I'm trying to perform clock correction using the AD9546 and so far have been unable to get it working. Here's a description of my setup:
I'm using the AD9546/PCBZ eval board for my PPS testing. I've modified the board as follows:
To use an external OCXO as a clock source instead of the on-board crystal: R308 & R309 -> DNP, C304 & C307 -> 0.1uF, R306 -> 649Ω, R307 -> 220Ω
To use an external PPS signal as a reference: R304: 49.9Ω, R305: 0Ω.
For my hardware setup, I connected the output of a 60 MHz OCXO eval board (3.3V logic) to J305 to be my system clock. I also connected the 1PPS output of a u-blox EVK-F9T to J304 (REFBB) to be my PPS source.
I then powered up the board and connected to it using the AD9546 Evaluation Software Rev1.3.0.0. I set up a configuration that takes in the OCXO and PPS inputs and outputs two signals: one at 1Hz and one at 60 MHz. I created a DPLL Translation Profile to use REFBB as the reference source and the 1Hz output signal as the feedback source.
When I run the system with this configuration, I see the following indications in the GUI: the system clock locks and is stable, the APLL locks, and REFBB is valid. However, the DPLL never gets a frequency or phase lock. When I watch the DPLL tub values as the system runs, they slowly decrement down to the min value of -2048, and sometimes they increase above that value, but they never rise above 0. I also see a red arrow appear behind the DPLL NCO in the Channel0 block diagram.
1. My specific question: do you know why the DPLL fails to lock in my tests?
2. My more general question: the AD9546 GUI is quite complicated, so I don't feel confident that I set up everything correctly. Do you know of a procedure that can be used to diagnose clocking failures like this one and fix them? Is there a document that guides the user through setting up clocking configurations that goes into more detail than the AD9546 eval board user's guide?
Any help with this would be appreciated.
Cam
