The output of AD9542 contains harmonics of 122.88MHz
Product Number: AD9542
Software Version: none
The output of AD9542 contains harmonics of 122.88MHz showing by picture below.
I have two question. Thanks.
1. Are these harmonics be eliminated by AD9542 itself?
2. Can ADRV9029 filter these harmonics?
    please send me the AD9542 configuration cso file you use.
    I cannot respond for the ADRV9029. You will need to post your question in the related Community.
    Petre
  • <?xml version="1.0" encoding="utf-8"?>
    <Session Name="Session" AppVersion="" FileVersion="" xmlns="AnalogDevices/Csa/Configuration/Schemas/Session.xsd">
      <Elements>
        <Element Id="EvalSystem">
          <System xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Name="System" xmlns="AnalogDevices/Csa/Evaluation/Sessions/EvalSystemSessionElement.Schema.xsd">
            <Subsystems>
              <Subsystem Name="Subsystem_1">
                <Components>
                  <Component ComponentId="AD9542Board" Name="AD9542 Board">
                    <Info Name="AD9542 Board" Description="A USB to SPI interface board for the AD9542." />
                    <SavedState>
                      <Board Id="AD9542Board" xmlns="">
                        <Parameter Id="virtual-parameter-vpserialtype" Value="0" />
                        <Parameter Id="virtual-parameter-vpspiioconfig" Value="true" />
                        <Parameter Id="virtual-parameter-vpspibitorder" Value="false" />
                        <Parameter Id="virtual-parameter-vpspistreamingtype" Value="0" />
                        <Parameter Id="virtual-parameter-vpSPISelected" Value="true" />
                        <Parameter Id="virtual-parameter-vpI2CSelected" Value="false" />
                        <Parameter Id="fx2-port-a-pins" Value="7" />
                        <Parameter Id="pa_usb_status-direction-fx2-port-a-pins" Value="true" />
                        <Parameter Id="pa_usb_status-data-fx2-port-a-pins" Value="true" />
                        <Parameter Id="pa_csb-direction-fx2-port-a-pins" Value="true" />
                        <Parameter Id="pa_csb-data-fx2-port-a-pins" Value="true" />
                        <Parameter Id="pa_resetb-direction-fx2-port-a-pins" Value="true" />
                        <Parameter Id="pa_resetb-data-fx2-port-a-pins" Value="true" />
                        <Parameter Id="pa_enable_i2c-direction-fx2-port-a-pins" Value="true" />
                        <Parameter Id="pa_enable_i2c-data-fx2-port-a-pins" Value="false" />
                        <Parameter Id="pa_gpio_4-direction-fx2-port-a-pins" Value="false" />
                        <Parameter Id="pa_gpio_4-data-fx2-port-a-pins" Value="false" />
                        <Parameter Id="pa_gpio_5-direction-fx2-port-a-pins" Value="false" />
                        <Parameter Id="pa_gpio_5-data-fx2-port-a-pins" Value="false" />
                        <Parameter Id="pa_gpio_6-direction-fx2-port-a-pins" Value="false" />
                        <Parameter Id="pa_gpio_6-data-fx2-port-a-pins" Value="false" />
                        <Parameter Id="pa_gpio_7-direction-fx2-port-a-pins" Value="false" />
                        <Parameter Id="pa_gpio_7-data-fx2-port-a-pins" Value="false" />
                        <Parameter Id="fx2-port-b-pins" Value="0" />
                        <Parameter Id="pb_sdio-direction-fx2-port-b-pins" Value="false" />
                        <Parameter Id="pb_sdio-data-fx2-port-b-pins" Value="false" />
                        <Parameter Id="pb_sdo-direction-fx2-port-b-pins" Value="false" />
                        <Parameter Id="pb_sdo-data-fx2-port-b-pins" Value="false" />
                        <Parameter Id="pb_gpio_2-direction-fx2-port-b-pins" Value="false" />
                        <Parameter Id="pb_gpio_2-data-fx2-port-b-pins" Value="false" />
                        <Parameter Id="pb_gpio_3-direction-fx2-port-b-pins" Value="false" />
                        <Parameter Id="pb_gpio_3-data-fx2-port-b-pins" Value="false" />
                        <Parameter Id="pb_gpio_4-direction-fx2-port-b-pins" Value="false" />
                        <Parameter Id="pb_gpio_4-data-fx2-port-b-pins" Value="false" />
                        <Parameter Id="pb_gpio_5-direction-fx2-port-b-pins" Value="false" />
                        <Parameter Id="pb_gpio_5-data-fx2-port-b-pins" Value="false" />
                        <Parameter Id="pb_gpio_6-direction-fx2-port-b-pins" Value="false" />
                        <Parameter Id="pb_gpio_6-data-fx2-port-b-pins" Value="false" />
                        <Parameter Id="pb_gpio_7-direction-fx2-port-b-pins" Value="false" />
                        <Parameter Id="pb_gpio_7-data-fx2-port-b-pins" Value="false" />
                        <Parameter Id="fx2-port-c-pins" Value="0" />
                        <Parameter Id="pc_gpio_0-direction-fx2-port-c-pins" Value="false" />
                        <Parameter Id="pc_gpio_0-data-fx2-port-c-pins" Value="false" />
                        <Parameter Id="pc_gpio_1-direction-fx2-port-c-pins" Value="false" />
                        <Parameter Id="pc_gpio_1-data-fx2-port-c-pins" Value="false" />
                        <Parameter Id="pc_gpio_2-direction-fx2-port-c-pins" Value="false" />
                        <Parameter Id="pc_gpio_2-data-fx2-port-c-pins" Value="false" />
                        <Parameter Id="pc_gpio_3-direction-fx2-port-c-pins" Value="false" />
                        <Parameter Id="pc_gpio_3-data-fx2-port-c-pins" Value="false" />
                        <Parameter Id="pc_gpio_4-direction-fx2-port-c-pins" Value="false" />
                        <Parameter Id="pc_gpio_4-data-fx2-port-c-pins" Value="false" />
                        <Parameter Id="pc_gpio_5-direction-fx2-port-c-pins" Value="false" />
                        <Parameter Id="pc_gpio_5-data-fx2-port-c-pins" Value="false" />
                        <Parameter Id="pc_gpio_6-direction-fx2-port-c-pins" Value="false" />
                        <Parameter Id="pc_gpio_6-data-fx2-port-c-pins" Value="false" />
                        <Parameter Id="pc_gpio_7-direction-fx2-port-c-pins" Value="false" />
                        <Parameter Id="pc_gpio_7-data-fx2-port-c-pins" Value="false" />
                        <Parameter Id="fx2-port-d-pins" Value="0" />
                        <Parameter Id="pd_mp0-direction-fx2-port-d-pins" Value="false" />
                        <Parameter Id="pd_mp0-data-fx2-port-d-pins" Value="false" />
                        <Parameter Id="pd_mp1-direction-fx2-port-d-pins" Value="false" />
                        <Parameter Id="pd_mp1-data-fx2-port-d-pins" Value="false" />
                        <Parameter Id="pd_mp2-direction-fx2-port-d-pins" Value="false" />
                        <Parameter Id="pd_mp2-data-fx2-port-d-pins" Value="false" />
                        <Parameter Id="pd_mp3-direction-fx2-port-d-pins" Value="false" />
                        <Parameter Id="pd_mp3-data-fx2-port-d-pins" Value="false" />
                        <Parameter Id="pd_mp4-direction-fx2-port-d-pins" Value="false" />
                        <Parameter Id="pd_mp4-data-fx2-port-d-pins" Value="false" />
                        <Parameter Id="pd_mp5-direction-fx2-port-d-pins" Value="false" />
                        <Parameter Id="pd_mp5-data-fx2-port-d-pins" Value="false" />
                        <Parameter Id="pd_mp6-direction-fx2-port-d-pins" Value="false" />
                        <Parameter Id="pd_mp6-data-fx2-port-d-pins" Value="false" />
                        <Parameter Id="pd_gpio_7-direction-fx2-port-d-pins" Value="false" />
                        <Parameter Id="pd_gpio_7-data-fx2-port-d-pins" Value="false" />
                        <Parameter Id="fx2-port-e-pins" Value="0" />
                        <Parameter Id="pe_gpio_0-direction-fx2-port-e-pins" Value="false" />
                        <Parameter Id="pe_gpio_0-data-fx2-port-e-pins" Value="false" />
                        <Parameter Id="pe_gpio_1-direction-fx2-port-e-pins" Value="false" />
                        <Parameter Id="pe_gpio_1-data-fx2-port-e-pins" Value="false" />
                        <Parameter Id="pe_gpio_2-direction-fx2-port-e-pins" Value="false" />
                        <Parameter Id="pe_gpio_2-data-fx2-port-e-pins" Value="false" />
                        <Parameter Id="pe_gpio_3-direction-fx2-port-e-pins" Value="false" />
                        <Parameter Id="pe_gpio_3-data-fx2-port-e-pins" Value="false" />
                        <Parameter Id="pe_gpio_4-direction-fx2-port-e-pins" Value="false" />
                        <Parameter Id="pe_gpio_4-data-fx2-port-e-pins" Value="false" />
                        <Parameter Id="pe_gpio_5-direction-fx2-port-e-pins" Value="false" />
                        <Parameter Id="pe_gpio_5-data-fx2-port-e-pins" Value="false" />
                        <Parameter Id="pe_gpio_6-direction-fx2-port-e-pins" Value="false" />
                        <Parameter Id="pe_gpio_6-data-fx2-port-e-pins" Value="false" />
                        <Parameter Id="pe_gpio_7-direction-fx2-port-e-pins" Value="false" />
                        <Parameter Id="pe_gpio_7-data-fx2-port-e-pins" Value="false" />
                        <Chips>
                          <Chip Id="Chip.AD9542.AD9542" InstanceName="AD9542">
                            <Parameter Id="virtual-parameter-feature_1" Value="false" />
                            <Parameter Id="virtual-parameter-feature_2" Value="false" />
                            <Parameter Id="virtual-parameter-feature_3" Value="false" />
                            <Parameter Id="ad9542-pins" Value="1" />
                            <Parameter Id="resetb-direction-ad9542-pins" Value="false" />
                            <Parameter Id="resetb-data-ad9542-pins" Value="true" />
                            <Parameter Id="ad9542-m-pins" Value="0" />
                            <Parameter Id="mp0-direction-ad9542-m-pins" Value="true" />
                            <Parameter Id="mp0-data-ad9542-m-pins" Value="false" />
                            <Parameter Id="mp1-direction-ad9542-m-pins" Value="true" />
                            <Parameter Id="mp1-data-ad9542-m-pins" Value="false" />
                            <Parameter Id="mp2-direction-ad9542-m-pins" Value="true" />
                            <Parameter Id="mp2-data-ad9542-m-pins" Value="false" />
                            <Parameter Id="mp3-direction-ad9542-m-pins" Value="true" />
                            <Parameter Id="mp3-data-ad9542-m-pins" Value="false" />
                            <Parameter Id="mp4-direction-ad9542-m-pins" Value="true" />
                            <Parameter Id="mp4-data-ad9542-m-pins" Value="false" />
                            <Parameter Id="mp5-direction-ad9542-m-pins" Value="true" />
                            <Parameter Id="mp5-data-ad9542-m-pins" Value="false" />
                            <Parameter Id="virtual-parameter-hwAttached" Value="true" />
                            <Parameter Id="virtual-parameter-feature1_0_gui_visible" Value="false" />
                            <Parameter Id="virtual-parameter-feature1_1_gui_visible" Value="false" />
                            <Parameter Id="virtual-parameter-_TestVP" Value="0" />
                            <Parameter Id="virtual-parameter-ListSelect" Value="0" />
                            <Parameter Id="virtual-parameter-dpll0_err_src" Value="true" />
                            <Parameter Id="virtual-parameter-dpll1_err_src" Value="false" />
                            <Parameter Id="virtual-parameter-sysclk_expression" Value="52 MHz" />
                            <Parameter Id="virtual-parameter-SysClkFreq" Value="52 MHz" />
                            <Parameter Id="virtual-parameter-SysClkFreq_wiz" Value="52 MHz" />
                            <Parameter Id="virtual-parameter-sysclk_decimal" Value="52000000" />
                            <Parameter Id="virtual-parameter-sysclk_fin_num" Value="52000000" />
                            <Parameter Id="virtual-parameter-sysclk_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-wiz_sysclk_Fpfd" Value="104000000" />
                            <Parameter Id="virtual-parameter-wiz_sysclk_Fvco" Value="2392000000" />
                            <Parameter Id="virtual-parameter-REFA_Expression" Value="30.74 MHz" />
                            <Parameter Id="virtual-parameter-REFA" Value="30.74 MHz" />
                            <Parameter Id="virtual-parameter-REFA_wiz" Value="30.74 MHz" />
                            <Parameter Id="virtual-parameter-refa_decimal" Value="30740000" />
                            <Parameter Id="virtual-parameter-refA_fin_num" Value="30740000" />
                            <Parameter Id="virtual-parameter-refA_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-refA_fphase_exp" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-refA_fphase_evaled" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-refA_fphase_wiz" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-refA_fphase_value" Value="1" />
                            <Parameter Id="virtual-parameter-refA_fphase_num" Value="1" />
                            <Parameter Id="virtual-parameter-refA_fphase_den" Value="1" />
                            <Parameter Id="virtual-parameter-refa_en" Value="true" />
                            <Parameter Id="virtual-parameter-refa_se" Value="true" />
                            <Parameter Id="virtual-parameter-refa_se_pd" Value="false" />
                            <Parameter Id="virtual-parameter-refa_demod_gui_visible" Value="false" />
                            <Parameter Id="virtual-parameter-REFAA_Expression" Value="25 MHz" />
                            <Parameter Id="virtual-parameter-REFAA" Value="25 MHz" />
                            <Parameter Id="virtual-parameter-REFAA_wiz" Value="25 MHz" />
                            <Parameter Id="virtual-parameter-refaa_decimal" Value="25000000" />
                            <Parameter Id="virtual-parameter-refAA_fin_num" Value="25000000" />
                            <Parameter Id="virtual-parameter-refAA_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-refAA_fphase_exp" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-refAA_fphase_evaled" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-refAA_fphase_wiz" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-refAA_fphase_value" Value="1" />
                            <Parameter Id="virtual-parameter-refAA_fphase_num" Value="1" />
                            <Parameter Id="virtual-parameter-refAA_fphase_den" Value="1" />
                            <Parameter Id="virtual-parameter-refaa_en" Value="false" />
                            <Parameter Id="virtual-parameter-refaa_se" Value="1" />
                            <Parameter Id="virtual-parameter-refaa_se_pd" Value="true" />
                            <Parameter Id="virtual-parameter-refaa_demod_gui_visible" Value="false" />
                            <Parameter Id="virtual-parameter-refa_diff" Value="false" />
                            <Parameter Id="virtual-parameter-refa_diff_pd" Value="true" />
                            <Parameter Id="virtual-parameter-REFB_Expression" Value="25 MHz" />
                            <Parameter Id="virtual-parameter-REFB" Value="25 MHz" />
                            <Parameter Id="virtual-parameter-REFB_wiz" Value="25 MHz" />
                            <Parameter Id="virtual-parameter-refb_decimal" Value="25000000" />
                            <Parameter Id="virtual-parameter-refB_fin_num" Value="25000000" />
