After a reseed request the relation between clock and sysref is fix, I could run the reseed_request multiple times. Always the same relation.
echo 1 > /sys/bus/iio/devices/iio:device1/reseed_request
If I run sysref_request multiple times, the relation clock and sysref seems random. (hmc7044 reg 0x005A = 1)
echo 1 > /sys/bus/iio/devices/iio:device1/sysref_request
If I set pulse generator mode to Continuous mode (hmc7044 reg 0x005A = 7), the phase relation is always the same.
Question: How could I send extra sysref pulse without stopping the clock (reseed_request stops the clock) with fix phase relation. What I expect is that I have to sync the hmc7044 one time after startup with the reseed_request and could send sysref pulses afterwards.
dtb configurations (I use channel 8 and 9 for the clock and sysref comparison):
hmc7044_fmc: hmc7044-fmc@2 { #address-cells = <1>; #size-cells = <0>; #clock-cells = <1>; compatible = "adi,hmc7044"; reg = <2>; spi-max-frequency = <10000000>; adi,pll1-clkin-frequencies = <240000000 240000000 0 0>; adi,pll1-ref-prio-ctrl = <0xE5>; /* prefer CLKIN1 */ adi,clkin0-buffer-mode = <0x09>; adi,clkin1-buffer-mode = <0x09>; adi,sync-pin-mode = <1>; adi,pll1-loop-bandwidth-hz = <200>; adi,vcxo-frequency = <240000000>; adi,pll2-output-frequency = <2880000000>; adi,jesd204-max-sysref-frequency-hz = <1000000>; adi,jesd204-desired-sysref-frequency-hz = <2560000>; adi,hmc-two-level-tree-sync-en; adi,sysref-timer-divider = <3840>; adi,pulse-generator-mode = <7>; adi,oscin-buffer-mode = <0x15>; adi,gpi-controls = <0x00 0x00 0x00 0x11>; adi,gpo-controls = <0x1f 0x2b 0x00 0x00>; adi,high-performance-mode-clock-dist-enable; adi,high-performance-mode-pll-vco-enable; clock-output-names = "hmc7044_fmc_out0_DEV_REFCLK_C", "hmc7044_fmc_out1_DEV_SYSREF_C", "hmc7044_fmc_out2_DEV_REFCLK_D", "hmc7044_fmc_out3_DEV_SYSREF_D", "hmc7044_fmc_out4_JESD_REFCLK_TX_OBS_CD", "hmc7044_fmc_out5_JESD_REFCLK_RX_CD", "hmc7044_fmc_out6_FPGA_SYSREF_TX_OBS_CD","hmc7044_fmc_out7_FPGA_SYSREF_RX_CD", "hmc7044_fmc_out8", "hmc7044_fmc_out9", "hmc7044_fmc_out10", "hmc7044_fmc_out11", "hmc7044_fmc_out12", "hmc7044_fmc_out13"; hmc7044_fmc_c0: channel@0 { reg = <0>; adi,extended-name = "DEV_REFCLK_C"; adi,divider = <12>; // 245760000 adi,driver-mode = <HMC7044_DRIVER_MODE_LVDS>; adi,coarse-digital-delay = <0>; /* 15 */ }; hmc7044_fmc_c1: channel@1 { reg = <1>; adi,extended-name = "DEV_SYSREF_C"; adi,divider = <3840>; // 768000 adi,driver-mode = <HMC7044_DRIVER_MODE_LVPECL>; adi,control0-rb4-enable; adi,force-mute-enable; adi,startup-mode-dynamic-enable; adi,high-performance-mode-disable; adi,driver-impedance-mode = <HMC7044_DRIVER_IMPEDANCE_100_OHM>; }; hmc7044_fmc_c2: channel@2 { reg = <2>; adi,extended-name = "DEV_REFCLK_D"; adi,divider = <12>; // 245760000 adi,driver-mode = <HMC7044_DRIVER_MODE_LVDS>; adi,coarse-digital-delay = <0>; /* 15 */ }; hmc7044_fmc_c3: channel@3 { reg = <3>; adi,extended-name = "DEV_SYSREF_D"; adi,divider = <3840>; // 768000 adi,driver-mode = <HMC7044_DRIVER_MODE_LVPECL>; adi,control0-rb4-enable; adi,force-mute-enable; adi,startup-mode-dynamic-enable; adi,high-performance-mode-disable; adi,driver-impedance-mode = <HMC7044_DRIVER_IMPEDANCE_100_OHM>; }; hmc7044_fmc_c4: channel@4 { reg = <4>; adi,extended-name = "JESD_REFCLK_TX_OBS_CD"; adi,divider = <12>; // 245760000 adi,driver-mode = <HMC7044_DRIVER_MODE_LVDS>; adi,coarse-digital-delay = <11>; /* 0 */ }; hmc7044_fmc_c5: channel@5 { reg = <5>; adi,extended-name = "JESD_REFCLK_RX_CD"; adi,divider = <12>; // 245760000 adi,driver-mode = <HMC7044_DRIVER_MODE_LVDS>; }; hmc7044_fmc_c6: channel@6 { reg = <6>; adi,extended-name = "FPGA_SYSREF_TX_OBS_CD"; adi,divider = <3840>; // 768000 adi,driver-mode = <HMC7044_DRIVER_MODE_LVPECL>; adi,control0-rb4-enable; adi,force-mute-enable; adi,startup-mode-dynamic-enable; adi,high-performance-mode-disable; }; hmc7044_fmc_c7: channel@7 { reg = <7>; adi,extended-name = "FPGA_SYSREF_RX_CD"; adi,divider = <3840>; // 768000 adi,driver-mode = <HMC7044_DRIVER_MODE_LVPECL>; adi,control0-rb4-enable; adi,force-mute-enable; adi,startup-mode-dynamic-enable; adi,high-performance-mode-disable; }; hmc7044_fmc_c8: channel@8 { reg = <8>; adi,extended-name = "hmc7044_fmc_out8"; adi,divider = <12>; // 240000000 adi,driver-mode = <HMC7044_DRIVER_MODE_LVPECL>; adi,coarse-digital-delay = <11>; /* 0 */ }; hmc7044_fmc_c9: channel@9 { reg = <9>; adi,extended-name = "hmc7044_fmc_out9"; adi,divider = <3840>; // 768000 adi,driver-mode = <HMC7044_DRIVER_MODE_LVPECL>; adi,control0-rb4-enable; adi,force-mute-enable; adi,startup-mode-dynamic-enable; adi,high-performance-mode-disable; };
