ADF4360 Phase Noise Spec
Product Number: ADF4360
Hi, I am currently using the ADF4360-9 to generate an LO ref in the range 146-152 MHz. My phase noise requirements are quite strict so have ended up running the VCO at double this and using the Divout f/2 output to get a slight improvement in noise performance. Am curious if there are any other synthesizer ICs with integrated VCOs that offer slightly better phase noise performance? Or would a topology with an external VCO be a better strategy to minimize phase noise? Also are there any designs which use an external varactor diode to reduce noise?
Many thanks in advance,
Dave
  • Hi Dave,
    We have various PLL with integrated VCO parts in our portfolio. Correct part selection depends on operating frequency and phase noise / integrated jitter requirement. If you can specify these, I can help to find best fit for your application. ADF4351, ADF4356, ADF4355 are the alternatives at first glance.
    Kudret
  • Thanks for the reply Kudret. My operating frequency range is ~155 - 165 MHz. Our channel BW is 25 kHz, and we have a requirement for -70dBc at adjacent channels, which equates to -70-(20log[25])=-114 dBc/Hz phase noise spec. The ADF4360-9 almost meets this spec with PFD frequency of 100kHz, by doubling the VCO frequency and using the DivOut port with a divide by 2. So my questions are:
    1. Is there a better choice of PLL synth for the above application?
    2. Do you recommend using a divide by 4/8 rather than 2 at the Divout port, would this theoretically further reduce phase noise by 3/6 dB?
    3. Is there anything to be gained in using an external varactor in the VCO, since the integrated varactor contributes noise to the VCO?
    Many Thanks,
    Dave
  • Hey, jut checking in to see if you have any feedback on the above? An integrated solution with better Phase Noise than the ADF4360-9 for the above specs, but in the same price range hopefully? Or would it be worth looking into PLLs with separate (either integrated or discrete) VCOs? Thanks, Dave
    ADF4351 or MAX2870/71 might be better for achieving that spec with a little price hit.
    Kudret