                            <Parameter Id="virtual-parameter-refB_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-refB_fphase_exp" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-refB_fphase_evaled" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-refB_fphase_wiz" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-refB_fphase_value" Value="1" />
                            <Parameter Id="virtual-parameter-refB_fphase_num" Value="1" />
                            <Parameter Id="virtual-parameter-refB_fphase_den" Value="1" />
                            <Parameter Id="virtual-parameter-refb_en" Value="false" />
                            <Parameter Id="virtual-parameter-refb_se" Value="true" />
                            <Parameter Id="virtual-parameter-refb_se_pd" Value="true" />
                            <Parameter Id="virtual-parameter-refb_demod_gui_visible" Value="false" />
                            <Parameter Id="virtual-parameter-REFBB_Expression" Value="25 MHz" />
                            <Parameter Id="virtual-parameter-REFBB" Value="25 MHz" />
                            <Parameter Id="virtual-parameter-REFBB_wiz" Value="25 MHz" />
                            <Parameter Id="virtual-parameter-refbb_decimal" Value="25000000" />
                            <Parameter Id="virtual-parameter-refBB_fin_num" Value="25000000" />
                            <Parameter Id="virtual-parameter-refBB_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-refBB_fphase_exp" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-refBB_fphase_evaled" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-refBB_fphase_wiz" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-refBB_fphase_value" Value="1" />
                            <Parameter Id="virtual-parameter-refBB_fphase_num" Value="1" />
                            <Parameter Id="virtual-parameter-refBB_fphase_den" Value="1" />
                            <Parameter Id="virtual-parameter-refbb_en" Value="false" />
                            <Parameter Id="virtual-parameter-refbb_se" Value="1" />
                            <Parameter Id="virtual-parameter-refbb_se_pd" Value="true" />
                            <Parameter Id="virtual-parameter-refbb_demod_gui_visible" Value="false" />
                            <Parameter Id="virtual-parameter-refb_diff" Value="false" />
                            <Parameter Id="virtual-parameter-refb_diff_pd" Value="true" />
                            <Parameter Id="virtual-parameter-dpll0p0_sel" Value="true" />
                            <Parameter Id="virtual-parameter-DPLL0p0 Reference Source" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL0p0 Feedback Source" Value="0" />
                            <Parameter Id="virtual-parameter-vpDPLL0p0OperatingMode" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL0p0 Feedback Divide Value" Value="1538.99805" />
                            <Parameter Id="virtual-parameter-dpll0p0_tag_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p0_tag_ignore_ref_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p0_tag_ignore_fb_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p0_tag_mode_wiz" Value="0" />
                            <Parameter Id="virtual-parameter-dpll0p0_slow_mode_resolve_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p0_slow_mode_resolve_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p0_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll0p0_loop_bw_converted" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-wiz_dpll0p0_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll0p0_loop_bw_decimal" Value="50" />
                            <Parameter Id="virtual-parameter-dpll0p0_fin_num" Value="50" />
                            <Parameter Id="virtual-parameter-dpll0p0_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-wiz_dpll0p0_title" Value=" " />
                            <Parameter Id="virtual-parameter-dpll0p1_sel" Value="false" />
                            <Parameter Id="virtual-parameter-DPLL0p1 Reference Source" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL0p1 Feedback Source" Value="0" />
                            <Parameter Id="virtual-parameter-vpDPLL0p1OperatingMode" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL0p1 Feedback Divide Value" Value="4001" />
                            <Parameter Id="virtual-parameter-dpll0p1_tag_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p1_tag_ignore_ref_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p1_tag_ignore_fb_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p1_tag_mode_wiz" Value="0" />
                            <Parameter Id="virtual-parameter-dpll0p1_slow_mode_resolve_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p1_slow_mode_resolve_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p1_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll0p1_loop_bw_converted" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-wiz_dpll0p1_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll0p1_loop_bw_decimal" Value="50" />
                            <Parameter Id="virtual-parameter-dpll0p1_fin_num" Value="50" />
                            <Parameter Id="virtual-parameter-dpll0p1_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-wiz_dpll0p1_title" Value=" " />
                            <Parameter Id="virtual-parameter-dpll0p2_sel" Value="false" />
                            <Parameter Id="virtual-parameter-DPLL0p2 Reference Source" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL0p2 Feedback Source" Value="0" />
                            <Parameter Id="virtual-parameter-vpDPLL0p2OperatingMode" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL0p2 Feedback Divide Value" Value="4001" />
                            <Parameter Id="virtual-parameter-dpll0p2_tag_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p2_tag_ignore_ref_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p2_tag_ignore_fb_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p2_tag_mode_wiz" Value="0" />
                            <Parameter Id="virtual-parameter-dpll0p2_slow_mode_resolve_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p2_slow_mode_resolve_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p2_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll0p2_loop_bw_converted" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-wiz_dpll0p2_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll0p2_loop_bw_decimal" Value="50" />
                            <Parameter Id="virtual-parameter-dpll0p2_fin_num" Value="50" />
                            <Parameter Id="virtual-parameter-dpll0p2_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-wiz_dpll0p2_title" Value=" " />
                            <Parameter Id="virtual-parameter-dpll0p3_sel" Value="false" />
                            <Parameter Id="virtual-parameter-DPLL0p3 Reference Source" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL0p3 Feedback Source" Value="0" />
                            <Parameter Id="virtual-parameter-vpDPLL0p3OperatingMode" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL0p3 Feedback Divide Value" Value="4001" />
                            <Parameter Id="virtual-parameter-dpll0p3_tag_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p3_tag_ignore_ref_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p3_tag_ignore_fb_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p3_tag_mode_wiz" Value="0" />
                            <Parameter Id="virtual-parameter-dpll0p3_slow_mode_resolve_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p3_slow_mode_resolve_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p3_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll0p3_loop_bw_converted" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-wiz_dpll0p3_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll0p3_loop_bw_decimal" Value="50" />
                            <Parameter Id="virtual-parameter-dpll0p3_fin_num" Value="50" />
                            <Parameter Id="virtual-parameter-dpll0p3_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-wiz_dpll0p3_title" Value=" " />
                            <Parameter Id="virtual-parameter-dpll0p4_sel" Value="false" />
                            <Parameter Id="virtual-parameter-DPLL0p4 Reference Source" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL0p4 Feedback Source" Value="0" />
                            <Parameter Id="virtual-parameter-vpDPLL0p4OperatingMode" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL0p4 Feedback Divide Value" Value="4001" />
                            <Parameter Id="virtual-parameter-dpll0p4_tag_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p4_tag_ignore_ref_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p4_tag_ignore_fb_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p4_tag_mode_wiz" Value="0" />
                            <Parameter Id="virtual-parameter-dpll0p4_slow_mode_resolve_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p4_slow_mode_resolve_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p4_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll0p4_loop_bw_converted" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-wiz_dpll0p4_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll0p4_loop_bw_decimal" Value="50" />
                            <Parameter Id="virtual-parameter-dpll0p4_fin_num" Value="50" />
                            <Parameter Id="virtual-parameter-dpll0p4_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-wiz_dpll0p4_title" Value=" " />
                            <Parameter Id="virtual-parameter-dpll0p5_sel" Value="false" />
                            <Parameter Id="virtual-parameter-DPLL0p5 Reference Source" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL0p5 Feedback Source" Value="0" />
                            <Parameter Id="virtual-parameter-vpDPLL0p5OperatingMode" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL0p5 Feedback Divide Value" Value="4001" />
                            <Parameter Id="virtual-parameter-dpll0p5_tag_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p5_tag_ignore_ref_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p5_tag_ignore_fb_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p5_tag_mode_wiz" Value="0" />
                            <Parameter Id="virtual-parameter-dpll0p5_slow_mode_resolve_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p5_slow_mode_resolve_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0p5_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll0p5_loop_bw_converted" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-wiz_dpll0p5_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll0p5_loop_bw_decimal" Value="50" />
                            <Parameter Id="virtual-parameter-dpll0p5_fin_num" Value="50" />
                            <Parameter Id="virtual-parameter-dpll0p5_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-wiz_dpll0p5_title" Value=" " />
                            <Parameter Id="virtual-parameter-DPLL0 Profile Selection" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL0 Manual Profile" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0_auto_profile_bar" Value="true" />
                            <Parameter Id="virtual-parameter-dpll0_profile_en" Value="true" />
                            <Parameter Id="virtual-parameter-dpll0_profile_active" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0_total_ndiv" Value="1538.99805" />
                            <Parameter Id="virtual-parameter-DPLL0 Feedback Source" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL0 Reference Source" Value="0" />
                            <Parameter Id="virtual-parameter-dpll0_src0_selected" Value="true" />
                            <Parameter Id="virtual-parameter-dpll0_src1_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0_src2_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0_src3_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0_src4_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0_src5_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0_src6_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0_src7_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0_src8_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0_src9_selected" Value="false" />
                            <Parameter Id="virtual-parameter-nco0_div" Value="7.78645833" />
                            <Parameter Id="virtual-parameter-dpll0_ext_zd" Value="0" />
                            <Parameter Id="virtual-parameter-dpll0_ext_zd_src" Value="0" />
                            <Parameter Id="virtual-parameter-dpll0_buildout_src" Value="0" />
                            <Parameter Id="virtual-parameter-dpll0_hitless" Value="0" />
                            <Parameter Id="virtual-parameter-dpll0_hitless_src" Value="0" />
                            <Parameter Id="virtual-parameter-dpll0_operating_mode" Value="0" />
                            <Parameter Id="virtual-parameter-dpll0_settings_button" Value="true" />
                            <Parameter Id="virtual-parameter-dpll0_profile_settings_button" Value="true" />
                            <Parameter Id="virtual-parameter-dpll0_tag_mode" Value="0" />
                            <Parameter Id="virtual-parameter-dpll0_fb_tagged" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0_ref_tagged" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0_fb_untagged" Value="true" />
                            <Parameter Id="virtual-parameter-dpll0_is_hitless" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0_is_buildout" Value="true" />
                            <Parameter Id="virtual-parameter-dpll0_is_internal" Value="false" />
                            <Parameter Id="virtual-parameter-dpll0_is_external" Value="false" />
                            <Parameter Id="virtual-parameter-out0a_expression" Value="122.88 MHz" />
                            <Parameter Id="virtual-parameter-out0A_gui" Value="122.88 MHz" />
                            <Parameter Id="virtual-parameter-OUT0A" Value="122.88 MHz" />
                            <Parameter Id="virtual-parameter-out0A_decimal" Value="122880000" />
                            <Parameter Id="virtual-parameter-out0A_num" Value="122880000" />
                            <Parameter Id="virtual-parameter-out0A_den" Value="1" />
                            <Parameter Id="virtual-parameter-out0A_en" Value="true" />
                            <Parameter Id="virtual-parameter-out0A_pd" Value="false" />
                            <Parameter Id="virtual-parameter-Output 0A Total Divide" Value="10" />
                            <Parameter Id="virtual-parameter-out0a_mod_gui_visible" Value="false" />
                            <Parameter Id="virtual-parameter-out0A_fphase_exp" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-out0A_fphase_evaled" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-out0A_fphase_wiz" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-out0A_fphase_value" Value="1" />
                            <Parameter Id="virtual-parameter-out0A_fphase_num" Value="1" />
                            <Parameter Id="virtual-parameter-out 0A_fphase_den" Value="1" />
                            <Parameter Id="virtual-parameter-out0b_expression" Value="122.88 MHz" />
                            <Parameter Id="virtual-parameter-out0B_gui" Value="122.88 MHz" />
                            <Parameter Id="virtual-parameter-OUT0B" Value="122.88 MHz" />
                            <Parameter Id="virtual-parameter-out0B_decimal" Value="122880000" />
                            <Parameter Id="virtual-parameter-out0B_num" Value="122880000" />
                            <Parameter Id="virtual-parameter-out0B_den" Value="1" />
