122.88 MHz Output from 30.72 MHz OCXO Ref clock as internal zero delay
Product Number: AD9545
Hello Team,
we have Eval-AD9545 on which 30.72 MHz OCXO is connected to REFBB (1.2 V, dc coupled, SE). For system clock, 52 MHz is given from R&S signal generator. We are having problem with follwing configurations:
1. We want to generate 122.88 MHz output from OUT0A as LVDS but are not able to generate due to restrictive and complicated divider from NCO and APLL0 PFD. Is there any .cso file for reference which can be used?
2. As next step we want to use DPLL0 in internal zero delay method where feedback clock will be OUT0A and REFBB will be used as input clock. As it can be seen in the screenshot the output is 122.88 MHz and REFBB clock is 30.72 MHz then also it is showing error.
As an attachment .cso file is sent which is being currently used by us.
Thank you for your time.
<?xml version="1.0" encoding="utf-8"?>
<Session Name="Session" AppVersion="" FileVersion="" xmlns="AnalogDevices/Csa/Configuration/Schemas/Session.xsd">
  <Elements>
    <Element Id="EvalSystem">
      <System xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Name="System" xmlns="AnalogDevices/Csa/Evaluation/Sessions/EvalSystemSessionElement.Schema.xsd">
        <Subsystems>
          <Subsystem Name="Subsystem_1">
            <Components>
              <Component ComponentId="AD9545Board" Name="AD9545 Board">
                <Info Name="AD9545 Board" Description="A USB to SPI interface board for the AD9545." />
                <SavedState>
                  <Board Id="AD9545Board" xmlns="">
                    <Parameter Id="virtual-parameter-vpserialtype" Value="0" />
                    <Parameter Id="virtual-parameter-vpspiioconfig" Value="true" />
                    <Parameter Id="virtual-parameter-vpspibitorder" Value="false" />
                    <Parameter Id="virtual-parameter-vpspistreamingtype" Value="0" />
                    <Parameter Id="virtual-parameter-vpSPISelected" Value="true" />
                    <Parameter Id="virtual-parameter-vpI2CSelected" Value="false" />
                    <Parameter Id="fx2-port-a-pins" Value="3" />
                    <Parameter Id="pa_usb_status-direction-fx2-port-a-pins" Value="true" />
                    <Parameter Id="pa_usb_status-data-fx2-port-a-pins" Value="true" />
                    <Parameter Id="pa_csb-direction-fx2-port-a-pins" Value="true" />
                    <Parameter Id="pa_csb-data-fx2-port-a-pins" Value="true" />
                    <Parameter Id="pa_resetb-direction-fx2-port-a-pins" Value="true" />
                    <Parameter Id="pa_resetb-data-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_enable_i2c-direction-fx2-port-a-pins" Value="true" />
                    <Parameter Id="pa_enable_i2c-data-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_4-direction-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_4-data-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_5-direction-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_5-data-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_6-direction-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_6-data-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_7-direction-fx2-port-a-pins" Value="false" />
                    <Parameter Id="pa_gpio_7-data-fx2-port-a-pins" Value="false" />
                    <Parameter Id="fx2-port-b-pins" Value="0" />
                    <Parameter Id="pb_sdio-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_sdio-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_sdo-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_sdo-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_2-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_2-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_3-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_3-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_4-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_4-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_5-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_5-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_6-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_6-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_7-direction-fx2-port-b-pins" Value="false" />
                    <Parameter Id="pb_gpio_7-data-fx2-port-b-pins" Value="false" />
                    <Parameter Id="fx2-port-c-pins" Value="0" />
                    <Parameter Id="pc_gpio_0-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_0-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_1-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_1-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_2-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_2-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_3-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_3-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_4-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_4-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_5-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_5-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_6-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_6-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_7-direction-fx2-port-c-pins" Value="false" />
                    <Parameter Id="pc_gpio_7-data-fx2-port-c-pins" Value="false" />
                    <Parameter Id="fx2-port-d-pins" Value="0" />
                    <Parameter Id="pd_mp0-direction-fx2-port-d-pins" Value="true" />
                    <Parameter Id="pd_mp0-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp1-direction-fx2-port-d-pins" Value="true" />
                    <Parameter Id="pd_mp1-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp2-direction-fx2-port-d-pins" Value="true" />
                    <Parameter Id="pd_mp2-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp3-direction-fx2-port-d-pins" Value="true" />
                    <Parameter Id="pd_mp3-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp4-direction-fx2-port-d-pins" Value="true" />
                    <Parameter Id="pd_mp4-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp5-direction-fx2-port-d-pins" Value="true" />
                    <Parameter Id="pd_mp5-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp6-direction-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_mp6-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_gpio_7-direction-fx2-port-d-pins" Value="false" />
                    <Parameter Id="pd_gpio_7-data-fx2-port-d-pins" Value="false" />
                    <Parameter Id="fx2-port-e-pins" Value="0" />
                    <Parameter Id="pe_gpio_0-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_0-data-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_1-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_1-data-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_2-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_2-data-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_3-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_3-data-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_4-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_4-data-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_5-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_5-data-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_6-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_6-data-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_7-direction-fx2-port-e-pins" Value="false" />
                    <Parameter Id="pe_gpio_7-data-fx2-port-e-pins" Value="false" />
                    <Chips>
                      <Chip Id="Chip.AD9545.AD9545" InstanceName="AD9545">
                        <Parameter Id="virtual-parameter-feature_1" Value="true" />
                        <Parameter Id="virtual-parameter-feature_2" Value="true" />
                        <Parameter Id="virtual-parameter-feature_3" Value="true" />
                        <Parameter Id="ad9545-pins" Value="0" />
                        <Parameter Id="resetb-direction-ad9545-pins" Value="false" />
                        <Parameter Id="resetb-data-ad9545-pins" Value="false" />
                        <Parameter Id="ad9545-m-pins" Value="0" />
                        <Parameter Id="mp0-direction-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp0-data-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp1-direction-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp1-data-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp2-direction-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp2-data-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp3-direction-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp3-data-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp4-direction-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp4-data-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp5-direction-ad9545-m-pins" Value="false" />
                        <Parameter Id="mp5-data-ad9545-m-pins" Value="false" />
                        <Parameter Id="virtual-parameter-hwAttached" Value="false" />
                        <Parameter Id="virtual-parameter-feature1_0_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-feature1_1_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-_TestVP" Value="0" />
                        <Parameter Id="virtual-parameter-ListSelect" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0_err_src" Value="true" />
                        <Parameter Id="virtual-parameter-dpll1_err_src" Value="false" />
                        <Parameter Id="virtual-parameter-sysclk_expression" Value="52 MHz" />
                        <Parameter Id="virtual-parameter-SysClkFreq" Value="52 MHz" />
                        <Parameter Id="virtual-parameter-SysClkFreq_wiz" Value="52 MHz" />
                        <Parameter Id="virtual-parameter-sysclk_decimal" Value="52000000" />
                        <Parameter Id="virtual-parameter-sysclk_fin_num" Value="52000000" />
                        <Parameter Id="virtual-parameter-sysclk_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_sysclk_Fpfd" Value="104000000" />
                        <Parameter Id="virtual-parameter-wiz_sysclk_Fvco" Value="2392000000" />
                        <Parameter Id="virtual-parameter-REFA_Expression" Value="30.72 MHz" />
                        <Parameter Id="virtual-parameter-REFA" Value="30.72 MHz" />
                        <Parameter Id="virtual-parameter-REFA_wiz" Value="30.72 MHz" />
                        <Parameter Id="virtual-parameter-refa_decimal" Value="30720000" />
                        <Parameter Id="virtual-parameter-refA_fin_num" Value="30720000" />
                        <Parameter Id="virtual-parameter-refA_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-refA_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refA_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refA_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refA_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-refA_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-refA_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-refa_en" Value="false" />
                        <Parameter Id="virtual-parameter-refa_se" Value="true" />
                        <Parameter Id="virtual-parameter-refa_se_pd" Value="true" />
                        <Parameter Id="virtual-parameter-refa_demod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-REFAA_Expression" Value="25 MHz" />
                        <Parameter Id="virtual-parameter-REFAA" Value="25 MHz" />
                        <Parameter Id="virtual-parameter-REFAA_wiz" Value="25 MHz" />
                        <Parameter Id="virtual-parameter-refaa_decimal" Value="25000000" />
                        <Parameter Id="virtual-parameter-refAA_fin_num" Value="25000000" />
                        <Parameter Id="virtual-parameter-refAA_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-refAA_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refAA_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refAA_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refAA_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-refAA_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-refAA_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-refaa_en" Value="false" />
                        <Parameter Id="virtual-parameter-refaa_se" Value="1" />
                        <Parameter Id="virtual-parameter-refaa_se_pd" Value="true" />
                        <Parameter Id="virtual-parameter-refaa_demod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-refa_demod_disable_gui" Value="true" />
                        <Parameter Id="virtual-parameter-refa_demod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-refa_demod_wiz_vis" Value="false" />
                        <Parameter Id="virtual-parameter-refaa_demod_disable_gui" Value="true" />
                        <Parameter Id="virtual-parameter-refaa_demod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-refaa_demod_wiz_vis" Value="false" />
                        <Parameter Id="virtual-parameter-refa_diff" Value="false" />
                        <Parameter Id="virtual-parameter-refa_diff_pd" Value="true" />
                        <Parameter Id="virtual-parameter-REFB_Expression" Value="30.72 MHz" />
                        <Parameter Id="virtual-parameter-REFB" Value="30.72 MHz" />
                        <Parameter Id="virtual-parameter-REFB_wiz" Value="30.72 MHz" />
                        <Parameter Id="virtual-parameter-refb_decimal" Value="30720000" />
                        <Parameter Id="virtual-parameter-refB_fin_num" Value="30720000" />
                        <Parameter Id="virtual-parameter-refB_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-refB_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refB_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refB_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refB_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-refB_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-refB_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-refb_en" Value="false" />
                        <Parameter Id="virtual-parameter-refb_se" Value="true" />
                        <Parameter Id="virtual-parameter-refb_se_pd" Value="true" />
                        <Parameter Id="virtual-parameter-refb_demod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-REFBB_Expression" Value="30.72 MHz" />
                        <Parameter Id="virtual-parameter-REFBB" Value="30.72 MHz" />
                        <Parameter Id="virtual-parameter-REFBB_wiz" Value="30.72 MHz" />
                        <Parameter Id="virtual-parameter-refbb_decimal" Value="30720000" />
                        <Parameter Id="virtual-parameter-refBB_fin_num" Value="30720000" />
                        <Parameter Id="virtual-parameter-refBB_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-refBB_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refBB_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refBB_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-refBB_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-refBB_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-refBB_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-refbb_en" Value="true" />
                        <Parameter Id="virtual-parameter-refbb_se" Value="1" />
                        <Parameter Id="virtual-parameter-refbb_se_pd" Value="false" />
                        <Parameter Id="virtual-parameter-refbb_demod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-refb_demod_disable_gui" Value="true" />
                        <Parameter Id="virtual-parameter-refb_demod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-refb_demod_wiz_vis" Value="false" />
                        <Parameter Id="virtual-parameter-refbb_demod_disable_gui" Value="true" />
                        <Parameter Id="virtual-parameter-refbb_demod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-refbb_demod_wiz_vis" Value="false" />
                        <Parameter Id="virtual-parameter-refb_diff" Value="false" />
                        <Parameter Id="virtual-parameter-refb_diff_pd" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0p0_sel" Value="true" />
                        <Parameter Id="virtual-parameter-DPLL0p0 Reference Source" Value="3" />
                        <Parameter Id="virtual-parameter-DPLL0p0 Feedback Source" Value="5" />
                        <Parameter Id="virtual-parameter-vpDPLL0p0OperatingMode" Value="1" />
