Issue in synchronization
Product Number: ad9547
Clock synchronizer AD9547, if i am not wrong, It supposed to indicate Phase lock condition only when the phase difference between OUT and REFin is within the limits set by "phase lock threshold" (set in registers x0629,x062A).
Whether the device achieved phase lock or not, is indicated by register x0D0A (or any assigned multifunction pin).
but in my case, once the phase lock achieved (with 30nsec between REFIN and OUT), after some time, the phase difference increased about 230nSec. i programmed phase lock threshold registers to 65nSec. but still device doesn't showing as phase is in unlock state. both D0A register and multifunction telling that device is in phase lock state.
i have two doubts here. what causing the phase difference between REFIN and OUT increasing over time?
Why device doesnt showing phase unlocked despite programmed value being 65nSec? can some one clear this out.
  • HI,
    It supposed to indicate Phase lock condition only when the phase difference between OUT and REFin is within the limits set by "phase lock threshold""
    It is not quite like this, The AD9547 looks at the difference between the reference and the feedback clock (not the output clock).
    Yes.
    i have two doubts here. what causing the phase difference between REFIN and OUT increasing over time?\
    Please send me the stp file you created with the evaluation software for me to take a look.
    The AD9547 DPLL has two modes in which it can be configured. One is phase buildout and in this mode the phase between the output and the reference may change from one power up to another. Important is that when the reference switches, the phase remains unchanged.
    The second mode is the hitless mode and this is what the data sheet states about it:
    From your description of the problem, the fact that you focus on the phase difference between the reference and the output, you seem to refer to a zero delay mode, described at page 42 in rev G data sheet
    Please send me the stp file and then I can discuss more. Are you running this configuration on the evaluation board or on your own designed board?
    Petre
  • Hi petre,
    Here is the registers data that i am using to program the AD9547.
    I am doing this in a custom board, not eval.
    /*Ref Input 32Khz (Differential), Sync out = 4.096MHz,32Khz(Single ended)*/
    /*System Clock=1G */
    /*Ref Selection Mode =Automatic*/
    /*Loop Mode = Automatic*/
    /*Phase Build out Threshold = 0*/
    /*Auto sync mode = Sync on Phase Lock*/
    /*SyncSource=Reference*/
    /*Output-Single ended, -ve out disabled*/
    /*Out divider= 40,5120, Free run frequency= 163.84Mhz*/
    /*Phase Lock threshhold changed to 65nSec*/
    /*REF A power Down, REF B-Single ended input*/
    /*M3-Frequency Lock, M4-Phase Lock, M6-REF B Valid*/
    0X0,0X10,
    0X1,0X0,
    0X4,0X0,
    0X5,0X0,
    0X100,0X18,
    0X101,0X28,
    0X102,0X45,
    0X103,0X40,
    0X104,0X42,
    0X105,0X0F,
    0X106,0X1,
    0X107,0X0,
    0X108,0X0,
    0X200,0X0,
    0X201,0X0,
    0X202,0X0,
    0X203,0X96,
    0X204,0X95,
    0X205,0X0,
    0X206,0XB2,
    0X207,0X0,
    0X208,0X0,
    0X209,0X0,
    0X20A,0X0,
    0X20B,0X0,
    0X20C,0X0,
    0X20D,0X0,
    0X20E,0X0,
    0X211,0X0,
    0X212,0X0,
    0X213,0XFF,
    0X214,0X1,
    0X300,0XD2,
    0X301,0XC6,
    0X302,0X11,
    0X303,0X6B,
    0X304,0XF1,
    0X305,0X29,
    0X306,0X0,
    0X307,0X0,
    0X308,0X0,
    0X309,0X0,
    0X30A,0XFF,
    0X30B,0XFF,
    0X30C,0XFF,
    0X30D,0X0,
    0X30E,0X0,
    0X30F,0X0,
    0X310,0X0,
    0X311,0X0,
    0X312,0X0,
    0X313,0X0,
    0X314,0XE8,
    0X315,0X3,
    0X316,0X0,
    0X317,0X0,
    0X318,0X30,
    0X319,0X75,
    0X31A,0X0,
    0X31B,0X0,
    0X400,0X0C,
    0X401,0X3,
    0X402,0X10,
    0X403,0X2,
    0X404,0X9,
    0X405,0X9,
    0X408,0X27,
    0X409,0X0,
    0X40A,0X0,
    0X40B,0X0,
    0X40C,0XFF,
    0X40D,0X13,
    0X40E,0X0,
    0X40F,0X0,
    0X418,0X0,
    0X419,0X0,
    0X500,0XF3,
    0X501,0X33,
    0X503,0X88,
    0X504,0X88,
    0X507,0X0,
    0X600,0X0,
    0X601,0X80,
    0X602,0X28,
    0X603,0XA5,
    0X604,0X46,
    0X605,0X7,
    0X606,0X0,
    0X607,0X0,
    0X608,0XE8,
    0X609,0X3,
    0X60A,0X0,
    0X60B,0XE8,
    0X60C,0X3,
    0X60D,0X0,
    0X60E,0X88,
    0X60F,0X13,
    0X610,0X88,
    0X611,0X13,
    0X612,0XED,
    0X613,0XA6,
    0X614,0X5,
    0X615,0XBE,
    0X616,0XA9,
    0X617,0X47,
    0X618,0X91,
    0X619,0XF7,
    0X61A,0X23,
    0X61B,0XAA,
    0X61C,0X69,
    0X61D,0X6,
    0X61E,0X0,
    0X61F,0X0,
    0X620,0X0,
    0X621,0X0,
    0X622,0XFF,
    0X623,0X13,
    0X624,0X0,