                            <Parameter Id="virtual-parameter-out0B_en" Value="true" />
                            <Parameter Id="virtual-parameter-out0B_pd" Value="false" />
                            <Parameter Id="virtual-parameter-Output 0B Total Divide" Value="10" />
                            <Parameter Id="virtual-parameter-out0b_mod_gui_visible" Value="false" />
                            <Parameter Id="virtual-parameter-out0B_fphase_exp" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-out0B_fphase_evaled" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-out0B_fphase_wiz" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-out0B_fphase_value" Value="1" />
                            <Parameter Id="virtual-parameter-out0B_fphase_num" Value="1" />
                            <Parameter Id="virtual-parameter-out 0B_fphase_den" Value="1" />
                            <Parameter Id="virtual-parameter-out0c_expression" Value="122.88 MHz" />
                            <Parameter Id="virtual-parameter-out0C_gui" Value="122.88 MHz" />
                            <Parameter Id="virtual-parameter-OUT0C" Value="122.88 MHz" />
                            <Parameter Id="virtual-parameter-out0C_decimal" Value="122880000" />
                            <Parameter Id="virtual-parameter-out0C_num" Value="122880000" />
                            <Parameter Id="virtual-parameter-out0C_den" Value="1" />
                            <Parameter Id="virtual-parameter-out0C_en" Value="true" />
                            <Parameter Id="virtual-parameter-out0C_pd" Value="false" />
                            <Parameter Id="virtual-parameter-Output 0C Total Divide" Value="10" />
                            <Parameter Id="virtual-parameter-out0c_mod_gui_visible" Value="false" />
                            <Parameter Id="virtual-parameter-out0C_fphase_exp" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-out0C_fphase_evaled" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-out0C_fphase_wiz" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-out0C_fphase_value" Value="1" />
                            <Parameter Id="virtual-parameter-out0C_fphase_num" Value="1" />
                            <Parameter Id="virtual-parameter-out 0C_fphase_den" Value="1" />
                            <Parameter Id="virtual-parameter-dpll1p0_sel" Value="true" />
                            <Parameter Id="virtual-parameter-DPLL1p0 Reference Source" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL1p0 Feedback Source" Value="0" />
                            <Parameter Id="virtual-parameter-vpDPLL1p0OperatingMode" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL1p0 Feedback Divide Value" Value="1619.79545" />
                            <Parameter Id="virtual-parameter-dpll1p0_tag_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p0_tag_ignore_ref_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p0_tag_ignore_fb_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p0_tag_mode_wiz" Value="0" />
                            <Parameter Id="virtual-parameter-dpll1p0_slow_mode_resolve_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p0_slow_mode_resolve_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p0_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll1p0_loop_bw_converted" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-wiz_dpll1p0_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll1p0_loop_bw_decimal" Value="50" />
                            <Parameter Id="virtual-parameter-dpll1p0_fin_num" Value="50" />
                            <Parameter Id="virtual-parameter-dpll1p0_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-wiz_dpll1p0_title" Value=" " />
                            <Parameter Id="virtual-parameter-dpll1p1_sel" Value="false" />
                            <Parameter Id="virtual-parameter-DPLL1p1 Reference Source" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL1p1 Feedback Source" Value="0" />
                            <Parameter Id="virtual-parameter-vpDPLL1p1OperatingMode" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL1p1 Feedback Divide Value" Value="4001" />
                            <Parameter Id="virtual-parameter-dpll1p1_tag_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p1_tag_ignore_ref_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p1_tag_ignore_fb_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p1_tag_mode_wiz" Value="0" />
                            <Parameter Id="virtual-parameter-dpll1p1_slow_mode_resolve_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p1_slow_mode_resolve_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p1_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll1p1_loop_bw_converted" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-wiz_dpll1p1_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll1p1_loop_bw_decimal" Value="50" />
                            <Parameter Id="virtual-parameter-dpll1p1_fin_num" Value="50" />
                            <Parameter Id="virtual-parameter-dpll1p1_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-wiz_dpll1p1_title" Value=" " />
                            <Parameter Id="virtual-parameter-dpll1p2_sel" Value="false" />
                            <Parameter Id="virtual-parameter-DPLL1p2 Reference Source" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL1p2 Feedback Source" Value="0" />
                            <Parameter Id="virtual-parameter-vpDPLL1p2OperatingMode" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL1p2 Feedback Divide Value" Value="4001" />
                            <Parameter Id="virtual-parameter-dpll1p2_tag_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p2_tag_ignore_ref_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p2_tag_ignore_fb_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p2_tag_mode_wiz" Value="0" />
                            <Parameter Id="virtual-parameter-dpll1p2_slow_mode_resolve_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p2_slow_mode_resolve_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p2_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll1p2_loop_bw_converted" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-wiz_dpll1p2_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll1p2_loop_bw_decimal" Value="50" />
                            <Parameter Id="virtual-parameter-dpll1p2_fin_num" Value="50" />
                            <Parameter Id="virtual-parameter-dpll1p2_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-wiz_dpll1p2_title" Value=" " />
                            <Parameter Id="virtual-parameter-dpll1p3_sel" Value="false" />
                            <Parameter Id="virtual-parameter-DPLL1p3 Reference Source" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL1p3 Feedback Source" Value="0" />
                            <Parameter Id="virtual-parameter-vpDPLL1p3OperatingMode" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL1p3 Feedback Divide Value" Value="4001" />
                            <Parameter Id="virtual-parameter-dpll1p3_tag_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p3_tag_ignore_ref_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p3_tag_ignore_fb_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p3_tag_mode_wiz" Value="0" />
                            <Parameter Id="virtual-parameter-dpll1p3_slow_mode_resolve_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p3_slow_mode_resolve_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p3_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll1p3_loop_bw_converted" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-wiz_dpll1p3_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll1p3_loop_bw_decimal" Value="50" />
                            <Parameter Id="virtual-parameter-dpll1p3_fin_num" Value="50" />
                            <Parameter Id="virtual-parameter-dpll1p3_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-wiz_dpll1p3_title" Value=" " />
                            <Parameter Id="virtual-parameter-dpll1p4_sel" Value="false" />
                            <Parameter Id="virtual-parameter-DPLL1p4 Reference Source" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL1p4 Feedback Source" Value="0" />
                            <Parameter Id="virtual-parameter-vpDPLL1p4OperatingMode" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL1p4 Feedback Divide Value" Value="4001" />
                            <Parameter Id="virtual-parameter-dpll1p4_tag_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p4_tag_ignore_ref_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p4_tag_ignore_fb_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p4_tag_mode_wiz" Value="0" />
                            <Parameter Id="virtual-parameter-dpll1p4_slow_mode_resolve_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p4_slow_mode_resolve_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p4_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll1p4_loop_bw_converted" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-wiz_dpll1p4_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll1p4_loop_bw_decimal" Value="50" />
                            <Parameter Id="virtual-parameter-dpll1p4_fin_num" Value="50" />
                            <Parameter Id="virtual-parameter-dpll1p4_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-wiz_dpll1p4_title" Value=" " />
                            <Parameter Id="virtual-parameter-dpll1p5_sel" Value="false" />
                            <Parameter Id="virtual-parameter-DPLL1p5 Reference Source" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL1p5 Feedback Source" Value="0" />
                            <Parameter Id="virtual-parameter-vpDPLL1p5OperatingMode" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL1p5 Feedback Divide Value" Value="4001" />
                            <Parameter Id="virtual-parameter-dpll1p5_tag_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p5_tag_ignore_ref_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p5_tag_ignore_fb_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p5_tag_mode_wiz" Value="0" />
                            <Parameter Id="virtual-parameter-dpll1p5_slow_mode_resolve_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p5_slow_mode_resolve_vis_wiz" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1p5_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll1p5_loop_bw_converted" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-wiz_dpll1p5_loop_bw" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-dpll1p5_loop_bw_decimal" Value="50" />
                            <Parameter Id="virtual-parameter-dpll1p5_fin_num" Value="50" />
                            <Parameter Id="virtual-parameter-dpll1p5_fin_den" Value="1" />
                            <Parameter Id="virtual-parameter-wiz_dpll1p5_title" Value=" " />
                            <Parameter Id="virtual-parameter-DPLL1 Profile Selection" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL1 Manual Profile" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1_auto_profile_bar" Value="true" />
                            <Parameter Id="virtual-parameter-dpll1_profile_en" Value="true" />
                            <Parameter Id="virtual-parameter-dpll1_profile_active" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1_total_ndiv" Value="1619.79545" />
                            <Parameter Id="virtual-parameter-DPLL1 Feedback Source" Value="0" />
                            <Parameter Id="virtual-parameter-DPLL1 Reference Source" Value="0" />
                            <Parameter Id="virtual-parameter-dpll1_src0_selected" Value="true" />
                            <Parameter Id="virtual-parameter-dpll1_src1_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1_src2_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1_src3_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1_src4_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1_src5_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1_src6_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1_src7_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1_src8_selected" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1_src9_selected" Value="false" />
                            <Parameter Id="virtual-parameter-nco1_div" Value="7.39806017" />
                            <Parameter Id="virtual-parameter-dpll1_ext_zd" Value="0" />
                            <Parameter Id="virtual-parameter-dpll1_ext_zd_src" Value="0" />
                            <Parameter Id="virtual-parameter-dpll1_buildout_src" Value="0" />
                            <Parameter Id="virtual-parameter-dpll1_hitless" Value="0" />
                            <Parameter Id="virtual-parameter-dpll1_hitless_src" Value="0" />
                            <Parameter Id="virtual-parameter-dpll1_operating_mode" Value="0" />
                            <Parameter Id="virtual-parameter-dpll1_settings_button" Value="true" />
                            <Parameter Id="virtual-parameter-dpll1_profile_settings_button" Value="true" />
                            <Parameter Id="virtual-parameter-dpll1_tag_mode" Value="0" />
                            <Parameter Id="virtual-parameter-dpll1_fb_tagged" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1_ref_tagged" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1_fb_untagged" Value="true" />
                            <Parameter Id="virtual-parameter-dpll1_is_hitless" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1_is_buildout" Value="true" />
                            <Parameter Id="virtual-parameter-dpll1_is_internal" Value="false" />
                            <Parameter Id="virtual-parameter-dpll1_is_external" Value="false" />
                            <Parameter Id="virtual-parameter-out1a_expression" Value="3.84 MHz" />
                            <Parameter Id="virtual-parameter-out1A_gui" Value="3.84 MHz" />
                            <Parameter Id="virtual-parameter-OUT1A" Value="3.84 MHz" />
                            <Parameter Id="virtual-parameter-out1A_decimal" Value="3840000" />
                            <Parameter Id="virtual-parameter-out1A_num" Value="3840000" />
                            <Parameter Id="virtual-parameter-out1A_den" Value="1" />
                            <Parameter Id="virtual-parameter-out1A_en" Value="true" />
                            <Parameter Id="virtual-parameter-out1A_pd" Value="false" />
                            <Parameter Id="virtual-parameter-Output 1A Total Divide" Value="421" />
                            <Parameter Id="virtual-parameter-out1a_mod_gui_visible" Value="false" />
                            <Parameter Id="virtual-parameter-out1A_fphase_exp" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-out1A_fphase_evaled" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-out1A_fphase_wiz" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-out1A_fphase_value" Value="1" />
                            <Parameter Id="virtual-parameter-out1A_fphase_num" Value="1" />
                            <Parameter Id="virtual-parameter-out 1A_fphase_den" Value="1" />
                            <Parameter Id="virtual-parameter-out1b_expression" Value="3.84 MHz" />
                            <Parameter Id="virtual-parameter-out1B_gui" Value="3.84 MHz" />
                            <Parameter Id="virtual-parameter-OUT1B" Value="3.84 MHz" />
                            <Parameter Id="virtual-parameter-out1B_decimal" Value="3840000" />
                            <Parameter Id="virtual-parameter-out1B_num" Value="3840000" />
                            <Parameter Id="virtual-parameter-out1B_den" Value="1" />
