ADF4382
Recommended for New Designs
The ADF4382 is a high performance, ultra-low jitter, fractional-N
phased-locked loop (PLL) with an integrated voltage controlled
oscillator (VCO) ideally...
Datasheet
ADF4382 on Analog.com
ADF4382A
The ADF4382A is a high performance, ultralow jitter, fractional-N phased-locked loop (PLL) with an integrated voltage controlled oscillator (VCO) ideally...
Datasheet
ADF4382A on Analog.com
According to ADF4382A datasheet rev.0, SYNCP/SYNCN are synchronization input signals. Both RF output signals are synchronized to an input signal at these pins.
I do not need nor plan to use these SYNCP/SYNCN inputs. How should I connect them if unused ? Can I left them floating ?
Best regards, and many thanks.
Yes, you can leave them floating if they are unused or put a 50ohms termination on both pins if you really need to, both cases works fine.
Regards.
Many thanks Jude!
