LTC6957-2 output are sinewave
Product Number: ltc6957-2
Hi Team,
I am trying to drive my LTC6957-2 with a 2v sinewave originated from an OCXO.
for some reason I get sinewave and not square wave at the output pins. the levels are LVDS levels but the shape is a sinewave.
I tried to load it with 100Ohm resistor as well as with ADCLK944 evalboard set LVDS input.
I am using the eval board for LTC6957.
what can be the issue? is it expecting a square wave input?
  • HI,
    Something is definitely wrong with your setup or the part.  The LVDS edges should have 170ps rise time, with either a sine wave or square wave input.
    Can you describe your setup?    What frequency is the OCXO?   What are you FILTA/B settings?
    Are you measuring the output with 100 ohm differential probe?  Or with a single ended probe terminated at 50 ohms?  If single ended, how is the unused output terminated?
    Can you send a picture of your setup?
    What supply current are you measuring?
    Thanks
    Chris