                            <Parameter Id="virtual-parameter-out1B_en" Value="true" />
                            <Parameter Id="virtual-parameter-out1B_pd" Value="false" />
                            <Parameter Id="virtual-parameter-Output 1B Total Divide" Value="421" />
                            <Parameter Id="virtual-parameter-out1b_mod_gui_visible" Value="false" />
                            <Parameter Id="virtual-parameter-out1B_fphase_exp" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-out1B_fphase_evaled" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-out1B_fphase_wiz" Value="1 Hz" />
                            <Parameter Id="virtual-parameter-out1B_fphase_value" Value="1" />
                            <Parameter Id="virtual-parameter-out1B_fphase_num" Value="1" />
                            <Parameter Id="virtual-parameter-out 1B_fphase_den" Value="1" />
                            <Parameter Id="virtual-parameter-M0_out_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M0_in_enabled" Value="true" />
                            <Parameter Id="virtual-parameter-M0_auxtdc0_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M0_auxtdc1_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M0_auxtdc_ping_pong_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M1_out_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M1_in_enabled" Value="true" />
                            <Parameter Id="virtual-parameter-M1_auxtdc0_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M1_auxtdc1_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M1_auxtdc_ping_pong_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M2_out_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M2_in_enabled" Value="true" />
                            <Parameter Id="virtual-parameter-M2_auxtdc0_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M2_auxtdc1_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M2_auxtdc_ping_pong_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M3_out_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M3_in_enabled" Value="true" />
                            <Parameter Id="virtual-parameter-M3_auxtdc0_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M3_auxtdc1_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M3_auxtdc_ping_pong_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M4_out_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M4_in_enabled" Value="true" />
                            <Parameter Id="virtual-parameter-M4_auxtdc0_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M4_auxtdc1_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M4_auxtdc_ping_pong_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M5_out_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M5_in_enabled" Value="true" />
                            <Parameter Id="virtual-parameter-M5_auxtdc0_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M5_auxtdc1_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M5_auxtdc_ping_pong_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M6_out_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M6_in_enabled" Value="true" />
                            <Parameter Id="virtual-parameter-M6_auxtdc0_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M6_auxtdc1_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-M6_auxtdc_ping_pong_enabled" Value="false" />
                            <Parameter Id="virtual-parameter-internal_temperature" Value="0" />
                            <Parameter Id="virtual-parameter-external_temperature" Value="0" />
                            <Parameter Id="virtual-parameter-aux_dpll_enable" Value="false" />
                            <Parameter Id="virtual-parameter-aux_dpll_bandwidth_input" Value="0 Hz" />
                            <Parameter Id="virtual-parameter-aux_dpll_bandwidth_converted" Value="0 Hz" />
                            <Parameter Id="virtual-parameter-aux_dpll_bandwidth_wiz" Value="50 Hz" />
                            <Parameter Id="virtual-parameter-aux_dpll_bandwidth_decimal" Value="0" />
                            <Parameter Id="virtual-parameter-aux_dpll_bandwidth_num" Value="0" />
                            <Parameter Id="virtual-parameter-aux_dpll_bandwidth_den" Value="1" />
                            <Parameter Id="virtual-parameter-wiz_nco0_enabled" Value="true" />
                            <Parameter Id="virtual-parameter-wiz_nco0_Fin" Value="2392000000" />
                            <Parameter Id="virtual-parameter-wiz_nco0_Fout" Value="307200000" />
                            <Parameter Id="virtual-parameter-wiz_nco1_enabled" Value="true" />
                            <Parameter Id="virtual-parameter-wiz_nco1_Fin" Value="2392000000" />
                            <Parameter Id="virtual-parameter-wiz_nco1_Fout" Value="323328000" />
                            <Parameter Id="virtual-parameter-wiz_dpll0_enable" Value="true" />
                            <Parameter Id="virtual-parameter-wiz_dpll0_fout" Value="307.2" />
                            <Parameter Id="virtual-parameter-wiz_dpll1_enable" Value="true" />
                            <Parameter Id="virtual-parameter-wiz_dpll1_fout" Value="323.328" />
                            <Parameter Id="virtual-parameter-ExtWizParamsVisible" Value="false" />
                            <Parameter Id="virtual-parameter-dist0_settings_button" Value="true" />
                            <Parameter Id="virtual-parameter-dist1_settings_button" Value="true" />
                            <Parameter Id="virtual-parameter-mpins_button" Value="true" />
                            <Parameter Id="virtual-parameter-temp_sensor_button" Value="true" />
                            <Parameter Id="virtual-parameter-aux_tdcs_button" Value="true" />
                            <Parameter Id="virtual-parameter-user_ts_button" Value="true" />
                            <Parameter Id="virtual-parameter-idTest" Value="1" />
                            <Parameter Id="virtual-parameter-Hidden" Value="false" />
                            <Parameter Id="virtual-parameter-sessionVersion" Value="1.1.8.0" />
                            <RegisterMap UniqueId="0.serial_port" Address="0" Count="10">
                              <Register Address="0" Value="24" />
                              <Register Address="1" Value="0" />
                              <Register Address="3" Value="5" />
                              <Register Address="4" Value="20" />
                              <Register Address="5" Value="1" />
                              <Register Address="6" Value="2" />
                              <Register Address="B" Value="0" />
                              <Register Address="C" Value="56" />
                              <Register Address="D" Value="4" />
                              <Register Address="F" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="10.serial_port_extensions" Address="10" Count="1">
                              <Register Address="10" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="20.scratchpad" Address="20" Count="4">
                              <Register Address="20" Value="0" />
                              <Register Address="21" Value="0" />
                              <Register Address="22" Value="0" />
                              <Register Address="23" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="100.mpin_status_control" Address="100" Count="12">
                              <Register Address="100" Value="0" />
                              <Register Address="101" Value="0" />
                              <Register Address="102" Value="0" />
                              <Register Address="103" Value="0" />
                              <Register Address="104" Value="0" />
                              <Register Address="105" Value="0" />
                              <Register Address="106" Value="0" />
                              <Register Address="107" Value="0" />
                              <Register Address="108" Value="0" />
                              <Register Address="109" Value="0" />
                              <Register Address="10A" Value="0" />
                              <Register Address="10B" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="10C.irq_common_mask" Address="10C" Count="5">
                              <Register Address="10C" Value="0" />
                              <Register Address="10D" Value="0" />
                              <Register Address="10E" Value="0" />
                              <Register Address="10F" Value="0" />
                              <Register Address="110" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="111.irq_pll_0_mask" Address="111" Count="5">
                              <Register Address="111" Value="0" />
                              <Register Address="112" Value="0" />
                              <Register Address="113" Value="0" />
                              <Register Address="114" Value="0" />
                              <Register Address="115" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="116.irq_pll_1_mask" Address="116" Count="5">
                              <Register Address="116" Value="0" />
                              <Register Address="117" Value="0" />
                              <Register Address="118" Value="0" />
                              <Register Address="119" Value="0" />
                              <Register Address="11A" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="200.system_clock" Address="200" Count="10">
                              <Register Address="200" Value="17" />
                              <Register Address="201" Value="09" />
                              <Register Address="202" Value="0" />
                              <Register Address="203" Value="08" />
                              <Register Address="204" Value="71" />
                              <Register Address="205" Value="1B" />
                              <Register Address="206" Value="0C" />
                              <Register Address="207" Value="32" />
                              <Register Address="208" Value="0" />
                              <Register Address="209" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="280.system_clock_comp" Address="280" Count="29">
                              <Register Address="280" Value="0" />
                              <Register Address="281" Value="0" />
                              <Register Address="282" Value="0" />
                              <Register Address="283" Value="0" />
                              <Register Address="284" Value="0" />
                              <Register Address="285" Value="0" />
                              <Register Address="286" Value="0" />
                              <Register Address="287" Value="0" />
                              <Register Address="288" Value="0" />
                              <Register Address="289" Value="0" />
                              <Register Address="28A" Value="0" />
                              <Register Address="28B" Value="0" />
                              <Register Address="28C" Value="0" />
                              <Register Address="28D" Value="0" />
                              <Register Address="28E" Value="0" />
                              <Register Address="28F" Value="0" />
                              <Register Address="290" Value="0" />
                              <Register Address="291" Value="0" />
                              <Register Address="292" Value="0" />
                              <Register Address="293" Value="0" />
                              <Register Address="294" Value="0" />
                              <Register Address="295" Value="0" />
                              <Register Address="296" Value="0" />
                              <Register Address="297" Value="0" />
                              <Register Address="298" Value="0" />
                              <Register Address="299" Value="0" />
                              <Register Address="29A" Value="0" />
                              <Register Address="29B" Value="0" />
                              <Register Address="29C" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="300.reference_general_a" Address="300" Count="1">
                              <Register Address="300" Value="10" />
                            </RegisterMap>
                            <RegisterMap UniqueId="304.reference_general_b" Address="304" Count="4">
                              <Register Address="304" Value="0" />
                              <Register Address="305" Value="0" />
                              <Register Address="306" Value="0" />
                              <Register Address="307" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="400.reference_input_a" Address="400" Count="21">
                              <Register Address="400" Value="099" />
                              <Register Address="401" Value="0" />
                              <Register Address="402" Value="0" />
                              <Register Address="403" Value="0" />
                              <Register Address="404" Value="27" />
                              <Register Address="405" Value="35" />
                              <Register Address="406" Value="0FE" />
                              <Register Address="407" Value="092" />
                              <Register Address="408" Value="7" />
                              <Register Address="409" Value="0" />
                              <Register Address="40A" Value="0" />
                              <Register Address="40B" Value="0" />
                              <Register Address="40C" Value="0A0" />
                              <Register Address="40D" Value="086" />
                              <Register Address="40E" Value="1" />
                              <Register Address="40F" Value="3" />
                              <Register Address="410" Value="0A" />
                              <Register Address="411" Value="0" />
                              <Register Address="412" Value="0" />
                              <Register Address="413" Value="0" />
                              <Register Address="414" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="420.reference_input_aa" Address="420" Count="21">
                              <Register Address="420" Value="7C" />
                              <Register Address="421" Value="0" />
                              <Register Address="422" Value="0" />
                              <Register Address="423" Value="0" />
                              <Register Address="424" Value="0" />
                              <Register Address="425" Value="090" />
                              <Register Address="426" Value="2F" />
                              <Register Address="427" Value="50" />
                              <Register Address="428" Value="09" />
                              <Register Address="429" Value="0" />
                              <Register Address="42A" Value="0" />
                              <Register Address="42B" Value="0" />
                              <Register Address="42C" Value="0A0" />
                              <Register Address="42D" Value="086" />
                              <Register Address="42E" Value="1" />
                              <Register Address="42F" Value="3" />
                              <Register Address="430" Value="0A" />
                              <Register Address="431" Value="0" />
                              <Register Address="432" Value="0" />
