;00 Hex, 000 Dec
    &h65E,&b00000000   ;00 Hex, 000 Dec
    &h65F,&b00000000   ;00 Hex, 000 Dec
    &h660,&b00000000   ;00 Hex, 000 Dec
    &h661,&b00000000   ;00 Hex, 000 Dec
    &h662,&b00000000   ;00 Hex, 000 Dec
    &h663,&b00000000   ;00 Hex, 000 Dec
    &h680,&b00000000   ;00 Hex, 000 Dec
    &h681,&b00000000   ;00 Hex, 000 Dec
    &h682,&b00000000   ;00 Hex, 000 Dec
    &h683,&b00000000   ;00 Hex, 000 Dec
    &h684,&b00000000   ;00 Hex, 000 Dec
    &h685,&b00000000   ;00 Hex, 000 Dec
    &h686,&b00000000   ;00 Hex, 000 Dec
    &h687,&b00000000   ;00 Hex, 000 Dec
    &h688,&b00000000   ;00 Hex, 000 Dec
    &h689,&b00000000   ;00 Hex, 000 Dec
    &h68A,&b00000000   ;00 Hex, 000 Dec
    &h68B,&b00000000   ;00 Hex, 000 Dec
    &h68C,&b00000000   ;00 Hex, 000 Dec
    &h68D,&b00000000   ;00 Hex, 000 Dec
    &h68E,&b00000000   ;00 Hex, 000 Dec
    &h68F,&b00000000   ;00 Hex, 000 Dec
    &h690,&b00000000   ;00 Hex, 000 Dec
    &h691,&b00000000   ;00 Hex, 000 Dec
    &h692,&b00000000   ;00 Hex, 000 Dec
    &h693,&b00000000   ;00 Hex, 000 Dec
    &h694,&b00000000   ;00 Hex, 000 Dec
    &h695,&b00000000   ;00 Hex, 000 Dec
    &h696,&b00000000   ;00 Hex, 000 Dec
    &h697,&b00000000   ;00 Hex, 000 Dec
    &h698,&b00000000   ;00 Hex, 000 Dec
    &h699,&b00000000   ;00 Hex, 000 Dec
    &h69A,&b00000000   ;00 Hex, 000 Dec
    &h69B,&b00000000   ;00 Hex, 000 Dec
    &h69C,&b00000000   ;00 Hex, 000 Dec
    &h69D,&b00000000   ;00 Hex, 000 Dec
    &h69E,&b00000000   ;00 Hex, 000 Dec
    &h69F,&b00000000   ;00 Hex, 000 Dec
    &h6A0,&b00000000   ;00 Hex, 000 Dec
    &h6A1,&b00000000   ;00 Hex, 000 Dec
    &h6A2,&b00000000   ;00 Hex, 000 Dec
    &h6A3,&b00000000   ;00 Hex, 000 Dec
    &h6A4,&b00000000   ;00 Hex, 000 Dec
    &h6A5,&b00000000   ;00 Hex, 000 Dec
    &h6A6,&b00000000   ;00 Hex, 000 Dec
    &h6A7,&b00000000   ;00 Hex, 000 Dec
    &h6A8,&b00000000   ;00 Hex, 000 Dec
    &h6A9,&b00000000   ;00 Hex, 000 Dec
    &h6AA,&b00000000   ;00 Hex, 000 Dec
    &h6AB,&b00000000   ;00 Hex, 000 Dec
    &h6AC,&b00000000   ;00 Hex, 000 Dec
    &h6AD,&b00000000   ;00 Hex, 000 Dec
    &h6AE,&b00000000   ;00 Hex, 000 Dec
    &h6AF,&b00000000   ;00 Hex, 000 Dec
    &h6B0,&b00000000   ;00 Hex, 000 Dec
    &h6B1,&b00000000   ;00 Hex, 000 Dec
    &h6B2,&b00000000   ;00 Hex, 000 Dec
    &h6B3,&b00000000   ;00 Hex, 000 Dec
    &h6B4,&b00000000   ;00 Hex, 000 Dec
    &h6B5,&b00000000   ;00 Hex, 000 Dec
    &h6B6,&b00000000   ;00 Hex, 000 Dec
    &h6B7,&b00000000   ;00 Hex, 000 Dec
    &h6B8,&b00000000   ;00 Hex, 000 Dec
    &h6B9,&b00000000   ;00 Hex, 000 Dec
    &h6BA,&b00000000   ;00 Hex, 000 Dec