                        <Parameter Id="virtual-parameter-DPLL0p0 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll0p0_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p0_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p0_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p0_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p0_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p0_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p0_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p0_loop_bw_converted" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p0_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p0_loop_bw_decimal" Value="50" />
                        <Parameter Id="virtual-parameter-dpll0p0_fin_num" Value="50" />
                        <Parameter Id="virtual-parameter-dpll0p0_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p0_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll0p1_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL0p1 Reference Source" Value="3" />
                        <Parameter Id="virtual-parameter-DPLL0p1 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL0p1OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p1 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll0p1_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p1_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p1_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p1_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p1_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p1_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p1_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p1_loop_bw_converted" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p1_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p1_loop_bw_decimal" Value="50" />
                        <Parameter Id="virtual-parameter-dpll0p1_fin_num" Value="50" />
                        <Parameter Id="virtual-parameter-dpll0p1_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p1_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll0p2_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL0p2 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p2 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL0p2OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p2 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll0p2_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p2_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p2_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p2_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p2_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p2_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p2_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p2_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p2_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p2_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p2_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p2_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p2_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll0p3_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL0p3 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p3 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL0p3OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p3 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll0p3_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p3_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p3_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p3_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p3_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p3_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p3_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p3_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p3_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p3_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p3_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p3_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p3_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll0p4_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL0p4 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p4 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL0p4OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p4 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll0p4_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p4_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p4_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p4_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p4_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p4_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p4_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p4_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p4_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p4_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p4_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p4_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p4_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll0p5_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL0p5 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p5 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL0p5OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0p5 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll0p5_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p5_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p5_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p5_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p5_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p5_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0p5_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p5_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p5_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll0p5_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p5_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0p5_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll0p5_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll0_mod_count" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0 Profile Selection" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL0 Manual Profile" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0_auto_profile_bar" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_profile_en" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0_profile_active" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0_total_ndiv" Value="4001" />
                        <Parameter Id="virtual-parameter-DPLL0 Feedback Source" Value="5" />
                        <Parameter Id="virtual-parameter-DPLL0 Reference Source" Value="3" />
                        <Parameter Id="virtual-parameter-dpll0_src0_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src1_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src2_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src3_selected" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0_src4_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src5_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src6_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src7_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src8_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_src9_selected" Value="false" />
                        <Parameter Id="virtual-parameter-nco0_div" Value="7.41558854" />
                        <Parameter Id="virtual-parameter-dpll0_ext_zd" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0_ext_zd_src" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0_buildout_src" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0_hitless" Value="1" />
                        <Parameter Id="virtual-parameter-dpll0_hitless_src" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0_operating_mode" Value="1" />
                        <Parameter Id="virtual-parameter-dpll0_settings_button" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0_profile_settings_button" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0_tag_mode" Value="0" />
                        <Parameter Id="virtual-parameter-dpll0_fb_tagged" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_ref_tagged" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_fb_untagged" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0_is_hitless" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0_is_buildout" Value="false" />
                        <Parameter Id="virtual-parameter-dpll0_is_internal" Value="true" />
                        <Parameter Id="virtual-parameter-dpll0_is_external" Value="false" />
                        <Parameter Id="virtual-parameter-out0A_mod_fout" Value="0" />
                        <Parameter Id="virtual-parameter-out0A_mod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-out0A_mod_disable" Value="true" />
                        <Parameter Id="virtual-parameter-out0a_mod_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out0a_expression" Value="125*(10/8) MHz" />
                        <Parameter Id="virtual-parameter-out0A_gui" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-OUT0A" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-out0A_decimal" Value="156250000" />
                        <Parameter Id="virtual-parameter-out0A_num" Value="156250000" />
                        <Parameter Id="virtual-parameter-out0A_den" Value="1" />
                        <Parameter Id="virtual-parameter-out0A_en" Value="true" />
                        <Parameter Id="virtual-parameter-out0A_pd" Value="false" />
                        <Parameter Id="virtual-parameter-Output 0A Total Divide" Value="10.5" />
                        <Parameter Id="virtual-parameter-out0a_mod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out0A_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0A_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0A_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0A_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-out0A_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-out 0A_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-out0B_mod_fout" Value="0" />
                        <Parameter Id="virtual-parameter-out0B_mod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-out0B_mod_disable" Value="true" />
                        <Parameter Id="virtual-parameter-out0b_mod_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out0b_expression" Value="125*(10/8) MHz" />
                        <Parameter Id="virtual-parameter-out0B_gui" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-OUT0B" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-out0B_decimal" Value="156250000" />
                        <Parameter Id="virtual-parameter-out0B_num" Value="156250000" />
                        <Parameter Id="virtual-parameter-out0B_den" Value="1" />
                        <Parameter Id="virtual-parameter-out0B_en" Value="false" />
                        <Parameter Id="virtual-parameter-out0B_pd" Value="false" />
                        <Parameter Id="virtual-parameter-Output 0B Total Divide" Value="8" />
                        <Parameter Id="virtual-parameter-out0b_mod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out0B_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0B_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0B_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0B_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-out0B_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-out 0B_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-out0C_mod_fout" Value="0" />
                        <Parameter Id="virtual-parameter-out0C_mod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-out0C_mod_disable" Value="true" />
                        <Parameter Id="virtual-parameter-out0c_mod_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out0c_expression" Value="125*(10/8) MHz" />
                        <Parameter Id="virtual-parameter-out0C_gui" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-OUT0C" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-out0C_decimal" Value="156250000" />
                        <Parameter Id="virtual-parameter-out0C_num" Value="156250000" />
                        <Parameter Id="virtual-parameter-out0C_den" Value="1" />
                        <Parameter Id="virtual-parameter-out0C_en" Value="false" />
                        <Parameter Id="virtual-parameter-out0C_pd" Value="false" />
                        <Parameter Id="virtual-parameter-Output 0C Total Divide" Value="8" />
                        <Parameter Id="virtual-parameter-out0c_mod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out0C_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0C_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0C_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out0C_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-out0C_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-out 0C_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-dpll1p0_sel" Value="true" />
                        <Parameter Id="virtual-parameter-DPLL1p0 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p0 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL1p0OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p0 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll1p0_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p0_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p0_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p0_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p0_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p0_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p0_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p0_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p0_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p0_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p0_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p0_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p0_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll1p1_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL1p1 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p1 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL1p1OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p1 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll1p1_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p1_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p1_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p1_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p1_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p1_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p1_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p1_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p1_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p1_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p1_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p1_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p1_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll1p2_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL1p2 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p2 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL1p2OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p2 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll1p2_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p2_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p2_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p2_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p2_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p2_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p2_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p2_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p2_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p2_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p2_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p2_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p2_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll1p3_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL1p3 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p3 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL1p3OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p3 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll1p3_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p3_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p3_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p3_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p3_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p3_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p3_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p3_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p3_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p3_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p3_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p3_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p3_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll1p4_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL1p4 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p4 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL1p4OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p4 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll1p4_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p4_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p4_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p4_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p4_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p4_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p4_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p4_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p4_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p4_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p4_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p4_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p4_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll1p5_sel" Value="false" />