    0X625,0X0,
    0X626,0X0,
    0X627,0X0,
    0X628,0X0,
    0X629,0XE8,
    0X62A,0XFD,
    0X62B,0X20,
    0X62C,0X44,
    0X62D,0XE8,
    0X62E,0X3,
    0X62F,0X0,
    0X630,0X20,
    0X631,0X44,
    0X632,0X0,
    0X633,0X0,
    0X634,0X0,
    0X635,0X0,
    0X636,0X0,
    0X637,0X0,
    0X638,0X0,
    0X639,0X0,
    0X63A,0X0,
    0X63B,0X0,
    0X63C,0X0,
    0X63D,0X0,
    0X63E,0X0,
    0X63F,0X0,
    0X640,0X0,
    0X641,0X0,
    0X642,0X0,
    0X643,0X0,
    0X644,0X0,
    0X645,0X0,
    0X646,0X0,
    0X647,0X0,
    0X648,0X0,
    0X649,0X0,
    0X64A,0X0,
    0X64B,0X0,
    0X64C,0X0,
    0X64D,0X0,
    0X64E,0X0,
    0X64F,0X0,
    0X650,0X0,
    0X651,0X0,
    0X652,0X0,
    0X653,0X0,
    0X654,0X0,
    0X655,0X0,
    0X656,0X0,
    0X657,0X0,
    0X658,0X0,
    0X659,0X0,
    0X65A,0X0,
    0X65B,0X0,
    0X65C,0X0,
    0X65D,0X0,
    0X65E,0X0,
    0X65F,0X0,
    0X660,0X0,
    0X661,0X0,
    0X662,0X0,
    0X663,0X0,
    0X680,0X0,
    0X681,0X0,
    0X682,0X0,
    0X683,0X0,
    0X684,0X0,
    0X685,0X0,
    0X686,0X0,
    0X687,0X0,
    0X688,0X0,
    0X689,0X0,
    0X68A,0X0,
    0X68B,0X0,
    0X68C,0X0,
    0X68D,0X0,
    0X68E,0X0,
    0X68F,0X0,
    0X690,0X0,
    0X691,0X0,
    0X692,0X0,
    0X693,0X0,
    0X694,0X0,
    0X695,0X0,
    0X696,0X0,
    0X697,0X0,
    0X698,0X0,
    0X699,0X0,
    0X69A,0X0,
    0X69B,0X0,
    0X69C,0X0,
    0X69D,0X0,
    0X69E,0X0,
    0X69F,0X0,
    0X6A0,0X0,
    0X6A1,0X0,
    0X6A2,0X0,
    0X6A3,0X0,
    0X6A4,0X0,
    0X6A5,0X0,
    0X6A6,0X0,
    0X6A7,0X0,
    0X6A8,0X0,
    0X6A9,0X0,
    0X6AA,0X0,
    0X6AB,0X0,
    0X6AC,0X0,
    0X6AD,0X0,
    0X6AE,0X0,
    0X6AF,0X0,
    0X6B0,0X0,
    0X6B1,0X0,
    0X6B2,0X0,
    0X6B3,0X0,
    0X6B4,0X0,
    0X6B5,0X0,
    0X6B6,0X0,
    0X6B7,0X0,
    0X6B8,0X0,
    0X6B9,0X0,
    0X6BA,0X0,
    0X6BB,0X0,
    0X6BC,0X0,
    0X6BD,0X0,
    0X6BE,0X0,
    0X6BF,0X0,
    0X6C0,0X0,
    0X6C1,0X0,
    0X6C2,0X0,
    0X6C3,0X0,
    0X6C4,0X0,
    0X6C5,0X0,
    0X6C6,0X0,
    0X6C7,0X0,
    0X6C8,0X0,
    0X6C9,0X0,
    0X6CA,0X0,
    0X6CB,0X0,
    0X6CC,0X0,
    0X6CD,0X0,
    0X6CE,0X0,
    0X6CF,0X0,
    0X6D0,0X0,
    0X6D1,0X0,
    0X6D2,0X0,
    0X6D3,0X0,
    0X6D4,0X0,
    0X6D5,0X0,
    0X6D6,0X0,
    0X6D7,0X0,
    0X6D8,0X0,
    0X6D9,0X0,
    0X6DA,0X0,
    0X6DB,0X0,
    0X6DC,0X0,
    0X6DD,0X0,
    0X6DE,0X0,
    0X6DF,0X0,
    0X6E0,0X0,
    0X6E1,0X0,
    0X6E2,0X0,
    0X6E3,0X0,
    0X700,0X0,
    0X701,0X0,
    0X702,0X0,
    0X703,0X0,
    0X704,0X0,
    0X705,0X0,
    0X706,0X0,
    0X707,0X0,
    0X708,0X0,
    0X709,0X0,
    0X70A,0X0,
    0X70B,0X0,
    0X70C,0X0,
    0X70D,0X0,
    0X70E,0X0,
    0X70F,0X0,
    0X710,0X0,
    0X711,0X0,
    0X712,0X0,
    0X713,0X0,
    0X714,0X0,
    0X715,0X0,
    0X716,0X0,
    0X717,0X0,
    0X718,0X0,
    0X719,0X0,
    0X71A,0X0,
    0X71B,0X0,
    0X71C,0X0,
    0X71D,0X0,
    0X71E,0X0,
    0X71F,0X0,
    0X720,0X0,
    0X721,0X0,
    0X722,0X0,
    0X723,0X0,
    0X724,0X0,
    0X725,0X0,
    0X726,0X0,
    0X727,0X0,
    0X728,0X0,
    0X729,0X0,
    0X72A,0X0,
    0X72B,0X0,
    0X72C,0X0,
    0X72D,0X0,
    0X72E,0X0,
    0X72F,0X0,
    0X730,0X0,
    0X731,0X0,
    0X732,0X0,
    0X733,0X0,
    0X734,0X0,
    0X735,0X0,
    0X736,0X0,
    0X737,0X0,
    0X738,0X0,
    0X739,0X0,
    0X73A,0X0,
    0X73B,0X0,
    0X73C,0X0,
    0X73D,0X0,
    0X73E,0X0,
    0X73F,0X0,
    0X740,0X0,
    0X741,0X0,
    0X742,0X0,
    0X743,0X0,
    0X744,0X0,
    0X745,0X0,
    0X746,0X0,
    0X747,0X0,
    0X748,0X0,
    0X749,0X0,
    0X74A,0X0,
    0X74B,0X0,
    0X74C,0X0,
    0X74D,0X0,
    0X74E,0X0,
    0X74F,0X0,
    0X750,0X0,
    0X751,0X0,
    0X752,0X0,
    0X753,0X0,
    0X754,0X0,
    0X755,0X0,
    0X756,0X0,
    0X757,0X0,
    0X758,0X0,
    0X759,0X0,
    0X75A,0X0,
    0X75B,0X0,
    0X75C,0X0,
    0X75D,0X0,
    0X75E,0X0,
    0X75F,0X0,
    0X760,0X0,
    0X761,0X0,
    0X762,0X0,
    0X763,0X0,
    0X780,0X0,
    0X781,0X0,
    0X782,0X0,
    0X783,0X0,
    0X784,0X0,
    0X785,0X0,
    0X786,0X0,
    0X787,0X0,
    0X788,0X0,
    0X789,0X0,
    0X78A,0X0,
    0X78B,0X0,
    0X78C,0X0,
    0X78D,0X0,
    0X78E,0X0,
    0X78F,0X0,
    0X790,0X0,
    0X791,0X0,
    0X792,0X0,
    0X793,0X0,
    0X794,0X0,
    0X795,0X0,
    0X796,0X0,
    0X797,0X0,
    0X798,0X0,
    0X799,0X0,
    0X79A,0X0,
    0X79B,0X0,
    0X79C,0X0,
    0X79D,0X0,
    0X79E,0X0,
    0X79F,0X0,
    0X7A0,0X0,
    0X7A1,0X0,
    0X7A2,0X0,
    0X7A3,0X0,
    0X7A4,0X0,
    0X7A5,0X0,
    0X7A6,0X0,
    0X7A7,0X0,
    0X7A8,0X0,
    0X7A9,0X0,
    0X7AA,0X0,
    0X7AB,0X0,
    0X7AC,0X0,
    0X7AD,0X0,
    0X7AE,0X0,
    0X7AF,0X0,
    0X7B0,0X0,