                              <Register Address="433" Value="0" />
                              <Register Address="434" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="440.reference_input_b" Address="440" Count="21">
                              <Register Address="440" Value="7C" />
                              <Register Address="441" Value="0" />
                              <Register Address="442" Value="0" />
                              <Register Address="443" Value="0" />
                              <Register Address="444" Value="0" />
                              <Register Address="445" Value="090" />
                              <Register Address="446" Value="2F" />
                              <Register Address="447" Value="50" />
                              <Register Address="448" Value="09" />
                              <Register Address="449" Value="0" />
                              <Register Address="44A" Value="0" />
                              <Register Address="44B" Value="0" />
                              <Register Address="44C" Value="0A0" />
                              <Register Address="44D" Value="086" />
                              <Register Address="44E" Value="1" />
                              <Register Address="44F" Value="3" />
                              <Register Address="450" Value="0A" />
                              <Register Address="451" Value="0" />
                              <Register Address="452" Value="0" />
                              <Register Address="453" Value="0" />
                              <Register Address="454" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="460.reference_input_bb" Address="460" Count="21">
                              <Register Address="460" Value="7C" />
                              <Register Address="461" Value="0" />
                              <Register Address="462" Value="0" />
                              <Register Address="463" Value="0" />
                              <Register Address="464" Value="0" />
                              <Register Address="465" Value="090" />
                              <Register Address="466" Value="2F" />
                              <Register Address="467" Value="50" />
                              <Register Address="468" Value="09" />
                              <Register Address="469" Value="0" />
                              <Register Address="46A" Value="0" />
                              <Register Address="46B" Value="0" />
                              <Register Address="46C" Value="0A0" />
                              <Register Address="46D" Value="086" />
                              <Register Address="46E" Value="1" />
                              <Register Address="46F" Value="3" />
                              <Register Address="470" Value="0A" />
                              <Register Address="471" Value="0" />
                              <Register Address="472" Value="0" />
                              <Register Address="473" Value="0" />
                              <Register Address="474" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="800.source_profile_0_a" Address="800" Count="18">
                              <Register Address="800" Value="0E8" />
                              <Register Address="801" Value="3" />
                              <Register Address="802" Value="0" />
                              <Register Address="803" Value="0A" />
                              <Register Address="804" Value="0A" />
                              <Register Address="805" Value="0E8" />
                              <Register Address="806" Value="3" />
                              <Register Address="807" Value="0" />
                              <Register Address="808" Value="0A" />
                              <Register Address="809" Value="0A" />
                              <Register Address="80A" Value="0" />
                              <Register Address="80B" Value="0" />
                              <Register Address="80C" Value="0" />
                              <Register Address="80D" Value="0" />
                              <Register Address="80E" Value="0" />
                              <Register Address="80F" Value="0" />
                              <Register Address="810" Value="0" />
                              <Register Address="811" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="820.source_profile_1_aa" Address="820" Count="18">
                              <Register Address="820" Value="0BC" />
                              <Register Address="821" Value="2" />
                              <Register Address="822" Value="0" />
                              <Register Address="823" Value="0A" />
                              <Register Address="824" Value="0A" />
                              <Register Address="825" Value="0BC" />
                              <Register Address="826" Value="2" />
                              <Register Address="827" Value="0" />
                              <Register Address="828" Value="0A" />
                              <Register Address="829" Value="0A" />
                              <Register Address="82A" Value="0" />
                              <Register Address="82B" Value="0" />
                              <Register Address="82C" Value="0" />
                              <Register Address="82D" Value="0" />
                              <Register Address="82E" Value="0" />
                              <Register Address="82F" Value="0" />
                              <Register Address="830" Value="0" />
                              <Register Address="831" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="840.source_profile_2_b" Address="840" Count="18">
                              <Register Address="840" Value="0BC" />
                              <Register Address="841" Value="2" />
                              <Register Address="842" Value="0" />
                              <Register Address="843" Value="0A" />
                              <Register Address="844" Value="0A" />
                              <Register Address="845" Value="0BC" />
                              <Register Address="846" Value="2" />
                              <Register Address="847" Value="0" />
                              <Register Address="848" Value="0A" />
                              <Register Address="849" Value="0A" />
                              <Register Address="84A" Value="0" />
                              <Register Address="84B" Value="0" />
                              <Register Address="84C" Value="0" />
                              <Register Address="84D" Value="0" />
                              <Register Address="84E" Value="0" />
                              <Register Address="84F" Value="0" />
                              <Register Address="850" Value="0" />
                              <Register Address="851" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="860.source_profile_3_bb" Address="860" Count="18">
                              <Register Address="860" Value="0BC" />
                              <Register Address="861" Value="2" />
                              <Register Address="862" Value="0" />
                              <Register Address="863" Value="0A" />
                              <Register Address="864" Value="0A" />
                              <Register Address="865" Value="0BC" />
                              <Register Address="866" Value="2" />
                              <Register Address="867" Value="0" />
                              <Register Address="868" Value="0A" />
                              <Register Address="869" Value="0A" />
                              <Register Address="86A" Value="0" />
                              <Register Address="86B" Value="0" />
                              <Register Address="86C" Value="0" />
                              <Register Address="86D" Value="0" />
                              <Register Address="86E" Value="0" />
                              <Register Address="86F" Value="0" />
                              <Register Address="870" Value="0" />
                              <Register Address="871" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="880.source_profile_4_auxnco_0" Address="880" Count="18">
                              <Register Address="880" Value="0BC" />
                              <Register Address="881" Value="2" />
                              <Register Address="882" Value="0" />
                              <Register Address="883" Value="0A" />
                              <Register Address="884" Value="0A" />
                              <Register Address="885" Value="0BC" />
                              <Register Address="886" Value="2" />
                              <Register Address="887" Value="0" />
                              <Register Address="888" Value="0A" />
                              <Register Address="889" Value="0A" />
                              <Register Address="88A" Value="0" />
                              <Register Address="88B" Value="0" />
                              <Register Address="88C" Value="0" />
                              <Register Address="88D" Value="0" />
                              <Register Address="88E" Value="0" />
                              <Register Address="88F" Value="0" />
                              <Register Address="890" Value="0" />
                              <Register Address="891" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="8A0.source_profile_5_auxnco_1" Address="8A0" Count="18">
                              <Register Address="8A0" Value="0BC" />
                              <Register Address="8A1" Value="2" />
                              <Register Address="8A2" Value="0" />
                              <Register Address="8A3" Value="0A" />
                              <Register Address="8A4" Value="0A" />
                              <Register Address="8A5" Value="0BC" />
                              <Register Address="8A6" Value="2" />
                              <Register Address="8A7" Value="0" />
                              <Register Address="8A8" Value="0A" />
                              <Register Address="8A9" Value="0A" />
                              <Register Address="8AA" Value="0" />
                              <Register Address="8AB" Value="0" />
                              <Register Address="8AC" Value="0" />
                              <Register Address="8AD" Value="0" />
                              <Register Address="8AE" Value="0" />
                              <Register Address="8AF" Value="0" />
                              <Register Address="8B0" Value="0" />
                              <Register Address="8B1" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="8C0.source_profile_6_dpll_0" Address="8C0" Count="18">
                              <Register Address="8C0" Value="0BC" />
                              <Register Address="8C1" Value="2" />
                              <Register Address="8C2" Value="0" />
                              <Register Address="8C3" Value="0A" />
                              <Register Address="8C4" Value="0A" />
                              <Register Address="8C5" Value="0BC" />
                              <Register Address="8C6" Value="2" />
                              <Register Address="8C7" Value="0" />
                              <Register Address="8C8" Value="0A" />
                              <Register Address="8C9" Value="0A" />
                              <Register Address="8CA" Value="0" />
                              <Register Address="8CB" Value="0" />
                              <Register Address="8CC" Value="0" />
                              <Register Address="8CD" Value="0" />
                              <Register Address="8CE" Value="0" />
                              <Register Address="8CF" Value="0" />
                              <Register Address="8D0" Value="0" />
                              <Register Address="8D1" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="8E0.source_profile_7_dpll_1" Address="8E0" Count="18">
                              <Register Address="8E0" Value="0BC" />
                              <Register Address="8E1" Value="2" />
                              <Register Address="8E2" Value="0" />
                              <Register Address="8E3" Value="0A" />
                              <Register Address="8E4" Value="0A" />
                              <Register Address="8E5" Value="0BC" />
                              <Register Address="8E6" Value="2" />
                              <Register Address="8E7" Value="0" />
                              <Register Address="8E8" Value="0A" />
                              <Register Address="8E9" Value="0A" />
                              <Register Address="8EA" Value="0" />
                              <Register Address="8EB" Value="0" />
                              <Register Address="8EC" Value="0" />
                              <Register Address="8ED" Value="0" />
                              <Register Address="8EE" Value="0" />
                              <Register Address="8EF" Value="0" />
                              <Register Address="8F0" Value="0" />
                              <Register Address="8F1" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="C00.lf_coefficients_0" Address="C00" Count="12">
                              <Register Address="C00" Value="0C2" />
                              <Register Address="C01" Value="0F0" />
                              <Register Address="C02" Value="0B3" />
                              <Register Address="C03" Value="55" />
                              <Register Address="C04" Value="0C9" />
                              <Register Address="C05" Value="0FB" />
                              <Register Address="C06" Value="5C" />
                              <Register Address="C07" Value="0F6" />
                              <Register Address="C08" Value="0CA" />
                              <Register Address="C09" Value="11" />
                              <Register Address="C0A" Value="0DF" />
                              <Register Address="C0B" Value="0CC" />
                            </RegisterMap>
                            <RegisterMap UniqueId="C0C.lf_coefficients_1" Address="C0C" Count="12">
                              <Register Address="C0C" Value="0A9" />
                              <Register Address="C0D" Value="0A0" />
                              <Register Address="C0E" Value="0B7" />
                              <Register Address="C0F" Value="0CD" />
                              <Register Address="C10" Value="0DB" />
                              <Register Address="C11" Value="0F3" />
                              <Register Address="C12" Value="79" />
                              <Register Address="C13" Value="0D4" />
                              <Register Address="C14" Value="0CE" />
                              <Register Address="C15" Value="4D" />
                              <Register Address="C16" Value="0A7" />
                              <Register Address="C17" Value="0CF" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1000.dpll_0" Address="1000" Count="43">
                              <Register Address="1000" Value="51" />
                              <Register Address="1001" Value="18" />
                              <Register Address="1002" Value="0DE" />
                              <Register Address="1003" Value="0A9" />