    &h6BB,&b00000000   ;00 Hex, 000 Dec
    &h6BC,&b00000000   ;00 Hex, 000 Dec
    &h6BD,&b00000000   ;00 Hex, 000 Dec
    &h6BE,&b00000000   ;00 Hex, 000 Dec
    &h6BF,&b00000000   ;00 Hex, 000 Dec
    &h6C0,&b00000000   ;00 Hex, 000 Dec
    &h6C1,&b00000000   ;00 Hex, 000 Dec
    &h6C2,&b00000000   ;00 Hex, 000 Dec
    &h6C3,&b00000000   ;00 Hex, 000 Dec
    &h6C4,&b00000000   ;00 Hex, 000 Dec
    &h6C5,&b00000000   ;00 Hex, 000 Dec
    &h6C6,&b00000000   ;00 Hex, 000 Dec
    &h6C7,&b00000000   ;00 Hex, 000 Dec
    &h6C8,&b00000000   ;00 Hex, 000 Dec
    &h6C9,&b00000000   ;00 Hex, 000 Dec
    &h6CA,&b00000000   ;00 Hex, 000 Dec
    &h6CB,&b00000000   ;00 Hex, 000 Dec
    &h6CC,&b00000000   ;00 Hex, 000 Dec
    &h6CD,&b00000000   ;00 Hex, 000 Dec
    &h6CE,&b00000000   ;00 Hex, 000 Dec
    &h6CF,&b00000000   ;00 Hex, 000 Dec
    &h6D0,&b00000000   ;00 Hex, 000 Dec
    &h6D1,&b00000000   ;00 Hex, 000 Dec
    &h6D2,&b00000000   ;00 Hex, 000 Dec
    &h6D3,&b00000000   ;00 Hex, 000 Dec
    &h6D4,&b00000000   ;00 Hex, 000 Dec
    &h6D5,&b00000000   ;00 Hex, 000 Dec
    &h6D6,&b00000000   ;00 Hex, 000 Dec
    &h6D7,&b00000000   ;00 Hex, 000 Dec
    &h6D8,&b00000000   ;00 Hex, 000 Dec
    &h6D9,&b00000000   ;00 Hex, 000 Dec
    &h6DA,&b00000000   ;00 Hex, 000 Dec
    &h6DB,&b00000000   ;00 Hex, 000 Dec
    &h6DC,&b00000000   ;00 Hex, 000 Dec
    &h6DD,&b00000000   ;00 Hex, 000 Dec
    &h6DE,&b00000000   ;00 Hex, 000 Dec
    &h6DF,&b00000000   ;00 Hex, 000 Dec
    &h6E0,&b00000000   ;00 Hex, 000 Dec
    &h6E1,&b00000000   ;00 Hex, 000 Dec
    &h6E2,&b00000000   ;00 Hex, 000 Dec
    &h6E3,&b00000000   ;00 Hex, 000 Dec
    &h700,&b00000000   ;00 Hex, 000 Dec
    &h701,&b00000000   ;00 Hex, 000 Dec
    &h702,&b00000000   ;00 Hex, 000 Dec
    &h703,&b00000000   ;00 Hex, 000 Dec
    &h704,&b00000000   ;00 Hex, 000 Dec
    &h705,&b00000000   ;00 Hex, 000 Dec
    &h706,&b00000000   ;00 Hex, 000 Dec
    &h707,&b00000000   ;00 Hex, 000 Dec
    &h708,&b00000000   ;00 Hex, 000 Dec
    &h709,&b00000000   ;00 Hex, 000 Dec
    &h70A,&b00000000   ;00 Hex, 000 Dec
    &h70B,&b00000000   ;00 Hex, 000 Dec
    &h70C,&b00000000   ;00 Hex, 000 Dec
    &h70D,&b00000000   ;00 Hex, 000 Dec
    &h70E,&b00000000   ;00 Hex, 000 Dec
    &h70F,&b00000000   ;00 Hex, 000 Dec
    &h710,&b00000000   ;00 Hex, 000 Dec
    &h711,&b00000000   ;00 Hex, 000 Dec
    &h712,&b00000000   ;00 Hex, 000 Dec
    &h713,&b00000000   ;00 Hex, 000 Dec
    &h714,&b00000000   ;00 Hex, 000 Dec
    &h715,&b00000000   ;00 Hex, 000 Dec
    &h716,&b00000000   ;00 Hex, 000 Dec
    &h717,&b00000000   ;00 Hex, 000 Dec
    &h718,&b00000000   ;00 Hex, 000 Dec