    0X7B1,0X0,
    0X7B2,0X0,
    0X7B3,0X0,
    0X7B4,0X0,
    0X7B5,0X0,
    0X7B6,0X0,
    0X7B7,0X0,
    0X7B8,0X0,
    0X7B9,0X0,
    0X7BA,0X0,
    0X7BB,0X0,
    0X7BC,0X0,
    0X7BD,0X0,
    0X7BE,0X0,
    0X7BF,0X0,
    0X7C0,0X0,
    0X7C1,0X0,
    0X7C2,0X0,
    0X7C3,0X0,
    0X7C4,0X0,
    0X7C5,0X0,
    0X7C6,0X0,
    0X7C7,0X0,
    0X7C8,0X0,
    0X7C9,0X0,
    0X7CA,0X0,
    0X7CB,0X0,
    0X7CC,0X0,
    0X7CD,0X0,
    0X7CE,0X0,
    0X7CF,0X0,
    0X7D0,0X0,
    0X7D1,0X0,
    0X7D2,0X0,
    0X7D3,0X0,
    0X7D4,0X0,
    0X7D5,0X0,
    0X7D6,0X0,
    0X7D7,0X0,
    0X7D8,0X0,
    0X7D9,0X0,
    0X7DA,0X0,
    0X7DB,0X0,
    0X7DC,0X0,
    0X7DD,0X0,
    0X7DE,0X0,
    0X7DF,0X0,
    0X7E0,0X0,
    0X7E1,0X0,
    0X7E2,0X0,
    0X7E3,0X0,
    0XA00,0X0,
    0XA01,0X0,
    0XA02,0X0,
    0XA03,0X0,
    0XA04,0X0,
    0XA05,0X0,
    0XA06,0X0,
    0XA07,0X0,
    0XA08,0X0,
    0XA09,0X0,
    0XA0C,0X0,
    0XA0D,0X0,
    0XA0E,0X0,
    0XA0F,0X0,
    0XA10,0X0,
    0XE00,0X0,
    0XE01,0X0,
    0XE02,0X0,
    0XE03,0X0,
    0XE10,0X8,
    0XE11,0X1,
    0XE12,0X0,
    0XE13,0X80,
    0XE14,0XA0,
    0XE15,0X14,
    0XE16,0X2,
    0XE17,0X0,
    0XE18,0X1B,
    0XE19,0X3,
    0XE1A,0X0,
    0XE1B,0X19,
    0XE1C,0X4,
    0XE1D,0X0,
    0XE1E,0X80,
    0XE1F,0X7,
    0XE20,0X5,
    0XE21,0X0,
    0XE22,0X63,
    0XE23,0X6,
    0XE24,0X0,
    0XE25,0X63,
    0XE26,0X6,
    0XE27,0X80,
    0XE28,0X63,
    0XE29,0X7,
    0XE2A,0X0,
    0XE2B,0X63,
    0XE2C,0X7,
    0XE2D,0X80,
    0XE2E,0X80,
    0XE2F,0X10,
    0XE30,0X0A,
    0XE31,0X0,
    0XE32,0X80,
    0XE33,0XFF,
    0XE34,0X0,
    0XE35,0X0,
    0XE36,0X0,
    0XE37,0X0,
    0XE38,0X0,
    0XE39,0X0,
    0XE3A,0X0,
    0XE3B,0X0,
    0XE3C,0X0,
    0XE3D,0X0,
    0XE3E,0X0,
    0XE3F,0X0,
  • HI,
    I understand that you are using a customer board, but the configuration registers you should have obtained using the evaluation software.
    You should have had a stp file.
    Anyway, I created a stp file based on your inputs and I'll try it on an evaluation board. I'll keep you posted
    Petre
  • Hi Petre,
    for your understanding, I am trying with following inputs
    Ref input =32Khz,
        here 32Khz signal is ORed with 1hz pulse (i.e., 1PPS). I hope it doesnt effect the working of AD9547 as rising edge is taken as reference for phase Lock. kindly let me know,if i can use same configuration registers when i use only 32Khz and when i use 32K+1Hz as reference.
     For ur reference, 32K ORed with 1hz looks like this:
    Out1 = 4.096MHz
    Out2 = 32Khz
          DDS freq =163.84Mhz, Divider, Q0=40, Divider, Q1=5120
    My goal is to achieve constant phase lock between Ref input and Outputs.
    I tried different configurations like, changing phase build out threshhold, auto sync mode, Sync source. But nothing seems to work.
    Hope you can help me with my issue.
    The AD9547 was not designed to deal with clocks that have embedded 1Hz. In this case, I recommend using the AD9545.
    Petre
  • Hi Petre,
    Thank you for your response.
    Could you please help me in creating a configuration for AD9547 for 32Khz ref in (without 1Hz embedded).
     Please note that following are the required frequencies.
            Ref in = 32Khz, OUT1=4.096Mhz, OUT2=32Khz.
    I would like to know, best way to choose the values here :
    I tried configuration as it is mentioned in the "Active Reference Synchronization (Zero Delay)" section of data sheet.
    but in this configuration , i was not able to get phase lock at all.
    Kindly go through this stp file and requesting you to let me know where its going wrong.
    ;Header contains information about the setup file and revision
    <Header>
    Product = AD9547
    FileVersion = 1.0
    DecimalSeparator=.    ;Used for internationalization
    </Header>
    <FileDescription>
    /*REF IN 32Khz (REFA- Differential, REFB-Single ended)*/
    /* phase Build out threshold=1*/
    /*Sync source=Direct, Auto Sync Mode=Disable*/
    /*OUT0 Divider=40, OUT1 Divider=5120*/
    /*M3= Phase Lock Status, M4=Frequency Lock Status, M6= REFB Vallid*/
    </FileDescription>
    <RegisterMap>
    &h0,&b00010000   ;10 Hex, 016 Dec
    &h1,&b00000000   ;00 Hex, 000 Dec
    &h4,&b00000000   ;00 Hex, 000 Dec
    &h5,&b00000000   ;00 Hex, 000 Dec
    &h100,&b00011000   ;18 Hex, 024 Dec
    &h101,&b00101000   ;28 Hex, 040 Dec
    &h102,&b01000101   ;45 Hex, 069 Dec
    &h103,&b01000000   ;40 Hex, 064 Dec
    &h104,&b01000010   ;42 Hex, 066 Dec
    &h105,&b00001111   ;0F Hex, 015 Dec
    &h106,&b00000001   ;01 Hex, 001 Dec
    &h107,&b00000000   ;00 Hex, 000 Dec
    &h108,&b00000000   ;00 Hex, 000 Dec