                        <Parameter Id="virtual-parameter-DPLL1p5 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p5 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-vpDPLL1p5OperatingMode" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1p5 Feedback Divide Value" Value="4001" />
                        <Parameter Id="virtual-parameter-dpll1p5_tag_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p5_tag_ignore_ref_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p5_tag_ignore_fb_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p5_tag_mode_wiz" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p5_slow_mode_resolve_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p5_slow_mode_resolve_vis_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1p5_loop_bw" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p5_loop_bw_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p5_loop_bw" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-dpll1p5_loop_bw_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p5_fin_num" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1p5_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_dpll1p5_title" Value=" " />
                        <Parameter Id="virtual-parameter-dpll1_mod_count" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1 Profile Selection" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1 Manual Profile" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_auto_profile_bar" Value="true" />
                        <Parameter Id="virtual-parameter-dpll1_profile_en" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_profile_active" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_total_ndiv" Value="4001" />
                        <Parameter Id="virtual-parameter-DPLL1 Feedback Source" Value="0" />
                        <Parameter Id="virtual-parameter-DPLL1 Reference Source" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_src0_selected" Value="true" />
                        <Parameter Id="virtual-parameter-dpll1_src1_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src2_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src3_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src4_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src5_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src6_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src7_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src8_selected" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_src9_selected" Value="false" />
                        <Parameter Id="virtual-parameter-nco1_div" Value="7.28990476" />
                        <Parameter Id="virtual-parameter-dpll1_ext_zd" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_ext_zd_src" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_buildout_src" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_hitless" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_hitless_src" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_operating_mode" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_settings_button" Value="true" />
                        <Parameter Id="virtual-parameter-dpll1_profile_settings_button" Value="true" />
                        <Parameter Id="virtual-parameter-dpll1_tag_mode" Value="0" />
                        <Parameter Id="virtual-parameter-dpll1_fb_tagged" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_ref_tagged" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_fb_untagged" Value="true" />
                        <Parameter Id="virtual-parameter-dpll1_is_hitless" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_is_buildout" Value="true" />
                        <Parameter Id="virtual-parameter-dpll1_is_internal" Value="false" />
                        <Parameter Id="virtual-parameter-dpll1_is_external" Value="false" />
                        <Parameter Id="virtual-parameter-out1A_mod_fout" Value="0" />
                        <Parameter Id="virtual-parameter-out1A_mod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-out1A_mod_disable" Value="true" />
                        <Parameter Id="virtual-parameter-out1a_mod_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out1a_expression" Value="156 + 1/4 MHz" />
                        <Parameter Id="virtual-parameter-out1A_gui" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-OUT1A" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-out1A_decimal" Value="156250000" />
                        <Parameter Id="virtual-parameter-out1A_num" Value="156250000" />
                        <Parameter Id="virtual-parameter-out1A_den" Value="1" />
                        <Parameter Id="virtual-parameter-out1A_en" Value="false" />
                        <Parameter Id="virtual-parameter-out1A_pd" Value="false" />
                        <Parameter Id="virtual-parameter-Output 1A Total Divide" Value="10.5" />
                        <Parameter Id="virtual-parameter-out1a_mod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out1A_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out1A_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out1A_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out1A_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-out1A_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-out 1A_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-out1B_mod_fout" Value="0" />
                        <Parameter Id="virtual-parameter-out1B_mod_en_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-out1B_mod_disable" Value="true" />
                        <Parameter Id="virtual-parameter-out1b_mod_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out1b_expression" Value="156 + 1/4 MHz" />
                        <Parameter Id="virtual-parameter-out1B_gui" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-OUT1B" Value="156.25 MHz" />
                        <Parameter Id="virtual-parameter-out1B_decimal" Value="156250000" />
                        <Parameter Id="virtual-parameter-out1B_num" Value="156250000" />
                        <Parameter Id="virtual-parameter-out1B_den" Value="1" />
                        <Parameter Id="virtual-parameter-out1B_en" Value="false" />
                        <Parameter Id="virtual-parameter-out1B_pd" Value="false" />
                        <Parameter Id="virtual-parameter-Output 1B Total Divide" Value="10.5" />
                        <Parameter Id="virtual-parameter-out1b_mod_gui_visible" Value="false" />
                        <Parameter Id="virtual-parameter-out1B_fphase_exp" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out1B_fphase_evaled" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out1B_fphase_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-out1B_fphase_value" Value="1" />
                        <Parameter Id="virtual-parameter-out1B_fphase_num" Value="1" />
                        <Parameter Id="virtual-parameter-out 1B_fphase_den" Value="1" />
                        <Parameter Id="virtual-parameter-M0_out_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M0_in_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-M0_auxtdc0_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M0_auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M0_auxtdc_ping_pong_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M1_out_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M1_in_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-M1_auxtdc0_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M1_auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M1_auxtdc_ping_pong_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M2_out_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M2_in_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-M2_auxtdc0_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M2_auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M2_auxtdc_ping_pong_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M3_out_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M3_in_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-M3_auxtdc0_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M3_auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M3_auxtdc_ping_pong_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M4_out_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M4_in_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-M4_auxtdc0_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M4_auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M4_auxtdc_ping_pong_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M5_out_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M5_in_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-M5_auxtdc0_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M5_auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M5_auxtdc_ping_pong_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M6_out_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M6_in_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-M6_auxtdc0_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M6_auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-M6_auxtdc_ping_pong_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-internal_temperature" Value="36.0390625" />
                        <Parameter Id="virtual-parameter-external_temperature" Value="0" />
                        <Parameter Id="virtual-parameter-aux_dpll_enable" Value="false" />
                        <Parameter Id="virtual-parameter-aux_dpll_bandwidth_input" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-aux_dpll_bandwidth_converted" Value="0 Hz" />
                        <Parameter Id="virtual-parameter-aux_dpll_bandwidth_wiz" Value="50 Hz" />
                        <Parameter Id="virtual-parameter-aux_dpll_bandwidth_decimal" Value="0" />
                        <Parameter Id="virtual-parameter-aux_dpll_bandwidth_num" Value="0" />
                        <Parameter Id="virtual-parameter-aux_dpll_bandwidth_den" Value="1" />
                        <Parameter Id="virtual-parameter-wiz_nco0_enabled" Value="true" />
                        <Parameter Id="virtual-parameter-wiz_nco0_Fin" Value="2392000000" />
                        <Parameter Id="virtual-parameter-wiz_nco0_Fout" Value="312500000" />
                        <Parameter Id="virtual-parameter-wiz_nco1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-wiz_nco1_Fin" Value="2392000000" />
                        <Parameter Id="virtual-parameter-wiz_nco1_Fout" Value="343750000" />
                        <Parameter Id="virtual-parameter-wiz_dpll0_enable" Value="true" />
                        <Parameter Id="virtual-parameter-wiz_dpll0_fout" Value="312.5" />
                        <Parameter Id="virtual-parameter-wiz_dpll1_enable" Value="false" />
                        <Parameter Id="virtual-parameter-wiz_dpll1_fout" Value="343.75" />
                        <Parameter Id="virtual-parameter-ExtWizParamsVisible" Value="false" />
                        <Parameter Id="virtual-parameter-dist0_settings_button" Value="true" />
                        <Parameter Id="virtual-parameter-dist1_settings_button" Value="true" />
                        <Parameter Id="virtual-parameter-mpins_button" Value="true" />
                        <Parameter Id="virtual-parameter-temp_sensor_button" Value="true" />
                        <Parameter Id="virtual-parameter-aux_tdcs_button" Value="true" />
                        <Parameter Id="virtual-parameter-user_ts_button" Value="true" />
                        <Parameter Id="virtual-parameter-idTest" Value="1" />
                        <Parameter Id="virtual-parameter-Hidden" Value="false" />
                        <Parameter Id="virtual-parameter-sessionVersion" Value="1.1.8.0" />
                        <Parameter Id="virtual-parameter-AuxNCO0 Fundamental" Value="50 kHz" />
                        <Parameter Id="virtual-parameter-auxnco0_carrier_decimal" Value="50000" />
                        <Parameter Id="virtual-parameter-AuxNCO0 Fundamental Wizard" Value="50 kHz" />
                        <Parameter Id="virtual-parameter-AuxNCO0_Fundamental_Express" Value="50 kHz" />
                        <Parameter Id="virtual-parameter-auxnco0_center" Value="49.872 kHz" />
                        <Parameter Id="virtual-parameter-auxnco0_offset" Value="128 Hz" />
                        <Parameter Id="virtual-parameter-auxnco0_pulse_width_input" Value="40 ns" />
                        <Parameter Id="virtual-parameter-auxnco0_pulse_width_display" Value="40.1338 ns" />
                        <Parameter Id="virtual-parameter-auxnco0_tag_rate_expression_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-auxnco0_tag_rate_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-auxnco0_tags_enable_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO0 Tag Rate" Value="50000" />
                        <Parameter Id="virtual-parameter-auxnco0_tags_wiz_visibility" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO0 Tag Rate Visibility" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO0 phase type" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO0 inverted phase type" Value="true" />
                        <Parameter Id="virtual-parameter-AuxNCO0 Enable" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO1 Fundamental" Value="50 kHz" />
                        <Parameter Id="virtual-parameter-auxnco1_carrier_decimal" Value="50000" />
                        <Parameter Id="virtual-parameter-AuxNCO1 Fundamental Wizard" Value="50 kHz" />
                        <Parameter Id="virtual-parameter-AuxNCO1_Fundamental_Express" Value="50 kHz" />
                        <Parameter Id="virtual-parameter-auxnco1_center" Value="49.872 kHz" />
                        <Parameter Id="virtual-parameter-auxnco1_offset" Value="128 Hz" />
                        <Parameter Id="virtual-parameter-auxnco1_pulse_width_input" Value="40 ns" />
                        <Parameter Id="virtual-parameter-auxnco1_pulse_width_display" Value="40.1338 ns" />
                        <Parameter Id="virtual-parameter-auxnco1_tag_rate_expression_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-auxnco1_tag_rate_wiz" Value="1 Hz" />
                        <Parameter Id="virtual-parameter-auxnco1_tags_enable_wiz" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO1 Tag Rate" Value="50000" />
                        <Parameter Id="virtual-parameter-auxnco1_tags_wiz_visibility" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO1 Tag Rate Visibility" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO1 phase type" Value="false" />
                        <Parameter Id="virtual-parameter-AuxNCO1 inverted phase type" Value="true" />
                        <Parameter Id="virtual-parameter-AuxNCO1 Enable" Value="false" />
                        <Parameter Id="virtual-parameter-auxtdc0_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-auxtdc0_fin_exp" Value="10 MHz" />
                        <Parameter Id="virtual-parameter-auxtdc0_fin_evaled" Value="10000000 / 1" />
                        <Parameter Id="virtual-parameter-auxtdc0_fin_wiz" Value="10 MHz" />