    &h719,&b00000000   ;00 Hex, 000 Dec
    &h71A,&b00000000   ;00 Hex, 000 Dec
    &h71B,&b00000000   ;00 Hex, 000 Dec
    &h71C,&b00000000   ;00 Hex, 000 Dec
    &h71D,&b00000000   ;00 Hex, 000 Dec
    &h71E,&b00000000   ;00 Hex, 000 Dec
    &h71F,&b00000000   ;00 Hex, 000 Dec
    &h720,&b00000000   ;00 Hex, 000 Dec
    &h721,&b00000000   ;00 Hex, 000 Dec
    &h722,&b00000000   ;00 Hex, 000 Dec
    &h723,&b00000000   ;00 Hex, 000 Dec
    &h724,&b00000000   ;00 Hex, 000 Dec
    &h725,&b00000000   ;00 Hex, 000 Dec
    &h726,&b00000000   ;00 Hex, 000 Dec
    &h727,&b00000000   ;00 Hex, 000 Dec
    &h728,&b00000000   ;00 Hex, 000 Dec
    &h729,&b00000000   ;00 Hex, 000 Dec
    &h72A,&b00000000   ;00 Hex, 000 Dec
    &h72B,&b00000000   ;00 Hex, 000 Dec
    &h72C,&b00000000   ;00 Hex, 000 Dec
    &h72D,&b00000000   ;00 Hex, 000 Dec
    &h72E,&b00000000   ;00 Hex, 000 Dec
    &h72F,&b00000000   ;00 Hex, 000 Dec
    &h730,&b00000000   ;00 Hex, 000 Dec
    &h731,&b00000000   ;00 Hex, 000 Dec
    &h732,&b00000000   ;00 Hex, 000 Dec
    &h733,&b00000000   ;00 Hex, 000 Dec
    &h734,&b00000000   ;00 Hex, 000 Dec
    &h735,&b00000000   ;00 Hex, 000 Dec
    &h736,&b00000000   ;00 Hex, 000 Dec
    &h737,&b00000000   ;00 Hex, 000 Dec
    &h738,&b00000000   ;00 Hex, 000 Dec
    &h739,&b00000000   ;00 Hex, 000 Dec
    &h73A,&b00000000   ;00 Hex, 000 Dec
    &h73B,&b00000000   ;00 Hex, 000 Dec
    &h73C,&b00000000   ;00 Hex, 000 Dec
    &h73D,&b00000000   ;00 Hex, 000 Dec
    &h73E,&b00000000   ;00 Hex, 000 Dec
    &h73F,&b00000000   ;00 Hex, 000 Dec
    &h740,&b00000000   ;00 Hex, 000 Dec
    &h741,&b00000000   ;00 Hex, 000 Dec
    &h742,&b00000000   ;00 Hex, 000 Dec
    &h743,&b00000000   ;00 Hex, 000 Dec
    &h744,&b00000000   ;00 Hex, 000 Dec
    &h745,&b00000000   ;00 Hex, 000 Dec
    &h746,&b00000000   ;00 Hex, 000 Dec
    &h747,&b00000000   ;00 Hex, 000 Dec
    &h748,&b00000000   ;00 Hex, 000 Dec
    &h749,&b00000000   ;00 Hex, 000 Dec
    &h74A,&b00000000   ;00 Hex, 000 Dec
    &h74B,&b00000000   ;00 Hex, 000 Dec
    &h74C,&b00000000   ;00 Hex, 000 Dec
    &h74D,&b00000000   ;00 Hex, 000 Dec
    &h74E,&b00000000   ;00 Hex, 000 Dec
    &h74F,&b00000000   ;00 Hex, 000 Dec
    &h750,&b00000000   ;00 Hex, 000 Dec
    &h751,&b00000000   ;00 Hex, 000 Dec
    &h752,&b00000000   ;00 Hex, 000 Dec
    &h753,&b00000000   ;00 Hex, 000 Dec
    &h754,&b00000000   ;00 Hex, 000 Dec
    &h755,&b00000000   ;00 Hex, 000 Dec
    &h756,&b00000000   ;00 Hex, 000 Dec
    &h757,&b00000000   ;00 Hex, 000 Dec
    &h758,&b00000000   ;00 Hex, 000 Dec
    &h759,&b00000000   ;00 Hex, 000 Dec
    &h75A,&b00000000   ;00 Hex, 000 Dec