    &h200,&b00000000   ;00 Hex, 000 Dec
    &h201,&b00000000   ;00 Hex, 000 Dec
    &h202,&b00000000   ;00 Hex, 000 Dec
    &h203,&b10010101   ;95 Hex, 149 Dec
    &h204,&b10010110   ;96 Hex, 150 Dec
    &h205,&b00000000   ;00 Hex, 000 Dec
    &h206,&b10110010   ;B2 Hex, 178 Dec
    &h207,&b00000000   ;00 Hex, 000 Dec
    &h208,&b00000000   ;00 Hex, 000 Dec
    &h209,&b00000000   ;00 Hex, 000 Dec
    &h20A,&b00000000   ;00 Hex, 000 Dec
    &h20B,&b00000000   ;00 Hex, 000 Dec
    &h20C,&b00000000   ;00 Hex, 000 Dec
    &h20D,&b00000000   ;00 Hex, 000 Dec
    &h20E,&b00000000   ;00 Hex, 000 Dec
    &h211,&b00000000   ;00 Hex, 000 Dec
    &h212,&b00000000   ;00 Hex, 000 Dec
    &h213,&b11111111   ;FF Hex, 255 Dec
    &h214,&b00000001   ;01 Hex, 001 Dec
    &h300,&b00000000   ;00 Hex, 000 Dec
    &h301,&b00000000   ;00 Hex, 000 Dec
    &h302,&b00000000   ;00 Hex, 000 Dec
    &h303,&b00000000   ;00 Hex, 000 Dec
    &h304,&b00000000   ;00 Hex, 000 Dec
    &h305,&b00000000   ;00 Hex, 000 Dec
    &h306,&b00000000   ;00 Hex, 000 Dec
    &h307,&b00000000   ;00 Hex, 000 Dec
    &h308,&b00000000   ;00 Hex, 000 Dec
    &h309,&b00000000   ;00 Hex, 000 Dec
    &h30A,&b11111111   ;FF Hex, 255 Dec
    &h30B,&b11111111   ;FF Hex, 255 Dec
    &h30C,&b11111111   ;FF Hex, 255 Dec
    &h30D,&b00000000   ;00 Hex, 000 Dec
    &h30E,&b00000000   ;00 Hex, 000 Dec
    &h30F,&b00000000   ;00 Hex, 000 Dec
    &h310,&b00000000   ;00 Hex, 000 Dec
    &h311,&b00000000   ;00 Hex, 000 Dec
    &h312,&b00000000   ;00 Hex, 000 Dec
    &h313,&b00000000   ;00 Hex, 000 Dec
    &h314,&b11101000   ;E8 Hex, 232 Dec
    &h315,&b00000011   ;03 Hex, 003 Dec
    &h316,&b00000000   ;00 Hex, 000 Dec
    &h317,&b00000000   ;00 Hex, 000 Dec
    &h318,&b00110000   ;30 Hex, 048 Dec
    &h319,&b01110101   ;75 Hex, 117 Dec
    &h31A,&b00000000   ;00 Hex, 000 Dec
    &h31B,&b00000000   ;00 Hex, 000 Dec
    &h400,&b00001100   ;0C Hex, 012 Dec
    &h401,&b00000011   ;03 Hex, 003 Dec
    &h402,&b00000000   ;00 Hex, 000 Dec
    &h403,&b00000000   ;00 Hex, 000 Dec
    &h404,&b00001001   ;09 Hex, 009 Dec
    &h405,&b00001001   ;09 Hex, 009 Dec
    &h408,&b00100111   ;27 Hex, 039 Dec
    &h409,&b00000000   ;00 Hex, 000 Dec
    &h40A,&b00000000   ;00 Hex, 000 Dec
    &h40B,&b00000000   ;00 Hex, 000 Dec
    &h40C,&b11111111   ;FF Hex, 255 Dec
    &h40D,&b00010011   ;13 Hex, 019 Dec
    &h40E,&b00000000   ;00 Hex, 000 Dec
    &h40F,&b00000000   ;00 Hex, 000 Dec
    &h418,&b00000000   ;00 Hex, 000 Dec
    &h419,&b00000000   ;00 Hex, 000 Dec
    &h500,&b11110000   ;F0 Hex, 240 Dec
    &h501,&b00000000   ;00 Hex, 000 Dec
    &h503,&b00000000   ;00 Hex, 000 Dec
    &h504,&b00000000   ;00 Hex, 000 Dec
    &h507,&b00000000   ;00 Hex, 000 Dec
    &h600,&b00000000   ;00 Hex, 000 Dec
    &h601,&b10000000   ;80 Hex, 128 Dec
    &h602,&b00101000   ;28 Hex, 040 Dec
    &h603,&b10100101   ;A5 Hex, 165 Dec
    &h604,&b01000110   ;46 Hex, 070 Dec
    &h605,&b00000111   ;07 Hex, 007 Dec
    &h606,&b00000000   ;00 Hex, 000 Dec
    &h607,&b00000000   ;00 Hex, 000 Dec
    &h608,&b11101000   ;E8 Hex, 232 Dec
    &h609,&b00000011   ;03 Hex, 003 Dec
    &h60A,&b00000000   ;00 Hex, 000 Dec
    &h60B,&b11101000   ;E8 Hex, 232 Dec
    &h60C,&b00000011   ;03 Hex, 003 Dec
    &h60D,&b00000000   ;00 Hex, 000 Dec
    &h60E,&b10001000   ;88 Hex, 136 Dec
    &h60F,&b00010011   ;13 Hex, 019 Dec
    &h610,&b10001000   ;88 Hex, 136 Dec
    &h611,&b00010011   ;13 Hex, 019 Dec
    &h612,&b11101101   ;ED Hex, 237 Dec
    &h613,&b10100110   ;A6 Hex, 166 Dec
    &h614,&b00000101   ;05 Hex, 005 Dec
    &h615,&b10111110   ;BE Hex, 190 Dec
    &h616,&b10101001   ;A9 Hex, 169 Dec
    &h617,&b01000111   ;47 Hex, 071 Dec
    &h618,&b10010001   ;91 Hex, 145 Dec
    &h619,&b11110111   ;F7 Hex, 247 Dec
    &h61A,&b00100011   ;23 Hex, 035 Dec
    &h61B,&b10101010   ;AA Hex, 170 Dec
    &h61C,&b01101001   ;69 Hex, 105 Dec
    &h61D,&b00000110   ;06 Hex, 006 Dec
    &h61E,&b00000000   ;00 Hex, 000 Dec
    &h61F,&b00000000   ;00 Hex, 000 Dec
    &h620,&b00000000   ;00 Hex, 000 Dec
    &h621,&b00000000   ;00 Hex, 000 Dec
    &h622,&b11111111   ;FF Hex, 255 Dec
    &h623,&b00010011   ;13 Hex, 019 Dec
    &h624,&b00000000   ;00 Hex, 000 Dec
    &h625,&b00000000   ;00 Hex, 000 Dec
    &h626,&b00000000   ;00 Hex, 000 Dec
    &h627,&b00000000   ;00 Hex, 000 Dec
    &h628,&b00000000   ;00 Hex, 000 Dec
    &h629,&b10001000   ;88 Hex, 136 Dec
    &h62A,&b00010011   ;13 Hex, 019 Dec
    &h62B,&b00100000   ;20 Hex, 032 Dec
    &h62C,&b01000100   ;44 Hex, 068 Dec
    &h62D,&b00000101   ;05 Hex, 005 Dec
    &h62E,&b00000000   ;00 Hex, 000 Dec
    &h62F,&b00000000   ;00 Hex, 000 Dec
    &h630,&b00100000   ;20 Hex, 032 Dec