                        <Parameter Id="virtual-parameter-auxtdc0_fin_value" Value="10000000" />
                        <Parameter Id="virtual-parameter-auxtdc0_fin_num" Value="10000000" />
                        <Parameter Id="virtual-parameter-auxtdc0_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-auxtdc0_T_exp" Value="100 ns" />
                        <Parameter Id="virtual-parameter-auxtdc0_T_evaled" Value="100 ns" />
                        <Parameter Id="virtual-parameter-auxtdc0_T_wiz" Value="100 ns" />
                        <Parameter Id="virtual-parameter-auxtdc0_T_value" Value="0.0000001" />
                        <Parameter Id="virtual-parameter-auxtdc0_T_num" Value="1" />
                        <Parameter Id="virtual-parameter-auxtdc0_T_den" Value="10000000" />
                        <Parameter Id="virtual-parameter-auxtdc0_display_string" Value="None" />
                        <Parameter Id="virtual-parameter-auxtdc1_enabled" Value="false" />
                        <Parameter Id="virtual-parameter-auxtdc1_fin_exp" Value="10 MHz" />
                        <Parameter Id="virtual-parameter-auxtdc1_fin_evaled" Value="10000000 / 1" />
                        <Parameter Id="virtual-parameter-auxtdc1_fin_wiz" Value="10 MHz" />
                        <Parameter Id="virtual-parameter-auxtdc1_fin_value" Value="10000000" />
                        <Parameter Id="virtual-parameter-auxtdc1_fin_num" Value="10000000" />
                        <Parameter Id="virtual-parameter-auxtdc1_fin_den" Value="1" />
                        <Parameter Id="virtual-parameter-auxtdc1_T_exp" Value="100 ns" />
                        <Parameter Id="virtual-parameter-auxtdc1_T_evaled" Value="100 ns" />
                        <Parameter Id="virtual-parameter-auxtdc1_T_wiz" Value="100 ns" />
                        <Parameter Id="virtual-parameter-auxtdc1_T_value" Value="0.0000001" />
                        <Parameter Id="virtual-parameter-auxtdc1_T_num" Value="1" />
                        <Parameter Id="virtual-parameter-auxtdc1_T_den" Value="10000000" />
                        <Parameter Id="virtual-parameter-auxtdc1_display_string" Value="None" />
                        <Parameter Id="virtual-parameter-auxtdc_ping_pong_display_string" Value="None" />
                        <RegisterMap UniqueId="0.serial_port" Address="0" Count="10">
                          <Register Address="0" Value="24" />
                          <Register Address="1" Value="0" />
                          <Register Address="3" Value="5" />
                          <Register Address="4" Value="21" />
                          <Register Address="5" Value="1" />
                          <Register Address="6" Value="2" />
                          <Register Address="B" Value="0" />
                          <Register Address="C" Value="56" />
                          <Register Address="D" Value="4" />
                          <Register Address="F" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="10.serial_port_extensions" Address="10" Count="1">
                          <Register Address="10" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="20.scratchpad" Address="20" Count="4">
                          <Register Address="20" Value="0" />
                          <Register Address="21" Value="0" />
                          <Register Address="22" Value="0" />
                          <Register Address="23" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="100.mpin_status_control" Address="100" Count="12">
                          <Register Address="100" Value="0" />
                          <Register Address="101" Value="0" />
                          <Register Address="102" Value="0" />
                          <Register Address="103" Value="0" />
                          <Register Address="104" Value="0" />
                          <Register Address="105" Value="0" />
                          <Register Address="106" Value="0" />
                          <Register Address="107" Value="0" />
                          <Register Address="108" Value="0" />
                          <Register Address="109" Value="0" />
                          <Register Address="10A" Value="0" />
                          <Register Address="10B" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="10C.irq_common_mask" Address="10C" Count="5">
                          <Register Address="10C" Value="0" />
                          <Register Address="10D" Value="0" />
                          <Register Address="10E" Value="0" />
                          <Register Address="10F" Value="0" />
                          <Register Address="110" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="111.irq_pll_0_mask" Address="111" Count="5">
                          <Register Address="111" Value="0" />
                          <Register Address="112" Value="0" />
                          <Register Address="113" Value="0" />
                          <Register Address="114" Value="0" />
                          <Register Address="115" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="116.irq_pll_1_mask" Address="116" Count="5">
                          <Register Address="116" Value="0" />
                          <Register Address="117" Value="0" />
                          <Register Address="118" Value="0" />
                          <Register Address="119" Value="0" />
                          <Register Address="11A" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="200.system_clock" Address="200" Count="10">
                          <Register Address="200" Value="2E" />
                          <Register Address="201" Value="0" />
                          <Register Address="202" Value="0" />
                          <Register Address="203" Value="08" />
                          <Register Address="204" Value="71" />
                          <Register Address="205" Value="1B" />
                          <Register Address="206" Value="0C" />
                          <Register Address="207" Value="32" />
                          <Register Address="208" Value="0" />
                          <Register Address="209" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="280.system_clock_comp" Address="280" Count="29">
                          <Register Address="280" Value="0" />
                          <Register Address="281" Value="0" />
                          <Register Address="282" Value="0" />
                          <Register Address="283" Value="0" />
                          <Register Address="284" Value="0" />
                          <Register Address="285" Value="0" />
                          <Register Address="286" Value="0" />
                          <Register Address="287" Value="0" />
                          <Register Address="288" Value="0" />
                          <Register Address="289" Value="0" />
                          <Register Address="28A" Value="0" />
                          <Register Address="28B" Value="0" />
                          <Register Address="28C" Value="0" />
                          <Register Address="28D" Value="0" />
                          <Register Address="28E" Value="0" />
                          <Register Address="28F" Value="0" />
                          <Register Address="290" Value="0" />
                          <Register Address="291" Value="0" />
                          <Register Address="292" Value="0" />
                          <Register Address="293" Value="0" />
                          <Register Address="294" Value="0" />
                          <Register Address="295" Value="0" />
                          <Register Address="296" Value="0" />
                          <Register Address="297" Value="0" />
                          <Register Address="298" Value="0" />
                          <Register Address="299" Value="0" />
                          <Register Address="29A" Value="0" />
                          <Register Address="29B" Value="0" />
                          <Register Address="29C" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="300.reference_general_a" Address="300" Count="4">
                          <Register Address="300" Value="0" />
                          <Register Address="301" Value="1" />
                          <Register Address="302" Value="40" />
                          <Register Address="303" Value="40" />
                        </RegisterMap>
                        <RegisterMap UniqueId="304.reference_general_b" Address="304" Count="4">
                          <Register Address="304" Value="40" />
                          <Register Address="305" Value="1" />
                          <Register Address="306" Value="40" />
                          <Register Address="307" Value="40" />
                        </RegisterMap>
                        <RegisterMap UniqueId="400.reference_input_a" Address="400" Count="21">
                          <Register Address="400" Value="099" />
                          <Register Address="401" Value="0" />
                          <Register Address="402" Value="0" />
                          <Register Address="403" Value="0" />
                          <Register Address="404" Value="085" />
                          <Register Address="405" Value="5F" />
                          <Register Address="406" Value="41" />
                          <Register Address="407" Value="094" />
                          <Register Address="408" Value="7" />
                          <Register Address="409" Value="0" />
                          <Register Address="40A" Value="0" />
                          <Register Address="40B" Value="0" />
                          <Register Address="40C" Value="0A0" />
                          <Register Address="40D" Value="086" />
                          <Register Address="40E" Value="1" />
                          <Register Address="40F" Value="3" />
                          <Register Address="410" Value="0A" />
                          <Register Address="411" Value="0" />
                          <Register Address="412" Value="0" />
                          <Register Address="413" Value="0" />
                          <Register Address="414" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="420.reference_input_aa" Address="420" Count="21">
                          <Register Address="420" Value="7C" />
                          <Register Address="421" Value="0" />
                          <Register Address="422" Value="0" />
                          <Register Address="423" Value="0" />
                          <Register Address="424" Value="0" />
                          <Register Address="425" Value="090" />
                          <Register Address="426" Value="2F" />
                          <Register Address="427" Value="50" />
                          <Register Address="428" Value="09" />
                          <Register Address="429" Value="0" />
                          <Register Address="42A" Value="0" />
                          <Register Address="42B" Value="0" />
                          <Register Address="42C" Value="0A0" />
                          <Register Address="42D" Value="086" />
                          <Register Address="42E" Value="1" />
                          <Register Address="42F" Value="3" />
                          <Register Address="430" Value="0A" />
                          <Register Address="431" Value="0" />
                          <Register Address="432" Value="0" />
                          <Register Address="433" Value="0" />
                          <Register Address="434" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="440.reference_input_b" Address="440" Count="21">
                          <Register Address="440" Value="099" />
                          <Register Address="441" Value="0" />
                          <Register Address="442" Value="0" />
                          <Register Address="443" Value="0" />
                          <Register Address="444" Value="085" />
                          <Register Address="445" Value="5F" />
                          <Register Address="446" Value="41" />
                          <Register Address="447" Value="094" />
                          <Register Address="448" Value="7" />
                          <Register Address="449" Value="0" />
                          <Register Address="44A" Value="0" />
                          <Register Address="44B" Value="0" />
                          <Register Address="44C" Value="0A0" />
                          <Register Address="44D" Value="086" />
                          <Register Address="44E" Value="1" />
                          <Register Address="44F" Value="3" />
                          <Register Address="450" Value="0A" />
                          <Register Address="451" Value="0" />
                          <Register Address="452" Value="0" />
                          <Register Address="453" Value="0" />
                          <Register Address="454" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="460.reference_input_bb" Address="460" Count="21">
                          <Register Address="460" Value="099" />
                          <Register Address="461" Value="0" />
                          <Register Address="462" Value="0" />
                          <Register Address="463" Value="0" />
                          <Register Address="464" Value="085" />
                          <Register Address="465" Value="5F" />
                          <Register Address="466" Value="41" />
                          <Register Address="467" Value="094" />
                          <Register Address="468" Value="7" />
                          <Register Address="469" Value="0" />
                          <Register Address="46A" Value="0" />
                          <Register Address="46B" Value="0" />
                          <Register Address="46C" Value="0A0" />
                          <Register Address="46D" Value="086" />
                          <Register Address="46E" Value="1" />
                          <Register Address="46F" Value="3" />
                          <Register Address="470" Value="0A" />
                          <Register Address="471" Value="0" />
                          <Register Address="472" Value="0" />
                          <Register Address="473" Value="0" />
                          <Register Address="474" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="800.source_profile_0_a" Address="800" Count="18">
                          <Register Address="800" Value="0BC" />
                          <Register Address="801" Value="2" />
                          <Register Address="802" Value="0" />
                          <Register Address="803" Value="0A" />
                          <Register Address="804" Value="0A" />
                          <Register Address="805" Value="0BC" />
                          <Register Address="806" Value="2" />
                          <Register Address="807" Value="0" />
                          <Register Address="808" Value="0A" />
                          <Register Address="809" Value="0A" />
                          <Register Address="80A" Value="0" />
                          <Register Address="80B" Value="0" />
                          <Register Address="80C" Value="0" />
                          <Register Address="80D" Value="0" />
                          <Register Address="80E" Value="0" />
                          <Register Address="80F" Value="0" />
                          <Register Address="810" Value="0" />
                          <Register Address="811" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="820.source_profile_1_aa" Address="820" Count="18">
                          <Register Address="820" Value="0BC" />
                          <Register Address="821" Value="2" />
                          <Register Address="822" Value="0" />
                          <Register Address="823" Value="0A" />
                          <Register Address="824" Value="0A" />
                          <Register Address="825" Value="0BC" />
                          <Register Address="826" Value="2" />
                          <Register Address="827" Value="0" />
                          <Register Address="828" Value="0A" />
                          <Register Address="829" Value="0A" />
                          <Register Address="82A" Value="0" />
                          <Register Address="82B" Value="0" />