    &h75B,&b00000000   ;00 Hex, 000 Dec
    &h75C,&b00000000   ;00 Hex, 000 Dec
    &h75D,&b00000000   ;00 Hex, 000 Dec
    &h75E,&b00000000   ;00 Hex, 000 Dec
    &h75F,&b00000000   ;00 Hex, 000 Dec
    &h760,&b00000000   ;00 Hex, 000 Dec
    &h761,&b00000000   ;00 Hex, 000 Dec
    &h762,&b00000000   ;00 Hex, 000 Dec
    &h763,&b00000000   ;00 Hex, 000 Dec
    &h780,&b00000000   ;00 Hex, 000 Dec
    &h781,&b00000000   ;00 Hex, 000 Dec
    &h782,&b00000000   ;00 Hex, 000 Dec
    &h783,&b00000000   ;00 Hex, 000 Dec
    &h784,&b00000000   ;00 Hex, 000 Dec
    &h785,&b00000000   ;00 Hex, 000 Dec
    &h786,&b00000000   ;00 Hex, 000 Dec
    &h787,&b00000000   ;00 Hex, 000 Dec
    &h788,&b00000000   ;00 Hex, 000 Dec
    &h789,&b00000000   ;00 Hex, 000 Dec
    &h78A,&b00000000   ;00 Hex, 000 Dec
    &h78B,&b00000000   ;00 Hex, 000 Dec
    &h78C,&b00000000   ;00 Hex, 000 Dec
    &h78D,&b00000000   ;00 Hex, 000 Dec
    &h78E,&b00000000   ;00 Hex, 000 Dec
    &h78F,&b00000000   ;00 Hex, 000 Dec
    &h790,&b00000000   ;00 Hex, 000 Dec
    &h791,&b00000000   ;00 Hex, 000 Dec
    &h792,&b00000000   ;00 Hex, 000 Dec
    &h793,&b00000000   ;00 Hex, 000 Dec
    &h794,&b00000000   ;00 Hex, 000 Dec
    &h795,&b00000000   ;00 Hex, 000 Dec
    &h796,&b00000000   ;00 Hex, 000 Dec
    &h797,&b00000000   ;00 Hex, 000 Dec
    &h798,&b00000000   ;00 Hex, 000 Dec
    &h799,&b00000000   ;00 Hex, 000 Dec
    &h79A,&b00000000   ;00 Hex, 000 Dec
    &h79B,&b00000000   ;00 Hex, 000 Dec
    &h79C,&b00000000   ;00 Hex, 000 Dec
    &h79D,&b00000000   ;00 Hex, 000 Dec
    &h79E,&b00000000   ;00 Hex, 000 Dec
    &h79F,&b00000000   ;00 Hex, 000 Dec
    &h7A0,&b00000000   ;00 Hex, 000 Dec
    &h7A1,&b00000000   ;00 Hex, 000 Dec
    &h7A2,&b00000000   ;00 Hex, 000 Dec
    &h7A3,&b00000000   ;00 Hex, 000 Dec
    &h7A4,&b00000000   ;00 Hex, 000 Dec
    &h7A5,&b00000000   ;00 Hex, 000 Dec
    &h7A6,&b00000000   ;00 Hex, 000 Dec
    &h7A7,&b00000000   ;00 Hex, 000 Dec
    &h7A8,&b00000000   ;00 Hex, 000 Dec
    &h7A9,&b00000000   ;00 Hex, 000 Dec
    &h7AA,&b00000000   ;00 Hex, 000 Dec
    &h7AB,&b00000000   ;00 Hex, 000 Dec
    &h7AC,&b00000000   ;00 Hex, 000 Dec
    &h7AD,&b00000000   ;00 Hex, 000 Dec
    &h7AE,&b00000000   ;00 Hex, 000 Dec
    &h7AF,&b00000000   ;00 Hex, 000 Dec
    &h7B0,&b00000000   ;00 Hex, 000 Dec
    &h7B1,&b00000000   ;00 Hex, 000 Dec
    &h7B2,&b00000000   ;00 Hex, 000 Dec
    &h7B3,&b00000000   ;00 Hex, 000 Dec
    &h7B4,&b00000000   ;00 Hex, 000 Dec
    &h7B5,&b00000000   ;00 Hex, 000 Dec
    &h7B6,&b00000000   ;00 Hex, 000 Dec
    &h7B7,&b00000000   ;00 Hex, 000 Dec
    &h7B8,&b00000000   ;00 Hex, 000 Dec