    &h631,&b01000100   ;44 Hex, 068 Dec
    &h632,&b00000000   ;00 Hex, 000 Dec
    &h633,&b00000000   ;00 Hex, 000 Dec
    &h634,&b00000000   ;00 Hex, 000 Dec
    &h635,&b00000000   ;00 Hex, 000 Dec
    &h636,&b00000000   ;00 Hex, 000 Dec
    &h637,&b00000000   ;00 Hex, 000 Dec
    &h638,&b00000000   ;00 Hex, 000 Dec
    &h639,&b00000000   ;00 Hex, 000 Dec
    &h63A,&b00000000   ;00 Hex, 000 Dec
    &h63B,&b00000000   ;00 Hex, 000 Dec
    &h63C,&b00000000   ;00 Hex, 000 Dec
    &h63D,&b00000000   ;00 Hex, 000 Dec
    &h63E,&b00000000   ;00 Hex, 000 Dec
    &h63F,&b00000000   ;00 Hex, 000 Dec
    &h640,&b00000000   ;00 Hex, 000 Dec
    &h641,&b00000000   ;00 Hex, 000 Dec
    &h642,&b00000000   ;00 Hex, 000 Dec
    &h643,&b00000000   ;00 Hex, 000 Dec
    &h644,&b00000000   ;00 Hex, 000 Dec
    &h645,&b00000000   ;00 Hex, 000 Dec
    &h646,&b00000000   ;00 Hex, 000 Dec
    &h647,&b00000000   ;00 Hex, 000 Dec
    &h648,&b00000000   ;00 Hex, 000 Dec
    &h649,&b00000000   ;00 Hex, 000 Dec
    &h64A,&b00000000   ;00 Hex, 000 Dec
    &h64B,&b00000000   ;00 Hex, 000 Dec
    &h64C,&b00000000   ;00 Hex, 000 Dec
    &h64D,&b00000000   ;00 Hex, 000 Dec
    &h64E,&b00000000   ;00 Hex, 000 Dec
    &h64F,&b00000000   ;00 Hex, 000 Dec
    &h650,&b00000000   ;00 Hex, 000 Dec
    &h651,&b00000000   ;00 Hex, 000 Dec
    &h652,&b00000000   ;00 Hex, 000 Dec
    &h653,&b00000000   ;00 Hex, 000 Dec
    &h654,&b00000000   ;00 Hex, 000 Dec
    &h655,&b00000000   ;00 Hex, 000 Dec
    &h656,&b00000000   ;00 Hex, 000 Dec
    &h657,&b00000000   ;00 Hex, 000 Dec
    &h658,&b00000000   ;00 Hex, 000 Dec
    &h659,&b00000000   ;00 Hex, 000 Dec
    &h65A,&b00000000   ;00 Hex, 000 Dec
    &h65B,&b00000000   ;00 Hex, 000 Dec
    &h65C,&b00000000   ;00 Hex, 000 Dec
    &h65D,&b00000000   ;00 Hex, 000 Dec
    &h65E,&b00000000   ;00 Hex, 000 Dec
    &h65F,&b00000000   ;00 Hex, 000 Dec
    &h660,&b00000000   ;00 Hex, 000 Dec
    &h661,&b00000000   ;00 Hex, 000 Dec
    &h662,&b00000000   ;00 Hex, 000 Dec
    &h663,&b00000000   ;00 Hex, 000 Dec
    &h680,&b00000000   ;00 Hex, 000 Dec
    &h681,&b00000000   ;00 Hex, 000 Dec
    &h682,&b00000000   ;00 Hex, 000 Dec
    &h683,&b00000000   ;00 Hex, 000 Dec
    &h684,&b00000000   ;00 Hex, 000 Dec
    &h685,&b00000000   ;00 Hex, 000 Dec
    &h686,&b00000000   ;00 Hex, 000 Dec
    &h687,&b00000000   ;00 Hex, 000 Dec
    &h688,&b00000000   ;00 Hex, 000 Dec
    &h689,&b00000000   ;00 Hex, 000 Dec
    &h68A,&b00000000   ;00 Hex, 000 Dec
    &h68B,&b00000000   ;00 Hex, 000 Dec
    &h68C,&b00000000   ;00 Hex, 000 Dec
    &h68D,&b00000000   ;00 Hex, 000 Dec
    &h68E,&b00000000   ;00 Hex, 000 Dec
    &h68F,&b00000000   ;00 Hex, 000 Dec
    &h690,&b00000000   ;00 Hex, 000 Dec
    &h691,&b00000000   ;00 Hex, 000 Dec
    &h692,&b00000000   ;00 Hex, 000 Dec
    &h693,&b00000000   ;00 Hex, 000 Dec
    &h694,&b00000000   ;00 Hex, 000 Dec
    &h695,&b00000000   ;00 Hex, 000 Dec
    &h696,&b00000000   ;00 Hex, 000 Dec
    &h697,&b00000000   ;00 Hex, 000 Dec
    &h698,&b00000000   ;00 Hex, 000 Dec
    &h699,&b00000000   ;00 Hex, 000 Dec
    &h69A,&b00000000   ;00 Hex, 000 Dec
    &h69B,&b00000000   ;00 Hex, 000 Dec
    &h69C,&b00000000   ;00 Hex, 000 Dec
    &h69D,&b00000000   ;00 Hex, 000 Dec
    &h69E,&b00000000   ;00 Hex, 000 Dec
    &h69F,&b00000000   ;00 Hex, 000 Dec
    &h6A0,&b00000000   ;00 Hex, 000 Dec
    &h6A1,&b00000000   ;00 Hex, 000 Dec
    &h6A2,&b00000000   ;00 Hex, 000 Dec
    &h6A3,&b00000000   ;00 Hex, 000 Dec
    &h6A4,&b00000000   ;00 Hex, 000 Dec
    &h6A5,&b00000000   ;00 Hex, 000 Dec
    &h6A6,&b00000000   ;00 Hex, 000 Dec
    &h6A7,&b00000000   ;00 Hex, 000 Dec
    &h6A8,&b00000000   ;00 Hex, 000 Dec
    &h6A9,&b00000000   ;00 Hex, 000 Dec
    &h6AA,&b00000000   ;00 Hex, 000 Dec
    &h6AB,&b00000000   ;00 Hex, 000 Dec
    &h6AC,&b00000000   ;00 Hex, 000 Dec
    &h6AD,&b00000000   ;00 Hex, 000 Dec
    &h6AE,&b00000000   ;00 Hex, 000 Dec
    &h6AF,&b00000000   ;00 Hex, 000 Dec
    &h6B0,&b00000000   ;00 Hex, 000 Dec
    &h6B1,&b00000000   ;00 Hex, 000 Dec
    &h6B2,&b00000000   ;00 Hex, 000 Dec
    &h6B3,&b00000000   ;00 Hex, 000 Dec
    &h6B4,&b00000000   ;00 Hex, 000 Dec
    &h6B5,&b00000000   ;00 Hex, 000 Dec
    &h6B6,&b00000000   ;00 Hex, 000 Dec
    &h6B7,&b00000000   ;00 Hex, 000 Dec
    &h6B8,&b00000000   ;00 Hex, 000 Dec
    &h6B9,&b00000000   ;00 Hex, 000 Dec
    &h6BA,&b00000000   ;00 Hex, 000 Dec
    &h6BB,&b00000000   ;00 Hex, 000 Dec
    &h6BC,&b00000000   ;00 Hex, 000 Dec
    &h6BD,&b00000000   ;00 Hex, 000 Dec
    &h6BE,&b00000000   ;00 Hex, 000 Dec
    &h6BF,&b00000000   ;00 Hex, 000 Dec
    &h6C0,&b00000000   ;00 Hex, 000 Dec
    &h6C1,&b00000000   ;00 Hex, 000 Dec