                          <Register Address="82C" Value="0" />
                          <Register Address="82D" Value="0" />
                          <Register Address="82E" Value="0" />
                          <Register Address="82F" Value="0" />
                          <Register Address="830" Value="0" />
                          <Register Address="831" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="840.source_profile_2_b" Address="840" Count="18">
                          <Register Address="840" Value="0BC" />
                          <Register Address="841" Value="2" />
                          <Register Address="842" Value="0" />
                          <Register Address="843" Value="0A" />
                          <Register Address="844" Value="0A" />
                          <Register Address="845" Value="0BC" />
                          <Register Address="846" Value="2" />
                          <Register Address="847" Value="0" />
                          <Register Address="848" Value="0A" />
                          <Register Address="849" Value="0A" />
                          <Register Address="84A" Value="0" />
                          <Register Address="84B" Value="0" />
                          <Register Address="84C" Value="0" />
                          <Register Address="84D" Value="0" />
                          <Register Address="84E" Value="0" />
                          <Register Address="84F" Value="0" />
                          <Register Address="850" Value="0" />
                          <Register Address="851" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="860.source_profile_3_bb" Address="860" Count="18">
                          <Register Address="860" Value="0BC" />
                          <Register Address="861" Value="2" />
                          <Register Address="862" Value="0" />
                          <Register Address="863" Value="0A" />
                          <Register Address="864" Value="0A" />
                          <Register Address="865" Value="0BC" />
                          <Register Address="866" Value="2" />
                          <Register Address="867" Value="0" />
                          <Register Address="868" Value="0A" />
                          <Register Address="869" Value="0A" />
                          <Register Address="86A" Value="0" />
                          <Register Address="86B" Value="0" />
                          <Register Address="86C" Value="0" />
                          <Register Address="86D" Value="0" />
                          <Register Address="86E" Value="0" />
                          <Register Address="86F" Value="0" />
                          <Register Address="870" Value="0" />
                          <Register Address="871" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="880.source_profile_4_auxnco_0" Address="880" Count="18">
                          <Register Address="880" Value="0BC" />
                          <Register Address="881" Value="2" />
                          <Register Address="882" Value="0" />
                          <Register Address="883" Value="0A" />
                          <Register Address="884" Value="0A" />
                          <Register Address="885" Value="0BC" />
                          <Register Address="886" Value="2" />
                          <Register Address="887" Value="0" />
                          <Register Address="888" Value="0A" />
                          <Register Address="889" Value="0A" />
                          <Register Address="88A" Value="0" />
                          <Register Address="88B" Value="0" />
                          <Register Address="88C" Value="0" />
                          <Register Address="88D" Value="0" />
                          <Register Address="88E" Value="0" />
                          <Register Address="88F" Value="0" />
                          <Register Address="890" Value="0" />
                          <Register Address="891" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="8A0.source_profile_5_auxnco_1" Address="8A0" Count="18">
                          <Register Address="8A0" Value="0BC" />
                          <Register Address="8A1" Value="2" />
                          <Register Address="8A2" Value="0" />
                          <Register Address="8A3" Value="0A" />
                          <Register Address="8A4" Value="0A" />
                          <Register Address="8A5" Value="0BC" />
                          <Register Address="8A6" Value="2" />
                          <Register Address="8A7" Value="0" />
                          <Register Address="8A8" Value="0A" />
                          <Register Address="8A9" Value="0A" />
                          <Register Address="8AA" Value="0" />
                          <Register Address="8AB" Value="0" />
                          <Register Address="8AC" Value="0" />
                          <Register Address="8AD" Value="0" />
                          <Register Address="8AE" Value="0" />
                          <Register Address="8AF" Value="0" />
                          <Register Address="8B0" Value="0" />
                          <Register Address="8B1" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="8C0.source_profile_6_dpll_0" Address="8C0" Count="18">
                          <Register Address="8C0" Value="0BC" />
                          <Register Address="8C1" Value="2" />
                          <Register Address="8C2" Value="0" />
                          <Register Address="8C3" Value="0A" />
                          <Register Address="8C4" Value="0A" />
                          <Register Address="8C5" Value="0BC" />
                          <Register Address="8C6" Value="2" />
                          <Register Address="8C7" Value="0" />
                          <Register Address="8C8" Value="0A" />
                          <Register Address="8C9" Value="0A" />
                          <Register Address="8CA" Value="0" />
                          <Register Address="8CB" Value="0" />
                          <Register Address="8CC" Value="0" />
                          <Register Address="8CD" Value="0" />
                          <Register Address="8CE" Value="0" />
                          <Register Address="8CF" Value="0" />
                          <Register Address="8D0" Value="0" />
                          <Register Address="8D1" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="8E0.source_profile_7_dpll_1" Address="8E0" Count="18">
                          <Register Address="8E0" Value="0BC" />
                          <Register Address="8E1" Value="2" />
                          <Register Address="8E2" Value="0" />
                          <Register Address="8E3" Value="0A" />
                          <Register Address="8E4" Value="0A" />
                          <Register Address="8E5" Value="0BC" />
                          <Register Address="8E6" Value="2" />
                          <Register Address="8E7" Value="0" />
                          <Register Address="8E8" Value="0A" />
                          <Register Address="8E9" Value="0A" />
                          <Register Address="8EA" Value="0" />
                          <Register Address="8EB" Value="0" />
                          <Register Address="8EC" Value="0" />
                          <Register Address="8ED" Value="0" />
                          <Register Address="8EE" Value="0" />
                          <Register Address="8EF" Value="0" />
                          <Register Address="8F0" Value="0" />
                          <Register Address="8F1" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="C00.lf_coefficients_0" Address="C00" Count="12">
                          <Register Address="C00" Value="0C2" />
                          <Register Address="C01" Value="0F0" />
                          <Register Address="C02" Value="0B3" />
                          <Register Address="C03" Value="55" />
                          <Register Address="C04" Value="0C9" />
                          <Register Address="C05" Value="0FB" />
                          <Register Address="C06" Value="5C" />
                          <Register Address="C07" Value="0F6" />
                          <Register Address="C08" Value="0CA" />
                          <Register Address="C09" Value="11" />
                          <Register Address="C0A" Value="0DF" />
                          <Register Address="C0B" Value="0CC" />
                        </RegisterMap>
                        <RegisterMap UniqueId="C0C.lf_coefficients_1" Address="C0C" Count="12">
                          <Register Address="C0C" Value="0A9" />
                          <Register Address="C0D" Value="0A0" />
                          <Register Address="C0E" Value="0B7" />
                          <Register Address="C0F" Value="0CD" />
                          <Register Address="C10" Value="0DB" />
                          <Register Address="C11" Value="0F3" />
                          <Register Address="C12" Value="79" />
                          <Register Address="C13" Value="0D4" />
                          <Register Address="C14" Value="0CE" />
                          <Register Address="C15" Value="4D" />
                          <Register Address="C16" Value="0A7" />
                          <Register Address="C17" Value="0CF" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1000.dpll_0" Address="1000" Count="43">
                          <Register Address="1000" Value="09A" />
                          <Register Address="1001" Value="3C" />
                          <Register Address="1002" Value="6B" />
                          <Register Address="1003" Value="099" />
                          <Register Address="1004" Value="085" />
                          <Register Address="1005" Value="22" />
                          <Register Address="1006" Value="0FF" />
                          <Register Address="1007" Value="0FF" />
                          <Register Address="1008" Value="0FF" />
                          <Register Address="1009" Value="0" />
                          <Register Address="100A" Value="0A" />
                          <Register Address="100B" Value="0" />
                          <Register Address="100C" Value="0" />
                          <Register Address="100D" Value="0" />
                          <Register Address="100E" Value="38" />
                          <Register Address="100F" Value="0" />
                          <Register Address="1010" Value="0" />
                          <Register Address="1011" Value="0" />
                          <Register Address="1012" Value="0" />
                          <Register Address="1013" Value="0" />
                          <Register Address="1014" Value="6" />
                          <Register Address="1015" Value="0" />
                          <Register Address="1016" Value="0" />
                          <Register Address="1017" Value="0" />
                          <Register Address="1018" Value="0" />
                          <Register Address="1019" Value="0" />
                          <Register Address="101A" Value="0" />
                          <Register Address="101B" Value="0" />
                          <Register Address="101C" Value="0" />
                          <Register Address="101D" Value="0" />
                          <Register Address="101E" Value="0" />
                          <Register Address="101F" Value="0" />
                          <Register Address="1020" Value="0" />
                          <Register Address="1021" Value="0" />
                          <Register Address="1022" Value="0" />
                          <Register Address="1023" Value="0" />
                          <Register Address="1024" Value="0" />
                          <Register Address="1025" Value="0" />
                          <Register Address="1026" Value="0" />
                          <Register Address="1027" Value="0" />
                          <Register Address="1028" Value="0" />
                          <Register Address="102A" Value="0" />
                          <Register Address="102B" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1080.apll_0" Address="1080" Count="4">
                          <Register Address="1080" Value="094" />
                          <Register Address="1081" Value="08" />
                          <Register Address="1082" Value="0E0" />
                          <Register Address="1083" Value="3" />
                        </RegisterMap>
                        <RegisterMap UniqueId="10C0.dist_0_general_0" Address="10C0" Count="29">
                          <Register Address="10C0" Value="0" />
                          <Register Address="10C1" Value="0" />
                          <Register Address="10C2" Value="0" />
                          <Register Address="10C3" Value="0" />
                          <Register Address="10C4" Value="0" />
                          <Register Address="10C5" Value="0" />
                          <Register Address="10C6" Value="0" />
                          <Register Address="10C7" Value="0" />
                          <Register Address="10C8" Value="0" />
                          <Register Address="10C9" Value="0" />
                          <Register Address="10CA" Value="0" />
                          <Register Address="10CB" Value="0" />
                          <Register Address="10CC" Value="0" />
                          <Register Address="10CD" Value="0" />
                          <Register Address="10CE" Value="0" />
                          <Register Address="10CF" Value="0" />
                          <Register Address="10D0" Value="0" />
                          <Register Address="10D1" Value="0" />
                          <Register Address="10D2" Value="0" />
                          <Register Address="10D3" Value="0" />
                          <Register Address="10D4" Value="0" />
                          <Register Address="10D5" Value="0" />
                          <Register Address="10D6" Value="0" />
                          <Register Address="10D7" Value="1" />
                          <Register Address="10D8" Value="1" />
                          <Register Address="10D9" Value="1" />
                          <Register Address="10DA" Value="0" />
                          <Register Address="10DB" Value="0" />
                          <Register Address="10DC" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1100.distribution_divider_0_a" Address="1100" Count="9">
                          <Register Address="1100" Value="0A" />
                          <Register Address="1101" Value="0" />
                          <Register Address="1102" Value="0" />
                          <Register Address="1103" Value="0" />
                          <Register Address="1104" Value="0" />
                          <Register Address="1105" Value="0" />
                          <Register Address="1106" Value="0" />
                          <Register Address="1107" Value="0" />
                          <Register Address="1108" Value="27" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1109.distribution_divider_0_aa" Address="1109" Count="9">
                          <Register Address="1109" Value="0" />
                          <Register Address="110A" Value="0" />
                          <Register Address="110B" Value="0" />
                          <Register Address="110C" Value="0" />
                          <Register Address="110D" Value="0" />
                          <Register Address="110E" Value="0" />
                          <Register Address="110F" Value="0" />
                          <Register Address="1110" Value="0" />
                          <Register Address="1111" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1112.distribution_divider_0_b" Address="1112" Count="9">
                          <Register Address="1112" Value="08" />
                          <Register Address="1113" Value="0" />
                          <Register Address="1114" Value="0" />
                          <Register Address="1115" Value="0" />
                          <Register Address="1116" Value="0" />
                          <Register Address="1117" Value="0" />
                          <Register Address="1118" Value="0" />
                          <Register Address="1119" Value="0" />