                              <Register Address="1004" Value="0E0" />
                              <Register Address="1005" Value="20" />
                              <Register Address="1006" Value="0FF" />
                              <Register Address="1007" Value="0FF" />
                              <Register Address="1008" Value="0FF" />
                              <Register Address="1009" Value="0" />
                              <Register Address="100A" Value="0A" />
                              <Register Address="100B" Value="0" />
                              <Register Address="100C" Value="0" />
                              <Register Address="100D" Value="0" />
                              <Register Address="100E" Value="38" />
                              <Register Address="100F" Value="0" />
                              <Register Address="1010" Value="0" />
                              <Register Address="1011" Value="0" />
                              <Register Address="1012" Value="0" />
                              <Register Address="1013" Value="0" />
                              <Register Address="1014" Value="6" />
                              <Register Address="1015" Value="0" />
                              <Register Address="1016" Value="0" />
                              <Register Address="1017" Value="0" />
                              <Register Address="1018" Value="0" />
                              <Register Address="1019" Value="0" />
                              <Register Address="101A" Value="0" />
                              <Register Address="101B" Value="0" />
                              <Register Address="101C" Value="0" />
                              <Register Address="101D" Value="0" />
                              <Register Address="101E" Value="0" />
                              <Register Address="101F" Value="0" />
                              <Register Address="1020" Value="0" />
                              <Register Address="1021" Value="0" />
                              <Register Address="1022" Value="0" />
                              <Register Address="1023" Value="0" />
                              <Register Address="1024" Value="0" />
                              <Register Address="1025" Value="0" />
                              <Register Address="1026" Value="0" />
                              <Register Address="1027" Value="0" />
                              <Register Address="1028" Value="0" />
                              <Register Address="102A" Value="0" />
                              <Register Address="102B" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1080.apll_0" Address="1080" Count="4">
                              <Register Address="1080" Value="094" />
                              <Register Address="1081" Value="08" />
                              <Register Address="1082" Value="0E0" />
                              <Register Address="1083" Value="3" />
                            </RegisterMap>
                            <RegisterMap UniqueId="10C0.dist_0_general_0" Address="10C0" Count="12">
                              <Register Address="10CE" Value="0" />
                              <Register Address="10D2" Value="0" />
                              <Register Address="10D3" Value="0" />
                              <Register Address="10D4" Value="0" />
                              <Register Address="10D5" Value="0" />
                              <Register Address="10D6" Value="0" />
                              <Register Address="10D7" Value="5" />
                              <Register Address="10D8" Value="5" />
                              <Register Address="10D9" Value="5" />
                              <Register Address="10DA" Value="0" />
                              <Register Address="10DB" Value="1" />
                              <Register Address="10DC" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1100.distribution_divider_0_a" Address="1100" Count="9">
                              <Register Address="1100" Value="0A" />
                              <Register Address="1101" Value="0" />
                              <Register Address="1102" Value="0" />
                              <Register Address="1103" Value="0" />
                              <Register Address="1104" Value="0" />
                              <Register Address="1105" Value="0" />
                              <Register Address="1106" Value="0" />
                              <Register Address="1107" Value="0" />
                              <Register Address="1108" Value="7" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1109.distribution_divider_0_aa" Address="1109" Count="9">
                              <Register Address="1109" Value="0" />
                              <Register Address="110A" Value="0" />
                              <Register Address="110B" Value="0" />
                              <Register Address="110C" Value="0" />
                              <Register Address="110D" Value="0" />
                              <Register Address="110E" Value="0" />
                              <Register Address="110F" Value="0" />
                              <Register Address="1110" Value="0" />
                              <Register Address="1111" Value="7" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1112.distribution_divider_0_b" Address="1112" Count="9">
                              <Register Address="1112" Value="0A" />
                              <Register Address="1113" Value="0" />
                              <Register Address="1114" Value="0" />
                              <Register Address="1115" Value="0" />
                              <Register Address="1116" Value="0" />
                              <Register Address="1117" Value="0" />
                              <Register Address="1118" Value="0" />
                              <Register Address="1119" Value="0" />
                              <Register Address="111A" Value="7" />
                            </RegisterMap>
                            <RegisterMap UniqueId="111B.distribution_divider_0_bb" Address="111B" Count="9">
                              <Register Address="111B" Value="0" />
                              <Register Address="111C" Value="0" />
                              <Register Address="111D" Value="0" />
                              <Register Address="111E" Value="0" />
                              <Register Address="111F" Value="0" />
                              <Register Address="1120" Value="0" />
                              <Register Address="1121" Value="0" />
                              <Register Address="1122" Value="0" />
                              <Register Address="1123" Value="7" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1124.distribution_divider_0_c" Address="1124" Count="9">
                              <Register Address="1124" Value="0A" />
                              <Register Address="1125" Value="0" />
                              <Register Address="1126" Value="0" />
                              <Register Address="1127" Value="0" />
                              <Register Address="1128" Value="0" />
                              <Register Address="1129" Value="0" />
                              <Register Address="112A" Value="0" />
                              <Register Address="112B" Value="0" />
                              <Register Address="112C" Value="7" />
                            </RegisterMap>
                            <RegisterMap UniqueId="112D.distribution_divider_0_cc" Address="112D" Count="9">
                              <Register Address="112D" Value="0" />
                              <Register Address="112E" Value="0" />
                              <Register Address="112F" Value="0" />
                              <Register Address="1130" Value="0" />
                              <Register Address="1131" Value="0" />
                              <Register Address="1132" Value="0" />
                              <Register Address="1133" Value="0" />
                              <Register Address="1134" Value="0" />
                              <Register Address="1135" Value="7" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1200.translation_profile_0_0" Address="1200" Count="24">
                              <Register Address="1200" Value="1" />
                              <Register Address="1201" Value="0" />
                              <Register Address="1202" Value="0" />
                              <Register Address="1203" Value="0" />
                              <Register Address="1204" Value="080" />
                              <Register Address="1205" Value="0F0" />
                              <Register Address="1206" Value="0FA" />
                              <Register Address="1207" Value="2" />
                              <Register Address="1208" Value="0A0" />
                              <Register Address="1209" Value="0F" />
                              <Register Address="120A" Value="0" />
                              <Register Address="120B" Value="0" />
                              <Register Address="120C" Value="1" />
                              <Register Address="120D" Value="6" />
                              <Register Address="120E" Value="0" />
                              <Register Address="120F" Value="0" />
                              <Register Address="1210" Value="0FE" />
                              <Register Address="1211" Value="5" />
                              <Register Address="1212" Value="0" />
                              <Register Address="1213" Value="1" />
                              <Register Address="1214" Value="6" />
                              <Register Address="1215" Value="0" />
                              <Register Address="1216" Value="0" />
                              <Register Address="1217" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1220.translation_profile_0_1" Address="1220" Count="24">
                              <Register Address="1220" Value="0" />
                              <Register Address="1221" Value="0" />
                              <Register Address="1222" Value="0" />
                              <Register Address="1223" Value="0" />
                              <Register Address="1224" Value="080" />
                              <Register Address="1225" Value="0F0" />
                              <Register Address="1226" Value="0FA" />
                              <Register Address="1227" Value="2" />
                              <Register Address="1228" Value="0A0" />
                              <Register Address="1229" Value="0F" />
                              <Register Address="122A" Value="0" />
                              <Register Address="122B" Value="0" />
                              <Register Address="122C" Value="0A0" />
                              <Register Address="122D" Value="0F" />
                              <Register Address="122E" Value="0" />
                              <Register Address="122F" Value="0" />
                              <Register Address="1230" Value="0" />
                              <Register Address="1231" Value="0" />
                              <Register Address="1232" Value="0" />
                              <Register Address="1233" Value="0" />
                              <Register Address="1234" Value="0" />
                              <Register Address="1235" Value="0" />
                              <Register Address="1236" Value="0" />
                              <Register Address="1237" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1240.translation_profile_0_2" Address="1240" Count="24">
                              <Register Address="1240" Value="0" />
                              <Register Address="1241" Value="0" />
                              <Register Address="1242" Value="0" />
                              <Register Address="1243" Value="0" />
                              <Register Address="1244" Value="080" />
                              <Register Address="1245" Value="0F0" />
                              <Register Address="1246" Value="0FA" />
                              <Register Address="1247" Value="2" />
                              <Register Address="1248" Value="0A0" />
                              <Register Address="1249" Value="0F" />
                              <Register Address="124A" Value="0" />
                              <Register Address="124B" Value="0" />
                              <Register Address="124C" Value="0A0" />
                              <Register Address="124D" Value="0F" />
                              <Register Address="124E" Value="0" />
                              <Register Address="124F" Value="0" />
                              <Register Address="1250" Value="0" />
                              <Register Address="1251" Value="0" />
                              <Register Address="1252" Value="0" />
                              <Register Address="1253" Value="0" />
                              <Register Address="1254" Value="0" />
                              <Register Address="1255" Value="0" />
                              <Register Address="1256" Value="0" />
                              <Register Address="1257" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1260.translation_profile_0_3" Address="1260" Count="24">
                              <Register Address="1260" Value="0" />
                              <Register Address="1261" Value="0" />
                              <Register Address="1262" Value="0" />
                              <Register Address="1263" Value="0" />
                              <Register Address="1264" Value="080" />
                              <Register Address="1265" Value="0F0" />
                              <Register Address="1266" Value="0FA" />
                              <Register Address="1267" Value="2" />
                              <Register Address="1268" Value="0A0" />
                              <Register Address="1269" Value="0F" />
                              <Register Address="126A" Value="0" />
                              <Register Address="126B" Value="0" />
                              <Register Address="126C" Value="0A0" />
                              <Register Address="126D" Value="0F" />
                              <Register Address="126E" Value="0" />
                              <Register Address="126F" Value="0" />
                              <Register Address="1270" Value="0" />
                              <Register Address="1271" Value="0" />
                              <Register Address="1272" Value="0" />
                              <Register Address="1273" Value="0" />
                              <Register Address="1274" Value="0" />
                              <Register Address="1275" Value="0" />
                              <Register Address="1276" Value="0" />
                              <Register Address="1277" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1280.translation_profile_0_4" Address="1280" Count="24">
                              <Register Address="1280" Value="0" />
                              <Register Address="1281" Value="0" />
                              <Register Address="1282" Value="0" />
                              <Register Address="1283" Value="0" />
                              <Register Address="1284" Value="080" />
                              <Register Address="1285" Value="0F0" />
                              <Register Address="1286" Value="0FA" />
