HMC7044 datasheet specifies GPIx Control settings in registers 0x0046, 0x0047, 0x0048, 0x0049. It is given that the setting 0010 is to Select PLL1 reference manually, Bit 1. Also, it is specified that the next setting 0011 is to Select PLL1 reference manually, Bit 0. How can we manually select any of the four reference clocks using these two settings?
Aysha
Subject changed
[edited by: aysha at 12:58 PM (GMT -4) on 8 Apr 2024]