                          <Register Address="111A" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="111B.distribution_divider_0_bb" Address="111B" Count="9">
                          <Register Address="111B" Value="0" />
                          <Register Address="111C" Value="0" />
                          <Register Address="111D" Value="0" />
                          <Register Address="111E" Value="0" />
                          <Register Address="111F" Value="0" />
                          <Register Address="1120" Value="0" />
                          <Register Address="1121" Value="0" />
                          <Register Address="1122" Value="0" />
                          <Register Address="1123" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1124.distribution_divider_0_c" Address="1124" Count="9">
                          <Register Address="1124" Value="08" />
                          <Register Address="1125" Value="0" />
                          <Register Address="1126" Value="0" />
                          <Register Address="1127" Value="0" />
                          <Register Address="1128" Value="0" />
                          <Register Address="1129" Value="0" />
                          <Register Address="112A" Value="0" />
                          <Register Address="112B" Value="0" />
                          <Register Address="112C" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="112D.distribution_divider_0_cc" Address="112D" Count="9">
                          <Register Address="112D" Value="0" />
                          <Register Address="112E" Value="0" />
                          <Register Address="112F" Value="0" />
                          <Register Address="1130" Value="0" />
                          <Register Address="1131" Value="0" />
                          <Register Address="1132" Value="0" />
                          <Register Address="1133" Value="0" />
                          <Register Address="1134" Value="0" />
                          <Register Address="1135" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1200.translation_profile_0_0" Address="1200" Count="24">
                          <Register Address="1200" Value="1" />
                          <Register Address="1201" Value="3" />
                          <Register Address="1202" Value="0" />
                          <Register Address="1203" Value="1" />
                          <Register Address="1204" Value="080" />
                          <Register Address="1205" Value="0F0" />
                          <Register Address="1206" Value="0FA" />
                          <Register Address="1207" Value="2" />
                          <Register Address="1208" Value="0A0" />
                          <Register Address="1209" Value="0F" />
                          <Register Address="120A" Value="0" />
                          <Register Address="120B" Value="0" />
                          <Register Address="120C" Value="1D" />
                          <Register Address="120D" Value="6" />
                          <Register Address="120E" Value="0" />
                          <Register Address="120F" Value="0" />
                          <Register Address="1210" Value="0B5" />
                          <Register Address="1211" Value="1" />
                          <Register Address="1212" Value="0" />
                          <Register Address="1213" Value="0" />
                          <Register Address="1214" Value="3" />
                          <Register Address="1215" Value="0" />
                          <Register Address="1216" Value="0" />
                          <Register Address="1217" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1220.translation_profile_0_1" Address="1220" Count="24">
                          <Register Address="1220" Value="1" />
                          <Register Address="1221" Value="3" />
                          <Register Address="1222" Value="0" />
                          <Register Address="1223" Value="1" />
                          <Register Address="1224" Value="080" />
                          <Register Address="1225" Value="0F0" />
                          <Register Address="1226" Value="0FA" />
                          <Register Address="1227" Value="2" />
                          <Register Address="1228" Value="0A0" />
                          <Register Address="1229" Value="0F" />
                          <Register Address="122A" Value="0" />
                          <Register Address="122B" Value="0" />
                          <Register Address="122C" Value="081" />
                          <Register Address="122D" Value="6" />
                          <Register Address="122E" Value="0" />
                          <Register Address="122F" Value="0" />
                          <Register Address="1230" Value="0B5" />
                          <Register Address="1231" Value="1" />
                          <Register Address="1232" Value="0" />
                          <Register Address="1233" Value="0" />
                          <Register Address="1234" Value="3" />
                          <Register Address="1235" Value="0" />
                          <Register Address="1236" Value="0" />
                          <Register Address="1237" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1240.translation_profile_0_2" Address="1240" Count="24">
                          <Register Address="1240" Value="0" />
                          <Register Address="1241" Value="0" />
                          <Register Address="1242" Value="0" />
                          <Register Address="1243" Value="0" />
                          <Register Address="1244" Value="0" />
                          <Register Address="1245" Value="0" />
                          <Register Address="1246" Value="0" />
                          <Register Address="1247" Value="0" />
                          <Register Address="1248" Value="0A0" />
                          <Register Address="1249" Value="0F" />
                          <Register Address="124A" Value="0" />
                          <Register Address="124B" Value="0" />
                          <Register Address="124C" Value="0A0" />
                          <Register Address="124D" Value="0F" />
                          <Register Address="124E" Value="0" />
                          <Register Address="124F" Value="0" />
                          <Register Address="1250" Value="0" />
                          <Register Address="1251" Value="0" />
                          <Register Address="1252" Value="0" />
                          <Register Address="1253" Value="0" />
                          <Register Address="1254" Value="0" />
                          <Register Address="1255" Value="0" />
                          <Register Address="1256" Value="0" />
                          <Register Address="1257" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1260.translation_profile_0_3" Address="1260" Count="24">
                          <Register Address="1260" Value="0" />
                          <Register Address="1261" Value="0" />
                          <Register Address="1262" Value="0" />
                          <Register Address="1263" Value="0" />
                          <Register Address="1264" Value="0" />
                          <Register Address="1265" Value="0" />
                          <Register Address="1266" Value="0" />
                          <Register Address="1267" Value="0" />
                          <Register Address="1268" Value="0A0" />
                          <Register Address="1269" Value="0F" />
                          <Register Address="126A" Value="0" />
                          <Register Address="126B" Value="0" />
                          <Register Address="126C" Value="0A0" />
                          <Register Address="126D" Value="0F" />
                          <Register Address="126E" Value="0" />
                          <Register Address="126F" Value="0" />
                          <Register Address="1270" Value="0" />
                          <Register Address="1271" Value="0" />
                          <Register Address="1272" Value="0" />
                          <Register Address="1273" Value="0" />
                          <Register Address="1274" Value="0" />
                          <Register Address="1275" Value="0" />
                          <Register Address="1276" Value="0" />
                          <Register Address="1277" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1280.translation_profile_0_4" Address="1280" Count="24">
                          <Register Address="1280" Value="0" />
                          <Register Address="1281" Value="0" />
                          <Register Address="1282" Value="0" />
                          <Register Address="1283" Value="0" />
                          <Register Address="1284" Value="0" />
                          <Register Address="1285" Value="0" />
                          <Register Address="1286" Value="0" />
                          <Register Address="1287" Value="0" />
                          <Register Address="1288" Value="0A0" />
                          <Register Address="1289" Value="0F" />
                          <Register Address="128A" Value="0" />
                          <Register Address="128B" Value="0" />
                          <Register Address="128C" Value="0A0" />
                          <Register Address="128D" Value="0F" />
                          <Register Address="128E" Value="0" />
                          <Register Address="128F" Value="0" />
                          <Register Address="1290" Value="0" />
                          <Register Address="1291" Value="0" />
                          <Register Address="1292" Value="0" />
                          <Register Address="1293" Value="0" />
                          <Register Address="1294" Value="0" />
                          <Register Address="1295" Value="0" />
                          <Register Address="1296" Value="0" />
                          <Register Address="1297" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="12A0.translation_profile_0_5" Address="12A0" Count="24">
                          <Register Address="12A0" Value="0" />
                          <Register Address="12A1" Value="0" />
                          <Register Address="12A2" Value="0" />
                          <Register Address="12A3" Value="0" />
                          <Register Address="12A4" Value="0" />
                          <Register Address="12A5" Value="0" />
                          <Register Address="12A6" Value="0" />
                          <Register Address="12A7" Value="0" />
                          <Register Address="12A8" Value="0A0" />
                          <Register Address="12A9" Value="0F" />
                          <Register Address="12AA" Value="0" />
                          <Register Address="12AB" Value="0" />
                          <Register Address="12AC" Value="0A0" />
                          <Register Address="12AD" Value="0F" />
                          <Register Address="12AE" Value="0" />
                          <Register Address="12AF" Value="0" />
                          <Register Address="12B0" Value="0" />
                          <Register Address="12B1" Value="0" />
                          <Register Address="12B2" Value="0" />
                          <Register Address="12B3" Value="0" />
                          <Register Address="12B4" Value="0" />
                          <Register Address="12B5" Value="0" />
                          <Register Address="12B6" Value="0" />
                          <Register Address="12B7" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1400.dpll_1" Address="1400" Count="43">
                          <Register Address="1400" Value="19" />
                          <Register Address="1401" Value="29" />
                          <Register Address="1402" Value="70" />
                          <Register Address="1403" Value="0F7" />
                          <Register Address="1404" Value="1D" />
                          <Register Address="1405" Value="23" />
                          <Register Address="1406" Value="0FF" />
                          <Register Address="1407" Value="0FF" />
                          <Register Address="1408" Value="0FF" />
                          <Register Address="1409" Value="0" />
                          <Register Address="140A" Value="0A" />
                          <Register Address="140B" Value="0" />
                          <Register Address="140C" Value="0" />
                          <Register Address="140D" Value="0" />
                          <Register Address="140E" Value="38" />
                          <Register Address="140F" Value="0" />
                          <Register Address="1410" Value="0" />
                          <Register Address="1411" Value="0" />
                          <Register Address="1412" Value="0" />
                          <Register Address="1413" Value="0" />
                          <Register Address="1414" Value="6" />
                          <Register Address="1415" Value="0" />
                          <Register Address="1416" Value="0" />
                          <Register Address="1417" Value="0" />
                          <Register Address="1418" Value="0" />
                          <Register Address="1419" Value="0" />
                          <Register Address="141A" Value="0" />
                          <Register Address="141B" Value="0" />
                          <Register Address="141C" Value="0" />
                          <Register Address="141D" Value="0" />
                          <Register Address="141E" Value="0" />
                          <Register Address="141F" Value="0" />
                          <Register Address="1420" Value="0" />
                          <Register Address="1421" Value="0" />
                          <Register Address="1422" Value="0" />
                          <Register Address="1423" Value="0" />
                          <Register Address="1424" Value="0" />
                          <Register Address="1425" Value="0" />
                          <Register Address="1426" Value="0" />
                          <Register Address="1427" Value="0" />
                          <Register Address="1428" Value="0" />
                          <Register Address="142A" Value="0" />
                          <Register Address="142B" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1480.apll_1" Address="1480" Count="4">
                          <Register Address="1480" Value="090" />
                          <Register Address="1481" Value="0A" />
                          <Register Address="1482" Value="0E0" />
                          <Register Address="1483" Value="3" />
                        </RegisterMap>
                        <RegisterMap UniqueId="14C0.dist_1_general_1" Address="14C0" Count="22">
                          <Register Address="14C0" Value="0" />
                          <Register Address="14C1" Value="0" />
                          <Register Address="14C2" Value="0" />
                          <Register Address="14C3" Value="0" />
                          <Register Address="14C4" Value="0" />
                          <Register Address="14C5" Value="0" />
                          <Register Address="14C6" Value="0" />
                          <Register Address="14C7" Value="0" />
                          <Register Address="14C8" Value="0" />
                          <Register Address="14C9" Value="0" />
                          <Register Address="14CE" Value="0" />
                          <Register Address="14CF" Value="0" />
                          <Register Address="14D0" Value="0" />
                          <Register Address="14D2" Value="0" />
                          <Register Address="14D3" Value="0" />
                          <Register Address="14D4" Value="0" />
                          <Register Address="14D6" Value="0" />
                          <Register Address="14D7" Value="1" />
                          <Register Address="14D8" Value="1" />
                          <Register Address="14DA" Value="0" />
                          <Register Address="14DB" Value="0" />
                          <Register Address="14DC" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1500.distribution_divider_1_a" Address="1500" Count="9">
                          <Register Address="1500" Value="0A" />
                          <Register Address="1501" Value="0" />