    &h7B9,&b00000000   ;00 Hex, 000 Dec
    &h7BA,&b00000000   ;00 Hex, 000 Dec
    &h7BB,&b00000000   ;00 Hex, 000 Dec
    &h7BC,&b00000000   ;00 Hex, 000 Dec
    &h7BD,&b00000000   ;00 Hex, 000 Dec
    &h7BE,&b00000000   ;00 Hex, 000 Dec
    &h7BF,&b00000000   ;00 Hex, 000 Dec
    &h7C0,&b00000000   ;00 Hex, 000 Dec
    &h7C1,&b00000000   ;00 Hex, 000 Dec
    &h7C2,&b00000000   ;00 Hex, 000 Dec
    &h7C3,&b00000000   ;00 Hex, 000 Dec
    &h7C4,&b00000000   ;00 Hex, 000 Dec
    &h7C5,&b00000000   ;00 Hex, 000 Dec
    &h7C6,&b00000000   ;00 Hex, 000 Dec
    &h7C7,&b00000000   ;00 Hex, 000 Dec
    &h7C8,&b00000000   ;00 Hex, 000 Dec
    &h7C9,&b00000000   ;00 Hex, 000 Dec
    &h7CA,&b00000000   ;00 Hex, 000 Dec
    &h7CB,&b00000000   ;00 Hex, 000 Dec
    &h7CC,&b00000000   ;00 Hex, 000 Dec
    &h7CD,&b00000000   ;00 Hex, 000 Dec
    &h7CE,&b00000000   ;00 Hex, 000 Dec
    &h7CF,&b00000000   ;00 Hex, 000 Dec
    &h7D0,&b00000000   ;00 Hex, 000 Dec
    &h7D1,&b00000000   ;00 Hex, 000 Dec
    &h7D2,&b00000000   ;00 Hex, 000 Dec
    &h7D3,&b00000000   ;00 Hex, 000 Dec
    &h7D4,&b00000000   ;00 Hex, 000 Dec
    &h7D5,&b00000000   ;00 Hex, 000 Dec
    &h7D6,&b00000000   ;00 Hex, 000 Dec
    &h7D7,&b00000000   ;00 Hex, 000 Dec
    &h7D8,&b00000000   ;00 Hex, 000 Dec
    &h7D9,&b00000000   ;00 Hex, 000 Dec
    &h7DA,&b00000000   ;00 Hex, 000 Dec
    &h7DB,&b00000000   ;00 Hex, 000 Dec
    &h7DC,&b00000000   ;00 Hex, 000 Dec
    &h7DD,&b00000000   ;00 Hex, 000 Dec
    &h7DE,&b00000000   ;00 Hex, 000 Dec
    &h7DF,&b00000000   ;00 Hex, 000 Dec
    &h7E0,&b00000000   ;00 Hex, 000 Dec
    &h7E1,&b00000000   ;00 Hex, 000 Dec
    &h7E2,&b00000000   ;00 Hex, 000 Dec
    &h7E3,&b00000000   ;00 Hex, 000 Dec
    &hA00,&b00000000   ;00 Hex, 000 Dec
    &hA01,&b00000000   ;00 Hex, 000 Dec
    &hA02,&b00000000   ;00 Hex, 000 Dec
    &hA03,&b00000000   ;00 Hex, 000 Dec
    &hA04,&b00000000   ;00 Hex, 000 Dec
    &hA05,&b00000000   ;00 Hex, 000 Dec
    &hA06,&b00000000   ;00 Hex, 000 Dec
    &hA07,&b00000000   ;00 Hex, 000 Dec
    &hA08,&b00000000   ;00 Hex, 000 Dec
    &hA09,&b00000000   ;00 Hex, 000 Dec
    &hA0C,&b00000000   ;00 Hex, 000 Dec
    &hA0D,&b00000000   ;00 Hex, 000 Dec
    &hA0E,&b00000000   ;00 Hex, 000 Dec
    &hA0F,&b00000000   ;00 Hex, 000 Dec
    &hA10,&b00000000   ;00 Hex, 000 Dec
    &hE00,&b00000000   ;00 Hex, 000 Dec
    &hE01,&b00000000   ;00 Hex, 000 Dec
    &hE02,&b00000000   ;00 Hex, 000 Dec
    &hE03,&b00000000   ;00 Hex, 000 Dec
    &hE10,&b00001000   ;08 Hex, 008 Dec
    &hE11,&b00000001   ;01 Hex, 001 Dec
    &hE12,&b00000000   ;00 Hex, 000 Dec
    &hE13,&b10000000   ;80 Hex, 128 Dec
