HMC856, CM level sweep of single-ended input signal
Category: Datasheet/Specs
Product Number: HMC856
I would like to use HMC856 to delay single-ended 24MHz CLK timing with ps reslolution.
As shown in the figure, the 24MHz CLK waveform is input as the single-ended through AC coupling for CML compatibility.
Question①
 Due to AC coupling, it takes time for the CM level stabilization of the input signal.
 Does the CM level of the output signal also sweep?
Question②
 Is there a relationship between the input signal amplitude and the output signal amplitude?
I’m Sorry to ask such a basic question.
Best regards, and many thanks.