                          <Register Address="1502" Value="0" />
                          <Register Address="1503" Value="0" />
                          <Register Address="1504" Value="0" />
                          <Register Address="1505" Value="0" />
                          <Register Address="1506" Value="0" />
                          <Register Address="1507" Value="0" />
                          <Register Address="1508" Value="27" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1509.distribution_divider_1_aa" Address="1509" Count="9">
                          <Register Address="1509" Value="0" />
                          <Register Address="150A" Value="0" />
                          <Register Address="150B" Value="0" />
                          <Register Address="150C" Value="0" />
                          <Register Address="150D" Value="0" />
                          <Register Address="150E" Value="0" />
                          <Register Address="150F" Value="0" />
                          <Register Address="1510" Value="0" />
                          <Register Address="1511" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1512.distribution_divider_1_b" Address="1512" Count="9">
                          <Register Address="1512" Value="0A" />
                          <Register Address="1513" Value="0" />
                          <Register Address="1514" Value="0" />
                          <Register Address="1515" Value="0" />
                          <Register Address="1516" Value="0" />
                          <Register Address="1517" Value="0" />
                          <Register Address="1518" Value="0" />
                          <Register Address="1519" Value="0" />
                          <Register Address="151A" Value="27" />
                        </RegisterMap>
                        <RegisterMap UniqueId="151B.distribution_divider_1_bb" Address="151B" Count="9">
                          <Register Address="151B" Value="0" />
                          <Register Address="151C" Value="0" />
                          <Register Address="151D" Value="0" />
                          <Register Address="151E" Value="0" />
                          <Register Address="151F" Value="0" />
                          <Register Address="1520" Value="0" />
                          <Register Address="1521" Value="0" />
                          <Register Address="1522" Value="0" />
                          <Register Address="1523" Value="7" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1600.translation_profile_1_0" Address="1600" Count="24">
                          <Register Address="1600" Value="0" />
                          <Register Address="1601" Value="0" />
                          <Register Address="1602" Value="0" />
                          <Register Address="1603" Value="0" />
                          <Register Address="1604" Value="0" />
                          <Register Address="1605" Value="0" />
                          <Register Address="1606" Value="0" />
                          <Register Address="1607" Value="0" />
                          <Register Address="1608" Value="0A0" />
                          <Register Address="1609" Value="0F" />
                          <Register Address="160A" Value="0" />
                          <Register Address="160B" Value="0" />
                          <Register Address="160C" Value="0A0" />
                          <Register Address="160D" Value="0F" />
                          <Register Address="160E" Value="0" />
                          <Register Address="160F" Value="0" />
                          <Register Address="1610" Value="0" />
                          <Register Address="1611" Value="0" />
                          <Register Address="1612" Value="0" />
                          <Register Address="1613" Value="0" />
                          <Register Address="1614" Value="0" />
                          <Register Address="1615" Value="0" />
                          <Register Address="1616" Value="0" />
                          <Register Address="1617" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1620.translation_profile_1_1" Address="1620" Count="24">
                          <Register Address="1620" Value="0" />
                          <Register Address="1621" Value="0" />
                          <Register Address="1622" Value="0" />
                          <Register Address="1623" Value="0" />
                          <Register Address="1624" Value="0" />
                          <Register Address="1625" Value="0" />
                          <Register Address="1626" Value="0" />
                          <Register Address="1627" Value="0" />
                          <Register Address="1628" Value="0A0" />
                          <Register Address="1629" Value="0F" />
                          <Register Address="162A" Value="0" />
                          <Register Address="162B" Value="0" />
                          <Register Address="162C" Value="0A0" />
                          <Register Address="162D" Value="0F" />
                          <Register Address="162E" Value="0" />
                          <Register Address="162F" Value="0" />
                          <Register Address="1630" Value="0" />
                          <Register Address="1631" Value="0" />
                          <Register Address="1632" Value="0" />
                          <Register Address="1633" Value="0" />
                          <Register Address="1634" Value="0" />
                          <Register Address="1635" Value="0" />
                          <Register Address="1636" Value="0" />
                          <Register Address="1637" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1640.translation_profile_1_2" Address="1640" Count="24">
                          <Register Address="1640" Value="0" />
                          <Register Address="1641" Value="0" />
                          <Register Address="1642" Value="0" />
                          <Register Address="1643" Value="0" />
                          <Register Address="1644" Value="0" />
                          <Register Address="1645" Value="0" />
                          <Register Address="1646" Value="0" />
                          <Register Address="1647" Value="0" />
                          <Register Address="1648" Value="0A0" />
                          <Register Address="1649" Value="0F" />
                          <Register Address="164A" Value="0" />
                          <Register Address="164B" Value="0" />
                          <Register Address="164C" Value="0A0" />
                          <Register Address="164D" Value="0F" />
                          <Register Address="164E" Value="0" />
                          <Register Address="164F" Value="0" />
                          <Register Address="1650" Value="0" />
                          <Register Address="1651" Value="0" />
                          <Register Address="1652" Value="0" />
                          <Register Address="1653" Value="0" />
                          <Register Address="1654" Value="0" />
                          <Register Address="1655" Value="0" />
                          <Register Address="1656" Value="0" />
                          <Register Address="1657" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1660.translation_profile_1_3" Address="1660" Count="24">
                          <Register Address="1660" Value="0" />
                          <Register Address="1661" Value="0" />
                          <Register Address="1662" Value="0" />
                          <Register Address="1663" Value="0" />
                          <Register Address="1664" Value="0" />
                          <Register Address="1665" Value="0" />
                          <Register Address="1666" Value="0" />
                          <Register Address="1667" Value="0" />
                          <Register Address="1668" Value="0A0" />
                          <Register Address="1669" Value="0F" />
                          <Register Address="166A" Value="0" />
                          <Register Address="166B" Value="0" />
                          <Register Address="166C" Value="0A0" />
                          <Register Address="166D" Value="0F" />
                          <Register Address="166E" Value="0" />
                          <Register Address="166F" Value="0" />
                          <Register Address="1670" Value="0" />
                          <Register Address="1671" Value="0" />
                          <Register Address="1672" Value="0" />
                          <Register Address="1673" Value="0" />
                          <Register Address="1674" Value="0" />
                          <Register Address="1675" Value="0" />
                          <Register Address="1676" Value="0" />
                          <Register Address="1677" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="1680.translation_profile_1_4" Address="1680" Count="24">
                          <Register Address="1680" Value="0" />
                          <Register Address="1681" Value="0" />
                          <Register Address="1682" Value="0" />
                          <Register Address="1683" Value="0" />
                          <Register Address="1684" Value="0" />
                          <Register Address="1685" Value="0" />
                          <Register Address="1686" Value="0" />
                          <Register Address="1687" Value="0" />
                          <Register Address="1688" Value="0A0" />
                          <Register Address="1689" Value="0F" />
                          <Register Address="168A" Value="0" />
                          <Register Address="168B" Value="0" />
                          <Register Address="168C" Value="0A0" />
                          <Register Address="168D" Value="0F" />
                          <Register Address="168E" Value="0" />
                          <Register Address="168F" Value="0" />
                          <Register Address="1690" Value="0" />
                          <Register Address="1691" Value="0" />
                          <Register Address="1692" Value="0" />
                          <Register Address="1693" Value="0" />
                          <Register Address="1694" Value="0" />
                          <Register Address="1695" Value="0" />
                          <Register Address="1696" Value="0" />
                          <Register Address="1697" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="16A0.translation_profile_1_5" Address="16A0" Count="24">
                          <Register Address="16A0" Value="0" />
                          <Register Address="16A1" Value="0" />
                          <Register Address="16A2" Value="0" />
                          <Register Address="16A3" Value="0" />
                          <Register Address="16A4" Value="0" />
                          <Register Address="16A5" Value="0" />
                          <Register Address="16A6" Value="0" />
                          <Register Address="16A7" Value="0" />
                          <Register Address="16A8" Value="0A0" />
                          <Register Address="16A9" Value="0F" />
                          <Register Address="16AA" Value="0" />
                          <Register Address="16AB" Value="0" />
                          <Register Address="16AC" Value="0A0" />
                          <Register Address="16AD" Value="0F" />
                          <Register Address="16AE" Value="0" />
                          <Register Address="16AF" Value="0" />
                          <Register Address="16B0" Value="0" />
                          <Register Address="16B1" Value="0" />
                          <Register Address="16B2" Value="0" />
                          <Register Address="16B3" Value="0" />
                          <Register Address="16B4" Value="0" />
                          <Register Address="16B5" Value="0" />
                          <Register Address="16B6" Value="0" />
                          <Register Address="16B7" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2000.op_ctrl" Address="2000" Count="6">
                          <Register Address="2000" Value="0" />
                          <Register Address="2001" Value="7" />
                          <Register Address="2002" Value="0" />
                          <Register Address="2003" Value="0" />
                          <Register Address="2004" Value="0" />
                          <Register Address="2005" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2006.irq_common_clear" Address="2006" Count="5">
                          <Register Address="2006" Value="0" />
                          <Register Address="2007" Value="0" />
                          <Register Address="2008" Value="0" />
                          <Register Address="2009" Value="0" />
                          <Register Address="200A" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="200B.irq_pll_0_clear" Address="200B" Count="5">
                          <Register Address="200B" Value="0" />
                          <Register Address="200C" Value="0" />
                          <Register Address="200D" Value="0" />
                          <Register Address="200E" Value="0" />
                          <Register Address="200F" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2010.irq_pll_1_clear" Address="2010" Count="5">
                          <Register Address="2010" Value="0" />
                          <Register Address="2011" Value="0" />
                          <Register Address="2012" Value="0" />
                          <Register Address="2013" Value="0" />
                          <Register Address="2014" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2100.operational_control_pll_0" Address="2100" Count="8">
                          <Register Address="2100" Value="0" />
                          <Register Address="2101" Value="0" />
                          <Register Address="2102" Value="0" />
                          <Register Address="2103" Value="10" />
                          <Register Address="2104" Value="10" />
                          <Register Address="2105" Value="0" />
                          <Register Address="2106" Value="0" />
                          <Register Address="2107" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2200.operational_control_pll_1" Address="2200" Count="7">
                          <Register Address="2200" Value="0" />
                          <Register Address="2201" Value="0" />
                          <Register Address="2202" Value="10" />
                          <Register Address="2203" Value="10" />
                          <Register Address="2205" Value="0" />
                          <Register Address="2206" Value="0" />
                          <Register Address="2207" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2800.auxnco_0" Address="2800" Count="31">
                          <Register Address="2800" Value="0" />
                          <Register Address="2801" Value="0" />
                          <Register Address="2802" Value="0" />
                          <Register Address="2803" Value="0" />
                          <Register Address="2804" Value="0" />
                          <Register Address="2805" Value="0D0" />
                          <Register Address="2806" Value="0C2" />
                          <Register Address="2807" Value="0" />
                          <Register Address="2808" Value="0" />
                          <Register Address="2809" Value="0" />
                          <Register Address="280A" Value="080" />
                          <Register Address="280B" Value="0" />
                          <Register Address="280C" Value="0" />
                          <Register Address="280D" Value="0" />
                          <Register Address="280E" Value="0" />
                          <Register Address="280F" Value="0" />
                          <Register Address="2810" Value="0" />
                          <Register Address="2811" Value="0" />
                          <Register Address="2812" Value="0" />
                          <Register Address="2813" Value="0" />
                          <Register Address="2814" Value="0" />
                          <Register Address="2815" Value="0" />
                          <Register Address="2816" Value="0" />