                              <Register Address="1287" Value="2" />
                              <Register Address="1288" Value="0A0" />
                              <Register Address="1289" Value="0F" />
                              <Register Address="128A" Value="0" />
                              <Register Address="128B" Value="0" />
                              <Register Address="128C" Value="0A0" />
                              <Register Address="128D" Value="0F" />
                              <Register Address="128E" Value="0" />
                              <Register Address="128F" Value="0" />
                              <Register Address="1290" Value="0" />
                              <Register Address="1291" Value="0" />
                              <Register Address="1292" Value="0" />
                              <Register Address="1293" Value="0" />
                              <Register Address="1294" Value="0" />
                              <Register Address="1295" Value="0" />
                              <Register Address="1296" Value="0" />
                              <Register Address="1297" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="12A0.translation_profile_0_5" Address="12A0" Count="24">
                              <Register Address="12A0" Value="0" />
                              <Register Address="12A1" Value="0" />
                              <Register Address="12A2" Value="0" />
                              <Register Address="12A3" Value="0" />
                              <Register Address="12A4" Value="080" />
                              <Register Address="12A5" Value="0F0" />
                              <Register Address="12A6" Value="0FA" />
                              <Register Address="12A7" Value="2" />
                              <Register Address="12A8" Value="0A0" />
                              <Register Address="12A9" Value="0F" />
                              <Register Address="12AA" Value="0" />
                              <Register Address="12AB" Value="0" />
                              <Register Address="12AC" Value="0A0" />
                              <Register Address="12AD" Value="0F" />
                              <Register Address="12AE" Value="0" />
                              <Register Address="12AF" Value="0" />
                              <Register Address="12B0" Value="0" />
                              <Register Address="12B1" Value="0" />
                              <Register Address="12B2" Value="0" />
                              <Register Address="12B3" Value="0" />
                              <Register Address="12B4" Value="0" />
                              <Register Address="12B5" Value="0" />
                              <Register Address="12B6" Value="0" />
                              <Register Address="12B7" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1400.dpll_1" Address="1400" Count="43">
                              <Register Address="1400" Value="0DF" />
                              <Register Address="1401" Value="5A" />
                              <Register Address="1402" Value="0D3" />
                              <Register Address="1403" Value="089" />
                              <Register Address="1404" Value="09A" />
                              <Register Address="1405" Value="22" />
                              <Register Address="1406" Value="0FF" />
                              <Register Address="1407" Value="0FF" />
                              <Register Address="1408" Value="0FF" />
                              <Register Address="1409" Value="0" />
                              <Register Address="140A" Value="0A" />
                              <Register Address="140B" Value="0" />
                              <Register Address="140C" Value="0" />
                              <Register Address="140D" Value="0" />
                              <Register Address="140E" Value="38" />
                              <Register Address="140F" Value="0" />
                              <Register Address="1410" Value="0" />
                              <Register Address="1411" Value="0" />
                              <Register Address="1412" Value="0" />
                              <Register Address="1413" Value="0" />
                              <Register Address="1414" Value="6" />
                              <Register Address="1415" Value="0" />
                              <Register Address="1416" Value="0" />
                              <Register Address="1417" Value="0" />
                              <Register Address="1418" Value="0" />
                              <Register Address="1419" Value="0" />
                              <Register Address="141A" Value="0" />
                              <Register Address="141B" Value="0" />
                              <Register Address="141C" Value="0" />
                              <Register Address="141D" Value="0" />
                              <Register Address="141E" Value="0" />
                              <Register Address="141F" Value="0" />
                              <Register Address="1420" Value="0" />
                              <Register Address="1421" Value="0" />
                              <Register Address="1422" Value="0" />
                              <Register Address="1423" Value="0" />
                              <Register Address="1424" Value="0" />
                              <Register Address="1425" Value="0" />
                              <Register Address="1426" Value="0" />
                              <Register Address="1427" Value="0" />
                              <Register Address="1428" Value="0" />
                              <Register Address="142A" Value="0" />
                              <Register Address="142B" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1480.apll_1" Address="1480" Count="4">
                              <Register Address="1480" Value="090" />
                              <Register Address="1481" Value="0A" />
                              <Register Address="1482" Value="0E0" />
                              <Register Address="1483" Value="3" />
                            </RegisterMap>
                            <RegisterMap UniqueId="14C0.dist_1_general_1" Address="14C0" Count="10">
                              <Register Address="14CE" Value="0" />
                              <Register Address="14D2" Value="0" />
                              <Register Address="14D3" Value="0" />
                              <Register Address="14D4" Value="0" />
                              <Register Address="14D6" Value="0" />
                              <Register Address="14D7" Value="4" />
                              <Register Address="14D8" Value="4" />
                              <Register Address="14DA" Value="0" />
                              <Register Address="14DB" Value="1" />
                              <Register Address="14DC" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1500.distribution_divider_1_a" Address="1500" Count="9">
                              <Register Address="1500" Value="0A5" />
                              <Register Address="1501" Value="1" />
                              <Register Address="1502" Value="0" />
                              <Register Address="1503" Value="0" />
                              <Register Address="1504" Value="0" />
                              <Register Address="1505" Value="0" />
                              <Register Address="1506" Value="0" />
                              <Register Address="1507" Value="0" />
                              <Register Address="1508" Value="7" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1509.distribution_divider_1_aa" Address="1509" Count="9">
                              <Register Address="1509" Value="0" />
                              <Register Address="150A" Value="0" />
                              <Register Address="150B" Value="0" />
                              <Register Address="150C" Value="0" />
                              <Register Address="150D" Value="0" />
                              <Register Address="150E" Value="0" />
                              <Register Address="150F" Value="0" />
                              <Register Address="1510" Value="0" />
                              <Register Address="1511" Value="7" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1512.distribution_divider_1_b" Address="1512" Count="9">
                              <Register Address="1512" Value="0A5" />
                              <Register Address="1513" Value="1" />
                              <Register Address="1514" Value="0" />
                              <Register Address="1515" Value="0" />
                              <Register Address="1516" Value="0" />
                              <Register Address="1517" Value="0" />
                              <Register Address="1518" Value="0" />
                              <Register Address="1519" Value="0" />
                              <Register Address="151A" Value="7" />
                            </RegisterMap>
                            <RegisterMap UniqueId="151B.distribution_divider_1_bb" Address="151B" Count="9">
                              <Register Address="151B" Value="0" />
                              <Register Address="151C" Value="0" />
                              <Register Address="151D" Value="0" />
                              <Register Address="151E" Value="0" />
                              <Register Address="151F" Value="0" />
                              <Register Address="1520" Value="0" />
                              <Register Address="1521" Value="0" />
                              <Register Address="1522" Value="0" />
                              <Register Address="1523" Value="7" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1600.translation_profile_1_0" Address="1600" Count="24">
                              <Register Address="1600" Value="1" />
                              <Register Address="1601" Value="0" />
                              <Register Address="1602" Value="0" />
                              <Register Address="1603" Value="0" />
                              <Register Address="1604" Value="080" />
                              <Register Address="1605" Value="0F0" />
                              <Register Address="1606" Value="0FA" />
                              <Register Address="1607" Value="2" />
                              <Register Address="1608" Value="0A0" />
                              <Register Address="1609" Value="0F" />
                              <Register Address="160A" Value="0" />
                              <Register Address="160B" Value="0" />
                              <Register Address="160C" Value="52" />
                              <Register Address="160D" Value="6" />
                              <Register Address="160E" Value="0" />
                              <Register Address="160F" Value="0" />
                              <Register Address="1610" Value="0E1" />
                              <Register Address="1611" Value="17" />
                              <Register Address="1612" Value="0" />
                              <Register Address="1613" Value="5" />
                              <Register Address="1614" Value="1E" />
                              <Register Address="1615" Value="0" />
                              <Register Address="1616" Value="0" />
                              <Register Address="1617" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1620.translation_profile_1_1" Address="1620" Count="24">
                              <Register Address="1620" Value="0" />
                              <Register Address="1621" Value="0" />
                              <Register Address="1622" Value="0" />
                              <Register Address="1623" Value="0" />
                              <Register Address="1624" Value="080" />
                              <Register Address="1625" Value="0F0" />
                              <Register Address="1626" Value="0FA" />
                              <Register Address="1627" Value="2" />
                              <Register Address="1628" Value="0A0" />
                              <Register Address="1629" Value="0F" />
                              <Register Address="162A" Value="0" />
                              <Register Address="162B" Value="0" />
                              <Register Address="162C" Value="0A0" />
                              <Register Address="162D" Value="0F" />
                              <Register Address="162E" Value="0" />
                              <Register Address="162F" Value="0" />
                              <Register Address="1630" Value="0" />
                              <Register Address="1631" Value="0" />
                              <Register Address="1632" Value="0" />
                              <Register Address="1633" Value="0" />
                              <Register Address="1634" Value="0" />
                              <Register Address="1635" Value="0" />
                              <Register Address="1636" Value="0" />
                              <Register Address="1637" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1640.translation_profile_1_2" Address="1640" Count="24">
                              <Register Address="1640" Value="0" />
                              <Register Address="1641" Value="0" />
                              <Register Address="1642" Value="0" />
                              <Register Address="1643" Value="0" />
                              <Register Address="1644" Value="080" />
                              <Register Address="1645" Value="0F0" />
                              <Register Address="1646" Value="0FA" />
                              <Register Address="1647" Value="2" />
                              <Register Address="1648" Value="0A0" />
                              <Register Address="1649" Value="0F" />
                              <Register Address="164A" Value="0" />
                              <Register Address="164B" Value="0" />
                              <Register Address="164C" Value="0A0" />
                              <Register Address="164D" Value="0F" />
                              <Register Address="164E" Value="0" />
                              <Register Address="164F" Value="0" />
                              <Register Address="1650" Value="0" />
                              <Register Address="1651" Value="0" />
                              <Register Address="1652" Value="0" />
                              <Register Address="1653" Value="0" />
                              <Register Address="1654" Value="0" />
                              <Register Address="1655" Value="0" />
                              <Register Address="1656" Value="0" />
                              <Register Address="1657" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1660.translation_profile_1_3" Address="1660" Count="24">
                              <Register Address="1660" Value="0" />
                              <Register Address="1661" Value="0" />
                              <Register Address="1662" Value="0" />
                              <Register Address="1663" Value="0" />
                              <Register Address="1664" Value="080" />
                              <Register Address="1665" Value="0F0" />
                              <Register Address="1666" Value="0FA" />
                              <Register Address="1667" Value="2" />
