MAX96724FGTN/V+ - sending a clock signal through the reverse-channel.
Category: Datasheet/Specs
Product Number: MAX96724FGTN/V+
Hi there,
My team and I are attempting to utilize the MAX96724FGTN/V+ with a custom Jetson Orin Nano carrier board. The Jetson Orin Nano has a signal referred to as CAM_MCLK which some cameras require as a clock signal to the camera sensor. Is it possible to send this clock signal backwards through the GMSL2 channel to the cameras on the other end? What information is required to determine this, e.g. clock frequency. Would it be easier to generate this signal on the other end instead? Thanks!
Edit Notes
Changed backwards to reverse
[edited by: HarrisonR at 11:48 AM (GMT -5) on 9 Nov 2024]