                          <Register Address="2817" Value="0" />
                          <Register Address="2818" Value="0" />
                          <Register Address="2819" Value="0" />
                          <Register Address="281A" Value="0" />
                          <Register Address="281B" Value="0" />
                          <Register Address="281C" Value="0" />
                          <Register Address="281D" Value="0" />
                          <Register Address="281E" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2840.auxnco_1" Address="2840" Count="31">
                          <Register Address="2840" Value="0" />
                          <Register Address="2841" Value="0" />
                          <Register Address="2842" Value="0" />
                          <Register Address="2843" Value="0" />
                          <Register Address="2844" Value="0" />
                          <Register Address="2845" Value="0D0" />
                          <Register Address="2846" Value="0C2" />
                          <Register Address="2847" Value="0" />
                          <Register Address="2848" Value="0" />
                          <Register Address="2849" Value="0" />
                          <Register Address="284A" Value="080" />
                          <Register Address="284B" Value="0" />
                          <Register Address="284C" Value="0" />
                          <Register Address="284D" Value="0" />
                          <Register Address="284E" Value="0" />
                          <Register Address="284F" Value="0" />
                          <Register Address="2850" Value="0" />
                          <Register Address="2851" Value="0" />
                          <Register Address="2852" Value="0" />
                          <Register Address="2853" Value="0" />
                          <Register Address="2854" Value="0" />
                          <Register Address="2855" Value="0" />
                          <Register Address="2856" Value="0" />
                          <Register Address="2857" Value="0" />
                          <Register Address="2858" Value="0" />
                          <Register Address="2859" Value="0" />
                          <Register Address="285A" Value="0" />
                          <Register Address="285B" Value="0" />
                          <Register Address="285C" Value="0" />
                          <Register Address="285D" Value="0" />
                          <Register Address="285E" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2900.temp_sensor" Address="2900" Count="7">
                          <Register Address="2900" Value="0" />
                          <Register Address="2901" Value="0" />
                          <Register Address="2902" Value="0" />
                          <Register Address="2903" Value="0" />
                          <Register Address="2904" Value="0" />
                          <Register Address="2905" Value="0" />
                          <Register Address="2906" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2A00.tdc_auxiliary" Address="2A00" Count="24">
                          <Register Address="2A00" Value="0" />
                          <Register Address="2A01" Value="0" />
                          <Register Address="2A02" Value="0" />
                          <Register Address="2A03" Value="0" />
                          <Register Address="2A04" Value="0" />
                          <Register Address="2A05" Value="0" />
                          <Register Address="2A06" Value="0" />
                          <Register Address="2A07" Value="0" />
                          <Register Address="2A08" Value="0" />
                          <Register Address="2A09" Value="0" />
                          <Register Address="2A0A" Value="0" />
                          <Register Address="2A0B" Value="0" />
                          <Register Address="2A0C" Value="0" />
                          <Register Address="2A0D" Value="0" />
                          <Register Address="2A0E" Value="0" />
                          <Register Address="2A0F" Value="0" />
                          <Register Address="2A10" Value="0" />
                          <Register Address="2A11" Value="0" />
                          <Register Address="2A12" Value="6" />
                          <Register Address="2A13" Value="7" />
                          <Register Address="2A14" Value="0" />
                          <Register Address="2A15" Value="0" />
                          <Register Address="2A16" Value="0" />
                          <Register Address="2A17" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2E00.eeprom" Address="2E00" Count="4">
                          <Register Address="2E00" Value="0" />
                          <Register Address="2E01" Value="0" />
                          <Register Address="2E02" Value="0" />
                          <Register Address="2E03" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="2E10.eeprom_sequence" Address="2E10" Count="15">
                          <Register Address="2E10" Value="0FF" />
                          <Register Address="2E11" Value="0FF" />
                          <Register Address="2E12" Value="0FF" />
                          <Register Address="2E13" Value="0FF" />
                          <Register Address="2E14" Value="0FF" />
                          <Register Address="2E15" Value="0FF" />
                          <Register Address="2E16" Value="0FF" />
                          <Register Address="2E17" Value="0FF" />
                          <Register Address="2E18" Value="0FF" />
                          <Register Address="2E19" Value="0FF" />
                          <Register Address="2E1A" Value="0FF" />
                          <Register Address="2E1B" Value="0FF" />
                          <Register Address="2E1C" Value="0FF" />
                          <Register Address="2E1D" Value="0FF" />
                          <Register Address="2E1E" Value="0FF" />
                        </RegisterMap>
                        <RegisterMap UniqueId="3000.status_readback" Address="3000" Count="11">
                          <Register Address="3000" Value="0" />
                          <Register Address="3001" Value="3" />
                          <Register Address="3002" Value="5" />
                          <Register Address="3003" Value="5" />
                          <Register Address="3004" Value="12" />
                          <Register Address="3005" Value="0B" />
                          <Register Address="3006" Value="0B" />
                          <Register Address="3007" Value="0B" />
                          <Register Address="3008" Value="10" />
                          <Register Address="3009" Value="1" />
                          <Register Address="300A" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="300B.irq_common_read" Address="300B" Count="5">
                          <Register Address="300B" Value="0" />
                          <Register Address="300C" Value="0" />
                          <Register Address="300D" Value="0" />
                          <Register Address="300E" Value="0" />
                          <Register Address="300F" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="3010.irq_pll_0_read" Address="3010" Count="5">
                          <Register Address="3010" Value="0" />
                          <Register Address="3011" Value="0" />
                          <Register Address="3012" Value="0" />
                          <Register Address="3013" Value="0" />
                          <Register Address="3014" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="3015.irq_pll_1_read" Address="3015" Count="5">
                          <Register Address="3015" Value="0" />
                          <Register Address="3016" Value="0" />
                          <Register Address="3017" Value="0" />
                          <Register Address="3018" Value="0" />
                          <Register Address="3019" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="3100.status_readback_pll_0" Address="3100" Count="15">
                          <Register Address="3100" Value="28" />
                          <Register Address="3101" Value="08" />
                          <Register Address="3102" Value="2" />
                          <Register Address="3103" Value="0" />
                          <Register Address="3104" Value="0" />
                          <Register Address="3105" Value="0" />
                          <Register Address="3106" Value="0" />
                          <Register Address="3107" Value="0" />
                          <Register Address="3108" Value="0" />
                          <Register Address="3109" Value="0" />
                          <Register Address="310A" Value="08" />
                          <Register Address="310B" Value="0" />
                          <Register Address="310C" Value="08" />
                          <Register Address="310D" Value="0" />
                          <Register Address="310E" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="3200.status_readback_pll_1" Address="3200" Count="15">
                          <Register Address="3200" Value="28" />
                          <Register Address="3201" Value="1" />
                          <Register Address="3202" Value="0" />
                          <Register Address="3203" Value="0" />
                          <Register Address="3204" Value="0" />
                          <Register Address="3205" Value="0" />
                          <Register Address="3206" Value="0" />
                          <Register Address="3207" Value="0" />
                          <Register Address="3208" Value="0" />
                          <Register Address="3209" Value="0" />
                          <Register Address="320A" Value="0" />
                          <Register Address="320B" Value="0" />
                          <Register Address="320C" Value="0" />
                          <Register Address="320D" Value="0" />
                          <Register Address="320E" Value="0" />
                        </RegisterMap>
                        <RegisterMap UniqueId="3A00.tdc_auxiliary_read" Address="3A00" Count="60">
                          <Register Address="3A00" Value="0" />
                          <Register Address="3A01" Value="0" />
                          <Register Address="3A02" Value="0" />
                          <Register Address="3A03" Value="0" />
                          <Register Address="3A04" Value="0" />
                          <Register Address="3A05" Value="0" />
                          <Register Address="3A06" Value="0" />
                          <Register Address="3A07" Value="0" />
                          <Register Address="3A08" Value="0" />
                          <Register Address="3A09" Value="0" />
                          <Register Address="3A0A" Value="0" />
                          <Register Address="3A0B" Value="0" />
                          <Register Address="3A0C" Value="0" />
                          <Register Address="3A0D" Value="0" />
                          <Register Address="3A0E" Value="0" />
                          <Register Address="3A0F" Value="0" />
                          <Register Address="3A10" Value="0" />
                          <Register Address="3A11" Value="0" />
                          <Register Address="3A12" Value="0" />
                          <Register Address="3A13" Value="0" />
                          <Register Address="3A14" Value="0" />
                          <Register Address="3A15" Value="0" />
                          <Register Address="3A16" Value="0" />
                          <Register Address="3A17" Value="0" />
                          <Register Address="3A18" Value="0" />
                          <Register Address="3A19" Value="0" />
                          <Register Address="3A1A" Value="0" />
                          <Register Address="3A1B" Value="0" />
                          <Register Address="3A1C" Value="0" />
                          <Register Address="3A1D" Value="0" />
                          <Register Address="3A1E" Value="0" />
                          <Register Address="3A1F" Value="0" />
                          <Register Address="3A20" Value="0" />
                          <Register Address="3A21" Value="0" />
                          <Register Address="3A22" Value="0" />
                          <Register Address="3A23" Value="0" />
                          <Register Address="3A24" Value="0" />
                          <Register Address="3A25" Value="0" />
                          <Register Address="3A26" Value="0" />
                          <Register Address="3A27" Value="0" />
                          <Register Address="3A28" Value="0" />
                          <Register Address="3A29" Value="0" />
                          <Register Address="3A2A" Value="0" />
                          <Register Address="3A2B" Value="0" />
                          <Register Address="3A2C" Value="0" />
                          <Register Address="3A2D" Value="0" />
                          <Register Address="3A2E" Value="0" />
                          <Register Address="3A2F" Value="0" />
                          <Register Address="3A30" Value="0" />
                          <Register Address="3A31" Value="0" />
                          <Register Address="3A32" Value="0" />
                          <Register Address="3A33" Value="0" />
                          <Register Address="3A34" Value="0" />
                          <Register Address="3A35" Value="0" />
                          <Register Address="3A36" Value="0" />
                          <Register Address="3A37" Value="0" />
                          <Register Address="3A38" Value="0" />
                          <Register Address="3A39" Value="0" />
                          <Register Address="3A3A" Value="0" />
                          <Register Address="3A3B" Value="0" />
                        </RegisterMap>
                      </Chip>
                    </Chips>
                    <StateControls AllowStatePolling="true" />
                  </Board>
                </SavedState>
              </Component>
            </Components>
            <Connections />
          </Subsystem>
        </Subsystems>
      </System>
    </Element>
    <Element Id="Controllers">
      <Controller Name="AD9545 Board" HardwareID="\\?\USB#VID_0456&PID_EE25#7&1587B11&0&3#{D2958CFD-F0E1-4752-8AFF-06D5B4411024}" Path="Root::System.Subsystem_1.AD9545 Board" xmlns="" />
    </Element>
    <Element Id="Macros">
      <MacroManager xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="AnalogDevices/Csa/Evaluation/UI/Models/Sessions/MacroManagerSessionElement.Schema.xsd">
        <Macros />
      </MacroManager>
    </Element>
    <Element Id="Views" ActiveWorkspaceElement="Root::System.Subsystem_1.AD9545 Board.AD9545" WorkspaceElements="Root::,Root::System,Root::System.Subsystem_1.AD9545 Board,Root::System.Subsystem_1.AD9545 Board.AD9545" />
  </Elements>
</Session>
  • ADI North America will be on winter shutdown starting December 25, 2023; perhaps another community member can assist you until our return on January 8, 2024.
  • HI,
    I'm very sorry for not seeing this issue. Please use the name of the product in the text next time.
    I tried to load the file that you attached into my ACE and I couldn't because ACE thought it was corrupt.
    I suppose you have an eval board and I see that you got the system clock PLL and the analog PLLs to lock, so the chip received well the 52 MHz clock from a signal generator.
    I then set REFBB=30.72MHz (set it yourself at correct format. Note that the eval board has this channel as dc coupled with 50ohm load to ground).
    I set OUT0A=122.88MHz, OUT0B=OUT0C=161.28MHz (based on the dividers you used). I then was able to set Profile 1 in internal zero delay mode (as you tried. I do not understand why you got the error)
    If you want to get OUT0A as LVDS, you need to set OUT0A as HCSL, 15mA:
    Note that on the eval board, to obtain HCSL outputs, you need to set the jumpers P300, 301, 302, 303, 304, 305 between pins 2 and 3 and connect TP307 (VOUT_COMMON) to TP308 (GND) as VOUT_COMMON was left floating.
    AD9545_setup2.cso.txt
    Take out the txt extension before loading it into ACE. It should work after you modify the way REFBB is applied to the board.
    Petre