    &h6C2,&b00000000   ;00 Hex, 000 Dec
    &h6C3,&b00000000   ;00 Hex, 000 Dec
    &h6C4,&b00000000   ;00 Hex, 000 Dec
    &h6C5,&b00000000   ;00 Hex, 000 Dec
    &h6C6,&b00000000   ;00 Hex, 000 Dec
    &h6C7,&b00000000   ;00 Hex, 000 Dec
    &h6C8,&b00000000   ;00 Hex, 000 Dec
    &h6C9,&b00000000   ;00 Hex, 000 Dec
    &h6CA,&b00000000   ;00 Hex, 000 Dec
    &h6CB,&b00000000   ;00 Hex, 000 Dec
    &h6CC,&b00000000   ;00 Hex, 000 Dec
    &h6CD,&b00000000   ;00 Hex, 000 Dec
    &h6CE,&b00000000   ;00 Hex, 000 Dec
    &h6CF,&b00000000   ;00 Hex, 000 Dec
    &h6D0,&b00000000   ;00 Hex, 000 Dec
    &h6D1,&b00000000   ;00 Hex, 000 Dec
    &h6D2,&b00000000   ;00 Hex, 000 Dec
    &h6D3,&b00000000   ;00 Hex, 000 Dec
    &h6D4,&b00000000   ;00 Hex, 000 Dec
    &h6D5,&b00000000   ;00 Hex, 000 Dec
    &h6D6,&b00000000   ;00 Hex, 000 Dec
    &h6D7,&b00000000   ;00 Hex, 000 Dec
    &h6D8,&b00000000   ;00 Hex, 000 Dec
    &h6D9,&b00000000   ;00 Hex, 000 Dec
    &h6DA,&b00000000   ;00 Hex, 000 Dec
    &h6DB,&b00000000   ;00 Hex, 000 Dec
    &h6DC,&b00000000   ;00 Hex, 000 Dec
    &h6DD,&b00000000   ;00 Hex, 000 Dec
    &h6DE,&b00000000   ;00 Hex, 000 Dec
    &h6DF,&b00000000   ;00 Hex, 000 Dec
    &h6E0,&b00000000   ;00 Hex, 000 Dec
    &h6E1,&b00000000   ;00 Hex, 000 Dec
    &h6E2,&b00000000   ;00 Hex, 000 Dec
    &h6E3,&b00000000   ;00 Hex, 000 Dec
    &h700,&b00000000   ;00 Hex, 000 Dec
    &h701,&b00000000   ;00 Hex, 000 Dec
    &h702,&b00000000   ;00 Hex, 000 Dec
    &h703,&b00000000   ;00 Hex, 000 Dec
    &h704,&b00000000   ;00 Hex, 000 Dec
    &h705,&b00000000   ;00 Hex, 000 Dec
    &h706,&b00000000   ;00 Hex, 000 Dec
    &h707,&b00000000   ;00 Hex, 000 Dec
    &h708,&b00000000   ;00 Hex, 000 Dec
    &h709,&b00000000   ;00 Hex, 000 Dec
    &h70A,&b00000000   ;00 Hex, 000 Dec
    &h70B,&b00000000   ;00 Hex, 000 Dec
    &h70C,&b00000000   ;00 Hex, 000 Dec
    &h70D,&b00000000   ;00 Hex, 000 Dec
    &h70E,&b00000000   ;00 Hex, 000 Dec
    &h70F,&b00000000   ;00 Hex, 000 Dec
    &h710,&b00000000   ;00 Hex, 000 Dec
    &h711,&b00000000   ;00 Hex, 000 Dec
    &h712,&b00000000   ;00 Hex, 000 Dec
    &h713,&b00000000   ;00 Hex, 000 Dec
    &h714,&b00000000   ;00 Hex, 000 Dec
    &h715,&b00000000   ;00 Hex, 000 Dec
    &h716,&b00000000   ;00 Hex, 000 Dec
    &h717,&b00000000   ;00 Hex, 000 Dec
    &h718,&b00000000   ;00 Hex, 000 Dec
    &h719,&b00000000   ;00 Hex, 000 Dec
    &h71A,&b00000000   ;00 Hex, 000 Dec
    &h71B,&b00000000   ;00 Hex, 000 Dec
    &h71C,&b00000000   ;00 Hex, 000 Dec
    &h71D,&b00000000   ;00 Hex, 000 Dec
    &h71E,&b00000000   ;00 Hex, 000 Dec
    &h71F,&b00000000   ;00 Hex, 000 Dec
    &h720,&b00000000   ;00 Hex, 000 Dec
    &h721,&b00000000   ;00 Hex, 000 Dec
    &h722,&b00000000   ;00 Hex, 000 Dec
    &h723,&b00000000   ;00 Hex, 000 Dec
    &h724,&b00000000   ;00 Hex, 000 Dec
    &h725,&b00000000   ;00 Hex, 000 Dec
    &h726,&b00000000   ;00 Hex, 000 Dec
    &h727,&b00000000   ;00 Hex, 000 Dec
    &h728,&b00000000   ;00 Hex, 000 Dec
    &h729,&b00000000   ;00 Hex, 000 Dec
    &h72A,&b00000000   ;00 Hex, 000 Dec
    &h72B,&b00000000   ;00 Hex, 000 Dec
    &h72C,&b00000000   ;00 Hex, 000 Dec
    &h72D,&b00000000   ;00 Hex, 000 Dec
    &h72E,&b00000000   ;00 Hex, 000 Dec
    &h72F,&b00000000   ;00 Hex, 000 Dec
    &h730,&b00000000   ;00 Hex, 000 Dec
    &h731,&b00000000   ;00 Hex, 000 Dec
    &h732,&b00000000   ;00 Hex, 000 Dec
    &h733,&b00000000   ;00 Hex, 000 Dec
    &h734,&b00000000   ;00 Hex, 000 Dec
    &h735,&b00000000   ;00 Hex, 000 Dec
    &h736,&b00000000   ;00 Hex, 000 Dec
    &h737,&b00000000   ;00 Hex, 000 Dec
    &h738,&b00000000   ;00 Hex, 000 Dec
    &h739,&b00000000   ;00 Hex, 000 Dec
    &h73A,&b00000000   ;00 Hex, 000 Dec
    &h73B,&b00000000   ;00 Hex, 000 Dec
    &h73C,&b00000000   ;00 Hex, 000 Dec
    &h73D,&b00000000   ;00 Hex, 000 Dec
    &h73E,&b00000000   ;00 Hex, 000 Dec
    &h73F,&b00000000   ;00 Hex, 000 Dec
    &h740,&b00000000   ;00 Hex, 000 Dec
    &h741,&b00000000   ;00 Hex, 000 Dec
    &h742,&b00000000   ;00 Hex, 000 Dec
    &h743,&b00000000   ;00 Hex, 000 Dec
    &h744,&b00000000   ;00 Hex, 000 Dec
    &h745,&b00000000   ;00 Hex, 000 Dec
    &h746,&b00000000   ;00 Hex, 000 Dec
    &h747,&b00000000   ;00 Hex, 000 Dec
    &h748,&b00000000   ;00 Hex, 000 Dec
    &h749,&b00000000   ;00 Hex, 000 Dec
    &h74A,&b00000000   ;00 Hex, 000 Dec
    &h74B,&b00000000   ;00 Hex, 000 Dec
    &h74C,&b00000000   ;00 Hex, 000 Dec
    &h74D,&b00000000   ;00 Hex, 000 Dec
    &h74E,&b00000000   ;00 Hex, 000 Dec
    &h74F,&b00000000   ;00 Hex, 000 Dec
    &h750,&b00000000   ;00 Hex, 000 Dec
    &h751,&b00000000   ;00 Hex, 000 Dec
    &h752,&b00000000   ;00 Hex, 000 Dec