    &hE14,&b10100000   ;A0 Hex, 160 Dec
    &hE15,&b00010100   ;14 Hex, 020 Dec
    &hE16,&b00000010   ;02 Hex, 002 Dec
    &hE17,&b00000000   ;00 Hex, 000 Dec
    &hE18,&b00011011   ;1B Hex, 027 Dec
    &hE19,&b00000011   ;03 Hex, 003 Dec
    &hE1A,&b00000000   ;00 Hex, 000 Dec
    &hE1B,&b00011001   ;19 Hex, 025 Dec
    &hE1C,&b00000100   ;04 Hex, 004 Dec
    &hE1D,&b00000000   ;00 Hex, 000 Dec
    &hE1E,&b10000000   ;80 Hex, 128 Dec
    &hE1F,&b00000111   ;07 Hex, 007 Dec
    &hE20,&b00000101   ;05 Hex, 005 Dec
    &hE21,&b00000000   ;00 Hex, 000 Dec
    &hE22,&b01100011   ;63 Hex, 099 Dec
    &hE23,&b00000110   ;06 Hex, 006 Dec
    &hE24,&b00000000   ;00 Hex, 000 Dec
    &hE25,&b01100011   ;63 Hex, 099 Dec
    &hE26,&b00000110   ;06 Hex, 006 Dec
    &hE27,&b10000000   ;80 Hex, 128 Dec
    &hE28,&b01100011   ;63 Hex, 099 Dec
    &hE29,&b00000111   ;07 Hex, 007 Dec
    &hE2A,&b00000000   ;00 Hex, 000 Dec
    &hE2B,&b01100011   ;63 Hex, 099 Dec
    &hE2C,&b00000111   ;07 Hex, 007 Dec
    &hE2D,&b10000000   ;80 Hex, 128 Dec
    &hE2E,&b10000000   ;80 Hex, 128 Dec
    &hE2F,&b00010000   ;10 Hex, 016 Dec
    &hE30,&b00001010   ;0A Hex, 010 Dec
    &hE31,&b00000000   ;00 Hex, 000 Dec
    &hE32,&b10000000   ;80 Hex, 128 Dec
    &hE33,&b11111111   ;FF Hex, 255 Dec
    &hE34,&b00000000   ;00 Hex, 000 Dec
    &hE35,&b00000000   ;00 Hex, 000 Dec
    &hE36,&b00000000   ;00 Hex, 000 Dec
    &hE37,&b00000000   ;00 Hex, 000 Dec
    &hE38,&b00000000   ;00 Hex, 000 Dec
    &hE39,&b00000000   ;00 Hex, 000 Dec
    &hE3A,&b00000000   ;00 Hex, 000 Dec
    &hE3B,&b00000000   ;00 Hex, 000 Dec
    &hE3C,&b00000000   ;00 Hex, 000 Dec
    &hE3D,&b00000000   ;00 Hex, 000 Dec
    &hE3E,&b00000000   ;00 Hex, 000 Dec
    &hE3F,&b00000000   ;00 Hex, 000 Dec
    </RegisterMap>
    <PinStates>
    MPins=&h0
    </PinStates>
    <SoftwareSettings>
    AutoIOUpdate=1              ;AutoIOUpdate Setting
    OverRideJumpersONReset=1    ;1 = Override M-Pin Jumper Settings, 0 = Use M-Pin Jumper Settings
    MPinStatesDuringReset=&h7   ;M-Pin States to be applied to the M-Pins durring a reset
    ExternalClock=1000    ;External Clock Frequency in MHz
    </SoftwareSettings>
    I then created an AD9547 setup targeting your situation: 1GHz system clock input, OUT0=150MHz  LVDS, OUT1=50 MHz CMOS based on the experience using the AD9548.
    It should work. I used REFA=10MHz, 3dBm from a signal generator. If you need to use a different one, change the profile. Do not forget to generate a reference acquisition as part of the initialization sequence. See section Device register programming at page 24, rev G data sheet
    Petre
