How to determine the phase detector frequency and loop band loop bandwidth of PLL?
HMC7044
Recommended for New Designs
The HMC7044 is a high performance, dual-loop, integer-N jitter attenuator capable of performing reference selection and generation of ultralow phase noise...
Datasheet
HMC7044 on Analog.com
You can use ADISimCLK simulation to simulate and determine Phase Detector frequency and loop bandwidth.
ADIsimCLK | Design Center | Analog Devices
Emrecan
CLKIN3 input 10MHz clock as reference of PLL1,and VCXO is 122.88MHz ,whether this setting is appropriate。Here is the clk fileHMC7044 CLK