    &h753,&b00000000   ;00 Hex, 000 Dec
    &h754,&b00000000   ;00 Hex, 000 Dec
    &h755,&b00000000   ;00 Hex, 000 Dec
    &h756,&b00000000   ;00 Hex, 000 Dec
    &h757,&b00000000   ;00 Hex, 000 Dec
    &h758,&b00000000   ;00 Hex, 000 Dec
    &h759,&b00000000   ;00 Hex, 000 Dec
    &h75A,&b00000000   ;00 Hex, 000 Dec
    &h75B,&b00000000   ;00 Hex, 000 Dec
    &h75C,&b00000000   ;00 Hex, 000 Dec
    &h75D,&b00000000   ;00 Hex, 000 Dec
    &h75E,&b00000000   ;00 Hex, 000 Dec
    &h75F,&b00000000   ;00 Hex, 000 Dec
    &h760,&b00000000   ;00 Hex, 000 Dec
    &h761,&b00000000   ;00 Hex, 000 Dec
    &h762,&b00000000   ;00 Hex, 000 Dec
    &h763,&b00000000   ;00 Hex, 000 Dec
    &h780,&b00000000   ;00 Hex, 000 Dec
    &h781,&b00000000   ;00 Hex, 000 Dec
    &h782,&b00000000   ;00 Hex, 000 Dec
    &h783,&b00000000   ;00 Hex, 000 Dec
    &h784,&b00000000   ;00 Hex, 000 Dec
    &h785,&b00000000   ;00 Hex, 000 Dec
    &h786,&b00000000   ;00 Hex, 000 Dec
    &h787,&b00000000   ;00 Hex, 000 Dec
    &h788,&b00000000   ;00 Hex, 000 Dec
    &h789,&b00000000   ;00 Hex, 000 Dec
    &h78A,&b00000000   ;00 Hex, 000 Dec
    &h78B,&b00000000   ;00 Hex, 000 Dec
    &h78C,&b00000000   ;00 Hex, 000 Dec
    &h78D,&b00000000   ;00 Hex, 000 Dec
    &h78E,&b00000000   ;00 Hex, 000 Dec
    &h78F,&b00000000   ;00 Hex, 000 Dec
    &h790,&b00000000   ;00 Hex, 000 Dec
    &h791,&b00000000   ;00 Hex, 000 Dec
    &h792,&b00000000   ;00 Hex, 000 Dec
    &h793,&b00000000   ;00 Hex, 000 Dec
    &h794,&b00000000   ;00 Hex, 000 Dec
    &h795,&b00000000   ;00 Hex, 000 Dec
    &h796,&b00000000   ;00 Hex, 000 Dec
    &h797,&b00000000   ;00 Hex, 000 Dec
    &h798,&b00000000   ;00 Hex, 000 Dec
    &h799,&b00000000   ;00 Hex, 000 Dec
    &h79A,&b00000000   ;00 Hex, 000 Dec
    &h79B,&b00000000   ;00 Hex, 000 Dec
    &h79C,&b00000000   ;00 Hex, 000 Dec
    &h79D,&b00000000   ;00 Hex, 000 Dec
    &h79E,&b00000000   ;00 Hex, 000 Dec
    &h79F,&b00000000   ;00 Hex, 000 Dec
    &h7A0,&b00000000   ;00 Hex, 000 Dec
    &h7A1,&b00000000   ;00 Hex, 000 Dec
    &h7A2,&b00000000   ;00 Hex, 000 Dec
    &h7A3,&b00000000   ;00 Hex, 000 Dec
    &h7A4,&b00000000   ;00 Hex, 000 Dec
    &h7A5,&b00000000   ;00 Hex, 000 Dec
    &h7A6,&b00000000   ;00 Hex, 000 Dec
    &h7A7,&b00000000   ;00 Hex, 000 Dec
    &h7A8,&b00000000   ;00 Hex, 000 Dec
    &h7A9,&b00000000   ;00 Hex, 000 Dec
    &h7AA,&b00000000   ;00 Hex, 000 Dec
    &h7AB,&b00000000   ;00 Hex, 000 Dec
    &h7AC,&b00000000   ;00 Hex, 000 Dec
    &h7AD,&b00000000   ;00 Hex, 000 Dec
    &h7AE,&b00000000   ;00 Hex, 000 Dec
    &h7AF,&b00000000   ;00 Hex, 000 Dec
    &h7B0,&b00000000   ;00 Hex, 000 Dec
    &h7B1,&b00000000   ;00 Hex, 000 Dec
    &h7B2,&b00000000   ;00 Hex, 000 Dec
    &h7B3,&b00000000   ;00 Hex, 000 Dec
    &h7B4,&b00000000   ;00 Hex, 000 Dec
    &h7B5,&b00000000   ;00 Hex, 000 Dec
    &h7B6,&b00000000   ;00 Hex, 000 Dec
    &h7B7,&b00000000   ;00 Hex, 000 Dec
    &h7B8,&b00000000   ;00 Hex, 000 Dec
    &h7B9,&b00000000   ;00 Hex, 000 Dec
    &h7BA,&b00000000   ;00 Hex, 000 Dec
    &h7BB,&b00000000   ;00 Hex, 000 Dec
    &h7BC,&b00000000   ;00 Hex, 000 Dec
    &h7BD,&b00000000   ;00 Hex, 000 Dec
    &h7BE,&b00000000   ;00 Hex, 000 Dec
    &h7BF,&b00000000   ;00 Hex, 000 Dec
    &h7C0,&b00000000   ;00 Hex, 000 Dec
    &h7C1,&b00000000   ;00 Hex, 000 Dec
    &h7C2,&b00000000   ;00 Hex, 000 Dec
    &h7C3,&b00000000   ;00 Hex, 000 Dec
    &h7C4,&b00000000   ;00 Hex, 000 Dec
    &h7C5,&b00000000   ;00 Hex, 000 Dec
    &h7C6,&b00000000   ;00 Hex, 000 Dec
    &h7C7,&b00000000   ;00 Hex, 000 Dec
    &h7C8,&b00000000   ;00 Hex, 000 Dec
    &h7C9,&b00000000   ;00 Hex, 000 Dec
    &h7CA,&b00000000   ;00 Hex, 000 Dec
    &h7CB,&b00000000   ;00 Hex, 000 Dec
    &h7CC,&b00000000   ;00 Hex, 000 Dec
    &h7CD,&b00000000   ;00 Hex, 000 Dec
    &h7CE,&b00000000   ;00 Hex, 000 Dec
    &h7CF,&b00000000   ;00 Hex, 000 Dec
    &h7D0,&b00000000   ;00 Hex, 000 Dec
    &h7D1,&b00000000   ;00 Hex, 000 Dec
    &h7D2,&b00000000   ;00 Hex, 000 Dec
    &h7D3,&b00000000   ;00 Hex, 000 Dec
    &h7D4,&b00000000   ;00 Hex, 000 Dec
    &h7D5,&b00000000   ;00 Hex, 000 Dec
    &h7D6,&b00000000   ;00 Hex, 000 Dec
    &h7D7,&b00000000   ;00 Hex, 000 Dec
    &h7D8,&b00000000   ;00 Hex, 000 Dec
    &h7D9,&b00000000   ;00 Hex, 000 Dec
    &h7DA,&b00000000   ;00 Hex, 000 Dec
    &h7DB,&b00000000   ;00 Hex, 000 Dec
    &h7DC,&b00000000   ;00 Hex, 000 Dec
    &h7DD,&b00000000   ;00 Hex, 000 Dec
    &h7DE,&b00000000   ;00 Hex, 000 Dec
    &h7DF,&b00000000   ;00 Hex, 000 Dec
    &h7E0,&b00000000   ;00 Hex, 000 Dec
    &h7E1,&b00000000   ;00 Hex, 000 Dec
    &h7E2,&b00000000   ;00 Hex, 000 Dec
    &h7E3,&b00000000   ;00 Hex, 000 Dec
