pulse noise
Product Number: ltc6993-1
LTC-6993 - 2
I try isolating noise using polarized capacitor
but noise is in there ill use manual datasheet and right computation of resistance in resistors but still noise is in there
    Do you have the LTspice simulation, or can you share the schematic? I would like to understand your application in detail.
    It seems that this noise is coupled into the output from external sources. Can you measure the supply level with an oscilloscope, I would like to investigate if there is a noise in the supply line.
    Emrecan