                              <Register Address="1668" Value="0A0" />
                              <Register Address="1669" Value="0F" />
                              <Register Address="166A" Value="0" />
                              <Register Address="166B" Value="0" />
                              <Register Address="166C" Value="0A0" />
                              <Register Address="166D" Value="0F" />
                              <Register Address="166E" Value="0" />
                              <Register Address="166F" Value="0" />
                              <Register Address="1670" Value="0" />
                              <Register Address="1671" Value="0" />
                              <Register Address="1672" Value="0" />
                              <Register Address="1673" Value="0" />
                              <Register Address="1674" Value="0" />
                              <Register Address="1675" Value="0" />
                              <Register Address="1676" Value="0" />
                              <Register Address="1677" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="1680.translation_profile_1_4" Address="1680" Count="24">
                              <Register Address="1680" Value="0" />
                              <Register Address="1681" Value="0" />
                              <Register Address="1682" Value="0" />
                              <Register Address="1683" Value="0" />
                              <Register Address="1684" Value="080" />
                              <Register Address="1685" Value="0F0" />
                              <Register Address="1686" Value="0FA" />
                              <Register Address="1687" Value="2" />
                              <Register Address="1688" Value="0A0" />
                              <Register Address="1689" Value="0F" />
                              <Register Address="168A" Value="0" />
                              <Register Address="168B" Value="0" />
                              <Register Address="168C" Value="0A0" />
                              <Register Address="168D" Value="0F" />
                              <Register Address="168E" Value="0" />
                              <Register Address="168F" Value="0" />
                              <Register Address="1690" Value="0" />
                              <Register Address="1691" Value="0" />
                              <Register Address="1692" Value="0" />
                              <Register Address="1693" Value="0" />
                              <Register Address="1694" Value="0" />
                              <Register Address="1695" Value="0" />
                              <Register Address="1696" Value="0" />
                              <Register Address="1697" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="16A0.translation_profile_1_5" Address="16A0" Count="24">
                              <Register Address="16A0" Value="0" />
                              <Register Address="16A1" Value="0" />
                              <Register Address="16A2" Value="0" />
                              <Register Address="16A3" Value="0" />
                              <Register Address="16A4" Value="080" />
                              <Register Address="16A5" Value="0F0" />
                              <Register Address="16A6" Value="0FA" />
                              <Register Address="16A7" Value="2" />
                              <Register Address="16A8" Value="0A0" />
                              <Register Address="16A9" Value="0F" />
                              <Register Address="16AA" Value="0" />
                              <Register Address="16AB" Value="0" />
                              <Register Address="16AC" Value="0A0" />
                              <Register Address="16AD" Value="0F" />
                              <Register Address="16AE" Value="0" />
                              <Register Address="16AF" Value="0" />
                              <Register Address="16B0" Value="0" />
                              <Register Address="16B1" Value="0" />
                              <Register Address="16B2" Value="0" />
                              <Register Address="16B3" Value="0" />
                              <Register Address="16B4" Value="0" />
                              <Register Address="16B5" Value="0" />
                              <Register Address="16B6" Value="0" />
                              <Register Address="16B7" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="2000.op_ctrl" Address="2000" Count="6">
                              <Register Address="2000" Value="0" />
                              <Register Address="2001" Value="0E" />
                              <Register Address="2002" Value="0" />
                              <Register Address="2003" Value="0" />
                              <Register Address="2004" Value="0" />
                              <Register Address="2005" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="2006.irq_common_clear" Address="2006" Count="5">
                              <Register Address="2006" Value="0" />
                              <Register Address="2007" Value="0" />
                              <Register Address="2008" Value="0" />
                              <Register Address="2009" Value="0" />
                              <Register Address="200A" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="200B.irq_pll_0_clear" Address="200B" Count="5">
                              <Register Address="200B" Value="0" />
                              <Register Address="200C" Value="0" />
                              <Register Address="200D" Value="0" />
                              <Register Address="200E" Value="0" />
                              <Register Address="200F" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="2010.irq_pll_1_clear" Address="2010" Count="5">
                              <Register Address="2010" Value="0" />
                              <Register Address="2011" Value="0" />
                              <Register Address="2012" Value="0" />
                              <Register Address="2013" Value="0" />
                              <Register Address="2014" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="2100.operational_control_pll_0" Address="2100" Count="8">
                              <Register Address="2100" Value="0" />
                              <Register Address="2101" Value="0" />
                              <Register Address="2102" Value="0" />
                              <Register Address="2103" Value="0" />
                              <Register Address="2104" Value="0" />
                              <Register Address="2105" Value="0" />
                              <Register Address="2106" Value="0" />
                              <Register Address="2107" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="2200.operational_control_pll_1" Address="2200" Count="7">
                              <Register Address="2200" Value="0" />
                              <Register Address="2201" Value="0" />
                              <Register Address="2202" Value="0" />
                              <Register Address="2203" Value="0" />
                              <Register Address="2205" Value="0" />
                              <Register Address="2206" Value="0" />
                              <Register Address="2207" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="2900.temp_sensor" Address="2900" Count="7">
                              <Register Address="2900" Value="0" />
                              <Register Address="2901" Value="0" />
                              <Register Address="2902" Value="0" />
                              <Register Address="2903" Value="0" />
                              <Register Address="2904" Value="0" />
                              <Register Address="2905" Value="0" />
                              <Register Address="2906" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="2E00.eeprom" Address="2E00" Count="4">
                              <Register Address="2E00" Value="0" />
                              <Register Address="2E01" Value="0" />
                              <Register Address="2E02" Value="0" />
                              <Register Address="2E03" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="2E10.eeprom_sequence" Address="2E10" Count="15">
                              <Register Address="2E10" Value="0FF" />
                              <Register Address="2E11" Value="0FF" />
                              <Register Address="2E12" Value="0FF" />
                              <Register Address="2E13" Value="0FF" />
                              <Register Address="2E14" Value="0FF" />
                              <Register Address="2E15" Value="0FF" />
                              <Register Address="2E16" Value="0FF" />
                              <Register Address="2E17" Value="0FF" />
                              <Register Address="2E18" Value="0FF" />
                              <Register Address="2E19" Value="0FF" />
                              <Register Address="2E1A" Value="0FF" />
                              <Register Address="2E1B" Value="0FF" />
                              <Register Address="2E1C" Value="0FF" />
                              <Register Address="2E1D" Value="0FF" />
                              <Register Address="2E1E" Value="0FF" />
                            </RegisterMap>
                            <RegisterMap UniqueId="3000.status_readback" Address="3000" Count="11">
                              <Register Address="3000" Value="0" />
                              <Register Address="3001" Value="0" />
                              <Register Address="3002" Value="0" />
                              <Register Address="3003" Value="0" />
                              <Register Address="3004" Value="0" />
                              <Register Address="3005" Value="0" />
                              <Register Address="3006" Value="0" />
                              <Register Address="3007" Value="0" />
                              <Register Address="3008" Value="0" />
                              <Register Address="3009" Value="0" />
                              <Register Address="300A" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="300B.irq_common_read" Address="300B" Count="5">
                              <Register Address="300B" Value="0" />
                              <Register Address="300C" Value="0" />
                              <Register Address="300D" Value="0" />
                              <Register Address="300E" Value="0" />
                              <Register Address="300F" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="3010.irq_pll_0_read" Address="3010" Count="5">
                              <Register Address="3010" Value="0" />
                              <Register Address="3011" Value="0" />
                              <Register Address="3012" Value="0" />
                              <Register Address="3013" Value="0" />
                              <Register Address="3014" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="3015.irq_pll_1_read" Address="3015" Count="5">
                              <Register Address="3015" Value="0" />
                              <Register Address="3016" Value="0" />
                              <Register Address="3017" Value="0" />
                              <Register Address="3018" Value="0" />
                              <Register Address="3019" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="3100.status_readback_pll_0" Address="3100" Count="15">
                              <Register Address="3100" Value="0" />
                              <Register Address="3101" Value="0" />
                              <Register Address="3102" Value="0" />
                              <Register Address="3103" Value="0" />
                              <Register Address="3104" Value="0" />
                              <Register Address="3105" Value="0" />
                              <Register Address="3106" Value="0" />
                              <Register Address="3107" Value="0" />
                              <Register Address="3108" Value="0" />
                              <Register Address="3109" Value="0" />
                              <Register Address="310A" Value="0" />
                              <Register Address="310B" Value="0" />
                              <Register Address="310C" Value="0" />
                              <Register Address="310D" Value="0" />
                              <Register Address="310E" Value="0" />
                            </RegisterMap>
                            <RegisterMap UniqueId="3200.status_readback_pll_1" Address="3200" Count="15">
                              <Register Address="3200" Value="0" />
                              <Register Address="3201" Value="0" />
                              <Register Address="3202" Value="0" />
                              <Register Address="3203" Value="0" />
                              <Register Address="3204" Value="0" />
                              <Register Address="3205" Value="0" />
                              <Register Address="3206" Value="0" />
                              <Register Address="3207" Value="0" />
                              <Register Address="3208" Value="0" />
                              <Register Address="3209" Value="0" />
                              <Register Address="320A" Value="0" />
                              <Register Address="320B" Value="0" />
                              <Register Address="320C" Value="0" />
                              <Register Address="320D" Value="0" />
                              <Register Address="320E" Value="0" />
                            </RegisterMap>
                          </Chip>
                        </Chips>
                        <StateControls AllowStatePolling="true" />
                      </Board>
                    </SavedState>
                  </Component>
                </Components>
                <Connections />
              </Subsystem>
            </Subsystems>
          </System>
        </Element>
        <Element Id="Controllers">
          <Controller Name="AD9542 Board" HardwareID="Virtual&180C3BEDAC0B" Path="Root::System.Subsystem_1.AD9542 Board" xmlns="" />
        </Element>
        <Element Id="Macros">
          <MacroManager xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="AnalogDevices/Csa/Evaluation/UI/Models/Sessions/MacroManagerSessionElement.Schema.xsd">
            <Macros />
          </MacroManager>
        </Element>
        <Element Id="Views" ActiveWorkspaceElement="Root::System.Subsystem_1.AD9542 Board.AD9542" WorkspaceElements="Root::,Root::System,Root::System.Subsystem_1.AD9542 Board,Root::System.Subsystem_1.AD9542 Board.AD9542,Root::System.Subsystem_1.AD9542 Board.AD9542.AD9542 Memory Map,Root::System.Subsystem_1" />
      </Elements>
    </Session>
    *.cso file is attached for your reference.
    Thanks.
    you did not spend time to install the ACE and plug in versions I recommended. This cso file had the same errors like the one from the other EZ item you have.
    Anyway, the 122.88MHz is a square wave clock. and the harmonics you are talking about are determined by the squares. Only if you had a sinusoidal output you would not have them.
    Then, I have been told the ADRV9029 has a PLL that works with a <1MHz bandwidth, so all these harmonics should be significantly filtered by this PLL.
    Petre