    &hA00,&b00000000   ;00 Hex, 000 Dec
    &hA01,&b00000000   ;00 Hex, 000 Dec
    &hA02,&b00000000   ;00 Hex, 000 Dec
    &hA03,&b00000000   ;00 Hex, 000 Dec
    &hA04,&b00000000   ;00 Hex, 000 Dec
    &hA05,&b00000000   ;00 Hex, 000 Dec
    &hA06,&b00000000   ;00 Hex, 000 Dec
    &hA07,&b00000000   ;00 Hex, 000 Dec
    &hA08,&b00000000   ;00 Hex, 000 Dec
    &hA09,&b00000000   ;00 Hex, 000 Dec
    &hA0C,&b00000000   ;00 Hex, 000 Dec
    &hA0D,&b00000000   ;00 Hex, 000 Dec
    &hA0E,&b00000000   ;00 Hex, 000 Dec
    &hA0F,&b00000000   ;00 Hex, 000 Dec
    &hA10,&b00000000   ;00 Hex, 000 Dec
    &hE00,&b00000000   ;00 Hex, 000 Dec
    &hE01,&b00000000   ;00 Hex, 000 Dec
    &hE02,&b00000000   ;00 Hex, 000 Dec
    &hE03,&b00000000   ;00 Hex, 000 Dec
    &hE10,&b00001000   ;08 Hex, 008 Dec
    &hE11,&b00000001   ;01 Hex, 001 Dec
    &hE12,&b00000000   ;00 Hex, 000 Dec
    &hE13,&b10000000   ;80 Hex, 128 Dec
    &hE14,&b10100000   ;A0 Hex, 160 Dec
    &hE15,&b00010100   ;14 Hex, 020 Dec
    &hE16,&b00000010   ;02 Hex, 002 Dec
    &hE17,&b00000000   ;00 Hex, 000 Dec
    &hE18,&b00011011   ;1B Hex, 027 Dec
    &hE19,&b00000011   ;03 Hex, 003 Dec
    &hE1A,&b00000000   ;00 Hex, 000 Dec
    &hE1B,&b00011001   ;19 Hex, 025 Dec
    &hE1C,&b00000100   ;04 Hex, 004 Dec
    &hE1D,&b00000000   ;00 Hex, 000 Dec
    &hE1E,&b10000000   ;80 Hex, 128 Dec
    &hE1F,&b00000111   ;07 Hex, 007 Dec
    &hE20,&b00000101   ;05 Hex, 005 Dec
    &hE21,&b00000000   ;00 Hex, 000 Dec
    &hE22,&b01100011   ;63 Hex, 099 Dec
    &hE23,&b00000110   ;06 Hex, 006 Dec
    &hE24,&b00000000   ;00 Hex, 000 Dec
    &hE25,&b01100011   ;63 Hex, 099 Dec
    &hE26,&b00000110   ;06 Hex, 006 Dec
    &hE27,&b10000000   ;80 Hex, 128 Dec
    &hE28,&b01100011   ;63 Hex, 099 Dec
    &hE29,&b00000111   ;07 Hex, 007 Dec
    &hE2A,&b00000000   ;00 Hex, 000 Dec
    &hE2B,&b01100011   ;63 Hex, 099 Dec
    &hE2C,&b00000111   ;07 Hex, 007 Dec
    &hE2D,&b10000000   ;80 Hex, 128 Dec
    &hE2E,&b10000000   ;80 Hex, 128 Dec
    &hE2F,&b00010000   ;10 Hex, 016 Dec
    &hE30,&b00001010   ;0A Hex, 010 Dec
    &hE31,&b00000000   ;00 Hex, 000 Dec
    &hE32,&b10000000   ;80 Hex, 128 Dec
    &hE33,&b11111111   ;FF Hex, 255 Dec
    &hE34,&b00000000   ;00 Hex, 000 Dec
    &hE35,&b00000000   ;00 Hex, 000 Dec
    &hE36,&b00000000   ;00 Hex, 000 Dec
    &hE37,&b00000000   ;00 Hex, 000 Dec
    &hE38,&b00000000   ;00 Hex, 000 Dec
    &hE39,&b00000000   ;00 Hex, 000 Dec
    &hE3A,&b00000000   ;00 Hex, 000 Dec
    &hE3B,&b00000000   ;00 Hex, 000 Dec
    &hE3C,&b00000000   ;00 Hex, 000 Dec
    &hE3D,&b00000000   ;00 Hex, 000 Dec
    &hE3E,&b00000000   ;00 Hex, 000 Dec
    &hE3F,&b00000000   ;00 Hex, 000 Dec
    </RegisterMap>
    <PinStates>
    MPins=&h0
    </PinStates>
    <SoftwareSettings>
    AutoIOUpdate=1              ;AutoIOUpdate Setting
    OverRideJumpersONReset=1    ;1 = Override M-Pin Jumper Settings, 0 = Use M-Pin Jumper Settings
    MPinStatesDuringReset=&h7   ;M-Pin States to be applied to the M-Pins durring a reset
    ExternalClock=25    ;External Clock Frequency in MHz
    </SoftwareSettings>
    I looked over the stp file you sent. I found several things:
    1) The free running frequency of 163.84MHz was not introduced into this window and I introduced it myself.
    2) You say you want to run the DPLL as in  "Active Reference Synchronization (Zero Delay)" section. This means you need to select the Reference as the source of Sync Source. I introduced this myself.
    3) You have both REFA and REFB set as differential. Make sure they are as such on your board.
    In the evaluation software, you have to check whichever REFA or REFB must be initiated by checking a box in this window:
    I checked them both. I clicked Load All button and the register 0x0A0D became 0x05. This value was saved into the stp file I attach. The register 0x0A0D was 0 in your file.
    <Header>
    Product = AD9547
    FileVersion = 1.0
    </Header>
    <FileDescription>
    </FileDescription>
    <RegisterMap>
    &h300,&b11010010   ;D2 Hex, 210 Dec
    &h301,&b11000110   ;C6 Hex, 198 Dec
    &h302,&b00010001   ;11 Hex, 017 Dec
    &h303,&b01101011   ;6B Hex, 107 Dec
    &h304,&b11110001   ;F1 Hex, 241 Dec
    &h305,&b00101001   ;29 Hex, 041 Dec
    &h402,&b00010000   ;10 Hex, 016 Dec
    &hA0D,&b00000101   ;05 Hex, 005 Dec
    </RegisterMap>
    <PinStates>
    MPins=&h0
    </PinStates>
    <SoftwareSettings>
    </SoftwareSettings>
    This should work.
    Petre
  • Hi Petre,
    I tried with the file u sent. Still i am not getting the proper lock condition.
    Can any of your team visit mistral solutions, Banglore and have a look into the same.
